 by using its expansion Write the Maple  program.
Type the Maple command string that calculates this expression for the number of n arbitrarily entered from the keyboard.Can you help me please ?
  1. a1 = x and for every n >= 1 ,
write the Maple procedure that calculates the term a100 for x = 2.
 Write the Maple program that finds the differential equation that accepts the solution. (c1, c2, c3 are arbitrary constants.)
After
 > save mytable, "foo.m";
in whitch folder may I find the file "foo.m" ?
I try with the function "search" of Windows 10, but it can't find it.
Thanks for a answer.
Serge
Hello all,
Is there any way to avoid the 'Error, recursive assignment' in the expressions below?
The 's' at the LHS of ':=' is different from the 's' in 'omega[s]' or 'omega['s']'.
s NULL:= omega[sl]/omega[s];
s ``:= omega[sl]/omega['s'];
Download Q_20200621.mw
I try to figure out how to add »kr« as a currency symbol, and as currency in the Numeric Formatting list.
Can it be done?
Kind regards
I hvae Maple 2020 installed on Linux Ubuntu, and there is a foler maple2020. Could anyone help me with, where is the user initialization file,  .mapleinit, in Maple Linux, or how to creat an  .mapleinit file?
Many Thanks.
This works
patmatch(3*g(x),A::nonunit(algebraic)*B::function,'la');
la
[A = 3, B = g(x)]
But this fails
patmatch(3*g(x),conditional(A::nonunit(algebraic)*B::function, true ),'la');
Error, (in PatternMatching:-AlgStruct:-Match) improper op or subscript selector
I am not able to see why. In the above I used true for the condition, just to keep things simple. Any boolean valued expression will work.
changing the above to
patmatch(3*g(x),conditional(A::anything*B::function, true ),'la');
it works. No error. [A = 3, B = g(x)]
What did I do wrong in the above syntax which generated the error?
Maple 2020.1
Please, l need assistance on maplesoft activation code
How can I determine an expression is of the form a*b where a is anything but a function of t, and b a function of t?
I thought I could do this using patmatch but I can't make it work correctly.
For instance I would like patmatch (or something else) to return [a=C, f=F] when called this way patmatch(C*F(t), ?)
I'm trying to arrange the constant terms of W(x). Like sinh (alpha*x) *(C2-C1).....and by defining C2-C1= D2 I want to rearrange the equation. Without this step, I'm not able to solve the equation further. I have also tried a few steps but it's not working.
When I type "with(combinat)" in Maple Linux, I got the following erros message:
"Error, invalid input: with expects its 1st argument, pname, to be of type {`module`, package}, but received combinat"
So how to make it work?
Many thanks.
Could anyone show me the exact command lines or exact steps to install the FGb package, specifically FGb-1.68.x86_64_linux.tar.gz here, to Maple 2020 in Linux Ubuntu? Many thanks.
FYI, here is one of the error messages I got:
"mv <14539>/*.so <~/maple2020>
bash: syntax error near unexpected token `14539'"
1.1 * 10^2
but export text become two lines
1.1 *   10
pretty printing = 3
but still two lines
how to export in one line such as 10^2 ?
First 569 570 571 572 573 574 575 Last Page 571 of 2458
