A triangle ABC with fixed B and C vertex is considered in the plane, A being variable so that b+c remains constant and equal to a given length L.
We call P, T, T' the points of contact of the exinscrit circle in the angle B with the sides BC, AB and AC respectively.
Show that P is fixed and is one of the vertex of the ellipse described by point A. What are the locus of T and T'? How to animate the drawing when A move ? Thank you.
Hello! Sorry if this question was already asked, I just can't find my answer and I don't really know how to form the question since I'm new to using Maple. My question is: How can I find a point on a plot I did in Maple? When I use the cursor position(from when I click Probe info) I can never align it right enough for me to not get a decimal answer. For instance, I can't figure out the y-value for when x=2 because the closest I can get to 2 is like 2.1 which isn't exact enough for me.
This is a very basic question and apologize for not being able to figure it out myself.     I would like to define a function that I can evaluate with a complicated argument.    For example for a simple function, the following works well
f:=x->x^2+x^3;
This allows me to plot f(x) or f(exp(-r)), etc.
However the following syntax does not work in the same way.
g:=x->diff(f(x),x);
I can plot g(x) correctly, but g(exp(-r))  cannot be plotted or evaluated.    The error message is
Error, (in g) invalid input: diff received exp(-r), which is not valid for its 2nd argument
Thanks in advance for your suggestions.
Hi guys,
an error appeared in solving a set of equations and plotting the solution, I dont know how to handle it!!
Thanks for your help
Best
problem.mw
please help me
Similar*solution
Similar*solution
eq11 := (10-9*lambda1)*n*diff(f(eta),eta,eta,eta)*(-diff(f(eta),eta,eta))^(n-1)-m*diff(f(eta),eta)^2+M^2*diff(f(eta),eta)+(m*(2*n-1)+1)/(n+1)*f(eta)*diff(f(eta),eta,eta)=0;
(10-9*lambda1)*n*(diff(diff(diff(f(eta), eta), eta), eta))*(-(diff(diff(f(eta), eta), eta)))^(n-1)-m*(diff(f(eta), eta))^2+M^2*(diff(f(eta), eta))+(m*(2*n-1)+1)*f(eta)*(diff(diff(f(eta), eta), eta))/(n+1) = 0
eq21 := (10-9*lambda1)*n*diff(theta(eta),eta,eta)*(-diff(theta(eta),eta))^(n-1)+(m*(2*n-1)+1)/(n+1)*f(eta)*diff(theta(eta),eta)-m*diff(f(eta), eta)*theta(eta)=0;
(10-9*lambda1)*n*(diff(diff(theta(eta), eta), eta))*(-(diff(theta(eta), eta)))^(n-1)+(m*(2*n-1)+1)*f(eta)*(diff(theta(eta), eta))/(n+1)-m*(diff(f(eta), eta))*theta(eta) = 0
bc21:= f(0)=0, D(f)(0)=1+alpha*(D@@2)(f)(0), D(f)(N)=0, theta(0)=1+b*D(theta)(0), theta(N)=0;
f(0) = 0, (D(f))(0) = 1+alpha*((D@@2)(f))(0), (D(f))(N) = 0, theta(0) = 1+b*(D(theta))(0), theta(N) = 0
n:=1.2: b:=0: M:=0: alpha:=0:
N:=6:
m:=0.8:
A11:=dsolve({eq11,eq21,bc21},numeric,continuation=lambda1,maxmesh=15000, output=array([seq( i, i=0..N,0.01 )])):
Error, (in unknown) unable to store '-HFloat(1.03827200589718e-4)+HFloat(7.543487679217342e-5)*I' when datatype=float[8]
m:=1.2:
A12:=dsolve({eq11,eq21,bc21},numeric,continuation=lambda1,maxmesh=15000, output=array([seq( i, i=0..N,0.01 )])):
Error, (in unknown) unable to store '-HFloat(1.239112373179345e-4)+HFloat(9.002678360924433e-5)*I' when datatype=float[8]
m:=2:
A13:=dsolve({eq11,eq21,bc21},numeric,continuation=lambda1,maxmesh=15000, output=array([seq( i, i=0..N,0.01 )])):
Error, (in unknown) unable to store '-HFloat(5.684098069533373e-5)+HFloat(4.129738980869168e-5)*I' when datatype=float[8]
p1:=odeplot(A11, [[eta,f(eta),color=red,linestyle=2]],0..N):
p2:=odeplot(A12, [[eta,f(eta),color=blue,linestyle=2]],0..N):
p3:=odeplot(A13, [[eta,f(eta),color=green,linestyle=2]],0..N):
display({p1,p2,p3}, axes=boxed,  title=`velerature Profiles:`);
Error, (in plots:-display) expecting plot structures but received: {p1, p2, p3}
for j from 1 to 100*(N-1) do eta[j]:=A11[2,1][j,1] end do:
for j from 1 to 100*(N-1) do vel1[j]:=A11[2,1][j,2] end do:
for j from 1 to 100*(N-1) do vel2[j]:=A12[2,1][j,2] end do:
for j from 1 to 100*(N-1) do vel3[j]:=A13[2,1][j,2] end do:
E1:= <<seq(eta[j], j=1..100*(N-1) )>|<seq(vel1[j], j=1..100*(N-1) )>|<seq(vel2[j], j=1..100*(N-1) )>|<seq(vel3[j], j=1..100*(N-1))>>;
_rtable[18446746174193268126]
#ExportMatrix("F:/D/Drive D/Local/Rashad/Paper 9/vel1.txt", E1, format = rectangular):
p1:=odeplot(A11, [[eta,theta(eta), color=red,linestyle=2]],0..N):
p2:=odeplot(A12, [[eta,theta(eta), color=blue,linestyle=2]],0..N):
p3:=odeplot(A13, [[eta,theta(eta), color=green,linestyle=2]],0..N):
display({p1,p2,p3}, axes=boxed,  title=`temperature Profiles:`);
"[[eta,F(eta),(&DifferentialD;)/(&DifferentialD;eta) F(eta),((&DifferentialD;)^2)/(&DifferentialD;eta^2) F(eta),Theta(eta),(&DifferentialD;)/(&DifferentialD;eta) Theta(eta),f(eta),(&DifferentialD;)/(&DifferentialD;eta) f(eta),((&DifferentialD;)^2)/(&DifferentialD;eta^2) f(eta),theta(eta),(&DifferentialD;)/(&DifferentialD;eta) theta(eta)]]"
for j from 1 to 100*(N-1) do temp1[j]:=A11[2,1][j,5] end do:
for j from 1 to 100*(N-1) do temp2[j]:=A12[2,1][j,5] end do:
for j from 1 to 100*(N-1) do temp3[j]:=A13[2,1][j,5] end do:
E2:= <<seq(eta[j], j=1..100*(N-1) )>|<seq(temp1[j], j=1..100*(N-1) )>|<seq(temp2[j], j=1..100*(N-1) )>|<seq(temp3[j], j=1..100*(N-1))>>;
_rtable[18446746174193227646]
#ExportMatrix("F:/D/Drive D/Local/Rashad/Paper 9/temp1.txt", E2, format = rectangular):
Download text.mw
When a real matrix have repeated eigenvalue (i.e. multiplicity >1) and the matrix is not the identity matrix, then it is called defective eigenvalue.
For example if the eigenvalue is repeated 2 times, there will be only one eigevector associated with it.
There is an algorithm to generate another (linearly independent) eigenvector from this same eigenvalue called the defective eigenvalue method.
My question is: Does Maple have support for finding such additional eigenvectors?  The standard Eigenvectors does not seem to do this. Here is an example.
A :=Matrix([[1,-2],[2,5]]);
(eigen_values, eigen_vectors) := LinearAlgebra:-Eigenvectors(A);
By hand, using the defective eigenvalue method it is possible find second eigenvector for this eigenvalue, which is linearly independent of the one returned by Maple. Such as
The method to find these additional eigenvector is described in number of places such as
https://en.wikipedia.org/wiki/Defective_matrix
And the pdf at the bottom show a more detailed example.
I can code this method by hand to find complete set of L.I. eigenvectors for this defective eigenvalue.
But before doing that, I thought to ask if Maple have buildin support for this, such as a single command to do this or some package.
I looked at help for LinearAlgebra and I am still not able to see anything, It only says this:
With an eigenvalue of multiplicity  k>1 , there may be fewer than  k linearly independent eigenvectors. In this case, the matrix is called defective.  By design, the returned matrix always has full column dimension.  Therefore, in the defective case, some of the columns that are returned are zero.  Thus, they are not eigenvectors.  With the option, output=list, only eigenvectors are returned.  For more information, see LinearAlgebra[JordanForm] and LinearAlgebra[SchurForm].
This PDF also describes using Maple, how to do it for one example
https://wps.prenhall.com/wps/media/objects/884/905485/chapt5/proj5.4/proj5-4.pdf
This PDF also describes how to do it by hand without using Maple, starting at end of page 3
http://www.math.utah.edu/~zwick/Classes/Fall2013_2280/Lectures/Lecture23_with_Examples.pdf
It is not too hard to code this method in Maple. But if Maple allready can do it, using some command, it will be better ofcourse.
To practice more in documentmode
Given  f := x^2 + y^2 + z^2 = 1
Asked:
surfacelevel on level 1  and surfacelevel upon wich the point (sqrt(3), 3, -2) is located.
1) x^2 + y^2 + z^2 = 1   : what solid ( a sphere with radius 1)  and  plot
2) surfacelevel (solid sphere)   for point  (sqrt(3), 3, -2) and plot
3) Plot together
Doing this calculation solely with contextpanel..no that's not always possible as it seems by trying to plot a sphere.
a:=0.2; b:=0.2; c:=5.7;
ode1:=diff(x(t),t)=-y(t)-z(t);
ode2:=diff(y(t),t)=x(t)+a*y(t);
ode3:=diff(z(t),t)=b+z(t)*(x(t)-c);
ic1:=x(0)=-0.7;
ic2:=y(0)=-0.7;
ic3:=z(0)=1;
sol:=dsolve({ode1,ode2,ode3,ic1,ic2,ic3},{x(t),y(t),z(t)},numeric,method=classical[rk4],stepsize=0.10,output=listprocedure);
b:=rhs(sol[2]);
c:=rhs(sol[3]);
d:=rhs(sol[4]);
animate (pointplot3d, [ [b(t),c(t),d(t)], symbol=box, color=blue],t=15..100,
background = odeplot(sol, [x(t),y(t),z(t)],t=15..100,numpoints=7000),frames=20);
UPD
And "Error, (in plots/animate) incorrect first argument" BUT if i use classic functions (sin,cos,sqrt) instead of b,c,d - all is well.
For example [sin(t),cos(t),t/10]
For example [b(t),c(t),d(t)]
Using latest Physics, I found case where it is not giving the Latex.
Please see attached worksheet.  This is on windows 10, Maple 2020.1.1
Physics:-Version()
`The "Physics Updates" version in the MapleCloud is 804 and is the same as the version installed in this computer, created 2020, September 7, 12:31 hours Pacific Time.`
ode:=diff(y(t),t) = -2*arctan(y(t))/(1+y(t)^2);
diff(y(t), t) = -2*arctan(y(t))/(1+y(t)^2)
sol:=dsolve(ode)
t+Intat((1/2)*(_a^2+1)/arctan(_a), _a = y(t))+_C1 = 0
Physics:-Latex(sol)
Error, (in unknown) invalid range for string subscript
latex(sol)
t+\int ^{y \left( t \right) }\!{\frac {{{\it \_a}}^{2}+1}{2\,\arctan
 \left( {\it \_a} \right) }}{d{\it \_a}}+{\it \_C1}=0
By trial and error, I found that the error was introduced in Physics 797. Since in Physics 796 it did work.
Here is screen shot
Download latex_issue_11.mw
If I call for the metric (27.27) in Stephani et al. in the Physics package, I expected the null tetrad employed to compute say the Weyl scalars would be the one given in conjunction with (27.27) (equation (27.22) in Stephani et al.). But, Weyl[scalars] returned long expressions for each of the five scalars, whereas with respect to the null tetrad in Stephani et al one expects the first two (or last two) scalars to be zero since the null vector k in their tetrad is the multiple pnd of Weyl. e_[nullvectors] and Setup(tetradmetric=null) followed by e_[ ] seem to output the same null tetrad, which does not appear to be that of Stephani et al. I assume this null tetrad is the null tetrad associated to the orthonomral tetrad that e_[ ]  returns if one hasn't used Setup(tetradmetric=null). How does Maple select this default orthonormal tetrad? What is the best way to set the null tetrad of Stephani et al as the null tetrad to compute Weyl[scalars]?
Here is a simpler example. Calling [27, 37, 1]. Stephani et al give the null tetrad in terms of the spacetime coordinates along with the metric in their equaiton (27.37). After using Setup(tetradmetic=null), e_[ ] returns a tetrad that might, I suppose, be that of Stephani et al. in disguise. Specifically, the tetrad vector defining the null congruence should have only a component with respect to the coordinate r, yet the Maple output gives expressions for the components with respct to the u and r coordinates for both the k and l elements of the null tetrad (while the expressions for the complex element m is exactly what one would expect). As in the previous example, all Weyl scalars are given by nontrivial expressions, even though two of them should be zero (since k is a multiple pnd). So is it the case that the experssions in the Maple output where one expects zero are in fact zero in disguise? The experssions are complicated enough that it is not obvious.  I have uploaded the Maple document for these calculations. SKMHH27_37.mw
I want to series expand the HeunB function. But I am facing some problems with this. please help. Here is the given HeunB function.
HB1 := HeunB(5/2, -5^(1/4)*(2*M - R)/sqrt((2*M - R)*(4*M - R)), (17*sqrt(5))/10, (3*5^(3/4)*(2*M - R))/(2*sqrt((2*M - R)*(4*M - R))), 5^(1/4)*sqrt((2*M - R)*(4*M - R))*r^2/(2*(2*M - R)*R^2))
Here M, R are arbitrary constants.
I can use a whole package in a procedure or a command from a package.
Writing your own code needs sometimes external code from outside a procedure used ( a package..what else more?)
This i don't find back in the Maple helpfiles easily using external code in procedure
 This old example uses display3d naming what is the same as display ( there is no display3d command in Maple )
It gives the error
diskmethod(f,0,2,10,fig);
Error, (in with) package plots does not export display3d
The disk methode calculates
V = int(Pi*f(x)^2, x = a .. b)
 The Code for diskmethoddisplay
diskmethod:=proc(f,a,b,N,figure::evaln)
  local X,Y,s,x,dX,i,disk;
  with(plots,display3d);
  X:=array(0..N);Y:=array(1..N);disk:=array(1..N);
  dX:=evalf((b-a)/N);
  X[0]:=a;s:=0;
  for i to N do
    X[i]:=a+i*dX; Y[i]:=evalf(f(X[i]));
    s:=s+evalf(Pi*Y[i]^2*dX);
    disk[i]:=plot3d([x,Y[i]*cos(theta),Y[i]*sin(theta)],
                x=X[i-1]..X[i],theta=0..2*Pi,grid=[2,51]):
  figure:= display3d({seq(disk[i],i=1..N)},
            axes=box,projection=0.8,orientation=[-60,70]);
  print(`The approximate volume using`,N,`disks is V =`, s);
Can anyone help me to draw a zoom picture of any plotted function as shown in the picture??
would like to show a list system one by one and ask question and wait for answer and then plot graph and ask question and wait for answer and then show next system ask question and contiune this for loop
but my script show all system at once but can not one by one and no pop up dialog and no wait for answer
how to do?
interface(prettyprint=2):
with(ListTools):
with(StringTools):
with(ExcelTools):
with(SumTools):
with(Maplets[Elements]):
count := 1:
RR := Import("C:\\Users\\ohungyeeel\\Documents\\EquationsLists.xls", "Candidate", "A1:Q65535"):
for mm from 2 to 20 do
try:
if RR[count,13] = "Complex" or RR[count,13] = "Beautiful system but no result" then
dummy := 0:
print(RR[count,1],RR[count,2]):
sol := solve(RR[count,2]):
print("Source:",RR[count,3]):
print("Solution:",sol):
choosesystem := Maplet(InputDialog['ID1']("Choose system?", 'Yes1' = Shutdown(['Yes']), 'No1' = Shutdown(['No']))):
Maplets[Display](maplet):
if choosesystem = "Yes" then
RR[count,15] := "SystemChosenAndSolutionCorrect":
RR[count,15] := "NotChosenAndSolutionWrong":
end if:
plot(sol):
choosesystem := Maplet(InputDialog['ID1']("Like and it works?", 'Yes1' = Shutdown(['Yes']), 'No1' = Shutdown(['No']))):
RR[count,16] := "Best":
RR[count,16] := "NotSelected":
end if:
end if:
catch:
print("error at ",RR[count,1],RR[count,2]):
end try:
count := count + 1:
Export(RR, "C:\\Users\\ohungyeeel\\Documents\\EquationsLists10092020.xls", "Candidate", "A1"):
eq1 := diff(f(eta), eta, eta, eta, eta)+(2*f(eta)*(diff(f(eta), eta, eta, eta))+2*g(eta)*(diff(g(eta), eta)))*(1-phi)^2.5*(1-phi+phi*rhos/rhof)-sigmanf*M*(diff(f(eta), eta, eta))*(1-phi)^2.5/sigmaf = 0
eq2 := diff(g(eta), eta, eta)-(1-phi)^2.5*(1-phi+phi*rhos/rhof)*(2*(diff(f(eta), eta))*g(eta)-2*(diff(g(eta), eta))*f(eta))-sigmanf*M*g(eta)*(1-phi)^2.5/sigmaf = 0
eq3 := k[nf]*(diff(theta(eta), eta, eta))/(Pr*k[f])+((1-phi+phi*rhos*cps/(rhof*cpf))*2)*f(eta)*(diff(theta(eta), eta))-4*lambda*(1-phi+phi*rhos*cps/(rhof*cpf))*(f(eta)^2*(diff(theta(eta), eta, eta))+f(eta)*(diff(f(eta), eta))*(diff(theta(eta), eta)))+sigmanf*M*Ec*((diff(f(eta), eta))^2+g(eta)^2)/sigmaf = 0
eq4 := (1-phi)^2.5*(diff(chi(eta), `$`(eta, 2)))+2*Sc*f(eta)*(diff(chi(eta), eta))-sigma*Sc*(1+delta*theta(eta))^n*exp(-E/(1+delta*theta(eta)))*chi(eta) = 0
Boundary Conditions
f(0) = 0, (D(f))(0) = A1+gamma1*((D@@2)(f))(0), f(10) = 0, (D(f))(10) = 0, g(0) = 1+gamma2*(D(g))(0), g(10) = 0, theta(0) = 1+gamma3*(D(theta))(0), theta(10) = 0, chi(0) = 1, chi(10) = 0
Parameters
lambda = 0.1e-1, sigma = .1, Ec = .2, E = .1, M = 5, delta = .1, n = .1, Sc = 3, A1 = .5, gamma1 = .5, gamma2 = .5, gamma3 = .5, Pr = 6.2, phi = 0.1e-1, rhos = 5.06*10^3, rhof = 997, cps = 397.21, cpf = 4179, k[nf] = .6358521729, k[f] = .613, sigmanf = 0.5654049962e-5, sigmaf = 5.5*10^(-6)
First 533 534 535 536 537 538 539 Last Page 535 of 2458
