what is the most elegant way to get coefficients of a series that contains negative powers.
for example in this:
tt := a*N__s^3 + N__s + CSxSx__0 + CSxSx__1/N__s + CSxSx__2/N__s^2 + CSxSx__3/N__s^3;
i would like
fancy_coeff(tt, 1/N__s, 3)
to give me `CSxSx__3`
while
fancy_coeff(tt, 1/N__s, -3)
give me `a`
(the standard coeff call doesn't work with this, as would be known to people here)
thanks!
The black circle below is vanishing at the peak. How do I make the entire  circle visible?
Transparency=0.5 is not a good solution.
A1 := -12; A1 = log*sigma[matrix];
                              -12
                    -12 = log sigma[matrix]
sigma[matrix] := 0.1e-11;
                                -12
                            1 10
A1 := 6; A1 = log*sigma[CNT];
                               6
                       6 = log sigma[CNT]
a := phi;
                              phi
sigma[CNT] = 0.1e7;
                                        6
                       sigma[CNT] = 1 10
eq := log10(sigma[CNT]*a+(1-a)*sigma[matrix]);
             /                     -12       -12    \
           ln\phi sigma[CNT] + 1 10    - 1 10    phi/
                             ln(10)
plot(eq, phi = 0.15e-1 .. 0.21e-1);
Warning, expecting only range variable phi in expression ln(phi*sigma[CNT]+.1e-11-.1e-11*phi)/ln(10) to be plotted but found name sigma[CNT]
How can i solve that please ?
How to find the values of unknown parameters for these equations with initial and  boundary conditions
where Pr=6.2,M=2,nu=0.3,phi=0.05 and lambda=Sc=Ks=1
Could some one help me out to find the exact way to find the values of unknown parameters
I'm trying to generate plots in Maple so that I can export the image and be easily read in a document. I usually use the plots [display] command as I often reuse "subplots". The main problem appears when entering a legend, as it disrupts the proportions and I have to rescale everything manually. In doing so I sometimes get small, hard-to-read images or captions. Is there any way to resize the image and caption other than manually? Even better, is there a way to scale both to a certain image size and to make the caption legible at that size (e.g. image 7 cm wide and font equivalent to 10 pt in Word)?
Thank you so much in advance
A is a 2 x 2 matrix with eigenvalue, eigenvector pairs:
5,<4,1> and 1,<3,4>.
1. Find an invertible matrix M and a diagonal matrix D such that A=MDM^(-1).
M=   Preview                                       D=   Preview
2. For any integer n, find the matrix A^n   as a single matrix (i.e. explicitly entry-by-entry). Use Maple notation for a matrix.
   An=   Preview
(Hint: compose your answer in Maple to make sure your syntax is correct and your answer is what you think it should be.)
Something goes wrong with the DE   : de
Error, unexpected single forward quote
I solved this by converting this : de  to a 2 D Math input
Something must be chanced
in the configuration settings ?
Ch05Sec03Prob19.mw
Let A be an m×n matrix. The image of A  is the set of vectors
im(A)={y:y=Ax for some x∈Rn} ,
which is a vector space.
The dimension of im(A)  is called the rank of A, denoted by rank(A) .
(a)  Find the rank of the matrix
v1:=<-146, -84, 28, -154>
v2:=<-203, 106, 34, -181>
v3:=<-94, -4, 106, -154>
v4:=<-36, 152, -86, 50>
v5:=< 173, 122, -390, 435>
A:=<v1|v2|v3|v4|v5>;
and enter in the box below.
rank(A)=
(b) For the matrix A in (a), select all the statements below which are true.
(1) <97,-8,-49,-66> is in im(A)
(2) <-65,74,10,-52> is in im(A)
(3)im(A) is subspace of R^4
(4) <2,-2,-4,4,-2> is in im(A)
(5) <0,0,0,0> is in im(A)
(6) <0,0,0,0,0> is in im(A)
(7) <-1,-2,1,-2,1> is in im(A)
(8) im(A) is a subspace of R^5
Let A be an m×n matrix. The kernel of A  is the set of vectors
ker(A)={x:Ax=0} ,
The dimension of ker(A)  is called the nullity of A, denoted by nullity(A) .
   (a)  Find the nullity of the matrix
v1:=<136, 40, 124, -94>
v2:=<-74, -54, 150, 99>
v3:=<-104, 68, 196, -134>
v4:=<-38, -142, -108, 280>
v5:=<342, -326, -634, 635>
A:=<v1|v2|v3|v4|v5>
nullity(A)=
 (1)  <71, -37, 44, 73> is in ker(A)
 (2) <-1,1,2,-2,1> is in ker(A)
 (3) <0,0,0,0> is in ker(A)
 (4) <0,0,0,0,0> is in ker(A)
 (5) ker(A) is a subspace of R^5
 (6) ker(A) is a subspace of R^4
 (7) <95,-72,-85,-12> is in ker(A)
 (8) <2,4,-2,4,-2> is in ker(A)
Hi there,
What is the algorithm implemented in Maple's function modp1(('Resultant')(...)?
@Carl Love
@acer
Hi.
This Carl code works
standings_DRAW.mw
Could someone please make my modified code work:
(Case D should be the same as P-Q=0 , when integer score P,Q is entered and P=Q)
standings_SCORE.mw
EDIT: corrected and reuploaded: should have been if P-Q <> 0 rather than P-Q=0. changes in purple.
(ps I don't want a substitution D when P-Q=0)
Dear house
I am new to maple and will really appreciate some assistance in calculating the disease free , endemic equilibrium states and basic reproduction number for my model.
I have been trying for weeks. any asistance will be much appreciated
SCI_HELP.mw
Is there a way to get the generalized Fourier series with respect to an arbitrary orthogonal system (instead of just sin, cos, exp, etc.) using the OrthogonalExpansions package or any other way in Maple?
Could you help me please...
There are lot's of packages and instructions how to expand function to Fourier Series but in 2006, 2010
Please help...
Hello there,
I wonder if there is any method to eliminate the terms ((6.*10^(-11))*I) in this worksheet. Apparently, they came from the limitation of the numerical precision.
M2[transform] := <<2/(sqrt(3)*a),-1/(sqrt(3)*a),-1/(sqrt(3)*a)> | <0, -1/a, 1/a>>;
Matrix(3, 2, {(1, 1) = (2/3)*sqrt(3)/a, (1, 2) = 0, (2, 1) = -(1/3)*sqrt(3)/a, (2, 2) = -1/a, (3, 1) = -(1/3)*sqrt(3)/a, (3, 2) = 1/a})
Iload := <i[T]*exp(-I*Phi[T])|I*i[M]*exp(-I*Phi[M])>;
Vector[row](2, {(1) = i[T]*exp(-I*Phi[T]), (2) = I*i[M]*exp(-I*Phi[M])})
alpha := exp(I*convert(120*degrees, radians));
-1/2+((1/2)*I)*3^(1/2)
ABC2SEQ :=  1/3 * <<1,1,1> | <alpha, alpha^2, 1> | <alpha^2, alpha, 1>>;
Matrix(3, 3, {(1, 1) = 1/3, (1, 2) = -1/6+((1/6)*I)*sqrt(3), (1, 3) = (1/3)*(-1/2+((1/2)*I)*sqrt(3))^2, (2, 1) = 1/3, (2, 2) = (1/3)*(-1/2+((1/2)*I)*sqrt(3))^2, (2, 3) = -1/6+((1/6)*I)*sqrt(3), (3, 1) = 1/3, (3, 2) = 1/3, (3, 3) = 1/3})
Iabc := M2[transform] . (Iload^(%T));
Vector(3, {(1) = (2/3)*sqrt(3)*i[T]*exp(-I*Phi[T])/a, (2) = -(1/3)*sqrt(3)*i[T]*exp(-I*Phi[T])/a-I*i[M]*exp(-I*Phi[M])/a, (3) = -(1/3)*sqrt(3)*i[T]*exp(-I*Phi[T])/a+I*i[M]*exp(-I*Phi[M])/a})
Iabcx := subs[eval]({a=1.0} , Iabc);
Vector(3, {(1) = .6666666667*sqrt(3)*i[T]*exp(-I*Phi[T]), (2) = -.3333333333*sqrt(3)*i[T]*exp(-I*Phi[T])-(1.000000000*I)*i[M]*exp(-I*Phi[M]), (3) = -.3333333333*sqrt(3)*i[T]*exp(-I*Phi[T])+(1.000000000*I)*i[M]*exp(-I*Phi[M])})
Ipnz := ABC2SEQ . Iabcx:
simplify( Ipnz );
Vector(3, {(1) = (.5773502693-0.6000000000e-10*I)*i[T]*exp(-I*Phi[T])+.5773502694*i[M]*exp(-I*Phi[M]), (2) = (.5773502693-0.6000000000e-10*I)*i[T]*exp(-I*Phi[T])-.5773502694*i[M]*exp(-I*Phi[M]), (3) = 0.})
Download Q20200727_2.mw
First 551 552 553 554 555 556 557 Last Page 553 of 2458
