with(geometry):
_EnvHorizontalName := x:
_EnvVerticalName := y:
a := 7:
b := a*(1/2 + 1/6*sqrt(45 - 24*sqrt(3)))^2:
r := b*sqrt(b)/(sqrt(a + b) + sqrt(a)):
point(A, -a, b): point(B, -a, -b):
point(C, a, -c): point(F, a, b):
Sq := square(Sq, [A, B, C, F]):
circle(C1, [point(P1, [r, 0]), r]):
circle(C2, [point(P2, [(1 + sqrt(3))*r, r]), r]):
circle(C3, [point(P3, [(1 + sqrt(3))*r, -r]), r]):
ellipse(E, x^2/a^2 + y^2/b^2 = 1, [x, y]):
solve({Equation(C1), x^2/a^2 + y^2/b^2 = 1}, {x, y}):
point(T, [5.349255162, 2.829908743]):
IsOnCircle(T, C1);
draw([E(color = cyan), C1(color = yellow, filled = true), T(symbol = solidcircle, symbolsize = 20, color = red), Sq, C2(color = red), C3(color = red),Sq(color=blue)], axes = normal, view = [-a .. a, -b .. b], scaling = constrained);
square: (196+(7*(1/2+(1/6)*(45-24*3^(1/2))^(1/2))^2+c)^2)^(1/2)-(196+196*(1/2+(1/6)*(45-24*3^(1/2))^(1/2))^4)^(1/2) = 0
square: (7/2)*(1/2+(1/6)*(45-24*3^(1/2))^(1/2))^2-(1/2)*c = 0
Error, (in geometry:-square) not enough information to define a square
Error, (in geometry:-draw) cannot determine the vertices for drawing .Why all these errors ? Thank you.
About a half hour ago, there was a Post titled "Read binary file" from a new user. I converted it to a Question. Now that I want to Answer the Question, I can't find it. If you are the author of that Question, and you still want an answer, please post it again, but put it in the Questions area.
(I think that there may be a bug in MaplePrimes that makes this happen. I've had it happen several times before.)
Anyway, please respond to this regardless of what you want regarding the Question. That'll help me figure out what went wrong.
i am a very new user of Maple.
is there an equivalent Mathematica function of
Transpose@Partition[BinaryReadList["Namefile","UnsignedInteger16"],8]
thank you very much and best regards
bruno
I'm seeking a way to test conditional statements for truth in Maple (2022).
The statements are like (\phi^2 > 2) implies (\phi > 1.4)
1) how can I input such kind of statements?
2) how can I get a result in form true/false
  a) for entire expression
  b) (depending on phi range)
Does anyone use the /= assignment operator?
I am trying to do a
while error  > error_tol do
sequence of ops,
# update error from last loop
# simple example of assignment test
error /= 2;    #to simulate decreasing error each loop.  Real equation on RHS is error(i) = error(i-1) + comparison of last iterates.
# Real operator assignment I'd like to use is error += comparison
the divide / keeps applying as the single divide and a long line under the variable before I can type =.   This happens in both 1-D and 2-D.   The "Operator Assignments" help page doesn't have a lot of help on syntax problems using these.
Bill
I am trying to find a fast method for integration of a function composed of several Heavisides. I used Quadrature-Romberg, but no success. What is the problem with it and what method do you recommend instead?
A := Heaviside(zeta__2-.6429162216568)*Heaviside(eta__2+.5050000000000-10.98537767108*sqrt(492.5151416233-zeta__2^2))+Heaviside(zeta__2-.9999999999936)*Heaviside(eta__2+.9875792458758+3.881485663812*10^9*sqrt(9.765625000000*10^22-zeta__2^2))+Heaviside(zeta__2+1.000000000000)*Heaviside(eta__2-.4637698986762+2.327456686822*10^11*sqrt(2.777777777778*10^24-zeta__2^2))-Heaviside(zeta__2+1.000000000000)*Heaviside(eta__2-.4637698986762-2.327456686822*10^11*sqrt(2.777777777778*10^24-zeta__2^2))+Heaviside(zeta__2+1.000000000000)*Heaviside(eta__2+.1619291800251+3.018371923484*10^11*sqrt(4.000000000000*10^24-zeta__2^2))-Heaviside(zeta__2+1.000000000000)*Heaviside(eta__2+.1619291800251-3.018371923484*10^11*sqrt(4.000000000000*10^24-zeta__2^2))+Heaviside(zeta__2+1.000000000000)*Heaviside(eta__2+.7243706106403+1.382194833711*10^11*sqrt(1.562500000000*10^24-zeta__2^2))-Heaviside(zeta__2+1.000000000000)*Heaviside(eta__2+.7243706106403-1.382194833711*10^11*sqrt(1.562500000000*10^24-zeta__2^2))+Heaviside(zeta__2-1.000000000000)*Heaviside(eta__2+.9875792458758-3.881485663812*10^9*sqrt(9.765625000000*10^22-zeta__2^2))-Heaviside(zeta__2-1.000000000000)*Heaviside(eta__2+.9875792458758+3.881485663812*10^9*sqrt(9.765625000000*10^22-zeta__2^2))+Heaviside(zeta__2-1.000000000000)*Heaviside(eta__2-.8341191288491-1.298592148442*10^10*sqrt(9.706617486471*10^21-zeta__2^2))-Heaviside(zeta__2-1.000000000000)*Heaviside(eta__2-.8341191288491+1.298592148442*10^10*sqrt(9.706617486471*10^21-zeta__2^2))-Heaviside(zeta__2-.9999999999796)*Heaviside(eta__2-.8341191288491-1.298592148442*10^10*sqrt(9.706617486471*10^21-zeta__2^2))-Heaviside(zeta__2-.5527964251744)*Heaviside(eta__2+.5050000000000-10.98537767108*sqrt(492.5151416233-zeta__2^2))+Heaviside(zeta__2-.5527964251744)*Heaviside(eta__2+.5050000000000+10.98537767108*sqrt(492.5151416233-zeta__2^2))+Heaviside(zeta__2-.7684252323012)*Heaviside(eta__2-.5050000000000-8.127372424924*sqrt(269.5813999936-zeta__2^2))-Heaviside(zeta__2-.6466146460206)*Heaviside(eta__2-.5050000000000-8.127372424924*sqrt(269.5813999936-zeta__2^2))-Heaviside(zeta__2-.7684252323012)*Heaviside(eta__2-.5050000000000+8.127372424924*sqrt(269.5813999936-zeta__2^2))+Heaviside(zeta__2-.6466146460206)*Heaviside(eta__2-.5050000000000+8.127372424924*sqrt(269.5813999936-zeta__2^2))-Heaviside(zeta__2-.9999999999936)*Heaviside(eta__2+.9875792458758-3.881485663812*10^9*sqrt(9.765625000000*10^22-zeta__2^2))+Heaviside(zeta__2-.9999999999796)*Heaviside(eta__2-.8341191288491+1.298592148442*10^10*sqrt(9.706617486471*10^21-zeta__2^2))+Heaviside(zeta__2+.9999999999972)*Heaviside(eta__2+.9842650870048-1.085166413462*10^10*sqrt(4.756242568371*10^23-zeta__2^2))-Heaviside(zeta__2+.9999999999972)*Heaviside(eta__2+.9842650870048+1.085166413462*10^10*sqrt(4.756242568371*10^23-zeta__2^2))+Heaviside(zeta__2+.9999999999990)*Heaviside(eta__2+.1619291800251-3.018371923484*10^11*sqrt(4.000000000000*10^24-zeta__2^2))-Heaviside(zeta__2+.9999999999990)*Heaviside(eta__2+.1619291800251+3.018371923484*10^11*sqrt(4.000000000000*10^24-zeta__2^2))+Heaviside(zeta__2+.9999999999988)*Heaviside(eta__2-.4637698986762-2.327456686822*10^11*sqrt(2.777777777778*10^24-zeta__2^2))-Heaviside(zeta__2+.9999999999988)*Heaviside(eta__2-.4637698986762+2.327456686822*10^11*sqrt(2.777777777778*10^24-zeta__2^2))+Heaviside(zeta__2+.9999999999984)*Heaviside(eta__2+.7243706106403-1.382194833711*10^11*sqrt(1.562500000000*10^24-zeta__2^2))-Heaviside(zeta__2+.9999999999984)*Heaviside(eta__2+.7243706106403+1.382194833711*10^11*sqrt(1.562500000000*10^24-zeta__2^2))+Heaviside(zeta__2+.9999999999984)*Heaviside(eta__2-.9031048925918-8.123652892875*10^10*sqrt(1.562500000000*10^24-zeta__2^2))-Heaviside(zeta__2+.9999999999984)*Heaviside(eta__2-.9031048925918+8.123652892875*10^10*sqrt(1.562500000000*10^24-zeta__2^2))-Heaviside(zeta__2+1.000000000000)*Heaviside(eta__2+.9842650870048-1.085166413462*10^10*sqrt(4.756242568371*10^23-zeta__2^2))+Heaviside(zeta__2+1.000000000000)*Heaviside(eta__2+.9842650870048+1.085166413462*10^10*sqrt(4.756242568371*10^23-zeta__2^2))-Heaviside(zeta__2-.6429162216568)*Heaviside(eta__2+.5050000000000+10.98537767108*sqrt(492.5151416233-zeta__2^2))-Heaviside(zeta__2+1.000000000000)*Heaviside(eta__2-.9031048925918-8.123652892875*10^10*sqrt(1.562500000000*10^24-zeta__2^2))+Heaviside(zeta__2+1.000000000000)*Heaviside(eta__2-.9031048925918+8.123652892875*10^10*sqrt(1.562500000000*10^24-zeta__2^2)):
plot3d(A, zeta__2 = -1 .. 1, eta__2 = -1 .. 1, color = green)
Digits := 22:
with(Student[NumericalAnalysis]):
Quadrature(Quadrature(A, zeta__2 = -1 .. 1, method = romberg[8]), eta__4 = -1 .. 1, method = romberg[8])
Float(undefined)*Heaviside(eta__2+1212964270000000000001.)+Float(undefined)*Heaviside(eta__2-1279401131003415700657.)-0.1513022270849353690226e-1*Heaviside(eta__2-133.8411610374164929382)+Float(undefined)*Heaviside(eta__2-7483906296259851792359.)+Float(undefined)*Heaviside(eta__2+7483906296259851792361.)+Float(undefined)*Heaviside(eta__2-0.1015456611625000000000e24)+Float(undefined)*Heaviside(eta__2+0.1015456611625000000000e24)+Float(undefined)*Heaviside(eta__2+0.3879094478488497112464e24)+Float(undefined)*Heaviside(eta__2+1279401131003415700655.)-0.4538512794872905686682e-1*Heaviside(eta__2-133.8360207224718595497)+0.4538512794872905686682e-1*Heaviside(eta__2+132.8260207224718595497)+0.4538512794872905686682e-1*Heaviside(eta__2+132.8042477794001150390)-0.4538512794872905686682e-1*Heaviside(eta__2-133.8253766167816064928)-0.4538512794872905686682e-1*Heaviside(eta__2-243.1883998382669648802)+0.1513022270849353690226e-1*Heaviside(eta__2+132.8311610374164929382)+Float(undefined)*Heaviside(eta__2-0.1727743542500000000000e24)-0.1513022270849353690226e-1*Heaviside(eta__2-243.2027260661341424950)+0.1513022270849353690226e-1*Heaviside(eta__2+244.2127260661341424950)+0.4538512794872905686682e-1*Heaviside(eta__2+244.1983998382669648802)-0.4538512794872905686682e-1*Heaviside(eta__2-243.1980716456433769010)+0.4538512794872905686682e-1*Heaviside(eta__2+244.2080716456433769010)+0.4538512794872905686682e-1*Heaviside(eta__2+132.8153766167816064928)+0.1513022270849353690226e-1*Heaviside(eta__2+132.8098727970154075001)+Float(undefined)*Heaviside(eta__2-0.3879094478488497112464e24)-0.4538512794872905686682e-1*Heaviside(eta__2-243.2072595071292620415)+Float(undefined)*Heaviside(eta__2+0.6036743846000000000000e24)+Float(undefined)*Heaviside(eta__2-0.6036743846000000000000e24)+Float(undefined)*Heaviside(eta__2+0.1727743542500000000000e24)-0.1916322521366165064753e-1*Heaviside(eta__2-133.8307592537082147847)+0.1916322521366165064753e-1*Heaviside(eta__2+132.8207592537082147847)-0.1916322521366165064753e-1*Heaviside(eta__2-243.2116719753798543789)+0.1916322521366165064753e-1*Heaviside(eta__2+244.2216719753798543789)-0.4538512794872905686682e-1*Heaviside(eta__2-133.8026340889186250133)+0.4538512794872905686682e-1*Heaviside(eta__2+132.7926340889186250133)-0.4538512794872905686682e-1*Heaviside(eta__2-133.8142477794001150390)-0.1513022270849353690226e-1*Heaviside(eta__2-133.8198727970154075001)+0.4538512794872905686682e-1*Heaviside(eta__2+244.2172595071292620415)-0.1903631769101229216919e-1*Heaviside(eta__2-133.8085015485931455736)+0.1903631769101229216919e-1*Heaviside(eta__2+132.7985015485931455736)+0.1903531841918040745676e-1*Heaviside(eta__2+244.2032962387251632874)-0.1903531841918040745676e-1*Heaviside(eta__2-243.1932962387251632874)+Float(undefined)*Heaviside(eta__2-1212964269999999999999.)
int(int(A, zeta__2 = -1 .. 1), eta__2 = -1 .. 1)
.4238607655960000000000
Download romberg.mw
I am trying to solce eq (2) by integration. But maple integrate only 1st term in eq. Why not other two terms?
Solve_integral.mw
and I try to fix my file use this method: https://www.mapleprimes.com/questions/129377-There-Were-Problems-During-The-Loading?reply=reply , but an error occurred as follows .
And my code is:
DeleteBadCharacters := proc(file :: string)
local base, badchar, char, cnt, msg, outfile, str, unicode;
    str := FileTools:-Text:-ReadFile(file);
    for cnt from 0 do
        try
            XMLTools:-ParseString(str);
            break;
        catch "An invalid XML character":
            msg := lastexception[2];
            if not StringTools:-RegMatch("Unicode: 0x([^)]+)", msg, 'all', 'unicode') then
                error;
            unicode := sscanf(unicode,"%x");
            char := convert(unicode,'bytes');
            badchar[cnt+1] := char;
            str := StringTools:-SubstituteAll(str, char, "");
        end try;
    if cnt=0 then
        printf("no errors in file\n");
        if not StringTools:-RegMatch("^(.*)\\.mw$", file, 'all', 'base') then
            error "problem extracting basename";
        printf("deleted bad characters: %A\n", {seq(badchar[cnt],cnt=1..cnt)});
        outfile := sprintf("%s-fixed.mw", base);
        FileTools:-Text:-WriteString(outfile, str);
        fclose(outfile);
        printf("wrote updated file to %s\n", outfile);
    return NULL;
NULL;
NULL;
DeleteBadCharacters( "E:/EchoModel_V3.mw" );
And the error is
"Error, (in XMLTools:-ParseString) XML document structures must start and end within the same entity."
I use maple 2021.  Thank you very much!
I can not find my Kamke book right now. But according to Maple help, Homogeneous ODE of Class C is the following
If I understand the above, it is saying that the RHS of the ode should be ratio of two polynomials, and both should be linear in y and x. Correct?
Given the above, then why Maple says the following ode is _homogeneous, `class C` ? Since the RHS is not linear in y and not linear in x:
ode:=diff(y(x),x)=(2*y(x)-1)*(4*y(x)+6*x-3)/(y(x)+3*x-1)^2;
ode:=lhs(ode)=expand(numer(rhs(ode)))/expand(denom(rhs(ode)))
DEtools:-odeadvisor(ode)
           [[_homogeneous, `class C`], _rational]
What Am I overlooking/misunderstanding  from reading this definition?
The system does not correctly calculate the CDF of a Binomial using the Regularized Incomplete Beta for p=0.5.
Ícono de validado por la comunidad
n := 10;
f := x -> int(t^(n - x - 1)*(1 - t)^x, t = 0 .. 1 - p)/Beta(n - x, x + 1);
p := 0.5;
plot(f(x), x = 0 .. 10);
gaussian.m.mw
This is the maple worksheet
It's showing an error. It's showing an error with its conditions. What to do? How can I solve it? Got stuck here on this issue?Unable to solve this problem. Please help me. This the maple worksheet:
6coupled.m.mw
I have a function that refuses to allow "fsolve" to compute a root for.  I'm trying to use a brute force Newton (or secant) algorithm to find the root.  This is successful
But I'm new enough in Maple Flow (and Maple) that I can't build an automatic recursion method.  All ideas welcome.
EqBIS := proc(P, U, V)
local a, eq1, M1, t, PU, PV, bissec1;
a := (P - U)/LinearAlgebra:-Norm(P - U, 2) + (P - V)/LinearAlgebra:-Norm(P - V, 2);
M1 := P + a*t;
eq1 := op(eliminate({x = M1[1], y = M1[2]}, t));
RETURN(op(eq1[2])); end proc;
EqBIS*([4, 5], [11, 7/3], [11, 5]);
why such a procedure gives no result Thabk you.
Trying to use the jets package from http://jets.math.slu.cz/ (file jets.s) for calculus of variations.
Test example -
coordinates([x,y],[f],3);
parameter(p);
g:=(f_x)^2+(f_y)^2-2*p*f;
vg:=variation(g,f);                  # first variation of g (from line 4354 of jets.s)
Now I want to find g from vg - inverse problem. The code for this starts on line 4367 of jets.s, command is lagrangian.
Tried -
Lg:=lagrangian(vg,f);
Lg:=lagrangian([vg,f]);
Lg:=lagrangian(vg,[f]);
Lg:=lagrangian(f=vg);
but all give syntax errors.
The authors of the package don't respond to query and the manual does't help.
Does anyone know what the correct syntax of lagrangian is. Or is there a better package to use for inverse problem.
First 318 319 320 321 322 323 324 Last Page 320 of 2458
