When I solve the equation
ode := diff(y(x), x, x) = t*y(x)+1
with
dsolve(ode)
everything is ok,
y(x) = exp(sqrt(t)*x)*_C2+exp(-sqrt(t)*x)*_C1-1/t
However, when I want to solve the system
Is there a way to ask Maple to kindly do this for me?  Perhaps if there is can the kind sir show me the steps?
How about something simple, r=sin(theta)-Pi.
I ask because I did this one by hand and maple would not implicitily plot it for me!
Thanks!!!
when i pass a pair of differential equations from a procedure (called expressions in the code below) to another procedure (main) I am unable to solve the equations with dsolve.
If I explicity include the equations in main I can solve it fine.
Does anyone know what I'm doing wrong?
please help!
below is the code that 1) doesnt work 2)does work
I want to plot the complex numbers
(-1/2)^q+(-1/2)^(1-q)  (0.25<=q<=0.5)
on the complex plane. Does exist a package (some commands) which can do it?
Sandor
there are n persons selected at random. the probability that at least two of them are born in the same day is p(n). i have to calculate:
a))   p(2),p(3),p(4)
b)) to establish a formula for p(n)
c)) to find out the values for "n" so that p(n)>0.5
if anyone can help me i would be forever grateful. i don't have no idea for this type of problem!
thanks!
Hi guys
How do you calculate the tensor product of 2 matrices in maple? Can't seem to find this simple operation in the tensor library.
I'm new to Vista, and I'm trying to get a network copy of Maple 11 to load correctly. I've read about the open/save problem, so I tried to run the install file as administrator under Windows 2000 compatibility mode, but the installation wouldn't finish properly, so I installed normally. Opening normally, Maple now runs fine except for the open/save problem. Opening as administrator andd under Windows 2000 compatibility mode, the program stops working before it finishes loading. I don't know what to do, I need this program for class. Please help.
how do i solve a matrix ^ 10?
thank you
Actually, I could just cut to the chase here...
I need to print out a 2-D ring and then attach that to a 3-D sphere.  The problem is that the 2-D ring will buckle as I attempt to attach the outer circumference of it to the sphere.
This problem arised in a math forum.
I would like to check wether the consecutive digits of a given positive integer (n) are in the first 100000 digits of Pi.
For example the given integer (n) = 1592653 and this is in 3,1415926535897.... so the result is true.
I also would like to use this pattern matching for checking the type of a variable in a procedure:
myproc:=proc(n::mytype)
...end proc;
The procedure accepts n if n fullfils the condition above.
Hi, I have a trouble in handling MathML in worksheet published by MapleNet. A simple worksheet published on the following page works fine. http://mapleoracles.maplesoft.com:8080/maplenet/primes/worksheet/256_int_math.mw However, same worksheet published on my own MapleNet server does not work nicely. http://thomas.phys.cs.is.nagoya-u.ac.jp/maplenet/App/int_math.mw
I have found this problem somewhere in a math forum: somebody wanted to simplify this expression ( I write it in maple syntax:, this was not a maple forum):
a:=(1253*sqrt(2)-963*sqrt(3))^(1/3)+(26209+10500*sqrt(6))^(1/4);
They tried with the simplify command of maple, but it didn't work, and they tried with Fullsimplify command of the other famous math program , and it worked. ( I haven't tried it.) The conclusion was that Maple couldn't do this job.
Actually Maple can do this job with radnormal:
radnormal(a);
14*2^(1/2)
I am having problems using implicitplot.  I run this code and it worked and today I tried it again and it gives me the following:
with(plots,implicitplot);
implicitplot(0=int(erf(  (T-e*t)/sqrt(2)  )*t^2*exp(-t/2),t=0..infinity),e=0..1,T=0..10);
Error, (in plots/implicitplot) invalid input: the following extra unknowns were found in the input expression: {t}
The weird thing is that this worked before (took about 10min though) and now it isn't.  Any suggestions?
I want to write some stats questions on forecasting. I would like to have a list which is a time series, and use Moving Average to derive forecasts, then calculate my errors, etc. I can do it all in Maple, but I don't know how to create a list in Maple TA. For instance, how do I create A in Maple TA's algorithm, where A is defined by:
A:= [seq(round(RandomTools[Generate](distribution(Normal(40,5)),1)), i=1..20)];
This is just a  list of some "sales figures" distributed approximately normally.
Stephen
Verify this by showing how to deduce Σ
First 2277 2278 2279 2280 2281 2282 2283 Last Page 2279 of 2457
