I would like to plot a specific vector with an initial point of <4,3,-5> and a terminal point of <3,-1,4>. I have been searching through Maple Primes and Maple Soft.
M1 := 12.3:
M2 := 12.4:
M3 := 12.5:
R := 50:
EQ:={(diff(F(x), x $ 4)) - M1*diff(G(x),x$2) -2*R*F(x)*diff(F(x),x$3)=0, diff(G(x),x$2)+ M2*(diff(F(x),x$2)-2*G(x)) +M3*(diff(F(x),x)*G(x)-2*F(x)*diff(G(x),x))=0}:
IC:={D(F)(-1)=0, D(F)(1)=0,F(-1)=-1,F(1)=1,G(-1)=0,  G(1)=0}:
sol:= dsolve(EQ union IC,numeric,output=Array([-1,-0.9,-0.8,-0.7,-0.6,-0.5,-0.4,-0.3,-0.2,-0.1,0,0.1,0.2,0.3,0.4,0.5,0.6,0.7,0.8,0.9,1]));
Error, (in dsolve/numeric/bvp) uanble to achieve continuous solution with requested accuracy of 0.1e-5 with maximum 128 point mesh (was able to get 0.47e-5), consider increasing `maxmesh` or using larger `abserr`
plots:-odeplot(sol,[x,F(x)],x=-1..1,color=red,axes=box)
plots:-odeplot(sol,  [x, diff(F(x), x)], x = -1 .. 1, color =  green, axes = box)
plots:-odeplot(sol,[[x,F(x)],[x,diff(F(x),x)],[x,G(x)]],x=-1..1,color=[red,green,blue],axes=box):
plots:-odeplot(sol, [x, G(x)], x = -1 .. 1, color = blue, axes = box);
solve( sum((1/(1+x+x^2))*y^n, n=1..infinity) = 1, parametric=true, real);
How to solve two variables summation equation with parametric true or real triangularize?
how to solve for x and y?
I just wonder how it is possible to store data between sessions. What I found out is that if a matrix is connected with a datatable, the matrix data is stored. If it is not connected with a datatable, it is not.
In the attached example there are 2 matrices. If you run the worksheet, both variables are defined as visible in the variable overview.
After reopening without running the worksheet, just the variable connected with a datatable is.
Any ideas how to also get the second variable stored between sessions (obviously not with the same method as used for a)?
storetable.mw
Download Analisa_Dinamik_Limb_v1_(30).mwAnalisa_Dinamik_Limb_v1_(30).mw
So I have an equation that basically takes the component of vectors to be used as an equation. The variables that I after are FB1z, FB2x, and FB3y For example here is my equation:
EOM1:=(AFB1[1]+AFB2[1]+AFB3[1])=TEOM[1]
EOM2:=(AFB1[2]+AFB2[2]+AFB3[2])=TEOM[2]
EOM3:=(AFB1[3]+AFB2[3]+AFB3[3])-TEOM[3]:
FBBp1:=FBPP1=(EulP1[1]+EulP2[1]+EulP3[1]):
FBBp2:=FBPP2=(EulP1[2]+EulP2[2]+EulP3[2]):
FBBp3:=FBPP3=(EulP1[3]+EulP2[3]+EulP3[3]):
However there are unknown variable in AFB2[1] named FB2x and AFB3[1] named FB3y. Then AFB1[2] has unknown equation named FB1z and AFB3[2] has FB3y and so on. While in my FBBp1,FBBp2,and FBBp3 holds all of the variable of FB1z, FB2x, and FB3x
I have tried to use 'solve' command to find the variable but my computer won't stop processing it:
sls:=solve({EOM1,EOM2,EOM3,FBBp1,FBBp2,FBBp3},{FB1z,FB2x,FB3y}):
I tried to use the Gauss-Elimination by forming a matrix but it doesn't work as well since I am really confused how to take out the variables out of the vector component.
zzz:=Matrix([0,AFB2[1],AFB3[1],jjj[1]],[AFB1[2],0,AFB3[2],jjj[2]],[AFB1[3],AFB2[3],0,jjj[3]],[FBP1[1],FBP2[1],FBP3[1],EulP[1]],[FBP1[2],FBP2[2],FBP3[2],EulP[2]],[FBP1[3],FBP2[3],FBP3[3],EulP[3]]):
GaussElimination:=(zzz)
I would be very grateful If someone could help me. Thankyou
Edit: here are the .txt files and .mpl files that required to run the program
Inverse_Kinematics_ADRIAN2.mw
RotInertiax0_ADRIAN.txt
Download DisplacementXYZ.txt
inersia_platfrom.txt
There is an .mpl file that I couldn't upload so I will upload it in the comments
I have to find the distance between a point and a plot. The point is (2,-3,4) and the plane is x+2y+2z=13. How do I plot this?
i need to find a y(2) and than work with it in a loop
but i cant do it because i solved my equation with "dsolve" and "sol(2)" and its solution is list
really need a help
I am a new user to maple and I have tried to solve a partial differential equation.
The solution is shown in the figure above but I don't know how to make a 3d plot or contour plot of the solution. The code of solving pde is down below:
pde := diff(T(x, y), x $ 2) + diff(T(x, y), y $ 2) = 0;
bc := T(0, y) = T1, T(a, y) = T2, T(x, 0) = T2, k*D[2](T)(x, b) = h*(-T(x, b) + T3);
sol1 := simplify((pdsolve([pde, bc], T(x, y)) assuming (0 < a, 0 < b)));
and the constant value are:  a = 250, b = 4, k = 2.091, T1 = -5, T2 = 0, h = 100, T3 = 1000
the plot range is 0<x<250, 0<y<4.
Thank you for helping me!
From another question I asked, I learned that parse("string") returns an unevaluated Maple expression.
But in interactive mode (in worksheet), the result looks the same as normal evaluated expression. That is why I did not know this. For example
ode1:= :-parse("diff(y(x),x$2)=0");
ode2:= diff(y(x),x$2)=0;
it gives
There is no difference when looking at it.  That is why when I was in Maple debugger, I could not see why Maple was complaining about it. An eval  was needed.
I looked at the types to see if there is something like type(variable,`unevaluated`) or such, and could not find one.
If Maple can at least display unevaluated expression with different color, or different notations when in the worksheet interface,  I would have noticed that parse returns unevaluated expression.
In Mathematica, these things are done using wrappers, (called Hold or Inactive) but these are visible in the notebook and use different color shading or Hold is present and had to expliclity removed,  and so looking at them, one can see the differerence between the expressions.
How can one in Maple distinguish between unevaluated expression such as ode1 above and evaluated one such as ode2 above?  This can be useful to use inside a proc for example.  Is there an option in the GUI itself to tell Maple may be to color each differently?
According to the help manual...
To perform an action when the data table is updated, click the data table, and then, from the Data Table context panel, select Edit Content Changed Code to open the Code Editor dialog for the data table.
I am unable to make this work, nothing happens when I click on that button.
Edit - Component code - shows everything greyed out.
Any hints?
I can't figure why dsolve and odeadvisor fail to process ode when it is parsed from string and only inside a proc, but works ok in global space.
This works OK:
ode  :=  :-parse("diff(y(x),x$2)=0"):
func := :-parse("y(x)"):
dsolve(ode);
DEtools:-odeadvisor(ode,func);
But the same code, when inside a proc, fail
foo:=proc()
  local ode,func;
  local x,y; #adding this did not  help
  ode  :=  :-parse("diff(y(x),x$2)=0");
  func :=  :-parse("y(x)");
  dsolve(ode);
  try
  catch:
     error lastexception;
  end try;
foo()
It seems to have with name scoping, but I do not see what is the problem. :-parse works fine.
How to resolve this? Since I must use :-parse as I am reading the ode as string from database with Maple as string from inside a proc inside a module and the above is just a simple example that shows the problem.
Maple 2020.1 with Physics 724
I know for ordinairy differential equations (ODE) there is a odeadvisor in Maple what shows information about the equation .
What is is possible with a partial differential equations (PDE) package.
Is there a help like for ODE's ?
The following is my code, it is working but when I add third model in pde1 , it is not working .
Note that: u :people move to right,w: move to left,v: infected people and stationary(not move)
please help me to reconize the problem
with(PDEtools);
pde1 := {diff(u(x, t), t) + Gamma*diff(u(x, t), x) = mu(w - u) - 0.5*beta*v*(w - u) - beta*u*v, diff(w(x, t), t) - Gamma*diff(w(x, t), x) = mu(u - w) - 0.5*beta*v*(u - w) - beta*w*v,diff(v(x,t),t)=beta*u*v-alpha*v};
IBC1 := {u(0, t) = 0, u(x, 0) = exp(-200*(x - 0.4)^2), w(1, t) = 0, w(x, 0) = exp(-200*(x - 0.6)^2),v(x,0)=0,v(0,t)=sin(t)};
mu := 0.0009;
Gamma := 10;alpha:=1;beta:=0.1
pds1 := pdsolve(pde1, IBC1, numeric, time = t, range = 0 .. 1, spacestep = 0.001);
[[p__jb = (Typesetting[delayDotProduct](c__a . ((rho*(-1+alpha)*t__a-alpha*t__b)/(t__b*t__a)), t__b, true)*t__a+((c__b+`p__-jb`)*alpha-c__b-t__b-`p__-jb`)*t__a-alpha*t__b*(c__b+`p__-jb`))/((2*alpha-2)*t__a-2*alpha*t__b)]]
I cannot seem to set up this integral correctly:
Gradshteyn 3.529
I think maple should do it.
`assuming`([int(((cosh(a*x)-1)/sinh(b*x))(1/x), x = 0 .. infinity)], [b > abs(a)])
I wonder where I'm going wrong here? Thank you in advance.
First 553 554 555 556 557 558 559 Last Page 555 of 2458
