I use WINDOW 10
for j from 1 to 3 do
pout := cat("C:/Users/Eli/Documents/Animation/", "file", j, ".bmp"):
print(pout):
plotsetup(bmp, plotoutput = pout):
# plot (...)
Hi, I have a problem related to the cancellation of the square root with a square in its argument, see the image below.
Thanks in advance,
Santiago
i have a task who is like this:
let h(x)=2/f(x)
and the function f meets the following criteria
f(-1)=4 and f '(-1)=2
what is h'(-1)
how to i solve this, i am thinking of ordinary differential equations (ODEs)
and dsolve funktion in maple. but how do i do this.
or is there another way to solve it
 Hello , I need to plot the following on the same axes of implicit plot where discrete wavenumbers k1, k2, k3 on the same set of axes (the wavenumbers are points [k1,0], [k2,0], [k3,0], ...) , where k_{n}=2*n*Pi/L and the domain [0,L]
Could you please help , I couldn't do. Thank you
with(plots, implicitplot);
alpha := 0.1;
beta := 0.1;
mu := 0.5;
u := 0.5;
v := 1;
gamma = 0.1;
                          alpha := 0.1
                          beta := 0.1
                           mu := 0.5
                            u := 0.5
                             v := 1
                          gamma = 0.1
Eq := -2*sigma*alpha*beta*mu*u - sigma*alpha*beta^2*u*v - 2.0*mu*alpha*beta^2*u*v - gamma^2*k^2*alpha*beta*u + beta*sigma^2*v + sigma^3 + 2*mu*sigma^2 - alpha*beta*sigma^2*u + sigma*beta^2*u*v + gamma^2*k^2*sigma + 2.0*mu*beta*sigma*v + 2.0*mu*beta^2*u*v;
                                            2  2              2
 Eq := 0.0995 sigma + 0.004500 - 0.005 gamma  k  + 1.095 sigma
           3        2  2
    + sigma  + gamma  k  sigma
implicitplot(Eq, k = 0 .. 10, sigma = -0.1 .. 0.1);
Please can someone help me out, have been trying for a very long time now on how to differentiate the lines on the graph.......please find attachment below and correct..................................................................
# Define the ODE system
  odeSys:= { (diff(F(eta), eta, eta, eta))*(1+epsilon-alpha((diff(F(eta), eta, eta))^2))+F(eta)*(diff(F(eta), eta, eta))+S*(diff(F(eta), eta))-(1/2)*S*eta*(diff(F(eta), eta, eta))-(diff(F(eta), eta))^2-M*(diff(F(eta), eta)), (diff(theta(eta), eta, eta))*(1+R)-delta*(diff(F(eta), eta))^2-Pr((3/2)*S*theta(eta)+(1/2)*S*eta*(diff(theta(eta), eta))-2*(diff(F(eta), eta))*theta(eta)+F*(diff(theta(eta), eta)))};
# Define the first set of boundary conditions
  bcs1:= { F(0) = 0, (D(F))(0) = 1, (D(F))(inf) = 0, theta(0) = 1, theta(inf) = 0
  RVals:=[0.1, 0.5, 1]:
  for k from 1 by 1 to numelems(RVals) do
      pList:=[ epsilon = 0.18, M = 0.5, S = 1.5, delta = 0.3, Pr = 1.5, alpha = 0.4, R = RVals[k],inf=1
      sol1[k]:= dsolve( eval
                        ( `union`( odeSys, bcs1),
                           pList
                       numeric
  display
  ( [ seq
      ( odeplot
        ( sol1[i],
          [eta, theta(eta)],
          eta=0..2
        i=1..numelems(RVals)
    color = [red, green, blue],
    title = typeset( theta(eta), " versus ", eta),
    titlefont = [times, bold, 20]
I want to do a organised introduction in Maple  with the student and main vectorcalculus package
Is there some studymatrial to find for this ?
I am using Maple to solve a system of ODEs numerically. Right now, I want to find the integration of the output of the system of ODEs. How it is possible to do this?
F := dsolve(ODESys union ICs, {y0(t), y1(t), y2(t), y3(t)}, type = numeric)
Y0 := t -> rhs(op(2, F(t)))
Now, I want to find int(Y0,t=0..1).
Why this simple case cannot be simplified to Complete Square form
EQ := 1/4*n[1]^4 - 1/2*n[1]^2 + 1/4
simplify(1/4*n[1]^4 - 1/2*n[1]^2 + 1/4, 'size')
with(Student[Precalculus])
CompleteSquare(EQ);
Would you tell me a way to apply the identity relationship in Maple, to rewrite 'subexp' below to 'subexp2'?
subexp := M__a*sin(omega*t + alpha)*I__a*sin(omega*t + phi);
M__a*sin(omega*t+alpha)*I__a*sin(omega*t+phi)
subexp2 := M__a * I__a * (-1/2*(cos(2*omega*t + alpha + phi)-cos(alpha - phi)));
M__a*I__a*(-(1/2)*cos(2*omega*t+alpha+phi)+(1/2)*cos(alpha-phi))
is(subexp = subexp2);
Download Q20200901.mw
In the plane, an ABC triangle is considered for the vertices B and C are fixed, A being variable so that b +c remains constant and equal to a given length l. (b=distance(A,C), (c=distance(A,B)
How to show that the product tan(B/2=*tan(C/2) remains constant ?
I would like to solve this equation and keep the parameters a and eta unknown and assign them a value later on. Is it possible ?
I know I can solve this equation numerically, it works, but I want to change the parameters to fit experimental data.
I tried this :
ode:=diff(y(t),t)=-(4/3)*(a/eta)*(y(t)^3+1):
lambdaE:=dsolve({ode,y(0)=1},y(t),explicit);
But the solution appears with RootOf expression and I can't get a numerical solution afterwards.
lambdaE := y(t) = RootOf(6*eta*sqrt(3)*arctan(((2*_Z - 1)*sqrt(3))/3) - eta*sqrt(3)*Pi - 3*eta*ln(_Z^2 - _Z + 1) + 6*eta*ln(_Z + 1) - 6*eta*ln(2) + 24*t*a)
I tried some things from forums but nothing works.
Do you have any leads on how to do it please ?
Thank you in advance
Manon
is there easy way to simulate lines rotation like robotic arm following point P moving by adjusting angle q1 and q2?
i feel point two lines and simulate static two lines in animate is also not easy.
with(geometry):
#Joint at (5,5)
#length a  2, y=7, x, solve(subs(y=7,2^2 = (y-5)^2+(x-5)^2), x)[1];
#length b 2, y=1, x, solve(subs(y=4,2^2 = (y-5)^2+(x-5)^2), x)[1];
point(A, 5, 5), point(B, solve(subs(y=7,2^2 = (y-5)^2+(x-5)^2), x)[1], 7):
point(C, 5, 5), point(D, solve(subs(y=4,2^2 = (y-5)^2+(x-5)^2), x)[1], 4):
line(L1, [A, B]);
line(L2, [C, D]);
_EnvHorizontalName := x;
_EnvVerticalName := y;
Equation(L1);
Equation(L2);
solve(Equation(L1), y);
solve(Equation(L2), y);
plot([solve(Equation(L1), y),solve(Equation(L2), y)], x = 1 .. 2);
animate(plot, [Equation(L1),Equation(L2), x = 0 .. 2], A = -3 .. 3);
Angle Reference from below
angle of L2 , q1a
angle of L1,  q2a
p1 := vector([a*cos(q1), a*sin(q1)]);
P := evalm(p1 + b*vector([cos(q1+q2), sin(q1+q2)]));
Pe := map(expand, P);
A := {cos(q1) = c1, sin(q1) =s1, cos(q2)=c2, sin(q2)=s2};
P := subs(A, op(Pe));
F1 := [x - P[1], y - P[2], s1^2+c1^2-1, s2^2+c2^2-1 ];
F2 := subs({a=1, b=1}, F1);
with(Groebner):
g1 := Basis(F2, plex(c2, s2, c1, s1, y, x));
g1 := [-4*x^2+x^4+2*x^2*y^2+y^4-4*y*x^2*s1-4*y^3*s1+4*s1^2*x^2+4*s1^2*y^2, 2*y*s1+2*x*c1-x^2-y^2, 4*x-x^3-y^2*x+2*y*x*s1-2*y^2*c1-4*s1^2*x+4*y*s1*c1, s1^2+c1^2-1, x*s1-y*c1+s2, -y^2+2-x^2+2*c2];
map(indets, g1);
g2 := Basis(F2, plex(c2, s2, c1, s1));
assume point x = 1, y = 0.5
g2spec := subs({x=1, y=1/2}, [g2[1],g2[3]]);
S1 := [solve(g2spec[1])];
q1a := evalf(arcsin(S1[1]));
q1b := evalf(arcsin(S1[2]));
S2 := [solve(subs(s1=S1[1], g2spec[2])), solve(subs(s1=S1[2], g2spec[2])) ];
q2a := evalf(arcsin(S2[1]));
q2b := evalf(arcsin(S2[2]));
q2a := subs({a=2,b=2}, q2a);
if q2a < 0 then
 q2a_pi := evalf(eval(-q2a-Pi));
 q2a_pi := evalf(eval(Pi-q2a));
end if:
q2a_pi;
q2b := subs({a=2,b=2}, q2b);
if q2b < 0 then
 q2b_pi := evalf(eval(-q2b-Pi));
 q2b_pi := evalf(eval(Pi-q2b));
end if:
q2b_pi;
I've been using Physics:-Latex in my large program, and checking the output visually. I noticed this small issue on one page.
When asking Physics:-Latex to generate Latex for this expression
It gives
While when using standard latex() command, the result is
Below is the worksheet attached. Using Latest Physics and Maple.
interface(version)
Physics:-Version()
`The "Physics Updates" version in the MapleCloud is 784 and is the same as the version installed in this computer, created 2020, August 31, 0:51 hours Pacific Time.`
expr:=1/2*int(exp(-t)*f(t),t)*exp(t)-1/2*exp(-t)*int(exp(t)*f(t),t)
(1/2)*(int(exp(-t)*f(t), t))*exp(t)-(1/2)*exp(-t)*(int(exp(t)*f(t), t))
Physics:-Latex(expr)
\frac{\left(\int {\rm e}^{-t} f \left(t \right)d t \right) {\rm e}^{t}}{2}+-\frac{1}{2} {\rm e}^{-t} \left(\int {\rm e}^{t} f \left(t \right)d t \right)
latex(expr)
{\frac {\int \!{{\rm e}^{-t}}f \left( t \right) \,{\rm d}t{{\rm e}^{t}
}}{2}}-{\frac {{{\rm e}^{-t}}\int \!{{\rm e}^{t}}f \left( t \right)
\,{\rm d}t}{2}}
THe latex file used to compile the Maple output Latex using TeXLive distribution on Linux is
\documentclass[12pt]{article}
\usepackage{amsmath}
%\usepackage{maplestd2e} %not needed for this example
\begin{document}
%output of Physics:-Latex()
%output of maple latex()
{\frac {\int \!{{\rm e}^{-t}}f \left( t \right) \,{\rm d}t{{\rm e}^{t}}}{2}}-{\frac {{{\rm e}^{-t}}\int \!{{\rm e}^{t}}f \left( t \right) \,{\rm d}t}{2}}
\end{document}
Download latex_issue_5.mw
Hello everyone, my computer installed Maple 2016, 2020 and set Maple 2016 as default opening files .mw, .mws. How to change default to Maple 2020 . I tried searching on Google but not found.
Thank you very much.
How to calculate the residual sum of squares of a Nonlinear Fitting?
I tried but was unsuccessful.
First 537 538 539 540 541 542 543 Last Page 539 of 2458
