Can someone please help me on this question ?
Verify this by showing how to deduce Σ
I am trying to plot q2:= (x) -> x*exp(x^2)*(1-erf(x)); for 0 <><>plot(q2(x),x=.1..10); then the resulting plot is incorrect. In reading other posts I get the impression that one needs to somehow prevent the plot routine(s?) from following their default behavior of refusing to compute with the
What is the big oh of the binomial coefficient
  n
  k
Hi, I'm hoping someone in here will be able to help me.
I've made two files in which I need to find a symbolic expression for the difference between two mathematical models of a mass, damper, spring system:
            I have a question regarding  Chebyshev interpolation of data. How can I interpolate the following data by Chebyshev interpolation using maple?
X:=[16,45,85,120];
Y:=[4,7.2,1.6,0.5];
I want to have a procedure define a function... If I do: >with(stats); >does_not_work:= proc(t) local v,d0,d1,x,y; > v = rhs(fit[leastsquare[[x,y], y=d0+d1*x]](t)); >end proc; then > does_not_work([[0,1,2],[3,4,5]]); results in "v = 3 + x" as expected, but if I try to have the procedure define a function d as in >does_not_work:= proc(t) local v,d0,d1,x,y; global d; > v = rhs(fit[leastsquare[[x,y], y=d0+d1*x]](t)); > d:= (x) -> v; >end proc; then > does_not_work([[0,1,2],[3,4,5]]); > d(1); does not result in 4, which should be the result of applying
Okay, I'm just really starting to get into Maple again, but I'm having a little trouble getting a package to work.
I'm trying to take a look and review the precalculus package from the application center but it doesn't seem to work.
It's from maple 7.  The new version doesn't seem to follow through on the commands made.
Hi there :) As i am new here first a short Hello: Hello, my Name is Gernot, and i am Physics Student of the 6th Semester. I am a beginner in Maple, and am prety new to Calculating on the Computer in General. At the moment i need Maple primary for calculations and analyzing Measuring Data from the Exoeriments in my Physics practica. And I have some Questions on that, and hope you can Help me a bit :) As i don't want to do a Monster Posting here, i will make more Topics on ym Questions, although they all stick together ;). So my first question is: I am Having a Vector
I'm trying to plot the solution of the following differential equation:
theta * y''(t) - y'(t) = 0  with boundary conditions  y(-1)=alpha  and  y(1)=beta. Theta is supposed to be very small, say 0.01, and for starters I put  alpha=1  and  beta=-1. But Maple does not compute. I use the following source code:
> singularperturbation:={0.01*diff(y(t),[t$2]) - y(t)*diff(y(t),t) = 0, y(-1)=1,y(1)=-1};
> differentialsolve:=(singularperturbation,y(t),type=numeric,method=bvp[midrich],abserr=1e-2);
Please help me solve these two problems please past the code for maple 11.
2. For the function
f
hi, what code do I use to sum the number of heads from a random coin toss to illustrate the Central limit theorem (relationship between the binomial and normal distribution). The more approachable the code is the better..
I'm very confuse with this question:
- Find one root/zero of  2*x^5-5*x^4+3*x^3-3*x^2+x+2 using Newton's Method. If your polynomial is sadly lackaing in a root, subtract some constant value until the polynomial cuts the x-axis
- Produce four iterations of the Newton's Method. This will result in four successively accurateapproximations to one solution of p(x)=0
- For each iteration, report your beginning xn and the subsequent xn+1 value. For each run, also product a graph of p(x) and the graph of the newest Newton created tangent line
solve({x11*x11+x12*y11+x13*z11=x11*x11+x12*x21+x13*x31,
x11*x12+x12*y12+x13*z12=x11*x12+x12*x22+x13*x32,
x11*x13+x12*y13+x13*z13=x11*x13+x12*x23+x13*x33,
x11*x21+x12*y21+x13*z21=x21*x11+x22*x21+x23*x31,
x11*x22+x12*y22+x13*z22=x21*x12+x22*x22+x23*x32,
x11*x23+x12*y23+x13*z23=x21*x13+x22*x23+x23*x33,
x11*x31+x12*y31+x13*z31=x31*x11+x32*x21+x33*x31,
Warning, computation interrupted
I have a matrix with 3 columns and I want to change the order of columns 2 and 3. In fact  column to must be column 3 and vice versa. I was wondering if there is a function that I can use? (the number of rows is variable)
Ibo
First 2278 2279 2280 2281 2282 2283 2284 Last Page 2280 of 2457
