For some work I am doing with matrices with polynomial entries in certain parameters, I need to know for which values of the parameters there is a possibility that the rank of the matrix drops down. I tried using fraction free Gaussian elimination in both linalg and LinearAlgebra. The two methods do not always give the same resulting matrix. Moreover, the matrix is not as simple as it should be. I understand that a Gauss-Bareiss algorithm produces a result which I would be happier with. Does anyone know of such an implementation for Maple? I have been having some difficulty finding an explicit form for the algorithm on the net.
i have a laplace function. this function contains a integral. how can i use maple to find the fisth 10 terms of a maclaurin series. please, i really need help
using maple find out the sum of the follwing series: sum(n=1,infinity) 1/n^2; sum(n=1,infinity) (-1)^n+1/n^2; sum(n=1,infinity) 1/(2n-1)^2;
There's a discussion on generating cross-correlated sequences( http://www.mapleprimes.com/forum/generate-correlated-random-numbers), but how do I create a sequence of correlated random variables from an arbitrary distribution? How do I test a given time series (list,vector) for a possible autocorrelation (serial dependence) with maple? Thanks.
why when men talk about graphing newton's basins of attraction they always give complex exaples . For the real polynomials we have the same idea for example the polynomial : f(x) = x^3 + 2*x^2 - x -2 this has 3 real roots 1, -1, -2 and of course we have some intial x0 makes newton formula converge and other not so we will have basins. or for x^3 - 1 which has 3 mix of real and complex roots. Can you please help me in writing a maple program that create the graph of newton's basin for such real polynomials? and If you think that my idea is not correct can you please provide me with a maple program that create the basins for a complex polynomial so that I maybe can modify it for the real ones?.
hi let's say i want to plot sin(x) in excel i know that in excel i should type =Maple("plot(sin(x),x") now how to do that within vba i have already included the reference of maple within vba thank you
f(x)=x^2 expand in fourier series: a)by cosinuses on (0,pi) b)by sinuses on (0,pi) c)on (0,2pi)
Hi let's say i have a list like this one u:=[1,2,5] i want to know the max that is 5 in this case how to do that thank you
Hi guys, i created a procedure to produce the commutator lie bracket, for the lie algebra so basically commutator(x,y)=x&*y-y&*x where x and y are not commutative. But there is a problem when i add constants into the mix, like a*x, a is treated as a variable. So i wonder if within the simplify function, there is a way to set certain variables/constants to be commutative or to declare a variable as a constant variable. If more information is needed check down here I am attempting to output the results of a derivation map D so say we have 2 elements of the lie algebra, x and y, and L is spanned by x and y,
hi lets say i have 2 functions
h:=x->piecewise(x <= 5, x-1, x <= 7, 4, x <= 15, 18-2*x);
h1:=x->piecewise(x <= 3, -3/2+(3/2)*x, x <= 5, 3, x <= 15, 21/2-(3/2)*x);
i'm looking for, when h1(x)=h(x)
when i plot it
plot({h(x), h1(x)}, x, thickness = 3);
i can see 2 intersections
when i do
fsolve(h(x)=h1(x),x);
it returns me only one solution =1
is there any alternative to this
Normally i should have 2 solutions in the interval 1 until 10 , that are x1=1 and x2=4
thank you
is it possible ti split the sreen of maple thank you
Hi let's say i have 2 functions the first one is f :=x->[[1, 0], [3, 3], [5, 3], [7, 0]]; the second one is g :=x->[[1, 0], [5, 4], [7, 4], [9, 0]]; when i use plot({f(x),g(x)}); i can see the both functions and the intersection but I don't know how to calculate the intersection Can you help me please thank you .
I am new to Maple and still learning syntax, what I would like to do is to generate the elemets of GF(8) or to even how to multiply ploynomials modulo x^3 + x +1? Thanks for help any one can provide.
I have a Maple spreadsheet which I would like to plot some of the data from. Is there a simple way to select the columns of data for a 2 dimensional plot? The Maple commands below generate three columns of data and I would like to plot the first two columns. I have exported the file to Excel and generated a plot, but there should be a way to stay within Maple and do the same. Thank you for your help. > restart; > with(Spread); > beta_N := proc () local i, k, sol, beta, N_bar, Eq15, Eq16; CreateSpreadsheet(Eq15_16); i := 1; for k from .10 by 0.2e-1 to .5 do Eq15 := -2*k*cos(beta) = 1/sqrt(N_bar);
Hi, I'd like to know how I can plot a simple math function that has undefined constants on it. For exemple, k*x^2 - k*x^4. Here x is my variable and k is the undefined variable. This function is plottable, bacause I can plot it with my hands... You derivate the function, get the critical poits, then look at the concavite of the function in each of those points by looking at the sign of the second derivate, and then you get a plot with critical points being functions of k which I assume is always greater than zero. From what I have found in all tutorials, books and forums, they teach only to plot numerical functions. But I can't really believe maple can't plot these functions I need. Another example would be x = k. It's a simple function where you get a horizontal line crossing the y axe in the k point. So, even if k is undefined it's still plottable. I think I made my point.
First 2310 2311 2312 2313 2314 2315 2316 Last Page 2312 of 2457
