Prove that vectors , and are coplanar if and only if vectors ,
hi,
i've a problem with a least square exercise.
3 measured values are given:
xi = 1, 4, 6
yi = 2,4,8
i've to find a optimized function of the type "y = f(x) = k * 2^(bx)"
till now i just worked with linear least square exercises like y = px + q. how do i get started with this one. what do i have to do?
thx for help in advance
I am looking for toolboxes that can handle simulation and solution of
SED with jumps, say levy processes, jump diffusion processes, etc.
Could anybody give me some pointers to really good ones in Maple and
Matlab? I did google search myself and have some findings... however I
would like to know some really good ones and popular ones so I can
discuss with fellow users more conveniently...
Suppose a random m*n matrix created with the palette in Maple 11. I want to replace each instance of the number 1 by the symbolic variable "a".  Does anyone have a simple way to do it?
I have derived a transfer function for a filter and would like to sweep the frequency and evaluate the result at each point.  Then I would like to plot all of this data to obtain the filter's frequency response. Anyone know how to do this?  Do I use a subs command??? Any suggestions would be great!!
Kirk
I have small script that uses syntax checker mint and latex command and latex to convert an expression in maple syntax to an image. But functional operators are causing me troubles.
Suppose I want to enter the equation  (x+1)*(x-1) and I forgot to use the star (*) for multiplication. The result (x+1)(x-1) is also correct because Maple thinks that I am using functional operator x. But I would like to evaluate this cas as wrong syntax. So I have to detect functional operators (somehow) but I don't want to detect operators such as +, -, * and so on.
I have this problem regarding how many employees (the variable x) is needed to get the lowest wage cost in a company. I have written the following model:
>restart:
>assume(x,integer)
>assume(x>=0)
>a:=16362-(40+x)*504:
>b:=IF(a<0,16362-(40+x)*420,(40+x)*84:
>c:=IF(b<0,16362,(40+x)*420)
>d:=IF(a>0,a*12.65*2.0)+IF(b>0,b*12.65*1.5)+c*12.65
hi,
tried to solve a least square problem with maple.
i've n=3 measured data
xi = 1, 4, 6
yi = 2, 4, 8
and have to create a optimised function of the type y=f(x) = px + q
i gave maple this input:
y := <2,4,8>;
x := <1,4,6>;
with(Student[LinearAlgebra]):
LeastSquares(x,y);
Can maple rsolve equations of the type y(t)=sum(b(t),1..y(t-1)) for y? Thanks.
I'm trying to optimize parameters in a implicit function. I can create a plot of the function using implicitplot. But I now need to find the maximum and minimum in a given range. How to do this.
I have been searching for quite sometime, but I cannot find an answer to this.  So at last, I'm posting.
I keep trying to solve this equation below, and this is the outcome I get.  And, I have no idea what the solution means.  I am largely confused by the percentage signs, periods, etc...
Thanks in advance!
-kD
I have to filter a load of analysis data and have written the following
We have an area defined in polar coordinates by
r = 1..3 and theta = 0..3*Pi /4
, and we wish to plot it in maple. Such a simple thing should be possible, but it seems impossible with implicitplot and polarplot.
Unfortunately, this exact maple plot is required for an assignment tuesday, so we would like some help
Sorry because I can not good speak English. I want to draw a graph with maple 10.
I want to draw a polar contour. I have some datas in a txt file. I want to read data and plot graphic. My datas have 3 colums. first column is radius (r) ,second column is angle (theta) ,third column is my fuction z. z=f(r,theta).
I do readdata and my datas reading. But I not drawing a contour graphics.
How do I to solve this problem?
It's probably a simple issue but I can't figure it out
If I do 3/(4.)  I get .7500000000 .  Why doesn't maple drop the zeros?
Is there a default so that when I divide a fraction like 3/8 or 1/4 and get .375 and .25 without the extra zeros?  or is it always standard for maple to tack on those extra zeros?
First 2274 2275 2276 2277 2278 2279 2280 Last Page 2276 of 2457
