I didn't use Maple before, I want to use it in this problem
How to get the displacement equation of the longitudinal vibration of rod (bar) when the boundary and initial conditions are
Dear Maple Users @acer @Carl Love @Kitonum @Preben Alsholm ,
Greetings.
How to plot a function "Am" for various values of "kt"(eg: kt=-1..1) at a point x=0.
Am vs kt.
The code has provided below.
Waiting for your response.
ktplot.mw
Hallo;
the following MAPLE code generates 2-vectors. To collect them into a set K unfortunately does not work. K contains vectors two-fold etc. So K is not a set which I hoped to get. What is wrong?
restart:m:=5;#m Module
with(LinearAlgebra[Modular]):
K:={};
M:=Matrix([[3, 4*168], [4,3]]);
L:=Matrix([[3],[4]]);
#with(LinearAlgebra[Modular]):
for s from 0 to 10 do
a:=Mod(m,(M^s).L,integer);
K:=K union {a};
K:=K;
Gerd
Hi experts
#epsilon:=5*Pi/2:
gammaa:=0.4:
gammao:=0.1:
gammab:=0.002:
omegab:=100:
X:=60:
Omega:=6*Pi:
g:=10:
sigmag:=5*gammaa:
a:=1/(sigmag*sqrt(2*Pi)):
#deltao:=1:
D7:=evalf(a*int(g*Omega*(gammao/2-I*Delta)*exp(-0.5*((Delta-deltao)/sigmag)^2)/(gammao^2/4+Delta^2),Delta=-infinity..infinity)):
D8:=evalf(0.5*a*int(g^2*gammao*exp(-0.5*((Delta-deltao)/sigmag)^2)/(gammao^2/4+Delta^2), Delta=-infinity..infinity)):
D9:=evalf(a*int(g^2*Delta*exp(-0.5*((Delta-deltao)/sigmag)^2)/(gammao^2/4+Delta^2), Delta=-infinity..infinity)):
b1 := (deltao-2*X^2*omegab*Y/(gammab^2+omegab^2)-D9)^2:
 f:=Y*((gammaa+D8)^2+(b1))=Im(D7)^2+(epsilon-Re(D7))^2:
#P1:=implicitplot(f,deltao=-70..50,Y=0..1,numpoints=100,axes=boxed,thickness=2,color=black,font=[1,1,20],tickmarks=[4, 3],linestyle=1);
implicitplot3d(f,Y = 0 .. 1,deltao=-40..40,epsilon=0..0.4,numpoints=100,labels=[Y,deltao,E],tickmarks=[3,3,3], style = surface, color = "Niagara Azure");
The above code to plot the implicitplot3d ,
first the figures are not smooth
second thing is how to make contourplot at epsilon= 5*Pi/2.
I appreciated any comments
i wanna solve a system of equations using ''fsolve'', I have found this example:
fsolve({2*x-x*y=0,-y+3*x*y=0},{x,y}, {x=0.1..5,y=0..4});
but i wanna understand how does this work,and what is the signification of term
thank you for your help.
This exact value of this serie must be calculated with help of a integral and another serie (Maclaurin)
Note: there is Taylor serie and Maclarin is a special case of this Taylor serie.
The serie is also numerical in Maple calculated , to get a idea of the exact value
foroum_vraag_3_inleiding.mw
I enclosed some book taks pdf about alternating series /infinite series and products
to get a idea what is asked for
blz_62.pdf
blz_63.pdf
blz64.pdf
blz66.pdf
blz_67.pdf
blz68.pdf
Let say the procedure MyProc returns two variables as
A,B:= MyProc(…);
However, for programming purpose, I do not want to create an unused variable. Assuming one only needs B, not A, is there a way not to create and assign A?
For information, in Matlab, it is a commonly used technique. The syntax is
[~,B]= MyProc(…);
In Maple, the meaning of ~ is different, but I am looking for something similar.
 Today I read the  Problem 5.21 from book Maple and Mathematica, A Problem Solving Approach for Mathematics:
The book uses following codes:
with(LinearAlgebra): n:=9; v:=Vector(n); T:=v->add(v[i]*x^(i-1),i=1..n); P:=Vector(n,symbol=p); Q:=Vector(n,symbol=q); Z1:=T(a*P+b*Q); Z2:=a*T(P)+b*T(Q);
expand(T(a*P+b*Q)-(a*T(P)+b*T(Q)));
evalb(expand(Z1)=expand(Z2));
But I think  these codes just verify rather than prove(n is always specific number). This example is not difficult to prove by hand. but I'd like to know Maple how to prove it. It seems not easy.
Write a Maple command to define the function f that is given by
f(x)=x^5+2*x^3+3 .
In the box below, enter the part of your Maple command that is to the right of the ":=".
(Do not include the semi-colon (";") at the end.)
The answer I typed in is x^5 + 2*x^3 + 3 but it is wrong. Can someone help me what am I missing.
How to plot polygon between solutions of Complex equation
ComplexQuestion.mw
Is it possible to connect Maple to
altibase
I am trying to use task programming but getting incorrect results and taking more time when using a single core.  Please help
TASK_PARALLEL3.mw
I would have a question about how to colour a region of complicated inequalities.
I'm curious about the region where my 'lambdas' are all negatives regarding the parameters 'pm2' and 'am2', but I always find difficulties even if I try with implicitplot or inequal commands. Also, I would like to put into the same graph with different colours when they are separately smaller than 0.
I've already tried plenty of things, I hopefully attached some pics by snipping tool about them.  And here is an example of my problem:
p61w:= implicitplot([lambda61 <= 0], pm2 = 0 .. 1, am2 = 0 .. 1)
in61 := inequal(lambda61 <= 0, pm2 = 0 .. 1, am2 = 0 .. 1)
display(in61,p61w)
So, the main issue that it is not just coloured where my condition is true, but elsewhere too. In plot 'in61' as you can see, there is a region approx. pm2=0..0.6 where it shouldn't be coloured since my condition is not true there. In the graph; 'display(in61, p61w)',  it is visible that under the red line should be just coloured however my 'inequal' command coloured it outside too.
Also, I tried with implicitplot, for example:
p6 := implicitplot([lambda61 <= 0], pm2 = 0 .. 1, am2 = 0 .. 1, filled = true, coloring = [blue, white], transparency = .5)
But the result is similarly wrong. And I'm not sure why it happens and how can I fix it.
(It's okay if for example for these particular lambdas (lambda61,lambda62) never negatives together, but I have more systems and I don't think it works properly)
I read similar questions too but I couldn't find an answer so, I would very appreciate any suggestions.
This is my first post in Maple, so please let me know if I have mistaken something.
Suppose I have an expression or a defined function that uses basic operations(typical stuff)... I have to go and add % to every operation to prevent it expanding so I can see the expression in detail. This really dirties up the formula.
Is there any way to automate this?
E.g., simple example
f := x->3%*x %+ x%^4;
Also %^ seems to have invalid order of operations, this seems like a bug in maple? 2%^x does not behave like 2^x in complex expressions, I have to put parathesis around it to avoid it grouping with other terms. It seems to do this with multiplication too. This then requires using tons of paranethesis to get normal expressions to behave correctly.
What would be real cool if one could automate all this and also have some way to control the expansion amount. E.g., some parameter than one can set to control from no expansion to full expansion(it would work by making inner most expressions inert then working to outer).
Also, it seems when I use the inert operators and make sure the precendence is correct maple evaluates the wrong value! I have used inert before and it seemed right but now I get very large values. There is something seriously buggy with %op.
If I type a differential equation in Maple software, I am getting a numerical value as in the below image. Can anybody help me to rectify the error? Thanks in advance.
First 573 574 575 576 577 578 579 Last Page 575 of 2458
