I want to export Maple 3d graphics to Latex with high quality. ( MAPLE 2020.1)
I export the 3d graphics to a .jpeg or.png file, but the quality of graphics is very poor. So, I want to prefer Encapsulated PostScript files (.eps) format.
 I select the figure, right-click it and choose "Export as". and  I save the figure as  .eps file. No problem I get a file. But when I add the eps figure to Latex, I live some problems:
MY Example Code:
scheme1 := ["zgradient",["Blue","Cyan","Green","Yellow","Orange","Red"]]:
P1:=plot3d(x*y, colorscheme=scheme1,style=surfacecontour ):
P2:=plot3d(x*y,colorscheme=scheme1,style=point,symbol=asterisk):
final_plot:=display({P1,P2}); #I want to export this figure to .eps
PROBLEMS which I live:
  • Sometimes I get the result as follows:
  • Sometimes compiling takes too long time in latex, I don't get any results or get an error. (I tried on the all of TexStudio or TexMaker or overleaf)
I read the previous post on this site and applied the suggestions, but I still live the same problem.
P.S.
I can add Maple 2d graphics to LATEX without any problem.
Hi everyone,
I have two expressions given by:
A := -sqrt(m(p[1](t))/m(q[1](t)))*p[2](t) - l[1]*q[1](t) + l[1]*p[1](t) + q[2](t);
B := -(-sqrt(m(p[1](t))/m(q[1](t))^3)*C(p[1](t))*m(q[1](t))^(3/2)*p[2](t)^2*m(p[1](t)) + C(p[1](t))*p[2](t)^3*m(q[1](t))^(3/2)*sqrt(m(p[1](t))/m(q[1](t))) - l[1]*p[2](t)^2*C(p[1](t))*(p[1](t) - q[1](t))*m(q[1](t))^(3/2) - sqrt(m(q[1](t)))*l[2]*(p[1](t) - q[1](t))*m(p[1](t))^(3/2) + m(p[1](t))*l[1]*p[2](t)*C(p[1](t))*(p[1](t) - q[1](t))*sqrt(m(q[1](t))) - C(q[1](t))*q[2](t)^2*sqrt(m(p[1](t)))*m(q[1](t))*(q[2](t) - 1))/(sqrt(m(p[1](t)))*m(q[1](t))^(3/2));
I would like to rewrite these two expressions according to a and b (replace in A and B each: q[1](t) - p[1](t)  by a and   sqrt(m(q[1](t)))*q[2](t) - sqrt(m(p[1](t)))*p[2](t) by ), such that :
a := q[1](t) - p[1](t);
b := sqrt(m(q[1](t)))*q[2](t) - sqrt(m(p[1](t)))*p[2](t);
I used subs and collect but doesn’t work.
Could you help me please ?
I would like to thank you in advance.
Best regards,
I want to write a procedure for adding gridlines to 3dplots of any function f on ([x_min,x_max]x[y_min,y_max])
grids:=proc(f,x_min,x_max,y_min,y_max)
 local z_min,z_max,plot_f,xz,yz,xy;
uses plots;
z_min:=0:
z_max:=10:
plot_f:=plot3d(f,x=x_min..x_max,y=y_min..y_max);
xz:=plot3d([x,y_min,z],x=x_min..x_max,z=z_min..z_max,style=line,color=blue,thickness=0,grid=[6,6]);
yz:=plot3d([x_min,y,z],y=y_min..y_max,z=z_min..z_max,style=line,color=blue,thickness=0,grid=[4,6]);
xy:=plot3d([x,y,z_min],x=x_min..x_max,y=y_min..y_max,style=line,color=blue,thickness=0,grid=[4,4]);
return
display(plot_f,xz,yz,xy,lightmodel=none,tickmarks=[3,3,6],labels=[x,y,"f(x,y)"],labeldirections=[horizontal,horizontal,vertical],axes=frame);
#EXAMPLE
f:=x^2-y:
x_min:=-1:
x_max:=3:
y_min:=-2:
y_max:=1:
grids(f,-1,3,-2,-1);
Some of the drawbacks of the above code are:
  1. The minimum value ( z_min ) and maximum value ( z_max ) of function f(x,y) can't be calculated automatically.
  2. grid=[6,6],grid=[4,6] etc. can't be calculated automatically. (it may be automatically calculated by considering the stepsize of axis x and axis y)
If I make this command in maple: solve(sin(x) = -1/2, x) I would like to get all the answers, but the only output I get is pi/6. I know I can find the other output myself, but I would like to know if I can make maple show all the answers.
Here is how my cas calculater would shows the answer/output: "x=2k*pi+7pi/6 or 2k*pi-pi/6" - shich is how I would like to see it in maple as well.
I was hoping to run two procs: tgf3 and tgf4 in parallel using Grid, Run and get a faster execution time. As I understood the description of Grid Run, the first call to Grid Run will run in the background and before it is finished the second call Grid Run will start. I do not believe I have that situation in my script. I am not understanding Grid Run. How can this problem be fixed? Here is just a portion of the script using Grid Run:
Use Grid Run 0 for tgf3 and 1 for tgf4. Determine the real time and compare times. The Grid Runs do not appear to run in parallel.
rgt := time[real]();
Grid:-Run(0, `~`[tgf3@op](convert(L, listlist)), 'assignto' = ans3roots);
Grid:-Run(1, `~`[tgf4@op](convert(L, listlist)), 'assignto' = ans4roots);
ans3roots;
ans4roots;
GridRunTime := time[real]() - rgt;
                     GridRunTime := 44.074
Here is my script:
Grid_Run_2.mw
Thank you for your help.
1. How did Maple come up with this answer?
I've tried all the packages in SumTools and none of them give an answer except Hypergeometric.
2. Is there a way to trace the steps Maple is using so I can try and answer this myself?
3. Why did it sum the series when I didn't even ask - I deliberately used the inert form (no arguments though - I like what it did).
______________________________________________________________________________
H1a := Sum(GAMMA(2*b - 1 + 2*n)*GAMMA(2*n - s)*(b - 1/2 + 2*n)/(GAMMA(2*b + 2*n + s)*GAMMA(2*n + 1)), n = 0 .. infinity);
H1b:=convert(H1a,Hypergeom);
The answer H1b it came up with is
GAMMA(-s)*2^(1 + 2*b)*GAMMA(b)/(8*GAMMA(b + s)*2^(2*b));
which seems to be correct.
How to plot absolute value in dsolve?
absolute_plot.mw
Plotting in the first coordinate in the plane......
Hello there,
Would please tell me how to pick up numerical vaules from answers given by 'solve()' command?
If you look at the worksheet (sorry for the error), one possible way is labeled by 'solution 1'. However, when I tried the expression in the 'attempt 1' label, I got an error. Therefore, I'm wondering if there is a way to extract the values from the answers, instead of using the 'rhs()' command.
Maple Worksheet - Error
Failed to load the worksheet /maplenet/convert/q20210206.mw .
Download q20210206.mw
Best Regards,
In Kwon Park
Dear Users!
First, I define the following polynomial as:
restart; with(LinearAlgebra); nu := 1/2; M1 := 3; M2 := 3; #(any value of M1 and M2)
for k1 from 0 while k1 <= M1-1 do for k2 from 0 while k2 <= M2-1 do
SGP[M2*k1+k2+1] := simplify(sum((-1)^(k1-i1)*GAMMA(k1+i1+2*nu)*GAMMA(nu+1/2)*x^i1*(sum((-1)^(k2-i2)*GAMMA(k2+i2+2*nu)*GAMMA(nu+1/2)*t^i2/(GAMMA(i2+nu+1/2)*factorial(k2-i2)*factorial(i2)*GAMMA(2*nu)), i2 = 0 .. k2))/(GAMMA(i1+nu+1/2)*factorial(k1-i1)*factorial(i1)*GAMMA(2*nu)), i1 = 0 .. k1))
end do end do;
Lambda := `<,>`(seq(SGP[i], i = 1 .. M1*M2));
then, I want to define a square matrix A of order M1M2 by M1M2 after collocating SGP[k](x,y) at x=(i-1)/(M1-1) and y=(j-1)/(M2-1) for i=1,2,3,...M1, j=1,2,3,...M2.
For example, for M1=2 and M3=3 this matrix A is given as:
A:=Matrix(6, 6, {(1, 1) = SGP[1](0, 0), (1, 2) = SGP[2](0, 0), (1, 3) = SGP[3](0, 0), (1, 4) = SGP[4](0, 0), (1, 5) = SGP[5](0, 0), (1, 6) = SGP[6](0, 0), (2, 1) = SGP[1](0, 1), (2, 2) = SGP[2](0, 1), (2, 3) = SGP[3](0, 1), (2, 4) = SGP[4](0, 1), (2, 5) = SGP[5](0, 1), (2, 6) = SGP[6](0, 1), (3, 1) = SGP[1](1/2, 0), (3, 2) = SGP[2](1/2, 0), (3, 3) = SGP[3](1/2, 0), (3, 4) = SGP[4](1/2, 0), (3, 5) = SGP[5](1/2, 0), (3, 6) = SGP[6](1/2, 0), (4, 1) = SGP[1](1/2, 1), (4, 2) = SGP[2](1/2, 1), (4, 3) = SGP[3](1/2, 1), (4, 4) = SGP[4](1/2, 1), (4, 5) = SGP[5](1/2, 1), (4, 6) = SGP[6](1/2, 1), (5, 1) = SGP[1](1, 0), (5, 2) = SGP[2](1, 0), (5, 3) = SGP[3](1, 0), (5, 4) = SGP[4](1, 0), (5, 5) = SGP[5](1, 0), (5, 6) = SGP[6](1, 0), (6, 1) = SGP[1](1, 1), (6, 2) = SGP[2](1, 1), (6, 3) = SGP[3](1, 1), (6, 4) = SGP[4](1, 1), (6, 5) = SGP[5](1, 1), (6, 6) = SGP[6](1, 1)});
for M1=3 and M=2 the matrix A is given as:
A:=Matrix(6, 6, {(1, 1) = SGP[1](0, 0), (1, 2) = SGP[2](0, 0), (1, 3) = SGP[3](0, 0), (1, 4) = SGP[4](0, 0), (1, 5) = SGP[5](0, 0), (1, 6) = SGP[6](0, 0), (2, 1) = SGP[1](0, 1/2), (2, 2) = SGP[2](0, 1/2), (2, 3) = SGP[3](0, 1/2), (2, 4) = SGP[4](0, 1/2), (2, 5) = SGP[5](0, 1/2), (2, 6) = SGP[6](0, 1/2), (3, 1) = SGP[1](0, 1), (3, 2) = SGP[2](0, 1), (3, 3) = SGP[3](0, 1), (3, 4) = SGP[4](0, 1), (3, 5) = SGP[5](0, 1), (3, 6) = SGP[6](0, 1), (4, 1) = SGP[1](1, 0), (4, 2) = SGP[2](1, 0), (4, 3) = SGP[3](1, 0), (4, 4) = SGP[4](1, 0), (4, 5) = SGP[5](1, 0), (4, 6) = SGP[6](1, 0), (5, 1) = SGP[1](1, 1/2), (5, 2) = SGP[2](1, 1/2), (5, 3) = SGP[3](1, 1/2), (5, 4) = SGP[4](1, 1/2), (5, 5) = SGP[5](1, 1/2), (5, 6) = SGP[6](1, 1/2), (6, 1) = SGP[1](1, 1), (6, 2) = SGP[2](1, 1), (6, 3) = SGP[3](1, 1), (6, 4) = SGP[4](1, 1), (6, 5) = SGP[5](1, 1), (6, 6) = SGP[6](1, 1)});
and for M1=M2=3 the matrix A should be the following form:
A:=Matrix(9, 9, {(1, 1) = SGP[1](0, 0), (1, 2) = SGP[2](0, 0), (1, 3) = SGP[3](0, 0), (1, 4) = SGP[4](0, 0), (1, 5) = SGP[5](0, 0), (1, 6) = SGP[6](0, 0), (1, 7) = SGP[7](0, 0), (1, 8) = SGP[8](0, 0), (1, 9) = SGP[9](0, 0), (2, 1) = SGP[1](0, 1/2), (2, 2) = SGP[2](0, 1/2), (2, 3) = SGP[3](0, 1/2), (2, 4) = SGP[4](0, 1/2), (2, 5) = SGP[5](0, 1/2), (2, 6) = SGP[6](0, 1/2), (2, 7) = SGP[7](0, 1/2), (2, 8) = SGP[8](0, 1/2), (2, 9) = SGP[9](0, 1/2), (3, 1) = SGP[1](0, 1), (3, 2) = SGP[2](0, 1), (3, 3) = SGP[3](0, 1), (3, 4) = SGP[4](0, 1), (3, 5) = SGP[5](0, 1), (3, 6) = SGP[6](0, 1), (3, 7) = SGP[7](0, 1), (3, 8) = SGP[8](0, 1), (3, 9) = SGP[9](0, 1), (4, 1) = SGP[1](1/2, 0), (4, 2) = SGP[2](1/2, 0), (4, 3) = SGP[3](1/2, 0), (4, 4) = SGP[4](1/2, 0), (4, 5) = SGP[5](1/2, 0), (4, 6) = SGP[6](1/2, 0), (4, 7) = SGP[7](1/2, 0), (4, 8) = SGP[8](1/2, 0), (4, 9) = SGP[9](1/2, 0), (5, 1) = SGP[1](1/2, 1/2), (5, 2) = SGP[2](1/2, 1/2), (5, 3) = SGP[3](1/2, 1/2), (5, 4) = SGP[4](1/2, 1/2), (5, 5) = SGP[5](1/2, 1/2), (5, 6) = SGP[6](1/2, 1/2), (5, 7) = SGP[7](1/2, 1/2), (5, 8) = SGP[8](1/2, 1/2), (5, 9) = SGP[9](1/2, 1/2), (6, 1) = SGP[1](1/2, 1), (6, 2) = SGP[2](1/2, 1), (6, 3) = SGP[3](1/2, 1), (6, 4) = SGP[4](1/2, 1), (6, 5) = SGP[5](1/2, 1), (6, 6) = SGP[6](1/2, 1), (6, 7) = SGP[7](1/2, 1), (6, 8) = SGP[8](1/2, 1), (6, 9) = SGP[9](1/2, 1), (7, 1) = SGP[1](1, 0), (7, 2) = SGP[2](1, 0), (7, 3) = SGP[3](1, 0), (7, 4) = SGP[4](1, 0), (7, 5) = SGP[5](1, 0), (7, 6) = SGP[6](1, 0), (7, 7) = SGP[7](1, 0), (7, 8) = SGP[8](1, 0), (7, 9) = SGP[9](1, 0), (8, 1) = SGP[1](1, 1/2), (8, 2) = SGP[2](1, 1/2), (8, 3) = SGP[3](1, 1/2), (8, 4) = SGP[4](1, 1/2), (8, 5) = SGP[5](1, 1/2), (8, 6) = SGP[6](1, 1/2), (8, 7) = SGP[7](1, 1/2), (8, 8) = SGP[8](1, 1/2), (8, 9) = SGP[9](1, 1/2), (9, 1) = SGP[1](1, 1), (9, 2) = SGP[2](1, 1), (9, 3) = SGP[3](1, 1), (9, 4) = SGP[4](1, 1), (9, 5) = SGP[5](1, 1), (9, 6) = SGP[6](1, 1), (9, 7) = SGP[7](1, 1), (9, 8) = SGP[8](1, 1), (9, 9) = SGP[9](1, 1)});
Please help to define general matrix A for any values of M1 and M2. I will be very grateful for you.
When I am using
Polynomialdeal package:
sys:=[p31,p32,p33];
as in the end of the post. (for one to reproduce)
`J := PolynomialIdeal(sys, characteristic = p)`
and calculate the corresponding Groebner basis.
It report this "Error, (in Groebner:-Basis) Segmentation Violation occurred in external routine".
Does anyone know how to fix this error?
Here is the output details.
infolevel[GroebnerBasis] := 5;
 GB:=Groebner[Basis](sys,IdealInfo[DefaultMonomialOrder](J),method=fgb);
memory used=712.9MB, alloc=103.8MB, time=4.48
memory used=779.3MB, alloc=111.8MB, time=4.89
-> MGb
 domain: rat_int_cof
F4 algorithm
1: prime=2132425153
 deg  pairs  taken         matrix                                        found
   6     20      1         8 x 1018       238.5 per row,     0.0 MB      1 new,      0 zero     0.007 sec
   8     22      3       310 x 20321      288.7 per row,     0.7 MB      3 new,      0 zero     0.035 sec
   9     28      5       818 x 38796      397.2 per row,     2.5 MB      5 new,      0 zero     0.069 sec
  10     37     18      5118 x 220200     532.9 per row,    20.8 MB     16 new,      2 zero     0.386 sec
  11     83     52     21117 x 653954     835.4 per row,   134.7 MB     35 new,     17 zero     1.844 sec
  12    218    153     84758 x 2148937   1314.0 per row,   850.0 MB    100 new,     53 zero    14.546 sec
  13    690    551    336032 x 6779582   2133.6 per row,  5471.1 MB    310 new,    241 zero   222.741 sec
  14   2256   1875   1144460 x 18963907  3811.9 per row, 33288.2 MB    732 new,   1143 zero  2407.556 sec
  15   5978   5202  error in FGb
p31:=-2*(a2^3*A20 + a2^2*a3*(2*A20 - A40) + a1^2*(A20*a3 - a3*A30 + a2*(A20 - A40) - a3*A40 + A10*(a3 - a5) - A20*a5) - a4*(A10*a3*(a3 + a4) + A40*a5*(a4 + a5) + A20*(a3 - a5)*(a3 + a4 + a5)) + a1*(A20*a3^2 - a3^2*A30 + 2*a3*A30*a4 + a2^2*(2*A20 - A40) - a3^2*A40 + 2*a3*a4*A40 + 2*a3*A30*a5 + 2*a3*A40*a5 - A20*a5^2 + a2*(2*A10*a3 + 3*A20*a3 - a3*A30 - 2*a3*A40 + 2*a4*A40 - A20*a5) + A10*(a3^2 - a5^2)) - a2*(A40*(a3^2 - 2*a3*a5 - 2*a4*a5) + A20*(-a3^2 + a3*a4 + a4^2 + a4*a5 + a5^2)));
p32:=1/8 + 2*(-(a2^3*A21) + A11*a3^2*a4 + A21*a3^2*a4 + A11*a3*a4^2 + A21*a3*a4^2 - A21*a4^2*a5 + a4^2*A41*a5 - A21*a4*a5^2 + a4*A41*a5^2 - A10*a3^2*b1 - A20*a3^2*b1 + a3^2*A30*b1 - 2*a3*A30*a4*b1 + a3^2*A40*b1 - 2*a3*a4*A40*b1 - 2*a3*A30*a5*b1 - 2*a3*A40*a5*b1 + A10*a5^2*b1 + A20*a5^2*b1 - A20*a3^2*b2 + A20*a3*a4*b2 + A20*a4^2*b2 + a3^2*A40*b2 + A20*a4*a5*b2 - 2*a3*A40*a5*b2 - 2*a4*A40*a5*b2 + A20*a5^2*b2 + 2*A10*a3*a4*b3 + 2*A20*a3*a4*b3 + A10*a4^2*b3 + A20*a4^2*b3 + a2^2*(-2*A21*a3 + a3*A41 - 2*A20*b1 + A40*b1 - 3*A20*b2 - 2*A20*b3 + A40*b3) + A10*a3^2*b4 + A20*a3^2*b4 + 2*A10*a3*a4*b4 + 2*A20*a3*a4*b4 - 2*A20*a4*a5*b4 + 2*a4*A40*a5*b4 - A20*a5^2*b4 + A40*a5^2*b4 - A20*a4^2*b5 + a4^2*A40*b5 - 2*A20*a4*a5*b5 + 2*a4*A40*a5*b5 + a1^2*(-(A21*a3) + a3*A31 + a3*A41 + a2*(-A21 + A41) + A21*a5 + A11*(-a3 + a5) - A20*b2 + A40*b2 - A10*b3 - A20*b3 + A30*b3 + A40*b3 + A10*b5 + A20*b5) + a1*(-(A21*a3^2) + a3^2*A31 - 2*a3*A31*a4 + a3^2*A41 - 2*a3*a4*A41 + a2^2*(-2*A21 + A41) - 2*a3*A31*a5 - 2*a3*A41*a5 + A21*a5^2 + A11*(-a3^2 + a5^2) - 2*A10*a3*b1 - 2*A20*a3*b1 + 2*a3*A30*b1 + 2*a3*A40*b1 + 2*A10*a5*b1 + 2*A20*a5*b1 - 2*A10*a3*b2 - 3*A20*a3*b2 + a3*A30*b2 + 2*a3*A40*b2 - 2*a4*A40*b2 + A20*a5*b2 - 2*A10*a3*b3 - 2*A20*a3*b3 + 2*a3*A30*b3 - 2*A30*a4*b3 + 2*a3*A40*b3 - 2*a4*A40*b3 - 2*A30*a5*b3 - 2*A40*a5*b3 - 2*a3*A30*b4 - 2*a3*A40*b4 - 2*a3*A30*b5 - 2*a3*A40*b5 + 2*A10*a5*b5 + 2*A20*a5*b5 + a2*(-2*A11*a3 - 3*A21*a3 + a3*A31 + 2*a3*A41 - 2*a4*A41 + A21*a5 - 2*A20*b1 + 2*A40*b1 - 4*A20*b2 + 2*A40*b2 - 2*A10*b3 - 3*A20*b3 + A30*b3 + 2*A40*b3 - 2*A40*b4 + A20*b5)) + a2*(a3^2*A41 - 2*a4*A41*a5 + A21*(-a3^2 + a3*a4 + a4^2 + a4*a5 + a5^2) - 2*a4*A40*b1 + A20*a5*b1 + A20*a4*b3 - 2*A40*a5*b3 + 2*A20*a4*b4 + A20*a5*b4 - 2*A40*a5*b4 + A20*a4*b5 - 2*a4*A40*b5 + 2*A20*a5*b5 + a3*(-2*A41*a5 - 2*A10*b1 - 3*A20*b1 + A30*b1 + 2*A40*b1 - 4*A20*b2 + 2*A40*b2 - 2*A20*b3 + 2*A40*b3 + A20*b4 - 2*A40*b5)));
p33:=2*(-(A11*a3^2*b1) - A21*a3^2*b1 + a3^2*A31*b1 - 2*a3*A31*a4*b1 + a3^2*A41*b1 - 2*a3*a4*A41*b1 - 2*a3*A31*a5*b1 - 2*a3*A41*a5*b1 + A11*a5^2*b1 + A21*a5^2*b1 - A10*a3*b1^2 - A20*a3*b1^2 + a3*A30*b1^2 + a3*A40*b1^2 + A10*a5*b1^2 + A20*a5*b1^2 - A21*a3^2*b2 + A21*a3*a4*b2 + A21*a4^2*b2 + a3^2*A41*b2 + A21*a4*a5*b2 - 2*a3*A41*a5*b2 - 2*a4*A41*a5*b2 + A21*a5^2*b2 - 2*A10*a3*b1*b2 - 3*A20*a3*b1*b2 + a3*A30*b1*b2 + 2*a3*A40*b1*b2 - 2*a4*A40*b1*b2 + A20*a5*b1*b2 - 2*A20*a3*b2^2 + a3*A40*b2^2 + 2*A11*a3*a4*b3 + 2*A21*a3*a4*b3 + A11*a4^2*b3 + A21*a4^2*b3 - 2*A10*a3*b1*b3 - 2*A20*a3*b1*b3 + 2*a3*A30*b1*b3 - 2*A30*a4*b1*b3 + 2*a3*A40*b1*b3 - 2*a4*A40*b1*b3 - 2*A30*a5*b1*b3 - 2*A40*a5*b1*b3 - 2*A20*a3*b2*b3 + A20*a4*b2*b3 + 2*a3*A40*b2*b3 - 2*A40*a5*b2*b3 + A10*a4*b3^2 + A20*a4*b3^2 + a2^2*(A41*(b1 + b3) - A21*(2*b1 + 3*b2 + 2*b3)) + A11*a3^2*b4 + A21*a3^2*b4 + 2*A11*a3*a4*b4 + 2*A21*a3*a4*b4 - 2*A21*a4*a5*b4 + 2*a4*A41*a5*b4 - A21*a5^2*b4 + A41*a5^2*b4 - 2*a3*A30*b1*b4 - 2*a3*A40*b1*b4 + A20*a3*b2*b4 + 2*A20*a4*b2*b4 + A20*a5*b2*b4 - 2*A40*a5*b2*b4 + 2*A10*a3*b3*b4 + 2*A20*a3*b3*b4 + 2*A10*a4*b3*b4 + 2*A20*a4*b3*b4 + A10*a3*b4^2 + A20*a3*b4^2 - A20*a5*b4^2 + A40*a5*b4^2 - A21*a4^2*b5 + a4^2*A41*b5 - 2*A21*a4*a5*b5 + 2*a4*A41*a5*b5 - 2*a3*A30*b1*b5 - 2*a3*A40*b1*b5 + 2*A10*a5*b1*b5 + 2*A20*a5*b1*b5 + A20*a4*b2*b5 - 2*a3*A40*b2*b5 - 2*a4*A40*b2*b5 + 2*A20*a5*b2*b5 - 2*A20*a4*b4*b5 + 2*a4*A40*b4*b5 - 2*A20*a5*b4*b5 + 2*A40*a5*b4*b5 - A20*a4*b5^2 + a4*A40*b5^2 + a1^2*(-(A11*b3) + A31*b3 + A41*(b2 + b3) - A21*(b2 + b3 - b5) + A11*b5) + a1*(-2*A21*a3*b1 + 2*a3*A31*b1 + 2*a3*A41*b1 + 2*A21*a5*b1 - 3*A21*a3*b2 + a3*A31*b2 + 2*a3*A41*b2 - 2*a4*A41*b2 + A21*a5*b2 - 2*A20*b1*b2 + 2*A40*b1*b2 - 2*A20*b2^2 + A40*b2^2 - 2*A21*a3*b3 + 2*a3*A31*b3 - 2*A31*a4*b3 + 2*a3*A41*b3 - 2*a4*A41*b3 - 2*A31*a5*b3 - 2*A41*a5*b3 - 2*A10*b1*b3 - 2*A20*b1*b3 + 2*A30*b1*b3 + 2*A40*b1*b3 - 2*A10*b2*b3 - 3*A20*b2*b3 + A30*b2*b3 + 2*A40*b2*b3 - A10*b3^2 - A20*b3^2 + A30*b3^2 + A40*b3^2 - 2*A11*a3*(b1 + b2 + b3) - 2*a3*A31*b4 - 2*a3*A41*b4 - 2*A40*b2*b4 - 2*A30*b3*b4 - 2*A40*b3*b4 - 2*a3*A31*b5 - 2*a3*A41*b5 + 2*A21*a5*b5 + 2*A10*b1*b5 + 2*A20*b1*b5 + A20*b2*b5 - 2*A30*b3*b5 - 2*A40*b3*b5 + A10*b5^2 + A20*b5^2 + 2*A11*a5*(b1 + b5) + a2*((-2*A11 + A31)*b3 + 2*A41*(b1 + b2 + b3 - b4) + A21*(-2*b1 - 4*b2 - 3*b3 + b5))) + a2*(-2*A11*a3*b1 + a3*A31*b1 + 2*a3*A41*b1 - 2*a4*A41*b1 - A20*b1^2 + A40*b1^2 + 2*a3*A41*b2 - 4*A20*b1*b2 + 2*A40*b1*b2 - 3*A20*b2^2 + 2*a3*A41*b3 - 2*A41*a5*b3 - 2*A10*b1*b3 - 3*A20*b1*b3 + A30*b1*b3 + 2*A40*b1*b3 - 4*A20*b2*b3 + 2*A40*b2*b3 - A20*b3^2 + A40*b3^2 - 2*A41*a5*b4 - 2*A40*b1*b4 + A20*b3*b4 + A20*b4^2 - 2*a3*A41*b5 - 2*a4*A41*b5 + A20*b1*b5 - 2*A40*b3*b5 + A20*b4*b5 - 2*A40*b4*b5 + A20*b5^2 + A21*(a3*(-3*b1 - 4*b2 - 2*b3 + b4) + a4*(b3 + 2*b4 + b5) + a5*(b1 + b4 + 2*b5))));
Good day everyone,
I am trying to write various parameters for two functions using "if loop" but it is substituting for the first one only. Anyone with useful information, please.
The link is attached below
nops_not_substituting.mw
Is it possible to solve DE without initial conditions
(1/24)*exp(-8)-(1/12)*exp(-5)+(1/24)*exp(-2)-(1/24)*exp(-10)+(1/24)*exp(-9)+(1/24)*exp(-1)+diff(f(x), x, x, x, x, x)+d*(diff(f(x), x))+e*f(x)+a*(diff(f(x), x, x, x, x))+b*(diff(f(x), x, x, x))+c*(diff(f(x), x, x))-1/24
where, a, b, c, d, and e are constant coefficients.....
I would like to have Maple give me sin(2nPi) = 0 assuming that n is a positive integer. Is there a way to do it?
mapleatha.
Dear there,
I have a code.mw
  • If I don't use command Digits in the code, I get the following result:
Question 1: The third column of matrix B includes 16 decimal, but the fourth column of matrix B includes 11 decimal. Why?
  • When I write the command Digits:=20, I get the following result:
Question 2: The last column of matrix B shows the absolute error of the method.
When asked what is the absolute error of the method, what is the right answer?  (Because the higher the digit is chosen, the lower the absolute error is.)
Question 3: Are the two results consistent? How can we explain to someone who asks why the difference comes from?
 12 yeas later, the probelm  is not still improved in following links
https://www.mapleprimes.com/posts/38473-Simplify-Ceil-And-Floor
simplify(ceil(x)+floor(-x));
                         floor(-x) + ceil(x)
I think extending simplify by Joe Riel 8221  is a little complicated.
`simplify/ceil` := proc(ex)
    evalindets(ex, 'specfunc(anything,ceil)', x -> -floor(-op(x)));
simplify(floor(-x) + ceil(x));
 It seems that maple know  ceil(x)=-floor(-x)
why does not maple2020 still handle that?
First 443 444 445 446 447 448 449 Last Page 445 of 2428
