hi, i am new to this and when i start up maple 11 i get the following error : "Java Virtual Machine Launcher,  Could not create the java virtual machine"
i hope there is a solution to this because i have searched everywhere and i cant get the solution.
error: http://img369.imageshack.us/my.php?image=problem1ek9.jpg
I'm trying to construct an iterative procedure NR1(f,x0,N) where f is a function, x0 is an initial estimate (which can be complex) and N the number of iterates.
Given:  xk+1=xk - f(xk)/f'(xk), k=0,1,2....,
Now for example by defining f:= x-> x^2-2 and inputting x0=1 and N=10 i should be able to check that my procedure calculates sqrt(2) correctly.
This is what i've got so far.....
Hi i'm trying to figure out how to write a procedure for creating a NxN matrix with conditions. The conditions for M[ij] are as follows:
a if j>i+1, c if i>j+1 and b otherwise.
So far this is what i've come up with but i've tied myself into a mental loop and cant seem to figure this out. I know it's really simple and that's what is frustrating me the most.
I am trying to solve the following equation with maple
g:=t->(-l*a^2*t+l*a^2*r^(-1/(a-1))*(A*l)^(-1/a)*(1-t)^(-1/a)*exp(1/(a-1))*t-l*a^2*r^(-1/(a-1))*(A*l)^(-1/a)*(1-t)^(-1/a)*exp(1/(a-1))+l*a^2-l*a-2*l*a*r^(-1/(a-1))*(A*l)^(-1/a)*(1-t)^(-1/a)*exp(1/(a-1))*t+2*l*a*r^(-1/(a-1))*(A*l)^(-1/a)*(1-t)^(-1/a)*exp(1/(a-1))+l*t*a-a*r^(-1/(a-1))*(A*l)^(-1/a)*(1-t)^(-1/a)*exp(1/(a-1))+l*t*r^(-1/(a-1))*(A*l)^(-1/a)*(1-t)^(-1/a)*exp(1/(a-1))-l*r^(-1/(a-1))*(A*l)^(-1/a)*(1-t)^(-1/a)*exp(1/(a-1))+r^(-1/(a-1))*(A*l)^(-1/a)*(1-t)^(-1/a)*exp(1/(a-1)))*exp(-1/(a-1))/(t-1)/a;
How do I find the derivative dy/dx of:
x+ y= 3xy
I think I use the Sum Rule for the LHS and the Product Rule for the RHS.  Where I am confused is how to treat the y on the LHS.  Do you change it to 3y and then solve the whole thing for y?, or do you keep dy/dx*y and then solve the whole thing for dy/dx?
Any thoughts?
How does one create the set of all positive integers less than and coprime to 66?
I created a set of integers from 1-66: L := {seq(i, i = 1 .. 66)}, then try define coprime66 as follws, coprime66 := isprime(igcd(L, 66)),  to get a set of the coprimes but i get an error.
I've tried op(L) but this doesn't work either. What am i doing wrong?
Does anybody know of a way to change the direction of an axis label in a plot without going back to the code and re-plotting? In the file I am working with that code has been deleted. It is possible to change the wording, font etc. of the labels, but I cannot find a way to change their directions. This becomes very annoying when I have a long label title on the y-axis, as my plot gets scrunched. Any help would be greatly appreciated. Thanks. -Evan
Greetings. Using the sequence command, I can generate a list of numbers.
>seq(1/(n^2+1), n=1..10);
1/2, 1/5, 1/10, 1/17, 1/26, 1/37, 1/50, 1/65, 1/82, 1/101
Given the list of numbers above, how does one derive
1/(n^2+1)
This is a specific example.  I am looking for a general case.  I scanned the genfunc and gfun packages, but I must be missing something.
Georgios Kokovidis
Has anyone ever written procedures in C that can be called from Maple on MAC OS X? I have looked at the WRAPPER help page and given it a go but I am completely lost. I have compiled the example C code from the WRAPPER page with XCode as a "shared library" but when I try to define it in maple I get the following error:
I have been using "Document Mode" in Maple 11 for the majority of my work.  I find that coding procedures and loops is stylistically different than the rest of my document content.  It is a bit uncomfortable using SHIFT+ENTER and struggling with manual indentation in the procedure and loop blocks.
What is the best editing mode for coding routines?
HI2all! I use c++ builder 5.0 to create interface for maple code.At first I tried to start example from openmaple help topics. I have copied example and have inserted it to console wizard of c++ builder. Copy header files to work directory... At first i received(for strings of .h files: INTEGER64 int64;): [C++ Error] mpltable.h(239): E2176 Too many types in declaration [C++ Error] mplshlib.h(148): E2176 Too many types in declaration [C++ Error] mplshlib.h(210): E2176 Too many types in declaration [C++ Error] maplec.h(266): E2176 Too many types in declaration
hi, how to use maple to do the programming?
consider the piecewise function
b:=piecewise(0>=t,-t,5>t,0,5<=t,t-5);
Why
maximize(b,t=0..3);
does not return correct answer?
maximize(b,t=1..3); or maximize(b,t=-1..3);
works correctly.
Moreover maximize(b,t=0..5);
returns an error.
Thank you for advice.
I am running Maple 11 on Mac OS 10.5, and so I use the older Java Runtime Engine to get decent looking prints. However, whenever I print something using pointplot, all the points have this anti-aliasing that makes it look really bad, especially if you use something a little thicker like the diamonds.
I attached a pdf of a printout of a recent homework I did plotting out the Lorenz attractor using pointplot. I noticed that the 3D version at the end looks okay, but the 2D projections I did show you what the problem is. If you zoom in you can see the "shadows"
Is there a way to get all your printouts entirely in vector format?
Download 8404_Untitled.pdf
View file details
When I solve the equation
ode := diff(y(x), x, x) = t*y(x)+1
with
dsolve(ode)
everything is ok,
y(x) = exp(sqrt(t)*x)*_C2+exp(-sqrt(t)*x)*_C1-1/t
However, when I want to solve the system
First 2276 2277 2278 2279 2280 2281 2282 Last Page 2278 of 2457
