Here is a strange one...
1> /Library/Frameworks/Maple.framework/Versions/2019/bin/maple ; exit;
    |\^/|     Maple 2019 (APPLE UNIVERSAL OSX)
._|\|   |/|_. Copyright (c) Maplesoft, a division of Waterloo Maple Inc. 2019
 \  MAPLE  /  All rights reserved. Maple is a trademark of
 <____ ____>  Waterloo Maple Inc.
      |       Type ? for help.
> version():
 User Interface: 1435526
         Kernel: 1435526
        Library: 1435526
> I0:=(x - 11)^(n)*x/(x^(n + 1));
                                             n
                                     (x - 11)  x
                               I0 := -----------
                                       (n + 1)
                                      x
> I1:=(x - 11)^(n)/(x^(n));
                                              n
                                      (x - 11)
                                I1 := ---------
                                          n
                                         x
> is(I1=I0);
memory used=2.5MB, alloc=40.3MB, time=0.14
> Limit(I0,x=infinity)=limit(I0,x=infinity) assuming n::posint;
                                            n
                                    (x - 11)  x
                          lim       ----------- = infinity
                     x -> infinity    (n + 1)
                                     x
> Limit(I1,x=infinity)=limit(I1,x=infinity) assuming n::posint;
                                                n
                                        (x - 11)
                              lim       --------- = 1
                         x -> infinity      n
                                           x
This was in Maple 2019.2 ... but I had Maple 18 (from 2014) running here, and it does the same thing.
How strange is this: replace 11 by 10 (or less) and the error goes away.
Recently found out about Steiner ellipsoids. This is an ellipsoid inscribed in a tetrahedron, and an ellipsoid described near a tetrahedron. One ellipsoid touches the faces of the tetrahedron in centroids, the other ellipsoid touches the planes in vertices of the tetrahedron, and these planes are parallel to the faces.
steiner_in_ellipsoid.mw
steiner_out_ellipsoid.mw
There is a desire to find out if 4 vertices determine the tetrahedron or not. And it seems Maple answer this question:
restart: with(geom3d):
point(A, 0, 0, 0), point(B, 1, 0, 0), point(C, 0, 0, 1), point(F, 0, 1, 0):
gtetrahedron(T1, [A, B, C, F]):
i := nops(op(0, detail(T1)));
if i = 1 then print("Ok gtetrahedron") else print("No gtetrahedron") end if:
 I want to stop further execution of the program if the tetrahedron is not determine, for example, when point
B = [0,0,0], but I don’t know how to do it.
I have a nested list like this,
Spectrums:=[ [graph1,eigenvalue of the graph1] , [graph2,eigenvalue of the graph2], ... ,[graphN,eigenvalue of the graphN] ]
What is the easiest / efficient way to group the list with respect to second value (eigenvalue)?
rfin := proc(m::integer)
local c, i, flg := 0;
for i from 0 to m do
	local b := i;
	do
		c := b mod 3;
		if (c <> 2) then next else flg := 1;
		b := 1/3*b - 1/3*c;
	until b = 0;
	if evalb(flg = 0) then print(i);
Hello everyone. I've written a procedure that outputs all numbers <= a given user I/P whose ternary representation has no 2.
However, I get an "Error, unterminated loop" message. Can someone please out the mistake(s)?
I am trying to simplify an expression, and leave W in terms of other variables. But unfortunately I can't delete the RootOf, and I can't see the expressions. Could you please help me.
I have an optimization problem. I would like to add a condition to obtain only a positive integer as the solution to the problem
Positive_integer.mw
Update:This bug ONLY occurs when the file title containing Chinese Characters.
The .mw files have already been associated with Maple 2020, but when clicking on any of them, Maple 2020 won't launch as expected and nothing actually will happen.
I have tried to reinstall Maple 2020, but the problem just keep existing.
The Windows version where the bug occurs is Windows 10 version 1909.
Hello everyone I need your help  please, I found a problem with solving an equation to explain this in detail ,here is  the problem how it is posed :
first of all we have N(q)=(exp(q)/sqrt(q))*sqrt(3/2)*D(3*q/2) .     (1)
with: D(3*q/2)=exp(-3*q/2)*integral(t^2)*dt with t varie from 0 to sqrt(3*q/2) this integral is known as Dawson's name     (2)
then we have q=(24/(n-3))*(x*k*m)/t with : t=0.6,n=6,k=1.3, so q=18.66666667*x*m    (3)
finaly we have m = 1/2*[(exp(q)/(q*N(q)))-1-1/q]     (4)
the quetion : is we must  find the expression of m  (4)  as a function of x only .
thank you evryone .
Hi everyone,
In the RandomTools package, the Generate(integer(range = A..B)) function generates a random integer in the range A..B. All integers in that range have the same probability to be generated, that is, 1/nops([seq(A..B)]). However, I would like to specify the probabilities of each integer. How to do so?
Example: range = 1..5. Instead of P(X=j)=1/5 with j =1,2,3,4,5, let's say the probabilities should be as follows:
P(X=1) = 0.2, P(X=2) = 0.5, P(X=3) = P(X=4) = P(X=5) = 0.1
How to generate a random integer between 1 and 5 with these probabilities?
Thank you in advance.
Error, numeric exception: division by zeroprpblem_maple_2.mw
Normalizer := simplify
simplify
asa := (1/1176215040)*(11762150400*Pi^(3/2)*c[2]*c[3]*sqrt(2)*x^(3/2)*cos(x)*FresnelS(sqrt(2)*sqrt(x)/sqrt(Pi))-11762150400*Pi^(3/2)*c[2]*c[3]*sqrt(2)*x^(3/2)*sin(x)*FresnelC(sqrt(2)*sqrt(x)/sqrt(Pi))-289348899840*Pi^(3/2)*c[5]*c[2]*sqrt(2)*x^(3/2)*cos(x)*FresnelS(sqrt(2)*sqrt(x)/sqrt(Pi))+289348899840*Pi^(3/2)*c[5]*c[2]*sqrt(2)*x^(3/2)*sin(x)*FresnelC(sqrt(2)*sqrt(x)/sqrt(Pi))-1176215040*Pi^(3/2)*c[0]*c[1]*sqrt(2)*x^(3/2)*cos(x)*FresnelS(sqrt(2)*sqrt(x)/sqrt(Pi))+1176215040*Pi^(3/2)*c[0]*c[1]*sqrt(2)*x^(3/2)*sin(x)*FresnelC(sqrt(2)*sqrt(x)/sqrt(Pi))-11762150400*Pi^(3/2)*c[3]*c[4]*sqrt(2)*x^(3/2)*cos(x)*FresnelS(sqrt(2)*sqrt(x)/sqrt(Pi))+11762150400*Pi^(3/2)*c[3]*c[4]*sqrt(2)*x^(3/2)*sin(x)*FresnelC(sqrt(2)*sqrt(x)/sqrt(Pi))+289348899840*Pi^(3/2)*c[5]*c[4]*sqrt(2)*x^(3/2)*cos(x)*FresnelS(sqrt(2)*sqrt(x)/sqrt(Pi))-289348899840*Pi^(3/2)*c[5]*c[4]*sqrt(2)*x^(3/2)*sin(x)*FresnelC(sqrt(2)*sqrt(x)/sqrt(Pi))+5881075200*Pi^(3/2)*c[0]*c[3]*sqrt(2)*x^(3/2)*cos(x)*FresnelS(sqrt(2)*sqrt(x)/sqrt(Pi))-5881075200*Pi^(3/2)*c[0]*c[3]*sqrt(2)*x^(3/2)*sin(x)*FresnelC(sqrt(2)*sqrt(x)/sqrt(Pi))-144674449920*Pi^(3/2)*c[5]*c[0]*sqrt(2)*x^(3/2)*cos(x)*FresnelS(sqrt(2)*sqrt(x)/sqrt(Pi))+144674449920*Pi^(3/2)*c[5]*c[0]*sqrt(2)*x^(3/2)*sin(x)*FresnelC(sqrt(2)*sqrt(x)/sqrt(Pi))-2352430080*Pi^(3/2)*c[1]*c[2]*sqrt(2)*x^(3/2)*cos(x)*FresnelS(sqrt(2)*sqrt(x)/sqrt(Pi))+2352430080*Pi^(3/2)*c[1]*c[2]*sqrt(2)*x^(3/2)*sin(x)*FresnelC(sqrt(2)*sqrt(x)/sqrt(Pi))+1176215040*Pi^(3/2)*c[1]*c[2]*sqrt(2)*sqrt(x)*sin(x)*FresnelS(sqrt(2)*sqrt(x)/sqrt(Pi))-1176215040*Pi^(3/2)*c[1]*c[4]*sqrt(2)*sqrt(x)*cos(x)*FresnelC(sqrt(2)*sqrt(x)/sqrt(Pi))-1176215040*Pi^(3/2)*c[1]*c[4]*sqrt(2)*sqrt(x)*sin(x)*FresnelS(sqrt(2)*sqrt(x)/sqrt(Pi))-5881075200*Pi^(3/2)*c[2]*c[3]*sqrt(2)*sqrt(x)*cos(x)*FresnelC(sqrt(2)*sqrt(x)/sqrt(Pi))-5881075200*Pi^(3/2)*c[2]*c[3]*sqrt(2)*sqrt(x)*sin(x)*FresnelS(sqrt(2)*sqrt(x)/sqrt(Pi))+144674449920*Pi^(3/2)*c[5]*c[2]*sqrt(2)*sqrt(x)*cos(x)*FresnelC(sqrt(2)*sqrt(x)/sqrt(Pi))+588107520*Pi^(3/2)*c[0]*c[1]*sqrt(2)*sqrt(x)*cos(x)*FresnelC(sqrt(2)*sqrt(x)/sqrt(Pi))+588107520*Pi^(3/2)*c[0]*c[1]*sqrt(2)*sqrt(x)*sin(x)*FresnelS(sqrt(2)*sqrt(x)/sqrt(Pi))+716931072*c[5]*c[3]*x^12*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+716931072*x^11*c[3]*c[4]*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-1158676480*x^13*c[4]*c[5]*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+716931072*x^13*c[4]*c[5]*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-6273146880*x^11*c[4]*c[5]*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-22224863232*x^11*c[4]*c[5]*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+716931072*c[5]*c[2]*x^11*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+716931072*c[2]*c[4]*x^10*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-6273146880*c[2]*c[4]*x^8*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-1838182301696*c[5]*c[4]*x^9*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+32944912678912*x^7*c[4]*c[5]*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+592633147392*x^7*c[4]*c[5]*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+428356051643520*x^5*c[4]*c[5]*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+716931072*c[4]*c[0]*x^8*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-6273146880*x^6*c[0]*c[4]*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-926941184*c[5]*c[2]*x^11*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+28590342144*c[5]*c[2]*x^9*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-6273146880*c[5]*c[2]*x^9*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-8065474560*c[5]*c[2]*x^9*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-450739634176*c[5]*c[2]*x^7*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+276018462720*c[5]*c[2]*x^7*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+8342470656*c[2]*c[3]*x^7*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+16395272192*c[2]*c[4]*x^8*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-1254629376*c[2]*c[4]*x^8*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+191330979840*c[2]*c[4]*x^6*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-579338240*c[4]*c[0]*x^8*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-225760870400*c[5]*c[1]*x^6*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+8800821839169360*c[5]^2*x^4*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-8800821839169360*c[5]^2*x^4*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-29999084544*c[2]^2*x^4*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+32149877760*c[2]^2*x^4*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+3763888128*c[2]^2*x^6*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+69004615680*x^2*c[4]^2*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+55517349888*c[4]^2*x^8*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-5045766485760*c[4]^2*x^6*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+358465536*c[2]^2*x^8*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-2352430080*Pi*c[1]*c[2]*x+2352430080*Pi*c[1]*c[4]*x+11762150400*Pi*c[2]*c[3]*x-289348899840*Pi*c[5]*c[2]*x-1176215040*Pi*c[0]*c[1]*x-11762150400*Pi*c[3]*c[4]*x+289348899840*Pi*c[5]*c[4]*x+27601846272*x^3*c[1]*c[4]*Pi+27601846272*x^3*c[3]*c[4]*Pi-82805538816*x^3*c[4]*c[5]*Pi+1254629376*x^3*c[0]*c[1]*Pi+1254629376*x^3*c[0]*c[3]*Pi-3763888128*x^3*c[0]*c[5]*Pi+31365734400*x^2*c[0]*c[4]*Pi+3136573440*x^2*c[0]*c[2]*Pi+69004615680*x^2*c[2]*c[4]*Pi+869007360*x^6*c[0]*c[4]*Pi+17647534080*x^7*c[4]*c[5]*Pi+802160640*x^7*c[0]*c[5]*Pi+23658725376*x^4*c[2]*c[4]*Pi+1075396608*x^4*c[0]*c[2]*Pi+955908096*x^5*c[0]*c[3]*Pi-955908096*x^5*c[0]*c[5]*Pi+21029978112*x^5*c[3]*c[4]*Pi-21029978112*x^5*c[4]*c[5]*Pi-6810845184*c[4]^2*x^10*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-405536768*c[3]^2*x^10*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-13830328512000*c[5]^2*x^8*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-8754008440320*c[5]^2*x^8*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+19885785088*c[4]^2*x^10*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+5881075200*Pi^(3/2)*c[3]*c[4]*sqrt(2)*sqrt(x)*cos(x)*FresnelC(sqrt(2)*sqrt(x)/sqrt(Pi))+5881075200*Pi^(3/2)*c[3]*c[4]*sqrt(2)*sqrt(x)*sin(x)*FresnelS(sqrt(2)*sqrt(x)/sqrt(Pi))-144674449920*Pi^(3/2)*c[5]*c[4]*sqrt(2)*sqrt(x)*cos(x)*FresnelC(sqrt(2)*sqrt(x)/sqrt(Pi))-144674449920*Pi^(3/2)*c[5]*c[4]*sqrt(2)*sqrt(x)*sin(x)*FresnelS(sqrt(2)*sqrt(x)/sqrt(Pi))-2940537600*Pi^(3/2)*c[0]*c[3]*sqrt(2)*sqrt(x)*cos(x)*FresnelC(sqrt(2)*sqrt(x)/sqrt(Pi))-2940537600*Pi^(3/2)*c[0]*c[3]*sqrt(2)*sqrt(x)*sin(x)*FresnelS(sqrt(2)*sqrt(x)/sqrt(Pi))+72337224960*Pi^(3/2)*c[5]*c[0]*sqrt(2)*sqrt(x)*cos(x)*FresnelC(sqrt(2)*sqrt(x)/sqrt(Pi))+72337224960*Pi^(3/2)*c[5]*c[0]*sqrt(2)*sqrt(x)*sin(x)*FresnelS(sqrt(2)*sqrt(x)/sqrt(Pi))+1176215040*Pi^(3/2)*c[1]*c[2]*sqrt(2)*sqrt(x)*cos(x)*FresnelC(sqrt(2)*sqrt(x)/sqrt(Pi))+2352430080*Pi^(3/2)*c[1]*c[4]*sqrt(2)*x^(3/2)*cos(x)*FresnelS(sqrt(2)*sqrt(x)/sqrt(Pi))-2352430080*Pi^(3/2)*c[1]*c[4]*sqrt(2)*x^(3/2)*sin(x)*FresnelC(sqrt(2)*sqrt(x)/sqrt(Pi))+228969861120*c[5]*c[1]*x^6*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+356001085440*c[5]*c[3]*x^8*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+716931072*c[1]*c[3]*x^8*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-6273146880*c[1]*c[3]*x^6*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+127344881664*c[5]*c[3]*x^8*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-10565155560960*c[5]*c[3]*x^6*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+26041253888*c[3]*c[4]*x^9*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-411923972096*c[3]*c[4]*x^7*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-60715100160*c[3]*c[4]*x^7*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-5531739333120*c[3]*c[4]*x^5*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+716931072*c[1]*c[4]*x^9*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-6273146880*c[1]*c[4]*x^7*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+1781465088*c[2]^2*x^6*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-289669120*c[2]^2*x^8*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+1337160464640*c[3]^2*x^4*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-87979326507072*c[4]^2*x^4*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+5881075200*Pi*c[0]*c[3]*x-144674449920*Pi*c[5]*c[0]*x-3136573440*c[5]^2*x^12*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-15862099968*c[5]^2*x^12*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-3136573440*c[2]^2*x^6*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+87989363542080*c[4]^2*x^4*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+1185624760320*c[2]*c[3]*x^3*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-6631612416*c[3]*c[4]*x^9*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+263472168960*c[3]*c[4]*x^7*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+473981054976*c[5]*c[4]*x^9*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-17407590520320*c[5]*c[4]*x^7*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+716931072*c[1]*c[2]*x^7*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-6273146880*c[1]*c[2]*x^5*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+3943120896*c[2]*c[3]*x^7*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+120758077440*c[2]*c[3]*x^5*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-55696582656*c[5]*c[2]*x^7*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-6137098007040*c[5]*c[2]*x^5*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+3291740135424*c[5]*c[2]*x^5*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+5231009152512*c[5]*c[2]*x^5*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+70978108481280*c[5]*c[2]*x^3*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-71286747307776*c[5]*c[2]*x^3*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+5185077248*c[1]*c[3]*x^6*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-89392343040*c[1]*c[3]*x^4*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-463470592*c[1]*c[2]*x^7*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+58455228416*c[5]*c[4]*x^11*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-695205888*c[1]*c[4]*x^9*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+11355029504*c[1]*c[4]*x^7*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+358465536*c[1]*c[4]*x^7*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+152123811840*c[1]*c[4]*x^5*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-579338240*c[1]*c[3]*x^8*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-695205888*c[2]*c[3]*x^9*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+716931072*c[2]*c[3]*x^9*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-6273146880*c[2]*c[3]*x^7*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-926941184*c[3]*c[4]*x^11*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-6273146880*c[3]*c[4]*x^9*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-463470592*c[0]*c[3]*x^7*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+716931072*c[0]*c[3]*x^7*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-6273146880*c[0]*c[3]*x^5*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+15062794240*c[5]*c[0]*x^7*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-3226189824*c[5]*c[0]*x^7*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+183489546240*c[5]*c[0]*x^5*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-695205888*c[5]*c[0]*x^9*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+716931072*c[5]*c[0]*x^9*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-6273146880*c[5]*c[0]*x^7*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+450098288640*c[5]*c[4]*x^9*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-811073536*c[2]*c[4]*x^10*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-1042808832*c[5]*c[3]*x^12*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+41277849600*c[5]*c[3]*x^10*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-946921111552*c[5]*c[3]*x^8*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-811073536*c[5]*c[1]*x^10*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+716931072*c[5]*c[1]*x^10*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+21261713408*c[5]*c[1]*x^8*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-6273146880*c[5]*c[1]*x^8*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-5556215808*c[5]*c[1]*x^8*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+174863969280*c[4]^2*x^8*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+5341870616576*c[4]^2*x^6*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+2630800972800*c[4]^2*x^6*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-95590809600*x^5*c[0]*c[5]*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-156246165504*x^5*c[0]*c[5]*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-2220693995520*x^3*c[0]*c[5]*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+2070138470400*x^3*c[0]*c[5]*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-70824099840*x^5*c[1]*c[4]*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-137426724864*x^5*c[1]*c[4]*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-1558876999680*x^3*c[1]*c[4]*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+1533784412160*x^3*c[1]*c[4]*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+3074618646528*x^5*c[3]*c[4]*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+4660600868352*x^5*c[3]*c[4]*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+66544561923840*x^3*c[3]*c[4]*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-66584710063872*x^3*c[3]*c[4]*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-263853041307648*x^5*c[4]*c[5]*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-355765111498368*x^5*c[4]*c[5]*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-5713675981453440*x^3*c[4]*c[5]*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+5714067425818752*x^3*c[4]*c[5]*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-165799362560*c[2]*c[4]*x^6*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-123536185344*c[2]*c[4]*x^6*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-2820171594240*x^4*c[2]*c[4]*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-54747463680*c[2]*c[3]*x^5*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-104268662784*c[2]*c[3]*x^5*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-1173078466560*c[2]*c[3]*x^3*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+144674449920*Pi^(3/2)*c[5]*c[2]*sqrt(2)*sqrt(x)*sin(x)*FresnelS(sqrt(2)*sqrt(x)/sqrt(Pi))-454255493120*c[4]^2*x^8*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-637272064*c[5]^2*x^14*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+358465536*c[5]^2*x^14*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-3136573440*x^10*c[4]^2*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+358465536*c[4]^2*x^12*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+358465536*x^4*c[0]^2*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-1568286720*x^2*c[0]^2*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-173801472*c[1]^2*x^6*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+3136573440*c[1]^2*x^4*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+40495742976*c[5]^2*x^12*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-1679392931840*c[5]^2*x^10*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+279155036160*c[5]^2*x^10*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+538280810496*c[5]^2*x^10*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+43491569811456*c[5]^2*x^8*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-539983223749632*c[5]^2*x^6*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+464578475961600*c[5]^2*x^6*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-219223333023552*c[5]^2*x^6*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-521404416*c[4]^2*x^12*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+358465536*c[3]^2*x^10*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-3136573440*c[3]^2*x^8*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+7676231680*c[3]^2*x^8*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-268849152*c[3]^2*x^8*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-80075407360*c[3]^2*x^6*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+92528916480*c[3]^2*x^6*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-56928807936*c[3]^2*x^6*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-1337160464640*c[3]^2*x^4*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+358465536*c[1]^2*x^6*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-3136573440*c[1]^2*x^4*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+3820738521600*c[5]*c[1]*x^4*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+11038361411584*c[5]*c[3]*x^6*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-181886855230080*c[5]*c[3]*x^4*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+2784325040640*x^4*c[2]*c[4]*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-69004615680*x^2*c[2]*c[4]*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-347602944*x^6*c[0]*c[2]*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+6990077952*x^4*c[0]*c[2]*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+7270694912*x^6*c[0]*c[4]*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-120220379136*c[4]*c[0]*x^4*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-3136573440*x^2*c[0]*c[2]*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-31365734400*x^2*c[0]*c[4]*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+716931072*x^6*c[0]*c[2]*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-6273146880*x^4*c[0]*c[2]*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+1792327680*x^6*c[0]*c[4]*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+114484930560*c[4]*c[0]*x^4*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+1998716928*c[1]*c[2]*x^5*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+7348543488*c[1]*c[2]*x^5*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+40775454720*c[1]*c[2]*x^3*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-43284713472*c[1]*c[2]*x^3*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+4660051968*c[1]*c[3]*x^6*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+89392343040*c[1]*c[3]*x^4*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-132856289280*c[5]*c[1]*x^6*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-3820738521600*c[5]*c[1]*x^4*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+5614197608448*c[5]*c[3]*x^6*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+181886855230080*c[5]*c[3]*x^4*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-173801472*x^5*c[0]*c[1]*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+716931072*x^5*c[0]*c[1]*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-6273146880*x^3*c[0]*c[1]*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+3763888128*x^3*c[0]*c[1]*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-6273146880*c[5]*c[3]*x^10*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-14338621440*c[5]*c[3]*x^10*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+2520121344*x^5*c[0]*c[3]*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+5197750272*x^5*c[0]*c[3]*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+59594895360*x^3*c[0]*c[3]*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-54576377856*x^3*c[0]*c[3]*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+1244672*x^2*Pi-882161280*x^(5/2)*c[3]*Pi^(3/2)-882161280*x^(5/2)*c[1]*Pi^(3/2)-735134400*x^(7/2)*c[2]*Pi^(3/2)-530675145*x^(13/2)*c[5]*Pi^(3/2)-578918340*x^(11/2)*c[4]*Pi^(3/2)+2352430080*c[4]*x^(3/2)*Pi^(3/2)-2352430080*c[2]*x^(3/2)*Pi^(3/2)-1176215040*c[0]*x^(3/2)*Pi^(3/2)+1996488704*x^8*c[4]*sqrt(Pi)+2867724288*x^4*c[0]*sqrt(Pi)+2139095040*x^7*c[3]*sqrt(Pi)+5735448576*x^4*c[2]*sqrt(Pi)-2139095040*x^7*c[5]*sqrt(Pi)+2549088256*x^5*c[1]*sqrt(Pi)+2549088256*x^5*c[3]*sqrt(Pi)-7647264768*x^5*c[5]*sqrt(Pi)+1879048192*x^9*c[5]*sqrt(Pi)+2317352960*x^6*c[2]*sqrt(Pi)+643242600*x^(9/2)*c[5]*Pi^(3/2)-643242600*x^(9/2)*c[3]*Pi^(3/2)+2646483840*x^(5/2)*c[5]*Pi^(3/2)+1568286720*x^2*c[0]^2*Pi-5735448576*x^4*c[4]*sqrt(Pi)+19118161920*x^6*c[4]^2*Pi-69004615680*x^2*c[4]^2*Pi)/(Pi^(3/2)*sqrt(x))
(1/1176215040)*(716931072*c[5]*c[3]*x^12*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+716931072*x^11*c[3]*c[4]*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-1158676480*x^13*c[4]*c[5]*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+716931072*x^13*c[4]*c[5]*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-6273146880*x^11*c[4]*c[5]*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-22224863232*x^11*c[4]*c[5]*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+716931072*c[5]*c[2]*x^11*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+716931072*c[2]*c[4]*x^10*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-6273146880*c[2]*c[4]*x^8*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-1838182301696*c[5]*c[4]*x^9*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+32944912678912*x^7*c[4]*c[5]*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+592633147392*x^7*c[4]*c[5]*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+428356051643520*x^5*c[4]*c[5]*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+716931072*c[4]*c[0]*x^8*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-6273146880*x^6*c[0]*c[4]*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-926941184*c[5]*c[2]*x^11*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+28590342144*c[5]*c[2]*x^9*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-6273146880*c[5]*c[2]*x^9*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-8065474560*c[5]*c[2]*x^9*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-450739634176*c[5]*c[2]*x^7*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+276018462720*c[5]*c[2]*x^7*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+8342470656*c[2]*c[3]*x^7*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+16395272192*c[2]*c[4]*x^8*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-1254629376*c[2]*c[4]*x^8*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+191330979840*c[2]*c[4]*x^6*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-579338240*c[4]*c[0]*x^8*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-225760870400*c[5]*c[1]*x^6*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+8800821839169360*c[5]^2*x^4*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-8800821839169360*c[5]^2*x^4*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-29999084544*c[2]^2*x^4*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+32149877760*c[2]^2*x^4*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+3763888128*c[2]^2*x^6*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+69004615680*x^2*c[4]^2*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+55517349888*c[4]^2*x^8*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-5045766485760*c[4]^2*x^6*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+358465536*c[2]^2*x^8*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-2352430080*Pi*c[1]*c[2]*x+2352430080*Pi*c[1]*c[4]*x+11762150400*Pi*c[2]*c[3]*x-289348899840*Pi*c[5]*c[2]*x-1176215040*Pi*c[0]*c[1]*x-11762150400*Pi*c[3]*c[4]*x+289348899840*Pi*c[5]*c[4]*x+27601846272*x^3*c[1]*c[4]*Pi+27601846272*x^3*c[3]*c[4]*Pi-82805538816*x^3*c[4]*c[5]*Pi+1254629376*x^3*c[0]*c[1]*Pi+1254629376*x^3*c[0]*c[3]*Pi-3763888128*x^3*c[0]*c[5]*Pi+31365734400*x^2*c[0]*c[4]*Pi+3136573440*x^2*c[0]*c[2]*Pi+69004615680*x^2*c[2]*c[4]*Pi+869007360*x^6*c[0]*c[4]*Pi+17647534080*x^7*c[4]*c[5]*Pi+802160640*x^7*c[0]*c[5]*Pi+23658725376*x^4*c[2]*c[4]*Pi+1075396608*x^4*c[0]*c[2]*Pi+955908096*x^5*c[0]*c[3]*Pi-955908096*x^5*c[0]*c[5]*Pi+21029978112*x^5*c[3]*c[4]*Pi-21029978112*x^5*c[4]*c[5]*Pi-11762150400*Pi^(3/2)*c[3]*c[4]*2^(1/2)*x^(3/2)*cos(x)*FresnelS(2^(1/2)*x^(1/2)/Pi^(1/2))+11762150400*Pi^(3/2)*c[3]*c[4]*2^(1/2)*x^(3/2)*sin(x)*FresnelC(2^(1/2)*x^(1/2)/Pi^(1/2))+289348899840*Pi^(3/2)*c[5]*c[4]*2^(1/2)*x^(3/2)*cos(x)*FresnelS(2^(1/2)*x^(1/2)/Pi^(1/2))-289348899840*Pi^(3/2)*c[5]*c[4]*2^(1/2)*x^(3/2)*sin(x)*FresnelC(2^(1/2)*x^(1/2)/Pi^(1/2))+5881075200*Pi^(3/2)*c[0]*c[3]*2^(1/2)*x^(3/2)*cos(x)*FresnelS(2^(1/2)*x^(1/2)/Pi^(1/2))-5881075200*Pi^(3/2)*c[0]*c[3]*2^(1/2)*x^(3/2)*sin(x)*FresnelC(2^(1/2)*x^(1/2)/Pi^(1/2))-144674449920*Pi^(3/2)*c[5]*c[0]*2^(1/2)*x^(3/2)*cos(x)*FresnelS(2^(1/2)*x^(1/2)/Pi^(1/2))+144674449920*Pi^(3/2)*c[5]*c[0]*2^(1/2)*x^(3/2)*sin(x)*FresnelC(2^(1/2)*x^(1/2)/Pi^(1/2))-2352430080*Pi^(3/2)*c[1]*c[2]*2^(1/2)*x^(3/2)*cos(x)*FresnelS(2^(1/2)*x^(1/2)/Pi^(1/2))+2352430080*Pi^(3/2)*c[1]*c[2]*2^(1/2)*x^(3/2)*sin(x)*FresnelC(2^(1/2)*x^(1/2)/Pi^(1/2))+1176215040*Pi^(3/2)*c[1]*c[2]*2^(1/2)*x^(1/2)*sin(x)*FresnelS(2^(1/2)*x^(1/2)/Pi^(1/2))-1176215040*Pi^(3/2)*c[1]*c[4]*2^(1/2)*x^(1/2)*cos(x)*FresnelC(2^(1/2)*x^(1/2)/Pi^(1/2))-1176215040*Pi^(3/2)*c[1]*c[4]*2^(1/2)*x^(1/2)*sin(x)*FresnelS(2^(1/2)*x^(1/2)/Pi^(1/2))-5881075200*Pi^(3/2)*c[2]*c[3]*2^(1/2)*x^(1/2)*cos(x)*FresnelC(2^(1/2)*x^(1/2)/Pi^(1/2))-5881075200*Pi^(3/2)*c[2]*c[3]*2^(1/2)*x^(1/2)*sin(x)*FresnelS(2^(1/2)*x^(1/2)/Pi^(1/2))+144674449920*Pi^(3/2)*c[5]*c[2]*2^(1/2)*x^(1/2)*cos(x)*FresnelC(2^(1/2)*x^(1/2)/Pi^(1/2))+588107520*Pi^(3/2)*c[0]*c[1]*2^(1/2)*x^(1/2)*cos(x)*FresnelC(2^(1/2)*x^(1/2)/Pi^(1/2))+588107520*Pi^(3/2)*c[0]*c[1]*2^(1/2)*x^(1/2)*sin(x)*FresnelS(2^(1/2)*x^(1/2)/Pi^(1/2))+5881075200*Pi^(3/2)*c[3]*c[4]*2^(1/2)*x^(1/2)*cos(x)*FresnelC(2^(1/2)*x^(1/2)/Pi^(1/2))+5881075200*Pi^(3/2)*c[3]*c[4]*2^(1/2)*x^(1/2)*sin(x)*FresnelS(2^(1/2)*x^(1/2)/Pi^(1/2))-144674449920*Pi^(3/2)*c[5]*c[4]*2^(1/2)*x^(1/2)*cos(x)*FresnelC(2^(1/2)*x^(1/2)/Pi^(1/2))-144674449920*Pi^(3/2)*c[5]*c[4]*2^(1/2)*x^(1/2)*sin(x)*FresnelS(2^(1/2)*x^(1/2)/Pi^(1/2))-2940537600*Pi^(3/2)*c[0]*c[3]*2^(1/2)*x^(1/2)*cos(x)*FresnelC(2^(1/2)*x^(1/2)/Pi^(1/2))-2940537600*Pi^(3/2)*c[0]*c[3]*2^(1/2)*x^(1/2)*sin(x)*FresnelS(2^(1/2)*x^(1/2)/Pi^(1/2))+72337224960*Pi^(3/2)*c[5]*c[0]*2^(1/2)*x^(1/2)*cos(x)*FresnelC(2^(1/2)*x^(1/2)/Pi^(1/2))+72337224960*Pi^(3/2)*c[5]*c[0]*2^(1/2)*x^(1/2)*sin(x)*FresnelS(2^(1/2)*x^(1/2)/Pi^(1/2))+1176215040*Pi^(3/2)*c[1]*c[2]*2^(1/2)*x^(1/2)*cos(x)*FresnelC(2^(1/2)*x^(1/2)/Pi^(1/2))+2352430080*Pi^(3/2)*c[1]*c[4]*2^(1/2)*x^(3/2)*cos(x)*FresnelS(2^(1/2)*x^(1/2)/Pi^(1/2))-2352430080*Pi^(3/2)*c[1]*c[4]*2^(1/2)*x^(3/2)*sin(x)*FresnelC(2^(1/2)*x^(1/2)/Pi^(1/2))+144674449920*Pi^(3/2)*c[5]*c[2]*2^(1/2)*x^(1/2)*sin(x)*FresnelS(2^(1/2)*x^(1/2)/Pi^(1/2))+11762150400*Pi^(3/2)*c[2]*c[3]*2^(1/2)*x^(3/2)*cos(x)*FresnelS(2^(1/2)*x^(1/2)/Pi^(1/2))-11762150400*Pi^(3/2)*c[2]*c[3]*2^(1/2)*x^(3/2)*sin(x)*FresnelC(2^(1/2)*x^(1/2)/Pi^(1/2))-289348899840*Pi^(3/2)*c[5]*c[2]*2^(1/2)*x^(3/2)*cos(x)*FresnelS(2^(1/2)*x^(1/2)/Pi^(1/2))+289348899840*Pi^(3/2)*c[5]*c[2]*2^(1/2)*x^(3/2)*sin(x)*FresnelC(2^(1/2)*x^(1/2)/Pi^(1/2))-1176215040*Pi^(3/2)*c[0]*c[1]*2^(1/2)*x^(3/2)*cos(x)*FresnelS(2^(1/2)*x^(1/2)/Pi^(1/2))+1176215040*Pi^(3/2)*c[0]*c[1]*2^(1/2)*x^(3/2)*sin(x)*FresnelC(2^(1/2)*x^(1/2)/Pi^(1/2))-6810845184*c[4]^2*x^10*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-405536768*c[3]^2*x^10*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-13830328512000*c[5]^2*x^8*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-8754008440320*c[5]^2*x^8*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+19885785088*c[4]^2*x^10*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+1996488704*x^8*c[4]*Pi^(1/2)+2867724288*x^4*c[0]*Pi^(1/2)+2139095040*x^7*c[3]*Pi^(1/2)+5735448576*x^4*c[2]*Pi^(1/2)-2139095040*x^7*c[5]*Pi^(1/2)+2549088256*x^5*c[1]*Pi^(1/2)+228969861120*c[5]*c[1]*x^6*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+356001085440*c[5]*c[3]*x^8*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+716931072*c[1]*c[3]*x^8*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-6273146880*c[1]*c[3]*x^6*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+127344881664*c[5]*c[3]*x^8*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-10565155560960*c[5]*c[3]*x^6*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+26041253888*c[3]*c[4]*x^9*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-411923972096*c[3]*c[4]*x^7*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-60715100160*c[3]*c[4]*x^7*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-5531739333120*c[3]*c[4]*x^5*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+716931072*c[1]*c[4]*x^9*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-6273146880*c[1]*c[4]*x^7*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+2549088256*x^5*c[3]*Pi^(1/2)-7647264768*x^5*c[5]*Pi^(1/2)+1879048192*x^9*c[5]*Pi^(1/2)+2317352960*x^6*c[2]*Pi^(1/2)-5735448576*x^4*c[4]*Pi^(1/2)+1781465088*c[2]^2*x^6*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-289669120*c[2]^2*x^8*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+1337160464640*c[3]^2*x^4*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-87979326507072*c[4]^2*x^4*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+5881075200*Pi*c[0]*c[3]*x-144674449920*Pi*c[5]*c[0]*x-3136573440*c[5]^2*x^12*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-15862099968*c[5]^2*x^12*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-3136573440*c[2]^2*x^6*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+87989363542080*c[4]^2*x^4*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+1185624760320*c[2]*c[3]*x^3*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-6631612416*c[3]*c[4]*x^9*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+263472168960*c[3]*c[4]*x^7*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+473981054976*c[5]*c[4]*x^9*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-17407590520320*c[5]*c[4]*x^7*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+716931072*c[1]*c[2]*x^7*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-6273146880*c[1]*c[2]*x^5*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+3943120896*c[2]*c[3]*x^7*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+120758077440*c[2]*c[3]*x^5*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-55696582656*c[5]*c[2]*x^7*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-6137098007040*c[5]*c[2]*x^5*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+3291740135424*c[5]*c[2]*x^5*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+5231009152512*c[5]*c[2]*x^5*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+70978108481280*c[5]*c[2]*x^3*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-71286747307776*c[5]*c[2]*x^3*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+5185077248*c[1]*c[3]*x^6*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-89392343040*c[1]*c[3]*x^4*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-463470592*c[1]*c[2]*x^7*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+58455228416*c[5]*c[4]*x^11*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-695205888*c[1]*c[4]*x^9*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+11355029504*c[1]*c[4]*x^7*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+358465536*c[1]*c[4]*x^7*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+152123811840*c[1]*c[4]*x^5*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-579338240*c[1]*c[3]*x^8*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-695205888*c[2]*c[3]*x^9*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+716931072*c[2]*c[3]*x^9*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-6273146880*c[2]*c[3]*x^7*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-926941184*c[3]*c[4]*x^11*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-6273146880*c[3]*c[4]*x^9*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-463470592*c[0]*c[3]*x^7*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+716931072*c[0]*c[3]*x^7*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-6273146880*c[0]*c[3]*x^5*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+15062794240*c[5]*c[0]*x^7*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-3226189824*c[5]*c[0]*x^7*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+183489546240*c[5]*c[0]*x^5*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-695205888*c[5]*c[0]*x^9*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+716931072*c[5]*c[0]*x^9*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-6273146880*c[5]*c[0]*x^7*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+450098288640*c[5]*c[4]*x^9*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-811073536*c[2]*c[4]*x^10*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-1042808832*c[5]*c[3]*x^12*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+41277849600*c[5]*c[3]*x^10*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-946921111552*c[5]*c[3]*x^8*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-811073536*c[5]*c[1]*x^10*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+716931072*c[5]*c[1]*x^10*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+21261713408*c[5]*c[1]*x^8*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-6273146880*c[5]*c[1]*x^8*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-5556215808*c[5]*c[1]*x^8*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+174863969280*c[4]^2*x^8*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+5341870616576*c[4]^2*x^6*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+2630800972800*c[4]^2*x^6*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-95590809600*x^5*c[0]*c[5]*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-156246165504*x^5*c[0]*c[5]*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-2220693995520*x^3*c[0]*c[5]*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+2070138470400*x^3*c[0]*c[5]*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-70824099840*x^5*c[1]*c[4]*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-137426724864*x^5*c[1]*c[4]*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-1558876999680*x^3*c[1]*c[4]*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+1533784412160*x^3*c[1]*c[4]*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+3074618646528*x^5*c[3]*c[4]*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+4660600868352*x^5*c[3]*c[4]*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+66544561923840*x^3*c[3]*c[4]*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-66584710063872*x^3*c[3]*c[4]*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-263853041307648*x^5*c[4]*c[5]*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-355765111498368*x^5*c[4]*c[5]*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-5713675981453440*x^3*c[4]*c[5]*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+5714067425818752*x^3*c[4]*c[5]*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-165799362560*c[2]*c[4]*x^6*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-123536185344*c[2]*c[4]*x^6*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-2820171594240*x^4*c[2]*c[4]*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-54747463680*c[2]*c[3]*x^5*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-104268662784*c[2]*c[3]*x^5*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-1173078466560*c[2]*c[3]*x^3*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-454255493120*c[4]^2*x^8*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-637272064*c[5]^2*x^14*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+358465536*c[5]^2*x^14*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-3136573440*x^10*c[4]^2*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+358465536*c[4]^2*x^12*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+358465536*x^4*c[0]^2*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-1568286720*x^2*c[0]^2*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-173801472*c[1]^2*x^6*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+3136573440*c[1]^2*x^4*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+40495742976*c[5]^2*x^12*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-1679392931840*c[5]^2*x^10*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+279155036160*c[5]^2*x^10*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+538280810496*c[5]^2*x^10*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+43491569811456*c[5]^2*x^8*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-539983223749632*c[5]^2*x^6*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+464578475961600*c[5]^2*x^6*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-219223333023552*c[5]^2*x^6*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-521404416*c[4]^2*x^12*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+358465536*c[3]^2*x^10*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-3136573440*c[3]^2*x^8*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+7676231680*c[3]^2*x^8*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-268849152*c[3]^2*x^8*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-80075407360*c[3]^2*x^6*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+92528916480*c[3]^2*x^6*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-56928807936*c[3]^2*x^6*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-1337160464640*c[3]^2*x^4*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+358465536*c[1]^2*x^6*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-3136573440*c[1]^2*x^4*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+3820738521600*c[5]*c[1]*x^4*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+11038361411584*c[5]*c[3]*x^6*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-181886855230080*c[5]*c[3]*x^4*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+2784325040640*x^4*c[2]*c[4]*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-69004615680*x^2*c[2]*c[4]*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-347602944*x^6*c[0]*c[2]*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+6990077952*x^4*c[0]*c[2]*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+7270694912*x^6*c[0]*c[4]*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-120220379136*c[4]*c[0]*x^4*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-3136573440*x^2*c[0]*c[2]*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-31365734400*x^2*c[0]*c[4]*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+716931072*x^6*c[0]*c[2]*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-6273146880*x^4*c[0]*c[2]*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+1792327680*x^6*c[0]*c[4]*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+114484930560*c[4]*c[0]*x^4*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+1998716928*c[1]*c[2]*x^5*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+7348543488*c[1]*c[2]*x^5*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+40775454720*c[1]*c[2]*x^3*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-43284713472*c[1]*c[2]*x^3*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+4660051968*c[1]*c[3]*x^6*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+89392343040*c[1]*c[3]*x^4*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-132856289280*c[5]*c[1]*x^6*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-3820738521600*c[5]*c[1]*x^4*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+5614197608448*c[5]*c[3]*x^6*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+181886855230080*c[5]*c[3]*x^4*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-173801472*x^5*c[0]*c[1]*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+716931072*x^5*c[0]*c[1]*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-6273146880*x^3*c[0]*c[1]*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+3763888128*x^3*c[0]*c[1]*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-6273146880*c[5]*c[3]*x^10*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-14338621440*c[5]*c[3]*x^10*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+2520121344*x^5*c[0]*c[3]*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+5197750272*x^5*c[0]*c[3]*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+59594895360*x^3*c[0]*c[3]*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-54576377856*x^3*c[0]*c[3]*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+1244672*x^2*Pi-882161280*x^(5/2)*c[3]*Pi^(3/2)-882161280*x^(5/2)*c[1]*Pi^(3/2)-735134400*x^(7/2)*c[2]*Pi^(3/2)-530675145*x^(13/2)*c[5]*Pi^(3/2)-578918340*x^(11/2)*c[4]*Pi^(3/2)+2352430080*c[4]*x^(3/2)*Pi^(3/2)-2352430080*c[2]*x^(3/2)*Pi^(3/2)-1176215040*c[0]*x^(3/2)*Pi^(3/2)+643242600*x^(9/2)*c[5]*Pi^(3/2)-643242600*x^(9/2)*c[3]*Pi^(3/2)+2646483840*x^(5/2)*c[5]*Pi^(3/2)+1568286720*x^2*c[0]^2*Pi+19118161920*x^6*c[4]^2*Pi-69004615680*x^2*c[4]^2*Pi)/(Pi^(3/2)*x^(1/2))
simplify(asa)
(1/1176215040)*(19118161920*x^6*c[4]^2*Pi-69004615680*x^2*c[4]^2*Pi+1568286720*x^2*c[0]^2*Pi-5735448576*x^4*c[4]*Pi^(1/2)+1996488704*x^8*c[4]*Pi^(1/2)+2867724288*x^4*c[0]*Pi^(1/2)+2139095040*x^7*c[3]*Pi^(1/2)+5735448576*x^4*c[2]*Pi^(1/2)-2139095040*x^7*c[5]*Pi^(1/2)+2549088256*x^5*c[1]*Pi^(1/2)+2549088256*x^5*c[3]*Pi^(1/2)-7647264768*x^5*c[5]*Pi^(1/2)+1879048192*x^9*c[5]*Pi^(1/2)+2317352960*x^6*c[2]*Pi^(1/2)+643242600*x^(9/2)*c[5]*Pi^(3/2)-643242600*x^(9/2)*c[3]*Pi^(3/2)+2646483840*x^(5/2)*c[5]*Pi^(3/2)-882161280*x^(5/2)*c[3]*Pi^(3/2)-882161280*x^(5/2)*c[1]*Pi^(3/2)-735134400*x^(7/2)*c[2]*Pi^(3/2)-530675145*x^(13/2)*c[5]*Pi^(3/2)-578918340*x^(11/2)*c[4]*Pi^(3/2)+2352430080*c[4]*x^(3/2)*Pi^(3/2)-2352430080*c[2]*x^(3/2)*Pi^(3/2)-1176215040*c[0]*x^(3/2)*Pi^(3/2)+1244672*x^2*Pi+716931072*c[5]*c[3]*x^12*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+716931072*x^11*c[3]*c[4]*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-1158676480*x^13*c[4]*c[5]*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+716931072*x^13*c[4]*c[5]*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-6273146880*x^11*c[4]*c[5]*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-22224863232*x^11*c[4]*c[5]*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+716931072*c[5]*c[2]*x^11*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-2352430080*Pi*c[1]*c[2]*x+2352430080*Pi*c[1]*c[4]*x+11762150400*Pi*c[2]*c[3]*x-289348899840*Pi*c[5]*c[2]*x-1176215040*Pi*c[0]*c[1]*x-11762150400*Pi*c[3]*c[4]*x+289348899840*Pi*c[5]*c[4]*x+27601846272*x^3*c[1]*c[4]*Pi+27601846272*x^3*c[3]*c[4]*Pi-82805538816*x^3*c[4]*c[5]*Pi+1254629376*x^3*c[0]*c[1]*Pi+1254629376*x^3*c[0]*c[3]*Pi-3763888128*x^3*c[0]*c[5]*Pi+31365734400*x^2*c[0]*c[4]*Pi+3136573440*x^2*c[0]*c[2]*Pi+69004615680*x^2*c[2]*c[4]*Pi+869007360*x^6*c[0]*c[4]*Pi+17647534080*x^7*c[4]*c[5]*Pi+802160640*x^7*c[0]*c[5]*Pi+23658725376*x^4*c[2]*c[4]*Pi+1075396608*x^4*c[0]*c[2]*Pi+955908096*x^5*c[0]*c[3]*Pi-955908096*x^5*c[0]*c[5]*Pi+21029978112*x^5*c[3]*c[4]*Pi-21029978112*x^5*c[4]*c[5]*Pi+5881075200*Pi*c[0]*c[3]*x-144674449920*Pi*c[5]*c[0]*x-3136573440*c[5]^2*x^12*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-15862099968*c[5]^2*x^12*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+716931072*c[2]*c[4]*x^10*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-6273146880*c[2]*c[4]*x^8*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-1838182301696*c[5]*c[4]*x^9*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+32944912678912*c[5]*c[4]*x^7*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+592633147392*c[5]*c[4]*x^7*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+428356051643520*c[5]*c[4]*x^5*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+716931072*c[4]*c[0]*x^8*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-6273146880*c[4]*c[0]*x^6*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-926941184*c[5]*c[2]*x^11*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+28590342144*c[5]*c[2]*x^9*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-6273146880*c[5]*c[2]*x^9*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-8065474560*c[5]*c[2]*x^9*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-450739634176*c[5]*c[2]*x^7*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+276018462720*c[5]*c[2]*x^7*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+8342470656*c[2]*c[3]*x^7*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+16395272192*c[2]*c[4]*x^8*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-1254629376*c[2]*c[4]*x^8*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+191330979840*c[2]*c[4]*x^6*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-579338240*c[4]*c[0]*x^8*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-225760870400*c[5]*c[1]*x^6*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+3820738521600*c[5]*c[1]*x^4*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+11038361411584*c[5]*c[3]*x^6*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-181886855230080*c[5]*c[3]*x^4*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+2784325040640*x^4*c[2]*c[4]*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-69004615680*x^2*c[2]*c[4]*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-347602944*x^6*c[0]*c[2]*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+6990077952*x^4*c[0]*c[2]*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+7270694912*c[4]*c[0]*x^6*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-120220379136*c[4]*c[0]*x^4*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-3136573440*x^2*c[0]*c[2]*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-31365734400*x^2*c[0]*c[4]*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+716931072*x^6*c[0]*c[2]*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-6273146880*x^4*c[0]*c[2]*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+1792327680*c[4]*c[0]*x^6*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+114484930560*c[4]*c[0]*x^4*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+1998716928*c[1]*c[2]*x^5*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+7348543488*c[1]*c[2]*x^5*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+40775454720*c[1]*c[2]*x^3*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-43284713472*c[1]*c[2]*x^3*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+4660051968*c[1]*c[3]*x^6*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+89392343040*c[1]*c[3]*x^4*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-132856289280*c[5]*c[1]*x^6*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-3820738521600*c[5]*c[1]*x^4*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+5614197608448*c[5]*c[3]*x^6*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+181886855230080*c[5]*c[3]*x^4*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-173801472*x^5*c[0]*c[1]*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+716931072*x^5*c[0]*c[1]*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-6273146880*x^3*c[0]*c[1]*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+3763888128*x^3*c[0]*c[1]*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-6273146880*c[5]*c[3]*x^10*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-14338621440*c[5]*c[3]*x^10*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+2520121344*x^5*c[0]*c[3]*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+5197750272*x^5*c[0]*c[3]*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+59594895360*x^3*c[0]*c[3]*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-54576377856*x^3*c[0]*c[3]*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-95590809600*x^5*c[0]*c[5]*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-156246165504*x^5*c[0]*c[5]*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-2220693995520*x^3*c[0]*c[5]*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+2070138470400*x^3*c[0]*c[5]*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-70824099840*x^5*c[1]*c[4]*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-137426724864*x^5*c[1]*c[4]*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-1558876999680*x^3*c[1]*c[4]*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+1533784412160*x^3*c[1]*c[4]*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+3074618646528*x^5*c[3]*c[4]*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+4660600868352*x^5*c[3]*c[4]*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+66544561923840*x^3*c[3]*c[4]*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-66584710063872*x^3*c[3]*c[4]*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-263853041307648*x^5*c[4]*c[5]*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-355765111498368*x^5*c[4]*c[5]*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-5713675981453440*x^3*c[4]*c[5]*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+5714067425818752*x^3*c[4]*c[5]*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-165799362560*x^6*c[2]*c[4]*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-123536185344*x^6*c[2]*c[4]*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-2820171594240*x^4*c[2]*c[4]*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-54747463680*c[2]*c[3]*x^5*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-104268662784*c[2]*c[3]*x^5*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-1173078466560*c[2]*c[3]*x^3*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+1185624760320*c[2]*c[3]*x^3*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-6631612416*c[3]*c[4]*x^9*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+263472168960*c[3]*c[4]*x^7*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+473981054976*c[5]*c[4]*x^9*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-17407590520320*c[5]*c[4]*x^7*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+716931072*c[1]*c[2]*x^7*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-6273146880*c[1]*c[2]*x^5*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+3943120896*c[2]*c[3]*x^7*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+120758077440*c[2]*c[3]*x^5*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-55696582656*c[5]*c[2]*x^7*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-6137098007040*c[5]*c[2]*x^5*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+3291740135424*c[5]*c[2]*x^5*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+5231009152512*c[5]*c[2]*x^5*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+70978108481280*c[5]*c[2]*x^3*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-71286747307776*c[5]*c[2]*x^3*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+5185077248*c[1]*c[3]*x^6*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-89392343040*c[1]*c[3]*x^4*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-463470592*c[1]*c[2]*x^7*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+58455228416*c[5]*c[4]*x^11*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-695205888*c[1]*c[4]*x^9*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+11355029504*c[1]*c[4]*x^7*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+358465536*c[1]*c[4]*x^7*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+152123811840*c[1]*c[4]*x^5*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-579338240*c[1]*c[3]*x^8*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-695205888*c[2]*c[3]*x^9*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+716931072*c[2]*c[3]*x^9*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-6273146880*c[2]*c[3]*x^7*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-926941184*c[3]*c[4]*x^11*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-6273146880*c[3]*c[4]*x^9*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-463470592*c[0]*c[3]*x^7*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+716931072*c[0]*c[3]*x^7*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-6273146880*c[0]*c[3]*x^5*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+15062794240*c[5]*c[0]*x^7*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-3226189824*c[5]*c[0]*x^7*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+183489546240*c[5]*c[0]*x^5*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-695205888*c[5]*c[0]*x^9*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+716931072*c[5]*c[0]*x^9*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-6273146880*c[5]*c[0]*x^7*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+450098288640*c[5]*c[4]*x^9*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-811073536*c[2]*c[4]*x^10*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-1042808832*c[5]*c[3]*x^12*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+41277849600*c[5]*c[3]*x^10*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-946921111552*c[5]*c[3]*x^8*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-811073536*c[5]*c[1]*x^10*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+716931072*c[5]*c[1]*x^10*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+21261713408*c[5]*c[1]*x^8*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-6273146880*c[5]*c[1]*x^8*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-5556215808*c[5]*c[1]*x^8*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+228969861120*c[5]*c[1]*x^6*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+356001085440*c[5]*c[3]*x^8*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+716931072*c[1]*c[3]*x^8*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-6273146880*c[1]*c[3]*x^6*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+127344881664*c[5]*c[3]*x^8*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-10565155560960*c[5]*c[3]*x^6*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+26041253888*c[3]*c[4]*x^9*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-411923972096*c[3]*c[4]*x^7*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-60715100160*c[3]*c[4]*x^7*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-5531739333120*c[3]*c[4]*x^5*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+716931072*c[1]*c[4]*x^9*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-6273146880*c[1]*c[4]*x^7*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-637272064*c[5]^2*x^14*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+358465536*c[5]^2*x^14*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-3136573440*x^10*c[4]^2*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+358465536*c[4]^2*x^12*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+5881075200*Pi^(3/2)*c[3]*c[4]*2^(1/2)*x^(1/2)*cos(x)*FresnelC(2^(1/2)*x^(1/2)/Pi^(1/2))+5881075200*Pi^(3/2)*c[3]*c[4]*2^(1/2)*x^(1/2)*sin(x)*FresnelS(2^(1/2)*x^(1/2)/Pi^(1/2))-144674449920*Pi^(3/2)*c[5]*c[4]*2^(1/2)*x^(1/2)*cos(x)*FresnelC(2^(1/2)*x^(1/2)/Pi^(1/2))-144674449920*Pi^(3/2)*c[5]*c[4]*2^(1/2)*x^(1/2)*sin(x)*FresnelS(2^(1/2)*x^(1/2)/Pi^(1/2))-2940537600*Pi^(3/2)*c[0]*c[3]*2^(1/2)*x^(1/2)*cos(x)*FresnelC(2^(1/2)*x^(1/2)/Pi^(1/2))-2940537600*Pi^(3/2)*c[0]*c[3]*2^(1/2)*x^(1/2)*sin(x)*FresnelS(2^(1/2)*x^(1/2)/Pi^(1/2))+72337224960*Pi^(3/2)*c[5]*c[0]*2^(1/2)*x^(1/2)*cos(x)*FresnelC(2^(1/2)*x^(1/2)/Pi^(1/2))+72337224960*Pi^(3/2)*c[5]*c[0]*2^(1/2)*x^(1/2)*sin(x)*FresnelS(2^(1/2)*x^(1/2)/Pi^(1/2))+1176215040*Pi^(3/2)*c[1]*c[2]*2^(1/2)*x^(1/2)*cos(x)*FresnelC(2^(1/2)*x^(1/2)/Pi^(1/2))+2352430080*Pi^(3/2)*c[1]*c[4]*2^(1/2)*x^(3/2)*cos(x)*FresnelS(2^(1/2)*x^(1/2)/Pi^(1/2))-2352430080*Pi^(3/2)*c[1]*c[4]*2^(1/2)*x^(3/2)*sin(x)*FresnelC(2^(1/2)*x^(1/2)/Pi^(1/2))+11762150400*Pi^(3/2)*c[2]*c[3]*2^(1/2)*x^(3/2)*cos(x)*FresnelS(2^(1/2)*x^(1/2)/Pi^(1/2))-11762150400*Pi^(3/2)*c[2]*c[3]*2^(1/2)*x^(3/2)*sin(x)*FresnelC(2^(1/2)*x^(1/2)/Pi^(1/2))-289348899840*Pi^(3/2)*c[5]*c[2]*2^(1/2)*x^(3/2)*cos(x)*FresnelS(2^(1/2)*x^(1/2)/Pi^(1/2))+289348899840*Pi^(3/2)*c[5]*c[2]*2^(1/2)*x^(3/2)*sin(x)*FresnelC(2^(1/2)*x^(1/2)/Pi^(1/2))-1176215040*Pi^(3/2)*c[0]*c[1]*2^(1/2)*x^(3/2)*cos(x)*FresnelS(2^(1/2)*x^(1/2)/Pi^(1/2))+1176215040*Pi^(3/2)*c[0]*c[1]*2^(1/2)*x^(3/2)*sin(x)*FresnelC(2^(1/2)*x^(1/2)/Pi^(1/2))-11762150400*Pi^(3/2)*c[3]*c[4]*2^(1/2)*x^(3/2)*cos(x)*FresnelS(2^(1/2)*x^(1/2)/Pi^(1/2))+11762150400*Pi^(3/2)*c[3]*c[4]*2^(1/2)*x^(3/2)*sin(x)*FresnelC(2^(1/2)*x^(1/2)/Pi^(1/2))+289348899840*Pi^(3/2)*c[5]*c[4]*2^(1/2)*x^(3/2)*cos(x)*FresnelS(2^(1/2)*x^(1/2)/Pi^(1/2))-289348899840*Pi^(3/2)*c[5]*c[4]*2^(1/2)*x^(3/2)*sin(x)*FresnelC(2^(1/2)*x^(1/2)/Pi^(1/2))+5881075200*Pi^(3/2)*c[0]*c[3]*2^(1/2)*x^(3/2)*cos(x)*FresnelS(2^(1/2)*x^(1/2)/Pi^(1/2))-5881075200*Pi^(3/2)*c[0]*c[3]*2^(1/2)*x^(3/2)*sin(x)*FresnelC(2^(1/2)*x^(1/2)/Pi^(1/2))-144674449920*Pi^(3/2)*c[5]*c[0]*2^(1/2)*x^(3/2)*cos(x)*FresnelS(2^(1/2)*x^(1/2)/Pi^(1/2))+144674449920*Pi^(3/2)*c[5]*c[0]*2^(1/2)*x^(3/2)*sin(x)*FresnelC(2^(1/2)*x^(1/2)/Pi^(1/2))-2352430080*Pi^(3/2)*c[1]*c[2]*2^(1/2)*x^(3/2)*cos(x)*FresnelS(2^(1/2)*x^(1/2)/Pi^(1/2))+2352430080*Pi^(3/2)*c[1]*c[2]*2^(1/2)*x^(3/2)*sin(x)*FresnelC(2^(1/2)*x^(1/2)/Pi^(1/2))+1176215040*Pi^(3/2)*c[1]*c[2]*2^(1/2)*x^(1/2)*sin(x)*FresnelS(2^(1/2)*x^(1/2)/Pi^(1/2))-1176215040*Pi^(3/2)*c[1]*c[4]*2^(1/2)*x^(1/2)*cos(x)*FresnelC(2^(1/2)*x^(1/2)/Pi^(1/2))-1176215040*Pi^(3/2)*c[1]*c[4]*2^(1/2)*x^(1/2)*sin(x)*FresnelS(2^(1/2)*x^(1/2)/Pi^(1/2))-5881075200*Pi^(3/2)*c[2]*c[3]*2^(1/2)*x^(1/2)*cos(x)*FresnelC(2^(1/2)*x^(1/2)/Pi^(1/2))-5881075200*Pi^(3/2)*c[2]*c[3]*2^(1/2)*x^(1/2)*sin(x)*FresnelS(2^(1/2)*x^(1/2)/Pi^(1/2))+144674449920*Pi^(3/2)*c[5]*c[2]*2^(1/2)*x^(1/2)*cos(x)*FresnelC(2^(1/2)*x^(1/2)/Pi^(1/2))+144674449920*Pi^(3/2)*c[5]*c[2]*2^(1/2)*x^(1/2)*sin(x)*FresnelS(2^(1/2)*x^(1/2)/Pi^(1/2))+588107520*Pi^(3/2)*c[0]*c[1]*2^(1/2)*x^(1/2)*cos(x)*FresnelC(2^(1/2)*x^(1/2)/Pi^(1/2))+588107520*Pi^(3/2)*c[0]*c[1]*2^(1/2)*x^(1/2)*sin(x)*FresnelS(2^(1/2)*x^(1/2)/Pi^(1/2))-405536768*c[3]^2*x^10*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+358465536*x^4*c[0]^2*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-1568286720*x^2*c[0]^2*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-173801472*c[1]^2*x^6*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+3136573440*c[1]^2*x^4*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+40495742976*c[5]^2*x^12*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-1679392931840*c[5]^2*x^10*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+279155036160*c[5]^2*x^10*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+538280810496*c[5]^2*x^10*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+43491569811456*c[5]^2*x^8*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-13830328512000*c[5]^2*x^8*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-8754008440320*c[5]^2*x^8*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-539983223749632*c[5]^2*x^6*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+464578475961600*c[5]^2*x^6*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-219223333023552*c[5]^2*x^6*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-521404416*c[4]^2*x^12*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+358465536*c[3]^2*x^10*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-3136573440*c[3]^2*x^8*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+7676231680*c[3]^2*x^8*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-268849152*c[3]^2*x^8*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-80075407360*c[3]^2*x^6*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+92528916480*c[3]^2*x^6*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-56928807936*c[3]^2*x^6*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-1337160464640*c[3]^2*x^4*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+358465536*c[1]^2*x^6*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-3136573440*c[1]^2*x^4*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+69004615680*x^2*c[4]^2*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+55517349888*c[4]^2*x^8*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-5045766485760*c[4]^2*x^6*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+358465536*c[2]^2*x^8*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-3136573440*c[2]^2*x^6*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+19885785088*c[4]^2*x^10*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)-6810845184*c[4]^2*x^10*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-454255493120*c[4]^2*x^8*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+174863969280*c[4]^2*x^8*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+5341870616576*c[4]^2*x^6*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+2630800972800*c[4]^2*x^6*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+87989363542080*c[4]^2*x^4*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-87979326507072*c[4]^2*x^4*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+1337160464640*c[3]^2*x^4*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-289669120*c[2]^2*x^8*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+1781465088*c[2]^2*x^6*Pi*hypergeom([3], [13/4, 15/4], -(1/4)*x^2)+3763888128*c[2]^2*x^6*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)+32149877760*c[2]^2*x^4*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)-29999084544*c[2]^2*x^4*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2)-8800821839169360*c[5]^2*x^4*Pi*hypergeom([1], [5/4, 7/4], -(1/4)*x^2)+8800821839169360*c[5]^2*x^4*Pi*hypergeom([2], [9/4, 11/4], -(1/4)*x^2))/(Pi^(3/2)*x^(1/2))
subs(x = 0, asa)
Download prpblem_maple_2.mw
Hello experts,
I am trying to use solve to find a solution to a system of two equations. The two equations involved are quite complicated, and so sometimes Maple has difficulty with this. In particular, the solve command tries evaluating but never comes up with a solution (I've waited at least an hour, before giving up).
I recently learned about fsolve, which gives approximate numeric solutions (which would be fine for my purposes), but fsolve too struggles with a solution and simply returns my input to me. I tried plotting the system of equations using plots:-implictplot to see if a solution existed, and as expected it does. I was hoping to get some tips on trying to solve a difficult system like this, perhaps given the knowledge that a solution definitely exists. Unfortunately, I need a solution for many variations of the same system, so simply reading off the approximate solution isn't really an option.
In my attatched code, the system with W = 49 is the first one where Maple really begins to struggle, and I believe that solutions for W>49 are also difficult.
06042020_Predicting_w_AB_Ratio_Maple_Primes.mw
I need to count and separate the nonlinear terms in a list.  Example:
w:=[[z, y, x, 1], [x*z, x*y, y, 1], [x*z, z, x*y]];
there are 4 nonlinear terms, x*z, x*y, x*z, and x*y.
The terms can be any combination of the given variables, that is, x, y, and z.
My solution to the problem of counting the nonlinear terms is
aux1:=[seq([seq(nops(w[j,i]),i=1..nops(w[j]))],j=1..nops(w))];
aux2:=[seq(selectremove(x->x>1,aux1[i])[1],i=1..nops(aux1))]
res:=convert([seq(convert(nops(aux2[i]),`+`),i=1..nops(aux2))],`+`);
It works but I wonder whether there is a better solution that includes showing the nonlinear terms themselves.
Many thanks
Ed
Cannot find integration proplem_in_maple.mw
with(LinearAlgebra)
with(orthopoly)
with(student)
Digits := 32
32
interface(rtablesize = 100)
10
a := 0; b := 1; N := 5; h := (b-a)/N; B[0] := 1; B[1] := x; n := 2; B[2] := x^2+2; alpha := 1/2
1/5
x
x^2+2
1/2
for j from 3 to N do B[j] := expand(x*B[j-1]-B[j-2]) end do
x^3+x
x^4-2
x^5-3*x-x^3
for i from 0 to N do x[i] := h*i+a end do
2/5
3/5
4/5
y := sum(c[s]*B[s], s = 0 .. N)
c[0]+c[1]*x+c[2]*(x^2+2)+c[3]*(x^3+x)+c[4]*(x^4-2)+c[5]*(x^5-3*x-x^3)
yt := subs(x = t, y)
c[0]+c[1]*t+c[2]*(t^2+2)+c[3]*(t^3+t)+c[4]*(t^4-2)+c[5]*(t^5-3*t-t^3)
k := expand(int(yt*sin(t)*x, t = 0 .. x))
x*c[0]+22*x*c[4]-c[1]*cos(x)*x^2-c[2]*cos(x)*x^3+2*c[2]*sin(x)*x^2-c[3]*cos(x)*x^4+3*c[3]*sin(x)*x^3+5*c[3]*cos(x)*x^2-c[4]*cos(x)*x^5+4*c[4]*sin(x)*x^4+12*c[4]*cos(x)*x^3-24*c[4]*sin(x)*x^2-c[5]*cos(x)*x^6+5*c[5]*sin(x)*x^5+21*c[5]*cos(x)*x^4-63*c[5]*sin(x)*x^3-123*c[5]*cos(x)*x^2-x*cos(x)*c[0]-22*x*cos(x)*c[4]+x*c[1]*sin(x)-5*x*c[3]*sin(x)+123*x*c[5]*sin(x)
k4 := k*y
(x*c[0]+22*x*c[4]-c[1]*cos(x)*x^2-c[2]*cos(x)*x^3+2*c[2]*sin(x)*x^2-c[3]*cos(x)*x^4+3*c[3]*sin(x)*x^3+5*c[3]*cos(x)*x^2-c[4]*cos(x)*x^5+4*c[4]*sin(x)*x^4+12*c[4]*cos(x)*x^3-24*c[4]*sin(x)*x^2-c[5]*cos(x)*x^6+5*c[5]*sin(x)*x^5+21*c[5]*cos(x)*x^4-63*c[5]*sin(x)*x^3-123*c[5]*cos(x)*x^2-x*cos(x)*c[0]-22*x*cos(x)*c[4]+x*c[1]*sin(x)-5*x*c[3]*sin(x)+123*x*c[5]*sin(x))*(c[0]+c[1]*x+c[2]*(x^2+2)+c[3]*(x^3+x)+c[4]*(x^4-2)+c[5]*(x^5-3*x-x^3))
f := (8*x^3*(1/3)-2*x^(1/2))*y/GAMMA(1/2)+(1/1260)*x+k4
((8/3)*x^3-2*x^(1/2))*(c[0]+c[1]*x+c[2]*(x^2+2)+c[3]*(x^3+x)+c[4]*(x^4-2)+c[5]*(x^5-3*x-x^3))/Pi^(1/2)+(1/1260)*x+(x*c[0]+22*x*c[4]-c[1]*cos(x)*x^2-c[2]*cos(x)*x^3+2*c[2]*sin(x)*x^2-c[3]*cos(x)*x^4+3*c[3]*sin(x)*x^3+5*c[3]*cos(x)*x^2-c[4]*cos(x)*x^5+4*c[4]*sin(x)*x^4+12*c[4]*cos(x)*x^3-24*c[4]*sin(x)*x^2-c[5]*cos(x)*x^6+5*c[5]*sin(x)*x^5+21*c[5]*cos(x)*x^4-63*c[5]*sin(x)*x^3-123*c[5]*cos(x)*x^2-x*cos(x)*c[0]-22*x*cos(x)*c[4]+x*c[1]*sin(x)-5*x*c[3]*sin(x)+123*x*c[5]*sin(x))*(c[0]+c[1]*x+c[2]*(x^2+2)+c[3]*(x^3+x)+c[4]*(x^4-2)+c[5]*(x^5-3*x-x^3))
"f(x):=((8/3 x^3-2 sqrt(x)) (c[0]+c[1] x+c[2] (x^2+2)+c[3] (x^3+x)+c[4] (x^4-2)+c[5] (x^5-3 x-x^3)))/(sqrt(Pi))+1/1260 x+(x c[0]+22 x c[4]+x c[1] sin(x)-5 x c[3] sin(x)+123 x c[5] sin(x)-x cos(x) c[0]-22 x cos(x) c[4]-c[1] cos(x) x^2-c[2] cos(x) x^3+2 c[2] sin(x) x^2-c[3] cos(x) x^4+3 c[3] sin(x) x^3+5 c[3] cos(x) x^2-c[4] cos(x) x^5+4 c[4] sin(x) x^4+12 c[4] cos(x) x^3-24 c[4] sin(x) x^2-c[5] cos(x) x^6+5 c[5] sin(x) x^5+21 c[5] cos(x) x^4-63 c[5] sin(x) x^3-123 c[5] cos(x) x^2) (c[0]+c[1] x+c[2] (x^2+2)+c[3] (x^3+x)+c[4] (x^4-2)+c[5] (x^5-3 x-x^3))"
proc (x) options operator, arrow; ((8/3)*x^3-2*sqrt(x))*(c[0]+Typesetting:-delayDotProduct(c[1], x, true)+c[2]*(x^2+2)+c[3]*(x^3+x)+c[4]*(x^4-2)+c[5]*(x^5-3*x-x^3))/sqrt(Pi)+Typesetting:-delayDotProduct(1/1260, x, true)+(Typesetting:-delayDotProduct(x, c[0], true)+22*x*c[4]+Typesetting:-delayDotProduct(x, c[1], true)*sin(x)-5*x*c[3]*sin(x)+123*x*c[5]*sin(x)-Typesetting:-delayDotProduct(x, cos(x), true)*c[0]-22*x*cos(x)*c[4]-c[1]*cos(x)*x^2-c[2]*cos(x)*x^3+2*c[2]*sin(x)*x^2-c[3]*cos(x)*x^4+3*c[3]*sin(x)*x^3+5*c[3]*cos(x)*x^2-c[4]*cos(x)*x^5+4*c[4]*sin(x)*x^4+12*c[4]*cos(x)*x^3-24*c[4]*sin(x)*x^2-c[5]*cos(x)*x^6+5*c[5]*sin(x)*x^5+21*c[5]*cos(x)*x^4-63*c[5]*sin(x)*x^3-123*c[5]*cos(x)*x^2)*(c[0]+Typesetting:-delayDotProduct(c[1], x, true)+c[2]*(x^2+2)+c[3]*(x^3+x)+c[4]*(x^4-2)+c[5]*(x^5-3*x-x^3)) end proc
"H(f,alpha,x):=Int((x-s)^(alpha-1)*f(s)/GAMMA(alpha), s = 0 .. x)"
proc (f, alpha, x) options operator, arrow; Int((x-s)^(alpha-1)*f(s)/GAMMA(alpha), s = 0 .. x) end proc
`assuming`([value(%)], [x > 0])
H(f, alpha, x)
Int((((8/3)*s^3-2*s^(1/2))*(c[0]+c[1]*s+c[2]*(s^2+2)+c[3]*(s^3+s)+c[4]*(s^4-2)+c[5]*(s^5-3*s-s^3))/Pi^(1/2)+(1/1260)*s+(s*c[0]+22*s*c[4]+c[1]*s*sin(s)-5*s*c[3]*sin(s)+123*s*c[5]*sin(s)-s*cos(s)*c[0]-22*s*cos(s)*c[4]-c[1]*cos(s)*s^2-c[2]*cos(s)*s^3+2*c[2]*sin(s)*s^2-c[3]*cos(s)*s^4+3*c[3]*sin(s)*s^3+5*c[3]*cos(s)*s^2-c[4]*cos(s)*s^5+4*c[4]*sin(s)*s^4+12*c[4]*cos(s)*s^3-24*c[4]*sin(s)*s^2-c[5]*cos(s)*s^6+5*c[5]*sin(s)*s^5+21*c[5]*cos(s)*s^4-63*c[5]*sin(s)*s^3-123*c[5]*cos(s)*s^2)*(c[0]+c[1]*s+c[2]*(s^2+2)+c[3]*(s^3+s)+c[4]*(s^4-2)+c[5]*(s^5-3*s-s^3)))/((x-s)^(1/2)*Pi^(1/2)), s = 0 .. x)
(14)
z := value(%)
int((((8/3)*s^3-2*s^(1/2))*(c[0]+c[1]*s+c[2]*(s^2+2)+c[3]*(s^3+s)+c[4]*(s^4-2)+c[5]*(s^5-3*s-s^3))/Pi^(1/2)+(1/1260)*s+(s*c[0]+22*s*c[4]+c[1]*s*sin(s)-5*s*c[3]*sin(s)+123*s*c[5]*sin(s)-s*cos(s)*c[0]-22*s*cos(s)*c[4]-c[1]*cos(s)*s^2-c[2]*cos(s)*s^3+2*c[2]*sin(s)*s^2-c[3]*cos(s)*s^4+3*c[3]*sin(s)*s^3+5*c[3]*cos(s)*s^2-c[4]*cos(s)*s^5+4*c[4]*sin(s)*s^4+12*c[4]*cos(s)*s^3-24*c[4]*sin(s)*s^2-c[5]*cos(s)*s^6+5*c[5]*sin(s)*s^5+21*c[5]*cos(s)*s^4-63*c[5]*sin(s)*s^3-123*c[5]*cos(s)*s^2)*(c[0]+c[1]*s+c[2]*(s^2+2)+c[3]*(s^3+s)+c[4]*(s^4-2)+c[5]*(s^5-3*s-s^3)))/((x-s)^(1/2)*Pi^(1/2)), s = 0 .. x)
(15)
(16)
Download proplem_in_maple.mw
hi
i have n  initial condition like x(0)=a0   ,x'(0)=a1       .....x(n-1)(0)=an-1  and also n equations like S[i]. i d like to write following code in maple
S[i]- ai-1  =0 for i=1,2,..,n
would you please help me how   should i  do it
thanks a lot
First 603 604 605 606 607 608 609 Last Page 605 of 2458
