Any idea why
if 2+89^(1/2)>0 then
   print("yes");
   print("no");
fi;
gives
Since
evalf(2+89^(1/2))
is 11.4339.
I tried in Mathematica, and it works there
If[2 + 89^(1/2) > 0, Print["Yes"], Print["No"]]
What is the correct way to do this in Maple? i.e. to check that a numerical value is >0 ?
This is done in code, where the value I am doing this check on are known to be numeric, but I do not know what form they will be, I just know they will contain no floating point numbers. Only exact numbers.
The problem is the 89^(1/2). Maple knows it is >0
is(89^(1/2)>0)
but
if (89)^(1/2)>0 then
   print("yes");
   print("no");
fi;
May be because 89 is prime. Should I replace my if with is for this check?
interface(version)
Standard Worksheet Interface, Maple 2020.1, Windows 10, July 30
   2020 Build ID 1482634
Physics:-Version()
The "Physics Updates" version in the MapleCloud is 867 and is
   the same as the version installed in this computer, created
   2020, November 12, 9:14 hours Pacific Time.
I often need to draw several curves on the same figure and the question of which colors to choose to distinguish them is crucial.
In particular when these curves depend on a parameter I would like to color them by using a "regular" change of color.
The trick I use is this one
# here I want to plot N=10 different curves
N := 10:
# step 1: generate a list of colours using colorscheme
# (I was hoping for 10 levels of colors but I got 19)
plot(x, x=0..1, colorscheme=["Gold", "Blue"], numpoints=N):
MyColors := op([1,2, 2], %);
M := numelems(MyColors[..,1]);
# step 2: do the plots of interest, for instance
plots:-display(
  seq(
    plot(m*x^2, x=0..1, color=ColorTools:-Color([entries(MyColors[round(m/N*M)], nolist)])),
    m=1..N
My question is: How can we make that MyColors be a matrix whose the number of rows equal N (this to avoid the round(m/N*M) operation)?
(I will accept any other strategy)
I am wondering if there are examples of agent-based models in economics domain that have been implemented in Maple.
Any infomration/source is more than welcome!
I actually want to numerically solve Karhunen-Loeve Decomposition, which is reduced to homogenous Fredholm integral equation second kind when the kernel is the function of correlation of variables, by using any procedures (Galerkin is better if it is availabe). FYI, with "intsolve" I just got f(x)=0.
The uploaded worksheet contains a copy of figure of a pencil from a geometry book, followed by a failed attempt to code Maple to produce the same figure.
The book containing the figure gives no indication of how to code for the figure. Can the figure be produced in Maple?
Respondents will have to establish their own path to DirectSearch.
Pencil.mw
I have Maple solve a system of equations.  I then want to assign the result to the different variables for use later in the worksheet.  How do I do this?
{C1 = .6666666670*Ceq, C2 = 2.000000002*Ceq, L1 = 0.1377592863e-15/Ceq, R1 = 0.8802817643e-8/Ceq}
(24)
c1 := sol3[1]
(25)
l1 := sol3[2]
(26)
r1 := sol3[3]
(27)
Solutions, C2=10pf
Ceqsol := 20*e-12
20*e-12
(28)
C1sol := subs(Ceq = Ceqsol, c1)
C1 = 13.33333334*e-8.000000004
(29)
First, all I want to do is assign the solution value for C1 to C1.  Not being able to do this, I try to assign C1 to "different" variable c1, but the assignment is C1~=.66667* Ceq, instead of just the value of C1.  Later, I then try to substitute the value of Ceq, to get the solution for c1, and instead of just getting the value, I get  that C1= 13.33x10^-8 is assigned to C1sol, again instead of just the value, 13.33x10^-8.  How do I just assign the values to these variables instead of the expressions?
Download new_filter_solution.mw
i have ode system of two dependent variables y and x  and one independent varibale time. how can i find explicit expression between y and x?
sys:=diff(x(t),t)=x(t)*y(t)+t,diff(y(t),t)=x(t)-t;
diff(x(t), t) = x(t)*y(t)+t, diff(y(t), t) = x(t)-t
dsolve([sys,x(0)=0,y(0)=1],[x(t),y(t)],series)
{x(t) = series((1/2)*t^2+(1/6)*t^3+(1/24)*t^4-(1/24)*t^5+O(t^6),t,6), y(t) = series(1-(1/2)*t^2+(1/6)*t^3+(1/24)*t^4+(1/120)*t^5+O(t^6),t,6)}
Download explicit.mw
I am a newbie in Maple! I tried both ThermophysicalData and its CoolProp package to find saturation pressure of vapor for given air-water mixture temperature.
I want to calculate water vapor density in air or simply Absolute humidity (kg/m3)
But i can not see any meaningful function or combination of functions/properties in CoolProp to give such output.
P_w in CoolProp, HApropSI takes this as input only that is not usefule either way inpoutput
The rationale is to work from RH and then calculate P_w as output: P_w=RH x P_g where P_g is vapor saturation pressure at the given ambient condition.
From there all world is yours!
You can use ideal gas rules to do everything. But i cant use CoolProp to calculate the ABsolute humidty for given RH and ambient condition.
Note that clearly i can calculate all these from hand calculation as well as approximation formuale of Clausius-Clapeyron equation. But i wanted to do in Maple with its packages.
Any help is appreciated!?
Sina
Dear there,
I want to create a new package.
Goal of the package:
I have two functions psi(n,m,x) and w(n,x).
These functions are defined differently in case A, and in case B
In my future works,
I want to use the functions psi(n,m,x) and w(n,x) in ONE (same) worksheet by calling the package.
Case A;
 K:=2^(k-1):
with(orthopoly):
psi:=(n,m,x)->piecewise((n-1)/K <= x and x <= n/K,
(sqrt((m+1/2)*2^k))*LegendreP(m,2^k*x-2*n+1), 0);
w:=(n,x)->1;
Case B;
K:=2^(k-1):
with(orthopoly):
unprotect(gamma):
h:=(m,epsilon,gamma)->2^(epsilon+gamma+1)*GAMMA(epsilon+m+1)*GAMMA(gamma+m+1)/((2*m+1+epsilon+gamma)*m!*GAMMA(epsilon+gamma+1));
psi:=(n,m,x)->piecewise((n-1)/K <= x and x <= n/K,  2^(k/2) *h(m,epsilon,gamma)*simplify(JacobiP(m,epsilon,gamma,2^(k)*x-2*n+1)), 0);
w:=(n,x)->(1-x)^(epsilon)*(1+x)^gamma;
How can we achieve this in the simplest way?
MY TRY: (Please click to download the code.mw)
test:=module()
export functionA,functionB;
 option package;
functionA:=proc(k,M) local K,h,psi,w;
K:=2^(k-1):
with(orthopoly):
w:=(n,x)->1;
return psi(n,m,x) ,w:
functionB:=proc(k,M,epsilon,gamma) local K,h,psi,w;
K:=2^(k-1):
with(orthopoly):
unprotect(gamma):
return psi(n,m,x),w(n,x):
end module;
savelib(test):
# FOR EXAMPLE
with(test);
#For k=2,M=3 in FunctionA, let's calculate values of "Psi(2)" and "w(2,x)"
k:=2:
M:=3:
K:=2^(k-1):
N:=K*M:
(psi,w):=functionA(2,3):
psi:=(n,m,x)->psi;
w:=(n,x)->w;
unprotect(Psi):
Psi:=x->Array([seq(seq(psi(i,j,x),j=0..M-1),i=1..K)] )^+:
Psi(2);
w(2,x);
#Now, let's calculate values of "Psi(2)" and "w(2,x)" For  k=3,M=4, epsilon=1, gamma=2 in FunctionA
 (psi,w):=functionB(3,4,1,2):
Psi(2);
w(2,x);
Please see the attached file.
s1.mw
Hi, I hope your going well
I was wondering if i can index my matrix column like in the image below and if i can replace u(1) for is estamted value
Thank a lot <3
How do I get Maple to simplify:
Io := I Cp Vin L1/(M sqrt(Cp L1))
to :  I sqrt(L1 CP) Vin/ M  ?
Furthermore, if  w = 1/sqrt(L1 *CP),  how do I get Maple to display the solution or the simplification as:
I*Vin/(w M) ?
I've t ried multiple substitutions and simplifications to no avail.
Jorge
I*Cp*RL*Vin*L1/(M*(Cp*L1)^(1/2))
simplify(I*Cp*RL*Vin*L1/(M*(L1*Cp)^(1/2)), 'symbolic')
I*Cp^(1/2)*RL*Vin*L1^(1/2)/M
Io := Vores/RL
I*Cp*Vin*L1/(M*(Cp*L1)^(1/2))
simplify(I*Cp*Vin*L1/(M*(L1*Cp)^(1/2)))
simplify(I*Cp*Vin*L1/(M*(L1*Cp)^(1/2)), 'assume = real')
combine(Vores/RL, power)
factor(I*Cp*Vin*L1/(M*(L1*Cp)^(1/2)))
combine(I*Cp*Vin*L1/(M*(L1*Cp)^(1/2)), radical)
cancel(I*Cp*Vin*L1/(M*(Cp*L1)^(1/2)))
simplify(cancel(I*Cp*Vin*L1/(M*(L1*Cp)^(1/2))), 'assume = real')
simplify(I*Cp*Vin*L1/(M*(L1*Cp)^(1/2)), 'radical')
(14)
simplify(I*Cp*Vin*L1/(M*(L1*Cp)^(1/2)), 'symbolic')
I*Cp^(1/2)*Vin*L1^(1/2)/M
(15)
Download Resonant_xformer.mw
Sometimes I find Maple a bit unconsequent regarding indexing, some things start with 0, others with 1.
The ReplaceChild function clearly starts with 1 for example, as you see in the help function.
ReplaceChild( 2 = XMLElement( "NEW", [], "text" ), doc )
replaces the second element in the list.
When using the AddChild function, one has to enter 0.
The AddChild(xmlTree, child, n) command creates a new XML element from xmlTree by inserting the XML element child at the position indicated by n. Parameter n must be less than or equal to the number of children in the original tree xmlTree. The new child node child becomes the n + 1st child of the resulting tree.
The first sentence sounds logical, but I would then expect the position of the first element to be 1. The other 2 sentences in the help file contradict the first one in my opinion. Either the position of the element is 0, as stated in the first sentence - then it also should be possible to get its value in the position 0. Or it is 1, but then it also should have been defined at position 1.
deq1 := diff(u(x, y), x) - diff(u(x, y), y$2) = exp(x+y);
                              /  2         \
              / d         \   | d          |
      deq1 := |--- u(x, y)| - |---- u(x, y)| = exp(x + y)
              \ dx        /   |   2        |
                              \ dy         /
deq2 := diff(u(x, y), x) - diff(u(x, y), y$2) = exp(1)^(x+y);
                            /  2         \
            / d         \   | d          |           (x + y)
    deq2 := |--- u(x, y)| - |---- u(x, y)| = (exp(1))
            \ dx        /   |   2        |
                            \ dy         /
pdsolve(deq1, u(x,y));  ### no result
pdsolve(deq2, u(x,y));
PDESolStrucApplyFunction|uApplyFunction(x,y)=_F1ApplyFunction(x)
  _F2ApplyFunction(y) - -
                       x+y
  (expApplyFunction(1))    (_C1 expApplyFunction(uminus0y)+_C2 expApplyFunction(y)+_C3 expApplyFunction(y) y)
  ,[{diffApplyFunction(_F1ApplyFunction(x),x)=_c[1] _F1
  ApplyFunction(x),diffApplyFunction(diffApplyFunction(_F2
  ApplyFunction(y),y),y)=_c[1] _F2ApplyFunction(y)}]|
No solution appears when the differential equation is expressed in standard form, but when exp(x + y) is converted to
exp(1)^(x + y) the correct solution appears.
First 509 510 511 512 513 514 515 Last Page 511 of 2458
