Any ideas why the attached package won't install?
We've been using Maple Cloud previously, but that doesn't work anymore apparently (same problem as stated here, https://www.mapleprimes.com/questions/226154-Installing-Packages-From-The-Cloud-Hangs, support case filed previously).
But I can't even get it installed manually either.
NODELibrary.zip
how I can sort differential equation [q] in terms of u(x,y,z,t) and its derivatives.
In other words, we should find three relations including L11(u) ,L12 (v), and L13(w).
For instance in L13{w) only w(x,y,z,t) and its derivatives would appear...
For example;
sort.mw
q := h*(A11*(diff(u(x, y, z, t), x, x)-(diff(w(x, y, z, t), x))/R+(diff(w(x, y, z, t), x))*(diff(w(x, y, z, t), x, x)))+A12*(diff(v(x, y, z, t), x, y)-(diff(w(x, y, z, t), x))/a+(diff(w(x, y, z, t), y))*(diff(w(x, y, z, t), x, y))))+h^2*(-B11*(diff(w(x, y, z, t), x, x, x))+B12*(-(diff(w(x, y, z, t), x, y, y))-(diff(v(x, y, z, t), x, y))/a))+B66*h^2*(-2*(diff(w(x, y, z, t), x, y, y))-(diff(v(x, y, z, t), x, y))/a)+A66*h*(diff(u(x, y, z, t), y, y)+diff(v(x, y, z, t), x, y)+(diff(w(x, y, z, t), y, y))*(diff(w(x, y, z, t), x))+(diff(w(x, y, z, t), y))*(diff(w(x, y, z, t), x, y))) = rho*(diff(u(x, y, z, t), t, t))-e0^2*a^2*(rho*(diff(u(x, y, z, t), t, t, x, x))+rho*(diff(u(x, y, z, t), t, t, y, y)))
h*(A11*(diff(diff(u(x, y, z, t), x), x)-(diff(w(x, y, z, t), x))/R+(diff(w(x, y, z, t), x))*(diff(diff(w(x, y, z, t), x), x)))+A12*(diff(diff(v(x, y, z, t), x), y)-(diff(w(x, y, z, t), x))/a+(diff(w(x, y, z, t), y))*(diff(diff(w(x, y, z, t), x), y))))+h^2*(-B11*(diff(diff(diff(w(x, y, z, t), x), x), x))+B12*(-(diff(diff(diff(w(x, y, z, t), x), y), y))-(diff(diff(v(x, y, z, t), x), y))/a))+B66*h^2*(-2*(diff(diff(diff(w(x, y, z, t), x), y), y))-(diff(diff(v(x, y, z, t), x), y))/a)+A66*h*(diff(diff(u(x, y, z, t), y), y)+diff(diff(v(x, y, z, t), x), y)+(diff(diff(w(x, y, z, t), y), y))*(diff(w(x, y, z, t), x))+(diff(w(x, y, z, t), y))*(diff(diff(w(x, y, z, t), x), y))) = rho*(diff(diff(u(x, y, z, t), t), t))-e0^2*a^2*(rho*(diff(diff(diff(diff(u(x, y, z, t), t), t), x), x))+rho*(diff(diff(diff(diff(u(x, y, z, t), t), t), y), y)))
Download sort.mw
This is the context. I am doing reduction of order on an ODE. This sometimes converts the ode to form  where common factor containing only  x can be moved outside, making the ode looks like  f(x)*(y''(x)+....etc...) = 0 then now I can eliminate f(x)  and only solve (y''(x)+....etc...) = 0 which is simpler.
I found if I can call factor on the ode, it works. It does remove any common terms. The problem I am having is how to cleanly determine the factors obtained. In the above example, it will be f(x) and (y''(x)+....etc...)
For an example, the ODE   x^2 y'' + x y' = 0 can be written (using factor) as  x ( x y'' + y') =0 and now canceling x<>0, the ode becomes simpler x y''+ y' = 0.
I am now trying to find the two factors, using using op() on the result of factor.
But it does not work for all cases. There should be a way more robust way to obtain the factors.  I give 2 examples to better explain.
Example 1
ode:=x^2*diff(y(x),x$2)-(x-3/16)*y(x)=0:
ode:=expand(algsubs( y(x)=v(x)*x^(1/4)*exp(2*sqrt(x)),ode));
ode:=factor(ode);
After factoring the original ODE, there is common term found, which is the one shown UP. I need to find this to cancel it and keep the rest.
Currently I do this, which does not work for call cases
#check it is factored OK. If the type is `*` then Maple
#found common factor.
if type(lhs(ode),`*`) then
   #add code to extract the two parts
   LHS:=op([1..-2],lhs(ode));
   RHS:=op(-1,lhs(ode));
fi;
Even though this worked here. I can now check it is the LHS which needs to be canceled. But all what I have are the operands. I do not know how to reconstruct the LHS from the operands. They could be + or *.  If it was `*` between the oprands for LHS, then I can do LHS:=mul(LHS) and this gives
But I got lucky here. I do not know if it will be `*` all the time for LHS operands.
example 2
ode:=x^2*diff(y(x),x$2)-x*(x+2)*diff(y(x),x)+(x+2)*y(x)=0;
ode:=algsubs( y(x)=v(x)*x,ode):
ode:=factor(ode);
For this, the code I have works, but this is only because the LHS was simple.
if type(lhs(ode),`*`) then #factored OK
fi;
My question is: I expect factor, if there is common factor, to generate 2 expressions with `*` between them. I am looking for a good way to find what these two factors are. Once I do, it is easy for me to find which is the ODE and which is not and cancel the one which is not out.
I tried collect, but this does not work in general. Since I do not know beforehand, what is the common term, if any, present.
If this needs more clarification please feel free to ask. I have many more examples. This is all done by coding. Non-interactive. So solution based on looking at the output then do something, will not work for me.
I have been working on some code today and I keep getting errors in my code trying to solve it. I am trying to solve this problem:
y' = (-2xy) + 1 , y(0) = 0
Solve this problem numerically using step size of h=0.1 (101 values) and h = (0.05) (201 values). Create a plot of the two approximate solutions and the analytic solution. Show all work!
I think I got the plot code correct, I must be entering the beginning code incorect as It says:
"Error, (in DEtools/DEplot/CheckDE) extra unknowns found: xy"
Here is my code. Somebody please help me or lead me in the right direction! Thank you!
TEST_CODE_1.mw
I compute the solution of a system of ordinary differential equaiton using Picard iteration. I have the following error:
Error, invalid input: f uses a 2nd argument, y, which is missing
My code
Picard_iteration.mw
Thank you for any help
Mac OS 11 Big Sur ist not listed as a compatible system with Maple 2020. Are there known issues? Could someone who already upgraded give feedback?
How can I plot the following function?
delta := t -> piecewise(t = 0, 1, 0)
Suspect that the point  at Y=1 automatically scales when zooming in.
Currently to parse initial conditions of ODE entered bu user in the form y(x0)=y0 in order to determine x0 and y0 I use patmatch on lhs and rhs separatly which is not a big deal. I wanted to see if I can use an equation inside patmatch.
I could not figure how to use patmatch on both sides of equation on one call.  Help says expression to patmatch is algebraic expression. Does this means an equation can't be used as whole? Here is an example to make it more clear
ic:=y(0) = 1;
patmatch(ic,y(x0::anything)=y0::anything,'la')
Which gives false. i.e. no match found.
Is there a trick to make the above work if possible? This is just a basic example. I might want to apply this on more complicated equation where more things are on lhs and rhs of =  but patmatch does not like `=` in the middle there.
Why won't Maple solve any of these inequalities for Q?
At first I tried solving the system of equations, but then I tried solving the inequalities individually for Q, and those too could not be solved by Maple.  What am I doing wrong?
assume(R1, real, R2, real, RL, real, XC1, real, XC2, real, XL1, real)
additionally(R1 > 0, R2 > 0, RL > 0, XC1 > 0, XC2 > 0, XL1 > 0)
eq3 := R1*(4*Q^2+1)-RL > 0
0 < R1*(4*Q^2+1)-RL
eq4 := 4*Q^2*R1*RL-(R1-RL)^2 >= 0
0 <= 4*Q^2*R1*RL-(R1-RL)^2
eq5 := Rs^2*(RL-R1)/Q^2+R1^2*RL > 0
0 < Rs^2*(RL-R1)/Q^2+RL*R1^2
sys1 := {eq3, eq4, eq5}
`assuming`([solve(sys1, {Q})], [R1 > RL])
`assuming`([solve(sys1, {Q})], [R1 < RL])
solve(sys1, {Q})
solve(eq3, Q)
solve(eq4, Q)
solve(eq5, Q)
Download pi-filter_anal_copy.mw
howca i determine the range of gains if g(x)=1/(x+x^2+x^3+2)
the answer is like closed loop
I need to use the fact that the expression under the radical in a larger expression is >0.
How do I programmaticaly "grab" the radical term to include it in an equation such as for example:
eq1:= b^2-4 a c>0
where lhs term would have come from a previous derivation or solution ?
Thank you...
How can I get Maple to simplify expressions into more meaningful forms?
For example,
xc1 := -(2*Q*R1 + sqrt(4*Q^2*R1*RL - R1^2 + 2*R1*RL - RL^2))*R1/(4*Q^2*R1 + R1 - RL)
The numerator, under the radical, is more meaningful as sqrt(4 Q^2 R1 RL-(R1-RL)^2).
Similarly, the denominator can be simplified to Rs(4 Q^2+1)-RL.
How do I get Maple to get me there?
i have plotted a histogram and then fitted a uniform distribution curve. I need to compare how well the distribution fits the histogram. We are allowed to use the statistics package but i am nit sure how to do that. Not my image but just showing what I get approximately. I just need to quantify how well the red line fits the histogram.
Many thanks
After I just updated to Physics 871, my main worksheet which allready has for long time now:
Physics:-Latex:-UseColor := false;
Physics:-Latex:-UseImaginaryUnit:=i;
Now I get
The reason I use Physics:-Latex:-UseImaginaryUnit:=i; is to make the Latex use for complex number in Latex instead of I
What is now the correct way to use these settings with the new Physics update? if I do not use them, then compelx I  will still show as I whcih I do not want. I want lower case i
I could add interface(imaginaryunit=i); in place of Physics:-Latex:-UseImaginaryUnit:=i; and that work for the latex, making the Latex generate i. But this solution now makes the User interface no longer accept I  as complex number any more and must be typed as lower case, which is not what I want.
That is why I was using Physics:-Latex:-UseImaginaryUnit:=i; This keeps the user interface complex number as Uppercase, but let the latex generated be lower case.
I feel I am doing something wrong, but do not see it. Made sure I use Physics:-Latex on everything now.
Please see below 2 worksheets. One using the 871 version and one using 865 version.
`The "Physics Updates" version in the MapleCloud is 871 and is the same as the version installed in this computer, created 2020, November 14, 14:16 hours Pacific Time.`
Physics:-Latex:-Settings()
[invisibletimes = ` `, powersoftrigonometricfunctions = mixed, usecolor = true, useimaginaryunit = I, useinputlineprompt = true, userestrictedinputtranslation = false, usespecialfunctionrules = true, usetypesettingcurrentsettings = false]
Error, attempting to assign to `Physics:-Latex:-UseColor` which is protected
Error, attempting to assign to `Physics:-Latex:-UseImaginaryUnit` which is protected
Physics:-Latex(I)
I
Download latex_871.mw
`The "Physics Updates" version in the MapleCloud is 871. The version installed in this computer is 865 created 2020, November 11, 8:43 hours Pacific Time, found in the directory C:\Users\me\maple\toolbox\2020\Physics Updates\lib\`
usecolor = true, useimaginaryunit = I, useinvisibletimes = ` `, useinputlineprompt = true, userestrictedinputtranslation = false, usespecialfunctionrules = true, usetypesettingcurrentsettings = false
Physics:-Latex(I);
i
i
Download latex_865.mw
New error seems to have been introduced
expr:=arccos(1/x);
Physics:-Latex(expr);
it seems to happen with the inverse trig functions when there is a fraction inside.
Do others have the same issue? I am currently using  869.  Maple 2020.1
Rolling back Physics version one at a time, I found the version this happened at. It was OK in version 865, but gives the error starting at version 866.
Hopefully this should make it easy to find the code change which caused it using source control diff.
First 508 509 510 511 512 513 514 Last Page 510 of 2458
