I want to creat a two dimisional plot of a circle.   Every time I try it gives me a parabola.
I am trying a multistart local search over a multimodal function. I need to locate around 700 local minima where the dimension of the function is very high. It will be really helpful if the computational time can be reduced. Thank you.
opt.mw
I must program exc set 3 task 2(i) and 2(ii)
Perhaps too much asked here on the mapleprime forum to come up with the solutions for this programming task ?
I did already some investigation how the code roughly works
Its a graphical programming task to let show the tread-riser outlines for a right -hand rule and mid-pointrule in a graph
exc_set_3_task_1_a_b.mw
blz_61_exc_set_3.pdf
blz_62.pdf
This is my code:
NEUZMinus:= proc(Unten, Oben, f,G,Liste,n)::real;
  #Unten:= Untere Intervallgrenze; Oben:= Obere Intervallgrenze; f:= zu integrierende Funktion;
  #G:= Gewicht; n:= Hinzuzufügende Knoten;
  local i;
  with(LinearAlgebra);
  with(ListTools);
  Basenwechsel:=proc(Dividend, m);
  print(Anfang,Dividend,p[m]);
  Koeffizient:=quo(Dividend, p[m],x);
  Rest:=rem(Dividend, p[m],x);
  if m=0 then
    Basenwechsel:=[Koeffizient];
    Basenwechsel:=[Koeffizient,op(Basenwechsel(Rest,m-1))];
p[-1]:=0;
p[0]:=1;
for i from 1 to (numelems(Liste)+n)*2 do
  p[i]:=(x^i-add(int(x^i*p[j]*diff(G,x),x=Unten..Oben)*p[j]/int(p[j]^2*diff(G,x),x=Unten..Oben),j=0..i-1));
  print(p[i]);
c[i-1]:=coeff(p[i],x,i)/coeff(p[i-1],x,i-1);
d[i-1]:=(coeff(p[i],x,(i-1))-coeff(p[i-1],x,(i-2)))/coeff(p[i-1],x,(i-1));
if i <> 1 then
  e[i-1]:=coeff(p[i]-(c[i-1]*x+d[i-1])*p[i-1],x,i-2)/coeff(p[i-2],x,i-2);
  e[i-1]:=0;
print(Liste[1],numelems(Liste));
Hn:=mul(x-Liste[i],i=1..numelems(Liste));
print(Hn);
 Koeffizienten:=Reverse(Basenwechsel(Hn,n)); #!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
print(Koeffizienten,HIER);
print(c,d,e);
a[0][0]:=1;
a[1][0]:=x;
a[1][1]:=-e[1]*c[0]/c[1]+(d[0]-d[1]*c[0]/c[1])*x+c[0]/c[1]*x^2;
for s from 2 to numelems(Liste)+n do
  a[s][0]:=x^s;
  a[s][1]:=-e[s]*c[0]/c[s]*x^(s-1)+(d[0]-d[s]*c[0]/c[s])*x^s+c[0]/c[s]*x^(s+1);
    print (coeff(a[s][1],x,s),as1s);
  for j from 2 to s do
      print(c[j-1]*sum(coeff(a[s][j-1],x,k-1)/c[k-1]*x^k,k=abs(s-j)+2..s+j));  print(sum((d[j-1]-c[j-1]*d[k]/c[k])*coeff(a[s][j-1],x,k)*x^k,k=abs(s-j)+1..s+j-1));  print(c[j-1]*sum(e[k+1]*coeff(a[s][j-1],x,k+1)/c[k+1]*x^k,k=abs(s-j)..s+j-2));print(e[j-1]*sum(coeff(a[s][j-2],x,k)*x^k,k=s-j+2..s+j-2));
     a[s][j]:=c[j-1]*sum(coeff(a[s][j-1],x,k-1)/c[k-1]*x^k,k=abs(s-j)+2..s+j)+sum((d[j-1]-c[j-1]*d[k]/c[k])*coeff(a[s][j-1],x,k)*x^k,k=abs(s-j)+1..s+j-1)-c[j-1]*sum(e[k+1]*coeff(a[s][j-1],x,k+1)/c[k+1]*x^k,k=abs(s-j)..s+j-2)+e[j-1]*sum(coeff(a[s][j-2],x,k)*x^k,k=abs(s-j)+2..s+j-2);
for s from 0 to numelems(Liste)-1 do
  for j from 0 to s do
    print(a[s][j], Polynom[s][j]);
M:=Matrix(n,n);
V:=Vector(n);
  for s from 0 to n-1 do
      M(s+1,j+1):=sum(coeff(a[s][j],x,k)*Koeffizienten[k+1],k=0..n);
      if s<>j then
        M(j+1,s+1):=M(s+1,j+1);
      print(M,1);
    print(testb1);print(coeff(a[n][s],x,2));print(Koeffizienten[3]);print(testb2);
    V(s+1):=-sum(coeff(a[n][s],x,k)*Koeffizienten[k+1],k=0..n);
    print(M,V);
print(M,V);
K:=LinearSolve(M,V);
K(n+1):=1;
print(K);
print(test2,coeff(a[max(3,2)][min(1,2)],x,2));
for l from 0 to n do
  for m from 0 to numelems(Liste)do
    print(Koeffizienten[m+1]*coeff(a[7][l],x,m),a[7][l],m,Koeff,Koeffizienten[m+1])
  print(K(l+1)*add(Koeffizienten[m+1]*coeff(a[max(k,l)][min(k,l)],x,m),m=0..numelems(Liste)));
    nNeu:=add(p[k]*add(K(l+1)*add(Koeffizienten[m+1]*coeff(a[max(k,l)][min(k,l)],x,m),m=0..numelems(Liste)),l=0..n),k=numelems(Liste)..numelems(Liste)+n);
fsolve(nNeu);
Em:=add(p[i]*K[i+1],i=0..n);
Hnm:=Hn*Em;
KnotenHnm:=fsolve(Hnm);
print(Hn,alt,Em,neu,Hnm);
print(Testergebnis,nNeu);
print(fsolve(Hnm),fsolve(nNeu));
KoeffizientenHnm:=Reverse(Basenwechsel(Hnm,n+numelems(Liste)));  #!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
print(KoeffizientenHnm);
h0:=int(diff(G,x),x=Unten..Oben);
b[n+numelems(Liste)+2]:=0;
b[n+numelems(Liste)+1]:=0;
  for i from 1 to n+numelems(Liste) do
    for j from n+numelems(Liste) by -1 to 1 do
      print(test21);
      b[j]:=KoeffizientenHnm[j]+(d[j]+KnotenHnm[i]*c[j])*b[j+1]+e[j+1]*b[j+2];
  print(test22);
    print(test23);
    gxi:=quo(Hnm,x-KnotenHnm[i],x);
   print(test24);
    Gewichte[i]:=c[1]*b[2]*h0/gxi(i);
    Delta[i]:=c[1]*b[2];
print(KnotenHnm);
print(Gewichte);
sum(Knoten[k]*Gewichte[k],k=1..n+numelems(Liste));
end proc
With the first use of the subprocedure Basenwechsel, everything works fine. With the input
NEUZMinus(-1,1,x,x,[-sqrt(3/5),0,sqrt(3/5)],4)
I get the result [0,0,0,1,0] correctly.
The following time I use it, the polynomial is different, and m is 7 in that case, so the list should have 8 entries, it just returns the same [0,0,0,1,0] again, however. Changing the polynomial in the first application to say 5*Hn results in [0,0,0,5,0] in both cases again. The procedure seems to have saved the old values and never overwrites them. How can I fix this? I have highlighted the use of the procedure with exclamation marks.
Thank you in advance!
P.S.: The lengthy result is this:
                               x
                              2   1
                             x  - -
                             3   3
                            x  - - x
                                 5
                          4   3    6  2
                         x  + -- - - x
                              35   7
                        5   5      10  3
                       x  + -- x - -- x
                            21     9
                     6    5    5   2   15  4
                    x  - --- + -- x  - -- x
                         231   11      11
                   7   35      105  3   21  5
                  x  - --- x + --- x  - -- x
                       429     143      13
                8    7     28   2   14  4   28  6
               x  + ---- - --- x  + -- x  - -- x
                    1287   143      13      15
              9    63      84   3   126  5   36  7
             x  + ---- x - --- x  + --- x  - -- x
                  2431     221      85       17
         10    63     315   2   210  4   630  6   45  8
        x   - ----- + ---- x  - --- x  + --- x  - -- x
              46189   4199      323      323      19
         11    33      55   3   330  5   330  7   55  9
        x   - ---- x + --- x  - --- x  + --- x  - -- x
              4199     323      323      133      21
    12    33     198   2   2475  4   660  6   495  8   66  10
   x   + ----- - ---- x  + ---- x  - --- x  + --- x  - -- x
         96577   7429      7429      437      161      23
 13    429       2574   3   1287  5   1716  7   429  9   78  11
x   + ------ x - ----- x  + ---- x  - ---- x  + --- x  - -- x
      185725     37145      2185      805       115      25
     14     143      1001   2   1001  4   1001  6   1001  8
    x   - ------- + ------ x  - ---- x  + ---- x  - ---- x
          1671525   111435      6555      1035      345
         1001  10   91  12
       + ---- x   - -- x
         225        27
                           1   (1/2)
                         - - 15     , 3
                           5
               /    1   (1/2)\   /    1   (1/2)\
               |x + - 15     | x |x - - 15     |
               \    5        /   \    5        /
           /    1   (1/2)\   /    1   (1/2)\   4   3    6  2
   Anfang, |x + - 15     | x |x - - 15     |, x  + -- - - x
           \    5        /   \    5        /       35   7
                            3   3     3   3
                   Anfang, x  - - x, x  - - x
                                5         5
                                   2   1
                       Anfang, 0, x  - -
                          Anfang, 0, x
                          Anfang, 0, 1
                     [0, 0, 0, 1, 0], HIER #!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
                            c, d, e
                            0, as1s
                            0, as1s
                            0, as1s
                            0, as1s
                            0, as1s
                            0, as1s
                           4   2    4
                           -- x  + x
                           15
                          - -- - -- x
                            45   35
                               1  2
                             - - x
                           9   3    5
                           -- x  + x
                           35
                        - --- x - -- x
                          175     63
                               1  3
                             - - x
                      12   2   8   4    6
                      --- x  + -- x  + x
                      175      45
                        4     8   2   25  4
                     - --- - --- x  - -- x
                       175   175      99
                          12   2   4   4
                        - --- x  - -- x
                          175      15
                           16  4    6
                           -- x  + x
                           63
                        - --- x  - -- x
                          245      99
                               1  4
                             - - x
                      16   3   40   5    7
                      --- x  + --- x  + x
                      245      231
                     64       640   3   36   5
                  - ---- x - ----- x  - --- x
                    3675     14553      143
                          64   3   4   5
                        - --- x  - -- x
                          945      15
                  64   2   16   4   72   6    8
                 ---- x  + --- x  + --- x  + x
                 3675      385      455
                64      144   2    40   4   49   6
             - ----- - ----- x  - ---- x  - --- x
               11025   13475      1001      195
                     24   4   9   6   144   2
                   - --- x  - -- x  - ---- x
                     539      35      8575
                           25  5    7
                           -- x  + x
                           99
                       - ---- x  - --- x
                         6237      143
                               1  5
                             - - x
                     400   4   20   6    8
                     ---- x  + --- x  + x
                     6237      117
                    80   2    500   4   49   6
                   4851      11583      195
                          20   4   4   6
                        - --- x  - -- x
                          297      15
                  80   3    40   5   7   7    9
                 ---- x  + ---- x  + -- x  + x
                 4851      1001      45
                64        640   3   28   5   64   7
             - ----- x - ----- x  - --- x  - --- x
               14553     63063      715      255
                     4   5   9   7    80   3
                   - -- x  - -- x  - ---- x
                     91      35      4851
           64    2    640   4   16   6   160   8    10
          ----- x  + ----- x  + --- x  + ---- x  + x
          14553      63063      455      1071
           64      128   2    80   4   224   6   81   8
        - ----- - ----- x  - ---- x  - ---- x  - --- x
          43659   49049      9009      5967      323
               640   4   16   6   16  8    1280   2
            - ----- x  - --- x  - -- x  - ------ x
              63063      405      63      305613
                          36   6    8
                          --- x  + x
                          143
                       - ---- x  - --- x
                         1573      195
                               1  6
                             - - x
                     100   5   28   7    9
                     ---- x  + --- x  + x
                     1573      165
                   1600   3   336   5   64   7
                   99099      7865      255
                          48   5   4   7
                        - --- x  - -- x
                          715      15
                1600   4   28   6   144  8    10
                ----- x  + --- x  + --- x  + x
                99099      715      935
              320   2    140   4   2352   6   81   8
           - ----- x  - ----- x  - ----- x  - --- x
             77077      14157      60775      323
                    12   6   9   8    180   4
                  - --- x  - -- x  - ----- x
                    275      35      11011
           320   3    320   5   32   7   216   9    11
          77077      33033      935      1463
       256        5120    3    1152   5    4608   7   100  9
    - ------ x - ------- x  - ------ x  - ------ x  - --- x
      231231     2081079      133705      124355      399
               64   5   256   7   16  9    25600   3
            - ---- x  - ---- x  - -- x  - ------- x
              6435      6545      63      6243237
   256    2    320    4    1280   6    800   8   100  10    12
  ------ x  + ------ x  + ------ x  + ----- x  + --- x   + x
  231231      127413      153153      24871      693
   256      64    2    32000    4    1120   6    900   8   121  10
- ------ - ----- x  - -------- x  - ------ x  - ----- x  - --- x
  693693   99099      15162147      138567      24871      483
       8000    4    160   6    600   8   25  10    8000    2
    - ------- x  - ----- x  - ----- x  - -- x   - ------- x
      3270267      18513      16093      99       7630623
                          49   7    9
                          --- x  + x
                          195
                       - ---- x  - --- x
                         9295      255
                               1  7
                             - - x
                     588   6   112  8    10
                     ---- x  + --- x  + x
                     9295      663
                   980   4    5488   6   81   8
                - ----- x  - ------ x  - --- x
                  61347      129285      323
                         196   6   4   8
                       - ---- x  - -- x
                         2925      15
               980   5   2352   7   189   9    11
              ----- x  + ----- x  + ---- x  + x
              61347      60775      1235
            2240   3    84672   5    4032   7   100  9
         - ------ x  - ------- x  - ------ x  - --- x
           552123      8690825      104975      399
                     48   7   9   9    756   5
                  - ---- x  - -- x  - ----- x
                    1105      35      46475
         2240   4    896   6    7776   8   40   10    12
        ------ x  + ----- x  + ------ x  + --- x   + x
        552123      94809      230945      273
      64    2    22400   4    127008   6   1080   8   121  10
   - ----- x  - ------- x  - -------- x  - ----- x  - --- x
     61347      9386091      15011425      29393      483
              1792   6    48   8   16  10    2240   4
           - ------ x  - ---- x  - -- x   - ------ x
             182325      1235      63       552123
  64    3    22400   5    1120   7    600   9   385   11    13
 ----- x  + ------- x  + ------ x  + ----- x  + ---- x   + x
 61347      9386091      138567      19019      2691
    256        51200    3    13440   5    2560   7    5500   9
 - ------ x - -------- x  - ------- x  - ------ x  - ------ x
   920205     84474819      6605027      323323      153387
      144  11
    - --- x
      575
      22400   5    4320   7   1000   9   25  11    56000    3
   - ------- x  - ------ x  - ----- x  - -- x   - -------- x
     9386091      508079      27027      99       54660177
  256    2     7168    4    13440   6    80000    8   100   10
 ------ x  + -------- x  + ------- x  + -------- x  + ---- x
 920205      11471889      6605027      10669659      3289
      504   12    14
    + ---- x   + x
      3575
    256       3072    2    112000    4    112000   6    8100    8
- ------- - -------- x  - --------- x  - -------- x  - ------- x
  2760615   19119815      217965891      59445243      1062347
     264   10   169  12
   - ---- x   - --- x
     7475       675
     89600    4    13440   6    21600   8   140   10   36   12
 - --------- x  - ------- x  - ------- x  - ---- x   - --- x
   149134557      6605027      2719717      3887       143
        768    2
    - ------- x
      2924207
                        1, Polynom[0][0]
                        x, Polynom[1][0]
                     1    2
                     - + x , Polynom[1][1]
                       x , Polynom[2][0]
                    4       3
                    -- x + x , Polynom[2][1]
                    15
                 4   2    4   4
                 -- x  + x  + --, Polynom[2][2]
                 21           45
             Matrix(%id = 18446745693991291350), 1
                             testb1
                             testb2
            Vector[column](%id = 18446745693991291470)
                             testb1
                             testb2
                             testb1
                              16
                              245
                             testb2
                             testb1
                             testb2
           Vector[column](%id = 18446745693991291830)
                                  9
                           test2, --
                                  35
                       0, x , 0, Koeff, 0
                           7
                       0, x , 1, Koeff, 0
                           7
                       0, x , 2, Koeff, 0
                           7
                       0, x , 3, Koeff, 1
                     49   6    8
                  0, --- x  + x , 0, Koeff, 0
                     195
                     49   6    8
                  0, --- x  + x , 1, Koeff, 0
                     195
                     49   6    8
                  0, --- x  + x , 2, Koeff, 0
                     195
                     49   6    8
                  0, --- x  + x , 3, Koeff, 1
                     195
                112  7    9   588   5
             0, --- x  + x  + ---- x , 0, Koeff, 0
                663           9295
                112  7    9   588   5
             0, --- x  + x  + ---- x , 1, Koeff, 0
                663           9295
                112  7    9   588   5
             0, --- x  + x  + ---- x , 2, Koeff, 0
                663           9295
                112  7    9   588   5
             0, --- x  + x  + ---- x , 3, Koeff, 1
                663           9295
         2352   6   189   8    10    980   4
      0, ----- x  + ---- x  + x   + ----- x , 0, Koeff, 0
         60775      1235            61347
      0, ----- x  + ---- x  + x   + ----- x , 1, Koeff, 0
         60775      1235            61347
      0, ----- x  + ---- x  + x   + ----- x , 2, Koeff, 0
         60775      1235            61347
      0, ----- x  + ---- x  + x   + ----- x , 3, Koeff, 1
         60775      1235            61347
    896   5    7776   7   40   9    11    2240   3
0, ----- x  + ------ x  + --- x  + x   + ------ x , 0, Koeff, 0
   94809      230945      273            552123
0, ----- x  + ------ x  + --- x  + x   + ------ x , 1, Koeff, 0
0, ----- x  + ------ x  + --- x  + x   + ------ x , 2, Koeff, 0
   2240    896   5    7776   7   40   9    11    2240   3
  ------, ----- x  + ------ x  + --- x  + x   + ------ x , 3,
  552123  94809      230945      273            552123
    Koeff, 1
/    1   (1/2)\   /    1   (1/2)\       155   10  2    4
|x + - 15     | x |x - - 15     |, alt, --- - -- x  + x , neu,
\    5        /   \    5        /       891   9
  /    1   (1/2)\   /    1   (1/2)\ /155   10  2    4\
  |x + - 15     | x |x - - 15     | |--- - -- x  + x |
  \    5        /   \    5        / \891   9         /
 Testergebnis,
      2459840   5    80254400        188027200   3    2240   7
   - --------- x  - ----------- x + ----------- x  + ------ x
     193795173      44766684963     19185722127      552123
-0.9604912687, -0.7745966692, -0.4342437493, 0., 0.4342437493,
  0.7745966692, 0.9604912687, -1.435338337, -0.8946894490,
  -0.5176357564, 0., 0.5176357564, 0.8946894490, 1.435338337
                        [0, 0, 0, 1, 0] #!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
                             test21
Error, (in NEUZMinus) invalid subscript selector
I want to contnue the simulation from the point (time) that the event accure
how can I do it ?
Hello there,
When I tried to solve a set of equations, represented in a matrix form, Maple complained. After the matrix form was decomposed to row by row and solve was attempted, Maple became happy. I wonder if I can solve the set of equations in a matrix form.
Goal: solve this set of equations in terms of Xl12/Xl23/Xl13
X1 = 0.5 * ( Xl12 + Xl13 - Xl23 )
X2 = 0.5 * ( Xl12 + Xl23 - Xl13 )
X3 = 0.5 * ( Xl13 + Xl23 - Xl12 )
X:=<X1, X2, X3>;
Vector(3, {(1) = X1, (2) = X2, (3) = X3})
Xeq:= X = <1/2*(xl12 + xl13-xl23), 1/2*(xl12 + xl23-xl13), 1/2*(xl13 + xl23-xl12)>;
(Vector(3, {(1) = X1, (2) = X2, (3) = X3})) = (Vector(3, {(1) = (1/2)*xl12+(1/2)*xl13-(1/2)*xl23, (2) = (1/2)*xl12+(1/2)*xl23-(1/2)*xl13, (3) = (1/2)*xl13+(1/2)*xl23-(1/2)*xl12}))
solve(Xeq, {xl12, xl13, xl23});
Error, invalid input: solve expects its 1st argument, eqs, to be of type {`and`, `not`, `or`, algebraic, relation(algebraic), ({list, set})({`and`, `not`, `or`, algebraic, relation(algebraic)})}, but received (Vector(3, {(1) = X1, (2) = X2, (3) = X3})) = (Vector(3, {(1) = (1/2)*xl12+(1/2)*xl13-(1/2)*xl23, (2) = (1/2)*xl12+(1/2)*xl23-(1/2)*xl13, (3) = (1/2)*xl13+(1/2)*xl23-(1/2)*xl12}))
Did not work.
solve({X1=1/2*(xl12 + xl13-xl23), X2=1/2*(xl12 + xl23-xl13), X3=1/2*(xl13 + xl23-xl12)}, {xl12, xl13, xl23});
{xl12 = X1+X2, xl13 = X3+X1, xl23 = X2+X3}
Did work.
Download Q_20200609.mw
I want to shade the function y=x*ln(x) on the domain of (0,1].
It would seem that if a package is loaded at the "top-level" via with() and the worksheet also has a procedure definition which contains a 'uses' statement for the same package (OK, admittedly a bit redundant), the commands from the relevant package actually "go missing".
See the output from test4() in the attached.
I can't believe that this is deliberate, because when trying to 'compartmentalise' code, then a 'uses' statement in a procedure seems like a good idea. To have this fail because the "top-level" worksheet contains a with() statement loading the same package seems perverse.
Please don't post workarounds - I already know several ways to do achieve it. I'm trying to find out if this behaviour is "deliberate" or a "bug". If the latter, it has been around for a long time because I have checked all the way back to Maple 18: every version exhibits the same behaviour
  kernelopts(version);
  test1:= proc(M::Matrix)
               uses LinearAlgebra:
               return MatrixInverse(M):
  test2:= proc(M::Matrix)
               return LinearAlgebra:-MatrixInverse(M):
  test3:= proc(M::Matrix)
  test4:= proc(M::Matrix)
               uses LinearAlgebra:
  test1( Matrix( [[1,2],[3,4]]));
  test2( Matrix( [[1,2],[3,4]]));
  test3( Matrix( [[1,2],[3,4]]));
  test4( Matrix( [[1,2],[3,4]]));
`Maple 2020.0, X86 64 WINDOWS, Mar 4 2020, Build ID 1455132`
Matrix(2, 2, {(1, 1) = -2, (1, 2) = 1, (2, 1) = 3/2, (2, 2) = -1/2})
MatrixInverse(Matrix(%id = 18446744074373391174))
Download usewith.mw
Please everybody, help me to make phaseportrait 3D
f:= (ln(4x-4)/4)-(ln(4x+4)/4)+(arctan(x)/2)
When I do plots([f(x),f(x)-2,f(x)+2]), the graphs don't extend infinitely like I want. They stop just themselves. How get I the plots to extended more? I attached a picture.
it really confused, with generating different sample some times the command fsolve is working and some times don't . is there any other way to solve this system of equations. because I am going to generate 1000 samples and for each sample, I supposed to solve this system.
f[1] := VectorCalculus:-`+`(VectorCalculus:-`+`(VectorCalculus:-`+`(VectorCalculus:-`+`(VectorCalculus:-`*`(VectorCalculus:-`+`(n_x, n_y), 1/theta1), VectorCalculus:-`-`(sum(VectorCalculus:-`*`(VectorCalculus:-`*`(VectorCalculus:-`+`(theta2, -1), x[t]), 1/VectorCalculus:-`+`(VectorCalculus:-`*`(VectorCalculus:-`*`(theta1, theta2), x[t]), 1)), t = 1 .. n_x))), VectorCalculus:-`-`(sum(VectorCalculus:-`*`(VectorCalculus:-`*`(VectorCalculus:-`+`(2, R_x[t]), x[t]), 1/VectorCalculus:-`*`(VectorCalculus:-`+`(VectorCalculus:-`*`(VectorCalculus:-`*`(theta1, theta2), x[t]), 1)^VectorCalculus:-`+`(1, VectorCalculus:-`-`(1/theta2)), VectorCalculus:-`+`(VectorCalculus:-`+`(VectorCalculus:-`+`(VectorCalculus:-`*`(VectorCalculus:-`*`(theta1, theta2), x[t]), 1)^(1/theta2), -1), theta3))), t = 1 .. n_x))), VectorCalculus:-`-`(sum(VectorCalculus:-`*`(VectorCalculus:-`*`(VectorCalculus:-`+`(theta2, -1), y[T]), 1/VectorCalculus:-`+`(VectorCalculus:-`*`(VectorCalculus:-`*`(theta1, theta2), y[T]), 1)), T = 1 .. n_y))), VectorCalculus:-`-`(sum(VectorCalculus:-`*`(VectorCalculus:-`*`(VectorCalculus:-`+`(2, R_y[T]), y[T]), 1/VectorCalculus:-`*`(VectorCalculus:-`+`(VectorCalculus:-`*`(VectorCalculus:-`*`(theta1, theta2), y[T]), 1)^VectorCalculus:-`+`(1, VectorCalculus:-`-`(1/theta2)), VectorCalculus:-`+`(VectorCalculus:-`+`(VectorCalculus:-`+`(VectorCalculus:-`*`(VectorCalculus:-`*`(theta1, theta2), y[T]), 1)^(1/theta2), -1), theta4))), T = 1 .. n_y))):
N_x := 30:
n_x := 30:
R_x := [seq(0, nl = 1 .. 30)];
[0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]
`&lambda;&lambda;` := 5; -1; QQ := 1; -1; `&alpha;&alpha;1` := 2; -1; `&alpha;&alpha;2` := 4
4
W := GenerateUniform(n_x, 0, 1):
fsolve({f[1], f[2], f[3], f[4]}, {theta1 = 0 .. infinity, theta2 = 0 .. infinity, theta3 = .5 .. infinity, theta4 = .5 .. infinity})
Download ask_maple.mw
I just need someone to explain to me why the following occurs:
showstat(rand)
rand := proc(r::{posint, numeric .. numeric}, $)
   1   if nargs = 0 then
   2     RandomTools:-MersenneTwister:-GenerateInteger()
   3     try
   4       if type(r,('numeric') .. ('numeric')) then
   5         if rhs(r) < lhs(r) then
   6           error "invalid range, end points are out of order"
             elif not type(r,('integer') .. ('integer')) then
   7           return () -> RandomTools:-Generate(float(('range') = r,('method') = ('uniform')))
             end if
   8       return RandomTools:-MersenneTwister:-NewGenerator(('range') = r)
         catch :
   9       error
         end try
       end if
end proc
showstat(RandomTools:-MersenneTwister:-GenerateInteger)
RandomTools:-MersenneTwister:-GenerateInteger := proc({range::{integer, integer .. integer} := 1000000000000}, $)
local bits, divisor, offset;
   1   if nargs = 0 then
   2     return MTKernelInterface(4)
   3   if type(range,'integer') then
   4     divisor := range;
   5     offset := 0
   6     if rhs(range) < lhs(range) then
   7       error "illegal range, end points out of order"
   8     if lhs(range) = rhs(range) then
   9       return lhs(range)
  10     offset := lhs(range);
  11     divisor := rhs(range)-offset+1
  12   if divisor = 0 then
  13     return offset
  14   bits := MTKernelInterface(5,divisor);
  15   MTKernelInterface(6,divisor,bits)+offset
end proc
showstat(MTKernelInterface)
Error, (in showstat) procedure name expected
Download rand_showstat.mw
Does maple provide any method for finding the saddle point of a function? Thank you
First 575 576 577 578 579 580 581 Last Page 577 of 2458
