I see this question at here
https://mathematica.stackexchange.com/questions/239874/how-to-reduce-timing-to-find-the-integer-numbers-a-b-c-d-e-f-g-h-k-m-of
How to solve this problem by Maple?
command completion (when hitting the ESC key) in Maple could be made more useful. It does not seem to support type names for example.
What shows up on the command completion window are  possible commands that start with that partial text.
It does not list other known names by Maple, such as type names and other options.
This makes it hard to use in many places, where one have to remember type names exactly instead of the system helping them by listing all possible type names that start with that string.
Is there a way around this? Will Maple next version support smarter and more complete command completion menu?
dear all
I would like to display the error ( tab_err) and plot it.
The code run without any mistakes but there is no table of error dispalyed and can then be plotted
integ_R.mw
Thank you for any help
How to plot Complex vales in 2D?
Z be complex.
rho := 1/4; mu := 1/4; E := sum(Z^k/GAMMA(k*rho+mu), k = 0 .. 5)
I am trying to run this code but this error message is coming up "Error, (in fprintf) number expected for floating point format
". What have I done wrong and how do I correct it.
Thank you and best regards.
Digits:=30:
f:=proc(n)
	-((sin(x[n]))/(2-sin(x[n])))*(2+sin(x[n]-Pi)):
e1:=y[n+1]=h*delta[n]-(1/2)*h^2*(-u^2*sin((1/2)*u)+2*cos((1/2)*u)*u-2*cos(u)*u-4*sin((1/2)*u)+2*sin(u))*f(n)/(u^2*(2*sin((1/2)*u)-sin(u)))+(1/2)*h^2*(u^2*sin((1/2)*u)+2*cos((1/2)*u)*u-4*sin((1/2)*u)+2*sin(u)-2*u)*f(n+1)/(u^2*(2*sin((1/2)*u)-sin(u)))-(1/2)*h^2*(u*sin(u)+2*cos(u)-2)*f(n+1/2)/(u*(2*sin((1/2)*u)-sin(u)))+y[n]:
e2:=h*delta[n+1]=h*delta[n]+h^2*(u*sin((1/2)*u)+cos(u)-1)*f(n)/(u*(2*sin((1/2)*u)-sin(u)))+h^2*(u*sin((1/2)*u)+cos(u)-1)*f(n+1)/(u*(2*sin((1/2)*u)-sin(u)))-h^2*(u*sin(u)+2*cos(u)-2)*f(n+1/2)/(u*(2*sin((1/2)*u)-sin(u))):
e3:=y[n+1/2]=(1/2)*h*delta[n]-(1/8)*h^2*(-u^2*sin((1/2)*u)+4*cos((1/2)*u)*u-4*cos(u)*u-16*sin((1/2)*u)+8*sin(u))*f(n)/(u^2*(2*sin((1/2)*u)-sin(u)))+(1/8)*h^2*(u*sin((1/2)*u)+4*cos((1/2)*u)-4)*f(n+1)/(u*(2*sin((1/2)*u)-sin(u)))-(1/8)*h^2*(u^2*sin(u)+4*cos(u)*u+16*sin((1/2)*u)-8*sin(u)-4*u)*f(n+1/2)/(u^2*(2*sin((1/2)*u)-sin(u)))+y[n]:
e4:=h*delta[n+1/2]=h*delta[n]-(1/2)*h^2*(-u*sin((1/2)*u)+4*cos((1/2)*u)-2*cos(u)-2)*f(n)/(u*(2*sin((1/2)*u)-sin(u)))+(1/2)*h^2*(u*sin((1/2)*u)+4*cos((1/2)*u)-4)*f(n+1)/(u*(2*sin((1/2)*u)-sin(u)))-(1/2)*h^2*(u*sin(u)+2*cos(u)-2)*f(n+1/2)/(u*(2*sin((1/2)*u)-sin(u))):
inx:=0:
ind:=1:
iny:=2:
h:=Pi/4:
n:=0:
omega:=1:
u:=omega*h:
N:=solve(h*p = 8*Pi, p):
c:=1:
for j from 0 to 1 by 1/2 do
	t[j]:=inx+j*h:
vars:=y[n+1/2],y[n+1],delta[n+1/2],delta[n+1]:
step := [seq](eval(x, x=c*h), c=1..N):
printf("%6s%15s%15s%16s%15s%15s%15s\n",
	"h","Num.y","Num.z","Ex.y","Ex.z","Error y","Error z");
#eval(<vars>, solve({e||(1..4)},{vars}));
st := time():
for k from 1 to N do
	par1:=x[0]=t[0],x[1/2]=t[1/2],x[1]=t[1]:
	par2:=y[n]=iny,delta[n]=ind:
	res:=eval(<vars>, fsolve(eval({e||(1..4)},[par1,par2]), {vars}));
	for i from 1 to 2 do
		exy:=eval(2+sin(c*h/2)):
		exz:=eval(-sin(c*h/2)+10*epsilon*cos(10*c*h)):
		printf("%6.5f%17.9f%15.9f%15.9f%15.9f %13.5g%15.5g\n",
		h*c,res[i],res[i+2],exy,exz,abs(res[i]-exy),
		abs(res[i+2]-exz)):
		c:=c+1:
	iny:=res[2]:
	ind:=res[4]:
	inx:=t[1]:
		t[j]:=inx + j*h:
How to add a legend to Statistics:-Histogram?
This could be particularly useful to compare histograms, for instance in
S := Statistics:-Sample(Normal(0, 1), 1000):
T := Statistics:-Sample(Normal(1, 1), 1000):
plots:-display(
  Statistics:-Histogram(S, color=gold, transparency=0.3, legend="N(0,1)"),
  Statistics:-Histogram(T, transparency=0.3, legend="N(1,1)")
But doing this generates the error Error, (in Statistics:-Histogram) display does not accept the legend option
And yes indeed, even this command
h := Statistics:-Histogram(S, legend="N(0,1)")
already produces the same error.
After having examined the structure of h and using a way Carl Love gave here How to change the colour inn Statistics:-Sunflower?  I finally obtained the expected plot.
HS := Statistics:-Histogram(S, color=gold, transparency=0.3):
HT := Statistics:-Histogram(T, transparency=0.3):
hs := evalindets([op(HS)], specfunc(COLOUR), c-> (c, LEGEND("N(0,1)")) ):
ht := evalindets([op(HT)], specfunc(COLOUR), c-> (c, LEGEND("N(1,1)")) ):
PLOT(op(hs), op(ht))
But this rather long a way to proceed (Note: it seems that the overrideoption  that acer suggested in this prevous thread doesn't "work" here?)
Do you have any idea if there is a simpler solution?
TIA
AoA....
sir how we solve partial differential equation by Adomian Decomposition method in maple? plz send me maple code..
I have a problem when running the follwoing code using the input proposed.
integ_R.mw
problem : print_table , used as input in  proc
Thank you for your help
I tried to compute an integral using trapezoidal rule using two differents methods but I get two different results
trap.mw
How to solve and plot the integral equation?
b.mw
I am trying to input X-data, Y-data from spreadsheet-section of Numbers (Apple App) to do reression analysis in Maple. I do not understand the export or import tools very well just yet, asis obvious from numerous wrong results.
Since I want to do regression of the X-Y data trends, what format would you recommend using for the data once imported into Maple; two sequences, two-vectors, multi-row column matrix ???
If someone has worked with Numbers-Apple-App (Not Excel) into Maple to do this and can provide simple example with steps/tools used. It would be appreciated. Thanks
I would like to sketch the solution of first ode, but by hand we can not get the solution. I used maple, to  solve the ode but unfortunattely there is no solution obtained so I can sketech the behavior of the solution.
Is there any way to sketch the solution behavior .
sketch_solution.mw
thank you
Hi. I have solved numerical an ODE and want to use the solution in the integrand of a subsequent integral. I'm being frustrated by my lack of knowledge and the internet isn't helping! I hope someone can put me right.....here's the relevant part of code.
dsysA := {diff(r(s), s) = sqrt((g*r(s) + h)^2 - 1 + 1/r(s)), r(0) = rinit};
dsnA := dsolve(dsysA, numeric, abserr = 10^(-6));
dsnA(0.1);
               [s = 0.1, r(s) = 1.51303353884965]
rA := s -> rhs(dsnA(s)[2]):
rA(0.2);
                        1.53235325247661
tA := s -> tinit + int((g*rA(p) + h)/(1 - 1/rA(p)), p = 0 .. s):
tA(0.01);
Error, (in rA) invalid input: rhs received dsnA(p)[2], which is not valid for its 1st argument, expr
Hi, I want to minimize a*x + log2(3+4.2^(-x)+2^(-2x)) , x>0 & 0<=a<=1 where a is some constant. Is there any command in maple which help me to minimize this. For command minimize, I am unable to minimize the function symbolically. I need to minimize it in terms of a.
Hi I am trying to compute the series approximation for the difference between these two divergent integrals
M := int(cosh(p)^2/sqrt(cosh(p)^2 - (1 + x)^2*sinh(p)^2), p = 0 .. 1/2*ln(1/x));
N := int((1 + x)*sinh(p)^2/sqrt(cosh(p)^2 - (1 + x)^2*sinh(p)^2), p = 0 .. 1/2*ln(1/x))
where x,p are positive and x is approaching zero. I would like to get a series expansion of M-N, but I am not quite if this is possible.
First 441 442 443 444 445 446 447 Last Page 443 of 2428
