Theoretically, if the multiplication sign  is missed Maple needs to give reminders or warnings.But the following is not the case, why?I am surprised its output.
x:=1
                             x := 1
x(2+1)Actually, I want to enter x*(2+1)
x(sin(y))Actually, I want to enter x*(sin(y))
I am a little confused by why this error occurs in the second line and not the first, as well as the weird details specified in it. I don't know if the commands that are being called are inbuilt or not, but it is a safe bet that they will be. thankyou.
MAX := max({[seq(seq(n-(n^k-floor(n^(1/k))^(k-1)*igcd(floor(ithprime(n)^k/n^k), floor(n^(1/k))))^(1/k), n = 2 .. 100), k = 2 .. 100)][]}):
seq(seq(piecewise(radnormal(n-(n^k-floor(n^(1/k))^(k-1)*igcd(floor(ithprime(n)^k/n^k), floor(n^(1/k))))^(1/k)) = MAX, [n, k], NULL), n = 2 .. 100), k = 2 .. 100)
Error, (in radnormal/rational/nthpower) cannot determine if this expression is true or false: iroot(646162507019111437893207695980096110233782566593779/(_c27_37*_c25_38), [_c25_38, 1]) < 0
Download ASKMAPLE000.mw
In preparing to sample problems, I came across this difference in an output depending upon the input type: 2d Input vs. Maple Input. Is there a typo on my part?
restart; kernelopts(version); Digits
`Maple 2020.1, X86 64 WINDOWS, Jun 10 2020, Build ID 1474787`
10
Very happy with the output of the following line:
x := evalf[30](3.0^1.2)
3.73719281884655197790004100992
But I'm confused about the output of the next line. Is it a limit to the calculation or a display problem?
a := evalf[30](3.0^(1.2))
3.737192819
and yet this next output looks fine:
b := evalf[30]( exp( 1.2 * ln(3)))
3.73719281884655197790004100989
Fortunately, there appears to be no difference between x and b:
evalf[30](x-b)
0.3e-28
But these next  lines suggest there is an actual limit in the calculation of a.
evalf[30](a-b)
0.15344802209995899011e-9
evalf[30](a - b);
Note - when Digits is set to 30, the calculation difference between x and a disappears.
Download 2020_evalf_digits.mw
How do I solve numerically this set of equations with the following ICs to plot U1(x), phi(x),diff(phi(x),x) versus x:
diff(U1(x),x)=-diff(phi(x),x)/(U1(x)-T/U1(x));
diff(phi(x),x$2)=(1+A1*phi(x)+A2*phi(x)**(3/2)+A3*phi(x)**2)-(M1/U1(x));
where
A1:=(2*k-1)/(2*k-3);
A2:=8*sqrt(2/pi)*(beta-1)*k*Gamma(k)/(3*Gamma(k-0.5)*(2*k-3)**(3/2));
A3:=(4*k**2-1)/(2*(2*k-3)**2);
M1=0.1+sqrt(T+(1/A1));
(Gamma is gamma function)
assume, for example, T=0.1, pi=3.14, beta=0.6, k=3.5
ICs:
U1(x=0)=M1, phi(x=0)=0, diff(phi(x=0),x)=0.001.
I know we can use Maple LPSolver for linear programming problem (eg. https://www.maplesoft.com/support/help/Maple/view.aspx?path=Optimization/LPSolveMatrixForm), while I am wondering if we can use maple to solve a LP problem symbolically when some of the constants in those examples are unknow parameters.
If no, any suggestions of other solutions?I guess I have to do the simplex method manually? Thanks.
From help, it says
coulditbe routine returns true if there is a possible value of x1 that satisfies prop1
my question is, how to find out this condition/possible values that Maple found?  This infomration is very useful, but now I do not see how to obtain it. All what coulditbe retuirn is true or false.
Context of why I am asking:  Sometimes odetest do not verify its own solutions. And coulditbe can help in finding under what conditions the solution can satisfy the ode. Here is an example
ode:=diff(y(x),x) = abs(y(x))+1;
solExplicit:=dsolve(ode);
offset := odetest~([solExplicit],ode)
gives
[exp(-x)/_C1 - abs((-exp(-x) + _C1)/_C1) - 1, exp(x)*_C1 - abs(exp(x)*_C1 - 1) - 1]
Both solution fail odetest.
coulditbe~(offset,0)
gives true
So there are assumptions/conditions which makes the solution satisfy the ODE. In this case, by inspection one can see what these conditions are. They are, for one solution:
(-exp(-x) + _C1)/_C1  >0
and for the other, the condition is
exp(x)*_C1 - 1 >0
Under these assumptions, odetest would have given 0 for each odetest.
And it is this information I wanted to obtain automatically from coulditbe.
In Mathematica, Reduce is used for this. Reduce gives conditions under which something is satisfied. For example,
Reduce[ C[1] Exp[x] - Abs[C[1] Exp[x] - 1] - 1 == 0, {x, C[1]}, Reals]
Gives
C[1] >= Exp[-x]
While the above in  Maple
coulditbe( C[1]*exp(x)- abs( C[1]*exp(x)-1)-1 = 0)
gives true  only, but without the important information, true under what conditions.
Is there a different command in Maple which could give this information?
Hello, dear forum users!
Does anyone use the method of homotopy analysis (HAM) and the NOPH package in their work. (moderator: link)
It seems to me that only HAM can help.
I ask for help if someone has already mastered.
There are no developments, as I do not own the NOPH package.
Could anyone help me with: How to start a command-line terminal for Maple in Linux Ubuntu? Thanks a lot
Hi there.
I need to calculate multiplcations of huge polynoms with reducing in GF(2^m) with m>1000.
For example, modpol(a*a,f_t,t,2^N) with N=4007, degree(a)=8008 and degree(f_t)=8009.
Standard modpol calculates this in 4-5 sec on my computer.
Maybe there is an easy way to speed up this calculation?
ex.mw
nn.txt
I am new to maplesim and trying to learn it.
While simulation of the battery operated 4 wheeled driven electric vehicle
it tells can't find solution.
Same time if i connect a fixed reference all four wheels are running (same place) but not moving since the frame fixed.
HELP ME TO SOLVE THIS.
thank you..
Hi everyone,
I am trying to integrate this function, however, it did not generate any results. Is there any chance to make this run?
I0 := 1/sqrt(1-C2OverC1*cos(t))^3
1/(1-C2OverC1*cos(t))^(3/2)
`assuming`([int(I0, t = 0 .. 2*Pi)], [C2OverC1 > -1, C2OverC1 < 1])
Download ellipticIntegral.mw
Hello all,
Would you please tell me how to rewrite the expression 'Is_square' like 'Is_square2'?
The way how the first expression is re-written is that both numerator and denominator were divided by 'sigma^2*omega[rK]^2':
One attempt I made was to use 'algsub' command using the subexpression ''sigma^2*omega[rK]'', but somehow it missed the term in the denominator.
Is_square := M[dmax]*(sigma^2*omega[rK]^2 + omega[r]^2)*L[sigma]/(3*p*omega[r]*omega[rK]*L[mu]^2*sigma^2);
(1/3)*M[dmax]*(sigma^2*omega[rK]^2+omega[r]^2)*L[sigma]/(p*omega[r]*omega[rK]*L[mu]^2*sigma^2)
Is_square2 := M[dmax]*(1 + omega[r]^2/(sigma^2*omega[rK]^2))*L[sigma]/(3*p*omega[r]*L[mu]^2/omega[rK]);
(1/3)*M[dmax]*(1+omega[r]^2/(sigma^2*omega[rK]^2))*L[sigma]*omega[rK]/(p*omega[r]*L[mu]^2)
algsubs(omega[rK]*sigma^2=tt, Is_square);
(1/3)*M[dmax]*L[sigma]*(tt*omega[rK]+omega[r]^2)/(p*omega[r]*L[mu]^2*omega[rK]*sigma^2)
Download Qprime_20200621.mw
Suppose I have
with(GraphTheory):
vertices:=["M","P","C"]:
edge_weights:={[{"M","P"},3],[{"M","C"},1]}:
G1:=Graph(vertices,edge_weights)
EigenvectorCentrality(G1)
Is it right to say the EigenvalueCentrality values correspond to the names in the vertices correspondingly?  ie M corresponds to 0.4415.. P corresponds to  0.4188.. and C corresponds to 0.1396... ?
sub:=x/C;
expr:=1/2*x*(p^2+a)/p;
And now
subs(p = sub, expr)
But
algsubs(p = sub,expr)
Notice one "p" is still not replaced.
This is very annoying. I looked at help and did not see anything about this. I could have missed it. It looks like it does not replace "p" when it is in denominator:
algsubs(p = x,1/p)
Remains 1/p but
subs(p = x,1/p)
gives 1/x as expected.
May be this is documented somewhere? But why it does this?
This was generated when running some code on Maple 2020.1.
Just wondering if this might indicate some problem internally, or is this something that can happen.
ZZ:=Int(-(a*_a^2+(_a^4*a^2-4*_a*b*y(x))^(1/2))/(a*_a^3+_a*(_a^4*a^2-4*_a*b*y(x))^(1/2)+6*y(x)),_a = _b .. x)+Intat(-2/(a*x^3+x*(a^2*x^4-4*_f*b*x)^(1/2)+6*_f)-Int(2/(_a^4*a^2-4*_a*_f*b)^(1/2)*b*_a/(a*_a^3+_a*(_a^4*a^2-4*_a*_f*b)^(1/2)+6*_f)+(a*_a^2+(_a^4*a^2-4*_a*_f*b)^(1/2))/(a*_a^3+_a*(_a^4*a^2-4*_a*_f*b)^(1/2)+6*_f)^2*(-2*_a^2/(_a^4*a^2-4*_a*_f*b)^(1/2)*b+6),_a = _b .. x),_f = y(x))+_C1 = 0;
timelimit(30,value(ZZ))
Error, (in discont/zero) too many levels of recursion
The problem is that I am not able to trap the error. This does not work
try
timelimit(30,value(ZZ));
catch:
  print("ignore");
end try;
Why can't one catch this error inside try/catch? It means the whole program can not  continue.
Maple 2020.1
Update Jan 9, 2025
This bug is still in Maple 2024.2. Will check again in 5 years. May be someone in Maplesoft will fix it by then.
Int(-(a*_a^2+(_a^4*a^2-4*_a*b*y(x))^(1/2))/(a*_a^3+_a*(_a^4*a^2-4*_a*b*y(x))^(1/2)+6*y(x)), _a = _b .. x)+Intat(-2/(a*x^3+x*(a^2*x^4-4*_f*b*x)^(1/2)+6*_f)-(Int(2*b*_a/((_a^4*a^2-4*_a*_f*b)^(1/2)*(a*_a^3+_a*(_a^4*a^2-4*_a*_f*b)^(1/2)+6*_f))+(a*_a^2+(_a^4*a^2-4*_a*_f*b)^(1/2))*(-2*_a^2*b/(_a^4*a^2-4*_a*_f*b)^(1/2)+6)/(a*_a^3+_a*(_a^4*a^2-4*_a*_f*b)^(1/2)+6*_f)^2, _a = _b .. x)), _f = y(x))+_C1 = 0
Download not_fixed_jan_9_2025.mw
First 568 569 570 571 572 573 574 Last Page 570 of 2458
