Dear everyone, ive been trying to get to learn Maple, and i am using the book: Advanced Problem
Solving Using Maple.
I am having issues with not getting the same results as the examples. Although i am using the same imput as the examples. So to me that is really odd. I also noted to get the same results as the examples, i had to change the imput to get there. Now this is a bit more complex problem, and i cant figure out where it went wrong.
Can you help me?
It did seem to produce the answers, however not in the same fashion as the example in the book. I still had to add the values together. No the solution i got is not what i am looking for.
Greetings,
The Function
DDS := a(n+1) = (1+.12*(1/12))*a(n)+1000
a(n+1) = 1.010000000*a(n)+1000
rsolve({DDS, a(0) = 0}, a(n)); a := unapply(%, n)
proc (n) options operator, arrow; 100000*(101/100)^n-100000 end proc
plot([-100000+100000*(101/100)^n], n = 0 .. 100, a = 0 .. 200000)
pts := {seq([k, a(k)], k = 0 .. 24)}; plot(pts, style = point, title = "Savings Account with Monthly Deposit")
rsolve({a(0) = 497.5124378, a(n+1) = -1.01*a(n)+1000}, a(n))
-(11/1005000000)*(-101/100)^n+100000/201
plot([-(11/1005000000)*(-101/100)^n+100000/201], n = 0 .. 20, a = 0 .. 1000)
solve(ev = -1.01*ev+1000, ev)
497.5124378
rsolve({a(n+1) = .5*a(n)+16}, a(n))
a(0)*(1/2)^n-32*(1/2)^n+32
rsolve({a(0) = 10, a(n+1) = .5*a(n)+16}, a(n))
-22*(1/2)^n+32
smartplot(-22*(1/2)^n+32)
rsolve({a(0) = 20, a(n+1) = .5*a(n)+16}, a(n))
-12*(1/2)^n+32
smartplot(-12*(1/2)^n+32)
rsolve({a(0) = 32, a(n+1) = .5*a(n)+16}, a(n))
32
rsolve({a(0) = 50, a(n+1) = .5*a(n)+16}, a(n))
18*(1/2)^n+32
smartplot(18*(1/2)^n+32)
solve(ev = .5*ev+16, ev)
32.
solve(ev = .5*ev+64, ev)
128.
rsolve({a(0) = A, a(n+1) = .5*a(n)+64}, a(n)); a := unapply(%, [A, n])
A*(1/2)^n+128-128*(1/2)^n
inits := [0, 50, 100, 150, 200]
gen := proc (i, j) options operator, arrow; evalf(a(inits, i)) end proc
DrugConcTable := Matrix(10, 5, gen)
Matrix(%id = 18446746425282593366)
(14)
help("matrix")
Download Discrete_Dynamical_Models_2.mw
At age 25, Carrie establishes an individual retirement account (IRA). If she invests #4000 per year for 30years in an ordinary annuity, the account earns 7.75% per year. How much will she have in the account at age 25?
How difficult is it to animate a process using a binary tree for visualization purposes, something that isn't too slow or too complex to implement(as I will then just go with python or something) but also nice to look at(not just boring straight lines).
I'd like to animate, say, a ball moving through different branchings of a multi-tree(binary mainly but ultimately different branchings per node).
As an aside. Is there anything like C++ objects/structs in maple that are easy to create using . notation?
I have a procedure where M:=[m2,m3,m4...] and I  assign the m's values from list L:=[0.1,2....]
The procedure will only run once. Rerunning will not reassign the m's.
What is the correct way to do this?
Assign_in_proc.mw
Hi, I have an equation and I want y be as a fuction, in fact, I 'd like a function in which x is independent variable and y is dependent to x,could you please help me how to do it?
A is a complicated equation but doesn't have "y" in it so it is not important what it is, a and b also have values.
(a*y-x*(a+1))/(x^(2)-b*a^(2)*(y-x)^(2))=A
sigma := 7.500*10^7+2.005*10^7*sinh(22985.642*z)-2.097*10^7*cosh(22985.642*z)
75000000.00+20050000.00*sinh(22985.642*z)-20970000.00*cosh(22985.642*z)
sigma_debond := 5.403*10^7
54030000.00
mid := 0.1653e-3
0.1653e-3
L := 0.2184e-3
0.2184e-3
plot(sigma, z = mid .. L)
plot(sigma_debond, z = 0 .. mid)
Download join_curves.mw
Hi everyone,
I have a system with trigonometric function, composed of 3 unknows (b,c,d) and 2 input (a,x). I would like to know how to express each of the unknowns in terms of a and x (if it's possible).
Here is my worksheet : test6.mw
Thanks everyone
HOW TO GUESS THE SUM OF FOLLOWING INFINITE SERIES IN MAPLE?
HOW TO GUESS THE EXACT  SOLUTION OF FOLLOWING INFINITE SERIES
How to plot 3D graph for the following infinite series sum?
How do I create a plot like Figure I as uploaded in the PDF-document?
On Figure I, you see the plot of two income functions. The income functions are defined by equations (5), (6), (7), and (8).
Please note that:
0<a<1
0<g<1
0<"tau"<1
0<"delta"*g<1
"delta" belongs to open interval (0,1)
/Regards.
IMG_499.pdf
For examples, they are two non-commutative variables x and y, and i use "Setup(noncommutativeprefix={x,y})" to define.
 As the previous results have shown that AntiCommutator(x,x)=0 and AntiCommutator(y,y)=0, so i just define Setup(algebrarules={%AntiCommutator(x,x)=0, %AntiCommutator(y,y)=0}).
When i am calculating AntiCommutator(x,y), the maple automatically simplifies the results and returns AntiCommutator(x,y)=0, as variables x and y are thought to be GrassmannParity =1 variables.
Consider two  3*3 matrix e23 and e32, the AntiCommutator of (e23, e23)=(e32,e32)=0, but the AntiCommutator(e23,e32)= e22+e33.
So how the algebrarules work and why there is the contradiction ?
How does Maple interpret the second line to get that result ??
I had to put expicitly a dot between the brackets to fix it.
Kind regards, Detlef Hoyer
restart; eq2 := ef*epsilon+x1*sinh(y1*L/r1)+x2*cosh(y1*L/r1)-.1*(ef*epsilon+x2) = 0; eq3 := ef*epsilon+x1*sinh(-y1*L/r1)+x2*cosh(-y1*L/r1)-.1*(ef*epsilon+x2) = 0; sol1 := solve({eq2, eq3}, {x1, x2})
.9*ef*epsilon+x1*sinh(y1*L/r1)+x2*cosh(y1*L/r1)-.1*x2 = 0
.9*ef*epsilon-x1*sinh(y1*L/r1)+x2*cosh(y1*L/r1)-.1*x2 = 0
{x1 = 0., x2 = -9.*ef*epsilon/(10.*cosh(y1*L/r1)-1.)}
assign(sol1); 1; x1, x2
0., -9.*ef*epsilon/(10.*cosh(y1*L/r1)-1.)
x1;
0.
x2;
eq4 := ef*epsilon+x1*sinh(y1*z/r1)+x2*cosh(y1*z/r1);
ef*epsilon-9.*ef*epsilon*cosh(y1*z/r1)/(10.*cosh(y1*L/r1)-1.)
avg_eq4 := Typesetting:-delayDotProduct(1/L, int(eq4, z));
1/L.(ef*epsilon*z-9.*ef*epsilon*r1*sinh(y1*z/r1)/((10.*cosh(y1*L/r1)-1.)*y1))
Ecomp := Typesetting:-delayDotProduct(simplify((eval(subs(z = L, avg_eq4)-subs(z = 0, avg_eq4)))/epsilon), Vf)+(1-Vf)*Em;
(1/L.(ef*epsilon*(10.*L*y1*cosh(y1*L/r1)-L*y1-9.*r1*sinh(y1*L/r1))/((10.*cosh(y1*L/r1)-1.)*y1)))/epsilon.Vf+(1-Vf)*Em
tau := .5*(diff(eq4, z))*r1;
-4.5*ef*epsilon*sinh(y1*z/r1)*y1/(10.*cosh(y1*L/r1)-1.)
L := lfact*r1;
lfact*r1
0.65e-5
ef := 0.75e11;
0.75e11
0.326e10
.3
.5
Theo_Ecomp := Vf*ef+(1-Vf)*Em;
0.39130e11
y1 := 2*Em/((1+nu)*ef*ln(1/Vf))
0.9647560684e-1
Ecomp
0.5979989095e17*(1/lfact.(epsilon*(0.6270914445e-5*lfact*cosh(0.9647560685e-1*lfact)-0.6270914445e-6*lfact-0.585e-4*sinh(0.9647560685e-1*lfact))/(10.*cosh(0.9647560685e-1*lfact)-1.)))/epsilon+0.1630e10
epsilon := 0.1e-2;
0.1e-2
(14)
plot(Ecomp, lfact = 1 .. 500)
lfact := 90.81506;
90.81506
(15)
eq4
0.75e8-21149.64968*cosh(14842.40105*z)
(16)
plot(eq4, z = 0 .. L)
plot(tau, z = 0 .. L)
Download Fuly_bonded_updated.mw
A line is deternined on one side by 16*x-2*y-11*z=0, 14*x-y-10*z=3 and on the other by (x-2)/3=(y-5)/2=(z-2)/4. Are they equivalent  ?  Thank you.
First 414 415 416 417 418 419 420 Last Page 416 of 2458
