I have the numeric solution of differential equation and interpolate the data points with a spline of third degree. Is there a way of differentiating the spline as a whole? Differentiating every single polynom seems awkward.
 Help me please.  How can i simulate murmuration in maple.
Hi:
How can I solve the below ODE system in Maple?
sys_ode := diff(F0(zeta), zeta, zeta)-b^2*F0(zeta)+G0(zeta)^2 = 0, diff(G0(zeta), zeta, zeta)-b^2*G0(zeta) = 0, 2*F0(zeta)+diff(H0(zeta), zeta) = 0:
ics := F0(0) = 0, G0(0) = 1, H0(0) = 0, F0(infinity) = 0, G0(infinity) = 0:
Note: b is a constant.
tnx...
Hi everyone:
How can I earn the coefficients with P only in this equation? (No P^2 or P^3).
eq:=p*(diff(F1(zeta), zeta, zeta))-b^2*p*F1(zeta)+2*G0(zeta)*p*G1(zeta)+p^2*G1(zeta)^2-p*H0(zeta)*(diff(F0(zeta), zeta))-H0(zeta)*p^2*(diff(F1(zeta), zeta))-p^2*H1(zeta)*(diff(F0(zeta), zeta))-p^3*H1(zeta)*(diff(F1(zeta), zeta))-p*F0(zeta)^2-2*F0(zeta)*p^2*F1(zeta)-p^3*F1(zeta)^2+p*b^2*F0(zeta)+b^2*p^2*F1(zeta):
tnx...
I would like to enable/disable the Explore(plot(...), parameters=[...]) command according to some boolean value.
First idea (note that ending the previous command by : instead of ; doesn't prevent a figure to be displayed) was to encapsulated this Explore command within a conditional structure:
if T then Explore(...) end if.
But I prefered trying to define my own command by doing something like this:
EXPLORE := proc(TF::boolean)
  if TF then
    Explore(_passed[2..-1])
  end if:
with a call made this way:
EXPLORE(true, 'plot(a*x, x=0..1)', 'parameters=[a=-1.0 .. 1.0]');
wich ended with this error
Error, (in Explore) No parameters to explore
I also tried this without any more success:
  if TF then
    Explore(_passed[1], parameters=_passed[2])
  end if:
EXPLORE(true, 'plot(a*x, x=0..1)', [a=-1.0 .. 1.0]);
I get no more error but this warning and an inactive Explore
Warning, expecting only range variable x in expression a*x to be plotted but found name a
Can you help me to fix this?
ddesys := {diff(x(t), t, t) + 2/25*diff(x(t), t) + 4*x(t) = 1/25*diff(x(t), t, t)*piecewise(t - 6/7 < 0, cos(t - 6/7), x(t - 6/7)) + 2/3*diff(x(t), t)*piecewise(t - 6/7 < 0, cos(t - 6/7), x(t - 6/7)) + 5/2*piecewise(t - 6/7 < 0, cos(t - 6/7), x(t - 6/7)), h(t) = diff(x(t), t, t), x(0) = cos(0), z(t) = diff(x(t), t), D(x)(0) = -sin(0)}
tdsn := dsolve(ddesys, numeric):
plots[odeplot](tdsn, [[t, x(t), color = red]], 0 .. 20, labels = [t, ""]);
I wish to make a simulation of a solution of  Neutral Delayed Differential  Equation (second order) whose initial condition is the history function cos(t) for t <0.
unfortunately Maple considers the history function as a constant and not a function, the simulation I tried to do by Maple is therefore not good.
Could somebody help me please ?
Restart:
pde := diff(w(x, t), x $ 4) + diff(w(x, t), t $ 2)/c^2 = 0;
diff(diff(diff(diff(w(x, t), x), x), x), x)+(diff(diff(w(x, t), t), t))/c^2 = 0
test1 := w(x, t) = W(x)*cos(omega*t); pde1 := expand((eval(pde, test1))/cos(omega*t))
diff(diff(diff(diff(W(x), x), x), x), x)-W(x)*omega^2/c^2 = 0
ode := algsubs(omega^2/c^2 = alpha^4, pde1); sol := dsolve(ode); sol := convert(sol, trig)
-W(x)*alpha^4+diff(diff(diff(diff(W(x), x), x), x), x) = 0
W(x) = _C1*exp(-alpha*x)+_C2*exp(alpha*x)+_C3*sin(alpha*x)+_C4*cos(alpha*x)
W(x) = _C1*(cosh(alpha*x)-sinh(alpha*x))+_C2*(cosh(alpha*x)+sinh(alpha*x))+_C3*sin(alpha*x)+_C4*cos(alpha*x)
L_collection := [indets(sol, specfunc({cos, cosh, sin, sinh}))[]]
[cos(alpha*x), cosh(alpha*x), sin(alpha*x), sinh(alpha*x)]
temp := collect(sol, [sinh, cosh, sin, cos])
W(x) = (-_C1+_C2)*sinh(alpha*x)+(_C1+_C2)*cosh(alpha*x)+_C3*sin(alpha*x)+_C4*cos(alpha*x)
CL := [coeffs(rhs(temp), L_collection)]NULL
[-_C1+_C2, _C1+_C2, _C3, _C4]
R:=[seq(cat(_D,i)=CL[i], i=1..nops(CL))]
[_D1 = -_C1+_C2, _D2 = _C1+_C2, _D3 = _C3, _D4 = _C4]
MX:= subs((rhs=lhs)~(R), temp);
W(x) = _D1*sinh(alpha*x)+_D2*cosh(alpha*x)+_D3*sin(alpha*x)+_D4*cos(alpha*x)
boundary_condition_1 := simplify(rhs(eval(diff(MX, `$`(x, 1)), x = 0))/alpha = 0)
_D1+_D3 = 0
boundary_condition_2 := simplify(rhs(eval(MX, x = 0)) = 0)
_D2+_D4 = 0
boundary_condition_3 := simplify(rhs(eval(diff(MX, `$`(x, 1)), x = L))/alpha = 0)
cosh(alpha*L)*_D1+sinh(alpha*L)*_D2+cos(alpha*L)*_D3-sin(alpha*L)*_D4 = 0
boundary_condition_4 := simplify(rhs(eval(MX, x = L)) = 0)
_D1*sinh(alpha*L)+_D2*cosh(alpha*L)+_D3*sin(alpha*L)+_D4*cos(alpha*L) = 0
boundary_condition_solve := solve([boundary_condition_1, boundary_condition_2, boundary_condition_3, boundary_condition_4]); MX := eval(MX, boundary_condition_solve)
{L = L, _D1 = -_D3, _D2 = -_D4, _D3 = _D3, _D4 = _D4, alpha = 0}, {L = 0, _D1 = -_D3, _D2 = -_D4, _D3 = _D3, _D4 = _D4, alpha = alpha}, {L = L, _D1 = 0, _D2 = 0, _D3 = 0, _D4 = 0, alpha = alpha}
Error, invalid input: eval received ({L = L, _D1 = -_D3, _D2 = -_D4, _D3 = _D3, _D4 = _D4, alpha = 0}, {L = 0, _D1 = -_D3, _D2 = -_D4, _D3 = _D3, _D4 = _D4, alpha = alpha}, {L = L, _D1 = 0, _D2 = 0, _D3 = 0, _D4 = 0, alpha = alpha}), which is not valid for its 2nd argument, eqns
Download Free_Vibration_Euler_Bernouli_Beam_1.mw
I have tried to solve these 4 equations to get the characteristic equation and finally the solution of the PDE.  But it shows some error. Can you please help with this issue?
How to draw an ellipse in a rectangle ? Thank you.
I tried to solve an inequality involving factorials using solve, but I failed. The code is
solve(1/(n+1)!<0.0001,n)
n should be 7.
Maple returns me "Warning, solutions may have been lost" message.
How can I solve an inequality like this using solve?
I worked around this with a for loop testing the value of the expression for every increasing value of n against the criteria. Is there a "magical" keyword that will help with solve?
sqrt(4) gives 2 in CAS systems, since the principal root is returned by default.
Is there an option to have Maple return all roots? Which in this case 2,-2?
I'll explain the context why I need this.
When I solve an ODE, I get a solution that I need to solve for constant of integration C from initial conditions. For an example assume the ODE becomes, after replacing initial condition the following  eq:=4^(1/2) = -2+_C1;
So now when solving for _C1  in maple and then calling simplify, gives one solution which _C1=4 (case root=2) which when replaced back into the general solution gives the particular solution.
But this means the second solution is lost, which is when _C1=0  (case root=-2) which could have been obtained from the non-principal root of 4^(1/2)
eq:=4^(1/2) = -2+_C;
solve(eq,_C);
gives
And I would like to get {4,0} instead.
In practice, this becomes important.
Here is an actual ODE, which should have 2 solutions. Mathematica gives both solutions, and Maple gives one solution.  This is due to the above.
ode:=diff(y(x),x)-y(x)=x*y(x)^(1/2);
ic:=y(0)=4;
dsolve([ode,ic])
In Mathematica
ode=y'[x]-y[x]==x*y[x]^(1/2);
ic={y[0]==4};
sol=DSolve[{ode,ic},y[x],x]
The second solution above came from when constant of integration is zero. The first solution is the one Maple  gave (when expanded).
When I worked the solution by hand, I tracked this to issue with sqrt(4) giving 2 and not +2,-2 when doing solve() to solve for C at the end.
I could ofcourse leave C=sqrt(4)  and not call simplify  on it  and that works.
But I thought to ask here to see if there is some option in Maple, so that when it sees (n)^m to return all m roots when calling solve() and not just the principal one. Even for m=2.
I looked at root and tried allsolutions=true but they did not help. Looked at solve/details and did not spot something. I tried only few of the options there, as there are so many.
Any suggestions what to try?
Suppose that S={u1,u2,u3,u4}⊂ℝ5  where
u1=<
u2=< -163, 171, 218, -92>
u3=< -287, 73, -284, -115>
u4=<-32, 172, 206, -180>
v=< 761, -1381, 7566, 3492>
The vector v  is in the span of S  written in the form
αu1+βu2+γu3+δu4 .
Find a possible set of values for α, β, γ, δ.  Enter the values of α, β, γ, δ  as a sequence in the box below
Suppose that
u1=<388, -635, -480, 554, -288, 732, -118>
u2=< -987, 789, 487, -919, 248, 994, -807>
u3=-316, -470, -522, -769, -159, 629, 806>
u4=<381, 740, -834, 722, -46, 49, 795>
Suppose that Av=(b1  b2  ⋯  b7)^T .
       Enter the value of b1  in the box below.
Can anyone help with this question with a step by step solution. TIA.
I am trying to use this command
plot({0, 2*x^2, 2*x^2 - 2*x^3 + 8/3*x^4 - 4*x^5}, x = -10 .. 10, color = ["DarkGreen", "CornflowerBlue", "Burgundy"])
However, only the last function is showing up. 0 and 2x^2 is not showing up. I can't change the axes sizes because then the last function disappears.
I would like to plot results that combine numerical solutions from odes with polynomials (from a collocation procedure). Here is the part of the worksheet:
What is the best way to plot the approximate solutions here?
Suppose that S={p1, p2, p3, p4},  where
              p1(x)=  71+73x−153x2−259x3−108x4+245x5,
              p2(x)=  37+189x+287x2−167x3+279x4−51x5,
              p3(x)=  -199−200x−62x2+59x3+262x4−70x5,
              p4(x)= 48+295x+18x2+235x3+209x4+279x5,  and
                p(x)= 6143+20711x+8974x2−30368x3+18964x4+17937x5.
To avoid typing errors, you can copy and past the following sequences to your Maple worksheet.
The polynomial p  is a linear combination of S  written in the form
αp1+βp2+γp3+δp4 .
[α,β,γ,δ]=
CAN ANYONE HELP ME WITH THIS QUESTION WITH A STEP BY STEP SOLUTION. TIA.
First 565 566 567 568 569 570 571 Last Page 567 of 2458
