hi,
how do i solve the following?
ode:=diff(y(t),t$2)+y(t)=piecewise(t in [0,Pi],t, t>Pi,Pi);
ics := y(0)=0, D(y)(0)=0;
dsolve({ode,ics});
Hi everybody,
I'm not really sure of where sould I post my question.
Let me explain my problem :
I've got a convolution product of my function f and my filter called G (let say a gaussian for example, or a top hat filter). It is as follows :
filtre:=proc(g);
return x->(1/(2*Delta)*int(g(t),t=(x-Delta)..(x+Delta)));
end;
filtre:=proc(g) local a,G;
G:=x->sqrt(gamma/(Pi*Delta^2))*exp(-gamma*x^2/(Delta^2));
return x->int(g(t)*G(x-t),t=-infinity..infinity);
end;
Hi, i have a dgl i want to transform:
y''-7y'+10y = (sin(2x))/x
The laplace command works, but how can i insert initial conditions ? The help page says:
Is there a command to extract the number of (significant) digits for each of the elements in a list?
Thanks for helping me.
Hans van Walen
Hello :) I would like to print my Maple Documents or Worksheets, or export them as a PDF. For sure i allready found the functions for that in the Drop Down Menue on top, but: The prints, as well as the PDFs convert the Font, and lots of things get converted somehow. For example a "Minus" Sign in an "l". I uploaded an example Screenshot here: http://gallery.mac.com/gernot.heissel#100024/BspFoto-20Maple-20Print&bgcolor=black First row is Screenshot of the expression in Maple 2nd row is what a convertion into PDF of this expression looks like.
hi,
i have to do a exercie to draw a sphere with maple. (radius = 5 )
first problem is to get the function for the sphere(implicit and explicit)
for the implicit one google helped me and gave me:
f(x, y, z)=x²+y²+z²-r²=0
i plotted it succesful with
plots:-implicitplot3d(f(x,y,z)=0, x=-5..5, y=-5..5, z=-5..5, scaling=constrained, axes=boxed);
for the explicit function i tried to solve the function for the x variable:
exp_x :=(y,z)->sqrt(r^2 - y^2 - z^2);
First, is there a simple way to write the double derivative of a function say x(t) so I will receive as output x(t) with the double quote on the top instead on writing it in a long form diff(x(t),t,t)
Secondly, I have a problem with a system of pulleys.  See if you can find where I am missing something.  Here the file:
For the last hour I have been starring at this problem.  Each time that I think I understand what is being asked my mind confuses itself.
Here is the problem.
http://img262.imageshack.us/img262/8387/helpxz2.png
Me or Maple?
Okay here's the problem.  A function is described as Y:={a*t^2*[exp^(-b*t)]*cos(c*t)}/(1+d*sqrt(t));
I differentiate Y wrt t to find the velocity of the funtion V:= diff(Y,t);  also acceleration A:=diff(Y,t,t);
I give some values to a,b,c,d and assign a T:=20  and so a:=2: b:=3/8: c:=10: d:=1
Now I plot to view the velocity of the function over the time t=0..T    plot(V,t=0..T);  GREAT!
I've written a procedure to generate a Farey sequence FN of order N where b=1,2,...,N & a=0,1,...b; as follows:
> farey:= proc(N::posint)
> local a,b,L:
> for b to N do:
>   for a to b do:
>   if a<=b then L:=sort([op({seq(seq(a/b,a=0..b),b=1..N)})]):
>   end if:
>  end do:
> end do:
> print(F[N]=L);
> end proc:
How can I show that the parity of the spherical harmonics Y[M,L](theta,phi)  is  (-1)^L?
hello..
everybody who read this message, please help me..
i really need your help..
i am given an assignment about heat equation and i need to solve it by using Maple.
i know nothing about Maple even never use it before.
this is the question:
Consider the heat equation ut(x,t)=0.2uxx(x,t) with the following boundary and initial condition:
u(0,t)=u(1,t)=0, t beetween 0 and 0.1
u(x,0)=100sin(pi*x), 0<x<1 take h=0.1 and k=0.01
I want to remove properties (assume) programmaticaly.
in all the following code, e is indets(f); where f can be any function, list etc.
none of the followings works :
unassign(e[])
map(x->unassign(x),e);
assign(map(x->x=uneval(x),e));
etc.
the following seems to work, at first
assign(map(x->x=uneval(uneval(x)),e));
but finally no:
assume(a,'constant');
e := indets(a*x+b);
This is a word file conatian a full discription for a partial differential equations please help me to solve it
 www.4shared.com/file/44705973/d2bd94e4/New_Microsoft_Word_Document__3_1.htmlplease
please help me
First 2273 2274 2275 2276 2277 2278 2279 Last Page 2275 of 2457
