Here are the inputs and output:
Why is it not possible to simplify the meter and the second (which are units).  If I do "simplify(pmin), the unit MeV becomes J and that is not what I want.  Simply said, is Maplesoft planning to include particle physics where c = h = 1 in the future version of the package "Physics"?
Until that happens, does someone knows how to give the answer in MeV/c.  The preceding problem was asking the mass of a particle in MeV/c^2.
Thank you in advance for your trouble.
Mario Lemelin
Geometry := 2;
if Geometry = 1 then
    f_obj := 4.5;
    f_fluo := 125;
    f_TIE := 45;
    d_sample := f_obj;
    d_max := 250;
    d_cam := f_TIE;
    d_interlens := d_max - d_cam;
if Geometry = 2 then
    f_obj := 4.5;
    f_fluo := 125;
    f_TIE := 45;
    d_sample := 4.6;
    d_max := 250;
                              4.5
                              125
                               45
                              4.6
                              250
                          250 - d_cam
TIE := (((((Distance(d_cam)) . (Lens(f_TIE))) . (Distance(d_interlens))) . (Lens(f_obj))) . (Distance(d_sample))) . (Vector(2, [distance, angle]));
           Vector[column](%id = 18446746239510517390)
d_cam_solved := fsolve(coeff(TIE[1], angle, 1), d_cam, d_cam = 20 .. 100);
Error, `,` unexpected
Hello, if I set d_sample to 4.6 then I get "Error, ',' unexpected when I try to find a solution using fsolve. However if I set it to 4.5 then the fsolve computes no problem and I get a solution. Does somebody know if this means fsolve has no solution or have I made a mistake somewhere else? Thanks
Could please help me what is the problem of the following and how I can plot it
with(LinearAlgebra);
with(plots, implicitplot);
M := Matrix([[sigma + Gamma*ik + 0.5 + 0.5*tanh(c - v) + beta*v, -0.5 + 0.5*tanh(c - v), 0.5*(w - u)*sech^2*(c - v) - beta*u], [-0.5 - 0.5*tanh(c - v), sigma - i*k*Gamma + 0.5 + 0.5*tanh(c - v) + beta*v, 0.5*(u - w)*sech^2*(c - v) - beta*w], [-beta*v, -beta*v, sigma - beta*alpha*(u + w)]]):
Eq := Determinant(M):
alpha := 0.1;
beta := 0.01;
mu := 0.5;
u := 0.5;
v := 1;
Gamma := 0.1;
c := 2;
w := 0.5;
p1r := evalc(Re(Eq)):
p1 := implicitplot(Eq, k = 0 .. 10, sigma = -0.01 .. 0.01);
Error, (in plots/implicitplot) invalid input: the following extra unknowns were found in the input expression: {i, ik}
Hollo everybody,
I want to plot the product u^4*j_{alpha+4}(u)*j_{alpha}(v)??
Or j_{alpha} is the modified Bessel function of the first kind and order alpha.
Best regards
I'm new to Maplesim and Maple. I've modeled a planar slider-crank mechanism in Maplesim and it works.
Now I want to extract the equations of motion (DAE) for further analysis. From 'Template' --> 'Worksheet', I used A:-GetEquations() to try to get the DAE. However, the equations are too long and not shown. Moreover, I don't know what coordinates Maplesim used to generated those 'unseen' equations. Here are the equations that can be hand-derived:
where I and m represent inertia and mass respectively. Theta, beta and s are the chosen generalized coordiantes, s_theta is sin(theta), c_theta is cos(theta)s_beta is sin(beta), c_beta is cos(beta). Rx and Ry are lagrange multipliers representing the reaction force in the pin between the crank and the connecting rod.
How can I generate such DAEs using Maplesim? Thank you very much.
Hello everyone
I am trying to plot some vectors that have both numeric entries and NA. The vectors represent the root of some function depending on certain parameters (NA means that there is no root for these parameters) and I want to represent the value of the root (vertical) vs the vector that store the variable parameter (horizontal) omitting the values that yield NA. Is there a fast way to do that?
Thank you so much in advance
A circle in XOY plane in a 3D axis system
There are two commands :
- spacecurve ( calculus)
- SpaceCurve ( vectorcalculus)
p1 := plots:-spacecurve([x, sqrt(-x^2 + 1), 0], x = -1 .. 1, color = black, thickness = 5);
p2 := plots:-spacecurve([x, -sqrt(-x^2 + 1), 0], x = -1 .. 1, color = black, thickness = 5);
plots:-display(p1, p2, scaling = constrained, labels = [x, y, z]);
spacecurve plot for circle in parametric form sin(t,cos(t) ?
Spacecurve plot for circle  ( coordinatesystem )?
I recently got a question answer regarding drawing a weighted digraph. That got me thinking about more "complicated" networks, i.e., electrical networks. Is it possible to draw the following electrical network in Maple? I know it can be done quite easily in MapleSim, but how about Maple?
When I give symgen a HINT, using functional form f(x),g(x)*y it does not generate the infinitesimals of the Lie group for this ODE.
But from the answer given using way=abaco1 it is clear they have this form, where f(x)=-1/x and g(x)=1/x^2
From help, it says
HINT=[e1,e2], indicates to the solver that it should take e1 and e2 as the infinitesimals, where e1 and e2 can contain a maximum of two indeterminate functions. The solver tries to determine the infinitesimals to solve the problem.
And I am using only two indeterminate functions. These are f(x) and g(x)
Am I making a mistake somewhere? Please see worksheet below.
interface(version)
Physics:-Version()
`The "Physics Updates" version in the MapleCloud is 801 and is the same as the version installed in this computer, created 2020, September 7, 14:32 hours Pacific Time.`
ode:=diff(y(x),x)=(1-y(x)^2)/(x*y(x))+1;
#why this below do not give result?
DEtools:-symgen(ode,HINT=[f(x),g(x)*y]);
diff(y(x), x) = (1-y(x)^2)/(x*y(x))+1
DEtools:-symgen(ode,way=abaco1);
[_xi = -1/x, _eta = y/x^2]
#it works for this though. May be the two functions
#can  not be both functions of x at same time?
#one function must be function of x and the other of y?
#But help does not say that.
ode :=diff(y(x),x)=(x+cos(exp(-x)*(1+x)+exp(y(x))))/(exp(x+y(x)));
DEtools:-symgen(ode,HINT=[f(x),x*g(y)]);
diff(y(x), x) = (x+cos(exp(-x)*(1+x)+exp(y(x))))/exp(x+y(x))
[_xi = exp(x), _eta = x*exp(-y)]
Download symgen_issue_2.mw
Hi. I recently downloaded Maple 2020 for school and I've run into some issues when trying to use it. I downloaded it for MS-Windows. I got the activation code from my school (it was provided for me for free) and inputed it during set up when I was prompted for the code. After I open Maple and start trying to use it I can't because it doesn't let me edit anything I typed (won't let me use backspace) and when I try to press enter to evaluate something nothing happens. When I try to use anything in the context bar it just freezes the application entirely and won't even let me close it so I have to restart my computer. How do I fix this and actually be able to use Maple?
How can this alteration occur by itself and what is the point of doing so? How do I change it back to $\cup$ and $\cap$?
I use "cat" to concatinate greek letters but the output is not correct.test_cat.mw
restart; with(linalg); QPT := proc (q) local nc, qp, qpp, i, p, pp; nc := vectdim(q); qp := Vector(nc); qpp := Vector(nc); for i to nc do qp[i] := cat(p, q[i]); qpp[i] := cat(pp, q[i]) end do; return qp, qpp end proc
q := convert([alpha, beta], Vector); QPT(q)
q := Vector(2, {(1) = alpha, (2) = beta})
Vector(2, {(1) = palpha, (2) = pbeta}), Vector(2, {(1) = ppalpha, (2) = ppbeta})
Download test_cat.mw
hi
i have expression like
z:=f0(x) + f1(x)*diff(y(x),x) + f2(x)*diff(y(x),x,x) + f4(x)*diff(y(x),x,x,x,x) ... etc ;
always linear terms diff((y(x),x) etc, never like diff((y(x),x)^2
want vector with coeffs of diff((y(x),x) etc in order low to high so want
<f1(x), f2(x), 0, f4(x) ...>
if z:=f0(x) + f2(x)*diff(y(x),x,x) + f4(x)*diff(y(x),x,x,x,x) ... etc ; want <0, f2(x), 0, f4(x) ...>
first term in vector always for diff((y(x),x)
how to do thanks
Dear Community,
I have a four compartment flow model described with the following system of linear ODEs:
diff(L[1](t), t) = L[2](t)/T[21] - L[1](t)/T[12]
diff(L[2](t), t) = L[1](t)/T[12] - L[2](t)/T[21] + L[3](t)/T[32] - L[2](t)/T[23] + Q(t)
diff(L[3](t), t) = L[2](t)/T[23] - L[3](t)/T[32] + L[4](t)/T[43] - L[3](t)/T[34]
diff(L[4](t), t) = L[3](t)/T[34] - L[4](t)/T[43]
(For easier readability I’ve also described the problem in the attached FourCompartmentModelDescription.docx Word file.)
The time constants are as follows:
T12 = 23.1481 d
T21 = 5.4537 d
T23 =  9.752 d
T32 = 14.9007 d
T34 = 8.8235 d
T43 = 363.7255 d
Initial conditions are as follows:
L1(0) = 2500.
L2(0) = 589.
L3(0) = 900.
L4(0) = 37100.
Simulation should run from 0 to 400 d.
Could you pls. help me, to solve it numerically in Maple? As a solution I would need L1(t), L2(t), L3(t) and L4(t) both numerically and graphically. I used Maple to solve ODEs previously, but this time I don’t know, how to correctly specify the problem with an external, tabulated source. I’ve also prepared and attached a Maple worksheet, but did not try to run it yet. (FourCompartments.mw). The external Q(t) source for compartment 2 is attached as Source.xlsx. Should I've forgotten something, pls. let me know.
Your kind help is appreciated in advance,
best regards
Andras
MaplePrimesFourCompartmentModelDescription.docx
FourCompartments.mw
Source.xlsx
I'm trying to put image in my maplet interface.
I use this following code
Label(Image(cat(currentdir(),"\\Image Folder\File name.png")))
The code work as well when i run the code in worksheet. But it doesn't work since i export the worksheet to .maplet file.
Please help. Thank you
First 534 535 536 537 538 539 540 Last Page 536 of 2458
