Hi, I hope your going well
I was wondering if i can index my matrix column like in the image below and if i can replace u(1) for is estamted value
Thank a lot <3
How do I get Maple to simplify:
Io := I Cp Vin L1/(M sqrt(Cp L1))
to :  I sqrt(L1 CP) Vin/ M  ?
Furthermore, if  w = 1/sqrt(L1 *CP),  how do I get Maple to display the solution or the simplification as:
I*Vin/(w M) ?
I've t ried multiple substitutions and simplifications to no avail.
Jorge
I*Cp*RL*Vin*L1/(M*(Cp*L1)^(1/2))
simplify(I*Cp*RL*Vin*L1/(M*(L1*Cp)^(1/2)), 'symbolic')
I*Cp^(1/2)*RL*Vin*L1^(1/2)/M
Io := Vores/RL
I*Cp*Vin*L1/(M*(Cp*L1)^(1/2))
simplify(I*Cp*Vin*L1/(M*(L1*Cp)^(1/2)))
simplify(I*Cp*Vin*L1/(M*(L1*Cp)^(1/2)), 'assume = real')
combine(Vores/RL, power)
factor(I*Cp*Vin*L1/(M*(L1*Cp)^(1/2)))
combine(I*Cp*Vin*L1/(M*(L1*Cp)^(1/2)), radical)
cancel(I*Cp*Vin*L1/(M*(Cp*L1)^(1/2)))
simplify(cancel(I*Cp*Vin*L1/(M*(L1*Cp)^(1/2))), 'assume = real')
simplify(I*Cp*Vin*L1/(M*(L1*Cp)^(1/2)), 'radical')
(14)
simplify(I*Cp*Vin*L1/(M*(L1*Cp)^(1/2)), 'symbolic')
I*Cp^(1/2)*Vin*L1^(1/2)/M
(15)
Download Resonant_xformer.mw
Sometimes I find Maple a bit unconsequent regarding indexing, some things start with 0, others with 1.
The ReplaceChild function clearly starts with 1 for example, as you see in the help function.
ReplaceChild( 2 = XMLElement( "NEW", [], "text" ), doc )
replaces the second element in the list.
When using the AddChild function, one has to enter 0.
The AddChild(xmlTree, child, n) command creates a new XML element from xmlTree by inserting the XML element child at the position indicated by n. Parameter n must be less than or equal to the number of children in the original tree xmlTree. The new child node child becomes the n + 1st child of the resulting tree.
The first sentence sounds logical, but I would then expect the position of the first element to be 1. The other 2 sentences in the help file contradict the first one in my opinion. Either the position of the element is 0, as stated in the first sentence - then it also should be possible to get its value in the position 0. Or it is 1, but then it also should have been defined at position 1.
deq1 := diff(u(x, y), x) - diff(u(x, y), y$2) = exp(x+y);
                              /  2         \
              / d         \   | d          |
      deq1 := |--- u(x, y)| - |---- u(x, y)| = exp(x + y)
              \ dx        /   |   2        |
                              \ dy         /
deq2 := diff(u(x, y), x) - diff(u(x, y), y$2) = exp(1)^(x+y);
                            /  2         \
            / d         \   | d          |           (x + y)
    deq2 := |--- u(x, y)| - |---- u(x, y)| = (exp(1))
            \ dx        /   |   2        |
                            \ dy         /
pdsolve(deq1, u(x,y));  ### no result
pdsolve(deq2, u(x,y));
PDESolStrucApplyFunction|uApplyFunction(x,y)=_F1ApplyFunction(x)
  _F2ApplyFunction(y) - -
                       x+y
  (expApplyFunction(1))    (_C1 expApplyFunction(uminus0y)+_C2 expApplyFunction(y)+_C3 expApplyFunction(y) y)
  ,[{diffApplyFunction(_F1ApplyFunction(x),x)=_c[1] _F1
  ApplyFunction(x),diffApplyFunction(diffApplyFunction(_F2
  ApplyFunction(y),y),y)=_c[1] _F2ApplyFunction(y)}]|
No solution appears when the differential equation is expressed in standard form, but when exp(x + y) is converted to
exp(1)^(x + y) the correct solution appears.
Can anyone help with forcing this to simplify
assume(x>0)
assum(y>0)
simplify(sqrt(-x^2-y^2))
I am looking for this to force the sqrt to return as the imaginary number multiplied by the square root of x^2+y^2
simplify(sqrt(-x^2)) does simplify as far as bringing in the imaginary number
Many thanks
I solved an equation using Maple . but in answer there is RootOf statement that I can't change to a simple statement without RootOf.
((Lr2*(vo+vs)*sqrt(Lr1*Lr2)+vo*Lr1*sqrt(Lr1*Lr2))*sin(t*sqrt((Lr1+Lr2)/(Lr1*Lr2*cr)))*sqrt(cr*(Lr1+Lr2))+vs*t*Lr1*(Lr1+Lr2))/((Lr1+Lr2)^2*Lr1)
((Lr2*(vo+vs)*(Lr1*Lr2)^(1/2)+vo*Lr1*(Lr1*Lr2)^(1/2))*sin(t*((Lr1+Lr2)/(Lr1*Lr2*cr))^(1/2))*(cr*(Lr1+Lr2))^(1/2)+vs*t*Lr1*(Lr1+Lr2))/((Lr1+Lr2)^2*Lr1)``
eq := ((Lr2*(vo+vs)*sqrt(Lr1*Lr2)+vo*Lr1*sqrt(Lr1*Lr2))*sin(t*sqrt((Lr1+Lr2)/(Lr1*Lr2*cr)))*sqrt(cr*(Lr1+Lr2))+vs*t*Lr1*(Lr1+Lr2))/((Lr1+Lr2)^2*Lr1)
solve(eq, t)
-(Lr1*Lr2)^(1/2)*(Lr1*cr+Lr2*cr)^(1/2)*sin(RootOf(Lr1*sin(_Z)*(Lr1*cr+Lr2*cr)^(1/2)*((Lr1+Lr2)/(Lr1*Lr2*cr))^(1/2)*(Lr1*Lr2)^(1/2)*vo+Lr2*sin(_Z)*(Lr1*cr+Lr2*cr)^(1/2)*((Lr1+Lr2)/(Lr1*Lr2*cr))^(1/2)*(Lr1*Lr2)^(1/2)*vo+Lr2*sin(_Z)*(Lr1*cr+Lr2*cr)^(1/2)*((Lr1+Lr2)/(Lr1*Lr2*cr))^(1/2)*(Lr1*Lr2)^(1/2)*vs+_Z*Lr1^2*vs+_Z*Lr1*vs*Lr2))*(Lr1*vo+Lr2*vo+Lr2*vs)/(Lr1*(Lr1+Lr2)*vs)
Download spr.mw
How can I simplify to an answer without RootOf?
Thank u
I want to create a 2D and 3D graph of the following question. Evaluate F xy+y+z along the curve r(t)=2ti+tj+(2-2t)k, 0<=t<=1 I found the line integral to be 13/2. I am just stuck on how to graph this in 2D and 3D.
Thank you all in advance! I enjoy learning all the new tricks in Maple from you all.
I am not familiar with the use of notsero in SolveTools:-PolynomialSystem. Is there any special syntax to use it?  In the following example, the trivial solution {x=0,y=0} is to be eliminated.
SolveTools:-PolynomialSystem({x*(x^2 - 2), y*(y^2 - 2)}, {x, y},explicit=true)
If I issue the command
SolveTools:-PolynomialSystem({x*(x^2 - 2), y*(y^2 - 2)}, {x, y},{x,y},explicit=true)
all roots with either x=0 or y=0 are eliminated.
Can netzero be used to eliminate only the trivial solution?
Many thanks
I'm trying to compute the numerical solution for a PDE using the numerical solution of a first-order ODE. I looked at the INTEGRATE keyword of the pdsolve function, but I'm not sure how to use it. Can someone show an example of how to use this keyword?
I'm new at Maple, so I'm still trying to figure out basic stuff. I have solved an ode with t as independent variable and x as dependent one and I have used plots[odeplot] to plot x over t, but I also need to plot t over x. Any ideas how I can do that? Here's my code:
ode := diff(x(t), t) = 16250.25391*(1 - (487*x(t))/168 + 4*Pi*x(t)^(3/2) + (274229*x(t)^2)/72576 - (254*Pi*x(t)^(5/2))/21 + (119.6109573 - (856*ln(16*x(t)))/105)*x(t)^3 + (30295*Pi*x(t)^(7/2))/1728 + (7.617741607 - 23.53000000*ln(x(t)))*x(t)^4 + (535.2001594 - 102.446*ln(x(t)))*x(t)^(9/2) + (413.8828821 + 323.5521650*ln(x(t)))*x(t)^5 + (1533.899179 - 390.2690000*ln(x(t)))*x(t)^(11/2) + (2082.250556 + 423.6762500*ln(x(t)) + 33.2307*ln(x(t)^2))*x(t)^6)*x(t)^5
ics := x(0) = xlow
solx := dsolve({ics, ode}, numeric, range = 0 .. tfin)
plots[odeplot](solx, 0 .. tfin)
I have the following fractional  system of differential equation. How to plot it for alpha=0.5, beta=0.5?
eq1:=diff(y1(t),t$alpha)=0.04-(0.09*y1(t)*y2(t))-(0.00250*y1(t)*y2(t))/((0.03500+y2(t)))-0.04*y1(t);
eq2:=diff(y2(t),t$beta)=(0.09*y1(t)*y2(t))+(0.00250*y1(t)*y2(t))/((0.035+y2(t)))-(0.02+0.04)*y2(t);
I have a funtion defined as
a := diff(u*ln(m__o/(-q*t + m__o)) - g*t, t)
where m_0, q, g, and u are constants with dimensions. T is the variable and has dimensions as well. I need to print out columns of this function and other similar functions, v and h, in 4 seconds intervals of t. So what I have is this:
for i from -4 by 4 to 80 do
    if i = -4 then printf("%12s %18s %15s %15s \n", "time", "acceleration", "velocity", "altitude"); else printf("%10d %c %10.2f  %s %10.2f  %s %10.2f  %s \n", i, "s", eval(a, t = i), "ft/s^2", eval(v, t = i), "ft/s", eval(h, t = i), "mi"); end if;
end do
this works perfectly fine until I assign units to the constants and t. Then I get the error: Error, (in fprintf) number expected for floating point format.
Then I also need to plot a v and h against t. Seems like plot doesn't work either with units.
So what do i do?
Hello. I have the equations written into the arrays. I want to combine them into a common system and solve it. I gave a simple example of what I need. How do I perform this operation?
T1 := array(1 .. 2);
array( 1 .. 2, [ ] )
x = 1
y = 2
T2 := array(1 .. 2);
z = 3
r = x+y+z
solve({T1, T2}, {r, x, y, z});
Download 4.mw
restart; with(Student[LinearAlgebra]); A := Matrix([[2, 3, -4], [0, -4, 2], [1, -1, 5]]); for i to 3 do for j to 3 do print((-1)^(i+j)*Minor(A, i, j)) end do end do; How to code to get that is egal to Adjoint(A)? Thank you.
Whenever I open Maple 2020 and type one single letter or number (doesn't matter) Maple 2020 will "freeze" and load forever (i have had it open for a long time, just watching that f**king blue circle spin...
I have tried reinstalling, repairing, running as admin, and changing the compatibility mode, still, nothing works:(
I run Maple 2020 as a Student with WithGym
Pc specs:
Intel i5-10300h 2.6 ghz
Geforce 1660 ti 6gb
Windows 10 x64
First 479 480 481 482 483 484 485 Last Page 481 of 2428
