f(x) := piecewise(0 < x, x^(3/2)*sin(1/x), x = 0, 0, undefined);
plot(f(x));
gives me the following error:
Error, (in plot) incorrect first argument piecewise(0 < x, (HFloat(2.739493386336394e-116)+HFloat(2.739493386336394e-116)*I)*x^(3/2), x = 0, 0, undefined)
I just want to see the function plot. With Wolfram Alpha this is no deal at all!
I used the implicit function to draw two images, how to display only the intersection of two images? Or, how do I draw the x^2+y^2+z^2=1 image under x+y+z=0 condition? Code show as above.Thank you.
Is it because I have handed subs a multiset or is it because I used the "``" things in the code producing my set? I seemed to remember algsubs and subs working perfectly well regardless of the dimensions of the argument in previous times i have needed it.
abCaseSet := {[`0<a<1`, `0<b<1`], [`0<a<1`, `b=-1`], [`0<a<1`, `b=0`], [`0<a<1`, `b=1`], [`0<a<1`, `1<b<&infin;`], [`0<a<1`, -`1<b<0`], [`0<a<1`, -`&infin;<b<-1`], [`a=-1`, `0<b<1`], [`a=-1`, `b=-1`], [`a=-1`, `b=0`], [`a=-1`, `b=1`], [`a=-1`, `1<b<&infin;`], [`a=-1`, -`1<b<0`], [`a=-1`, -`&infin;<b<-1`], [`a=0`, `0<b<1`], [`a=0`, `b=-1`], [`a=0`, `b=0`], [`a=0`, `b=1`], [`a=0`, `1<b<&infin;`], [`a=0`, -`1<b<0`], [`a=0`, -`&infin;<b<-1`], [`a=1`, `0<b<1`], [`a=1`, `b=-1`], [`a=1`, `b=0`], [`a=1`, `b=1`], [`a=1`, `1<b<&infin;`], [`a=1`, -`1<b<0`], [`a=1`, -`&infin;<b<-1`], [`1<a<&infin;`, `0<b<1`], [`1<a<&infin;`, `b=-1`], [`1<a<&infin;`, `b=0`], [`1<a<&infin;`, `b=1`], [`1<a<&infin;`, `1<b<&infin;`], [`1<a<&infin;`, -`1<b<0`], [`1<a<&infin;`, -`&infin;<b<-1`], [-`1<a<0`, `0<b<1`], [-`1<a<0`, `b=-1`], [-`1<a<0`, `b=0`], [-`1<a<0`, `b=1`], [-`1<a<0`, `1<b<&infin;`], [-`1<a<0`, -`1<b<0`], [-`1<a<0`, -`&infin;<b<-1`], [-`&infin;<a<-1`, `0<b<1`], [-`&infin;<a<-1`, `b=-1`], [-`&infin;<a<-1`, `b=0`], [-`&infin;<a<-1`, `b=1`], [-`&infin;<a<-1`, `1<b<&infin;`], [-`&infin;<a<-1`, -`1<b<0`], [-`&infin;<a<-1`, -`&infin;<b<-1`]}
map(subs, {[`0<a<1`, `0<b<1`], [`0<a<1`, `b=-1`], [`0<a<1`, `b=0`], [`0<a<1`, `b=1`], [`0<a<1`, `1<b<&infin;`], [`0<a<1`, -`1<b<0`], [`0<a<1`, -`&infin;<b<-1`], [`a=-1`, `0<b<1`], [`a=-1`, `b=-1`], [`a=-1`, `b=0`], [`a=-1`, `b=1`], [`a=-1`, `1<b<&infin;`], [`a=-1`, -`1<b<0`], [`a=-1`, -`&infin;<b<-1`], [`a=0`, `0<b<1`], [`a=0`, `b=-1`], [`a=0`, `b=0`], [`a=0`, `b=1`], [`a=0`, `1<b<&infin;`], [`a=0`, -`1<b<0`], [`a=0`, -`&infin;<b<-1`], [`a=1`, `0<b<1`], [`a=1`, `b=-1`], [`a=1`, `b=0`], [`a=1`, `b=1`], [`a=1`, `1<b<&infin;`], [`a=1`, -`1<b<0`], [`a=1`, -`&infin;<b<-1`], [`1<a<&infin;`, `0<b<1`], [`1<a<&infin;`, `b=-1`], [`1<a<&infin;`, `b=0`], [`1<a<&infin;`, `b=1`], [`1<a<&infin;`, `1<b<&infin;`], [`1<a<&infin;`, -`1<b<0`], [`1<a<&infin;`, -`&infin;<b<-1`], [-`1<a<0`, `0<b<1`], [-`1<a<0`, `b=-1`], [-`1<a<0`, `b=0`], [-`1<a<0`, `b=1`], [-`1<a<0`, `1<b<&infin;`], [-`1<a<0`, -`1<b<0`], [-`1<a<0`, -`&infin;<b<-1`], [-`&infin;<a<-1`, `0<b<1`], [-`&infin;<a<-1`, `b=-1`], [-`&infin;<a<-1`, `b=0`], [-`&infin;<a<-1`, `b=1`], [-`&infin;<a<-1`, `1<b<&infin;`], [-`&infin;<a<-1`, -`1<b<0`], [-`&infin;<a<-1`, -`&infin;<b<-1`]}, a = A)
Error, invalid input: subs received [`0<a<1`, `0<b<1`], which is not valid for its 1st argument
Download subsQuestionMP.mw
Why Maple returns -1/x as singular solution below when this solution can be obtained from the general solution when constant of integration is zero?
ode:=2*y(x)+2*x*y(x)^2+(2*x+2*x^2*y(x))*diff(y(x),x) = 0;
dsolve(ode,singsol=false);
2*y(x)+2*x*y(x)^2+(2*x+2*x^2*y(x))*(diff(y(x), x)) = 0
y(x) = (-1-_C1)/x, y(x) = (-1+_C1)/x
sol:=[dsolve(ode,singsol=essential)];
[y(x) = -1/x, y(x) = (-1-_C1)/x, y(x) = (-1+_C1)/x]
subs(_C1=0,sol)
[y(x) = -1/x, y(x) = -1/x, y(x) = -1/x]
Download essential.mw
How can I get a seq(seq(...))) to print each sub-sequence per line? It currently prints all the sequences as one big sequence. I'd like some way to tell it to "eol".
I've made this proc and it has 2 outputs
How do I fix that?
Some mathematical functions and also some (not so) inert functions are implemented as objects.
For example, Perm is used to represent permutations.
p :=Perm([2,3,1,5,4]);  # ==> disjoint cycles representation
        p:=(1,2,3)(4,5);
lprint(p);
Perm([[1, 2, 3], [4, 5]])
Perm acts as an inert function (like RootOf) but it's an object.
Is it possible to convert it into a true inert form such as PERM([[1, 2, 3], [4, 5]]) and so, being able to extract the arguments with op?
In this specific case we may use
convert(p, disjcyc);
       [[1, 2, 3], [4, 5]]
but this is possible only because Perm has a convert export.
So, is it possible to obtain the arguments directly (without convert)?
This would be useful for other situations.
Hi there,
ist there any possibility to change the native look and feel of the gui? I use Arch-Linux. I've tried other java runtimes instead of the shipped. Maple works, but only with the awful look and feel :D
Thx :)
Heiko
We all know that Maple's Latex is not the best of Maple to say the least.
But this one is really strange. Maple prints a `1` for no apparant reason in the latex which makes it ugly.
I wonder if Maplesoft still maintains its Latex conversion code at all?  So one can at least hope may be one day all of this will get fixed? Year after year, and Maple's Latex still not changed.
If Mapesoft do not intend to make any changes in its Latex conversion software at all, it will be good if an official statement is made in this regards so that at least customers know.
sol:=dsolve((x-a)*(x-b)*diff(y(x),x)+k*(y(x)-a)*(y(x)-b) = 0,y(x)):
sol:=subs(_C1=C[1],sol);
y(x) = ((x-b)^(-k)*(x-a)^k*a*exp(a*k*C[1]-b*k*C[1])-(x-b)^(-k)*(x-a)^k*b*exp(a*k*C[1]-b*k*C[1])+b*((-x+b)/(-x+a))^(-k)*exp(a*k*C[1]-b*k*C[1])-b)/(-1+((-x+b)/(-x+a))^(-k)*exp(a*k*C[1]-b*k*C[1]))
latex(sol)
y \left( x \right) ={1 \left(  \left( x-b \right) ^{-k} \left( x-a
 \right) ^{k}a{{\rm e}^{akC_{{1}}-bkC_{{1}}}}- \left( x-b \right) ^{-k
} \left( x-a \right) ^{k}b{{\rm e}^{akC_{{1}}-bkC_{{1}}}}+b \left( {
\frac {-x+b}{-x+a}} \right) ^{-k}{{\rm e}^{akC_{{1}}-bkC_{{1}}}}-b
 \right)  \left( -1+ \left( {\frac {-x+b}{-x+a}} \right) ^{-k}{{\rm e}
^{akC_{{1}}-bkC_{{1}}}} \right) ^{-1}}
Download why_1_in_latex.mw
Why odetest sometimes fail to give 0  from odetest when simply using C[1] instead of _C1 as constant of integration?
I do not remember now if I asked about this before now. But for me as a user, this does not look right. I like to use C[1] instead of _C1 as the constant of integration as it looks better in Latex. I had no idea it will make a difference to odetest what the constant of integration symbol used is.
Is this a known issue? Do you consider this a bug? Maple 2019.1 on windows 10.
ode:= x^2*diff(y(x),x)+x*y(x)+sqrt(y(x)) = 0;
x^2*(diff(y(x), x))+x*y(x)+y(x)^(1/2) = 0
sol_1:=sqrt(y(x))=1/x+_C1/sqrt(x);
odetest(sol_1,ode)
y(x)^(1/2) = 1/x+_C1/x^(1/2)
sol_2:=subs(_C1=C[1],sol_1);
odetest(sol_2,ode); #why this now fails??
y(x)^(1/2) = 1/x+C[1]/x^(1/2)
-y(x)^(1/2)-y(x)^(1/2)*x^(1/2)*C[1]+x*y(x)
sol_3:=subs(C[1]=_C1,sol_2);
odetest(sol_3,ode)
Download why_odetest_fail.mw
I was playing with plots:-fieldplot in Maple 2019 and found that sometime the grid option gives a strange result.  The code I used was
fieldplot([-x/(x^2+y^2)^1.5,-y/(x^2+y^2)^1.5],x=-1..1,y=-1..1);
fieldplot([-x/(x^2+y^2)^1.5,-y/(x^2+y^2)^1.5],x=-1..1,y=-1..1,grid=[8,8]);
fieldplot([-x/(x^2+y^2)^1.5,-y/(x^2+y^2)^1.5],x=-1..1,y=-1..1,grid=[7,7]);
The first two plots come out as expected.  The third plot has (0,0) in the grid, a point where the vector field does not exist.  Rather than giving an error or ignoring the point, Maple 2019 (and 2018) plots a single arrow through the origin. The file with plots is below.  I hope that this can be changed to give a different output.
Download fieldplots_1.mw
I am trying to use the StringTools package to extract the URLs from the html file exported from Microsoft Edge when i wish to transfer these to another browser, in a text file without all of the nonsense I havent learnt yet.
I just want to trim the file name to set up a Boolean function to check it's update for the day and the output went crazy and decided to spoil my day again
with(StringTools);
[Anagrams, AndMap, ApproximateSearch, ApproximateSearchAll, ArithmeticMean, Border, BorderArray, BorderLength, CamelCase, Capitalize, CaseJoin, CaseSplit, Center, Centre, Char, CharacterFrequencies, CharacterMap, Chomp, Chop, CommonPrefix, CommonSuffix, Compare, CompareCI, Compress, CountCharacterOccurrences, Decode, Delete, DeleteSpace, DifferencePositions, Drop, EditDistance, Encode, Entropy, Escape, Exchange, ExpandCharacterClass, ExpandTabs, Explode, Fence, Fibonacci, Fill, FirstFromLeft, FirstFromRight, FormatMessage, FormatTime, FromByteArray, Generate, GenerateIdentifier, Group, HammingDistance, HammingSearch, HammingSearchAll, Has, HasASCII, HasAlpha, HasAlphaNumeric, HasBinaryDigit, HasControlCharacter, HasDigit, HasGraphic, HasHexDigit, HasIdentifier, HasIdentifier1, HasLower, HasOctalDigit, HasPrintable, HasPunctuation, HasSpace, HasUpper, HasVowel, Hash, Implode, Indent, IndexOfCoincidence, Insert, Iota, IsASCII, IsAlpha, IsAlphaNumeric, IsAnagram, IsBalanced, IsBinaryDigit, IsConjugate, IsControlCharacter, IsDerangement, IsDigit, IsEodermdrome, IsGraphic, IsHexDigit, IsIdentifier, IsIdentifier1, IsLower, IsMonotonic, IsOctalDigit, IsPalindrome, IsPeriod, IsPermutation, IsPrefix, IsPrimitive, IsPrintable, IsPunctuation, IsSorted, IsSpace, IsSubSequence, IsSuffix, IsUpper, IsVowel, Join, Kasiski, LeftFold, LeftRecursivePathOrder, Length, LengthSplit, Levenshtein, LexOrder, LongestCommonSubSequence, LongestCommonSubString, LowerCase, LyndonFactors, Map, MatchFence, MaxChar, MaximalPalindromicSubstring, Metaphone, MinChar, MinimumConjugate, MonotonicFactors, NGrams, NthWord, OrMap, Ord, OtherCase, Overlap, PadLeft, PadRight, ParseTime, PatternCanonicalForm, PatternDictionary, PatternEquivalent, Period, Permute, PrefixDistance, PrimitiveRoot, Random, Randomize, Readability, RegMatch, RegSplit, RegSub, RegSubs, Remove, Repeat, Repeats, RevLexOrder, Reverse, RightFold, RightRecursivePathOrder, Rotate, Search, SearchAll, Select, SelectRemove, Sentences, Shift, ShortLexOrder, ShortRevLexOrder, SimilarityCoefficient, Snarf, Sort, SortPermutation, Soundex, Split, Squeeze, Stem, StringBuffer, StringSplit, SubString, Substitute, SubstituteAll, SuffixDistance, Support, SyllableLength, Tabulate, Take, ThueMorse, ToByteArray, Trim, TrimLeft, TrimRight, Uncompress, Unique, UpperCase, Visible, WildcardMatch, WordContaining, WordCount, WordEnd, WordStart, Words, WrapText]
currentdir("G:\\Computer Science\\EDGE\\fav_exports"):
if is(currentdir() = "G:\\Computer Science\\EDGE\\fav_exports") = true then "Edge favorites usb import html directory is the current file path" end if;
Filename0 := ListDirectory(currentdir())[]
"Microsoft_Edge_‎08_‎29_‎2019.html"
StringTools['Reverse']("Microsoft_Edge_‎08_‎29_‎2019.html")
"lmth.9102���_92���_80���_egdE_tfosorciM"
Delete(Delete(Filename0, 1 .. 15), nops(Delete(Filename0, 1 .. 14))-4 .. nops(Delete(Filename0, 1 .. 14)))
Error, (in StringTools:-Delete) invalid range
dt := ParseTime("%Y-%m-%d", "2002-11-05")
dt:-year, dt:-month, dt:-monthDay
2002, 11, 5
Download microsoft_edge_fav_import_fail.mw
Edit: I have gotten closer with the following:
with(StringTools);
Filename1 := StringTools:-Delete(Filename0, 1 .. nops(StringTools:-Explode(Filename0))-15)
"29_‎2019.html"
StringTools:-Delete(Filename1, nops(StringTools:-Explode(Filename1))-4 .. nops(StringTools:-Explode(Filename1)))
"29_‎2019"
StringTools:-Delete(StringTools:-Delete(Filename0, 1 .. nops(Filename0)), nops(StringTools:-Delete(Filename0, 1 .. nops(Filename0)))-4 .. nops(StringTools:-Delete(Filename0, 1 .. 10)))
2002, 11, 5
Download microsoft_edge_fav_import_fail2.mw
In statistics a  "degree of freedom" is a strictly positive integer.
The three distributions ChiSquare, StudentT and FRatio from package Statistics have degrees of freedom as parameters. Nevertheless they accept any strictly positive real values for them.
(one can verify that their "Conditions" attribute is of the form [0 < n] instead of [n::posint]).
I think this ought to be corrected in future versions
A=B  but not able to simplify arctanh(A)-arctanh(B)  to be zero.  Why? Is there a workaround? Using Maple 2019.1
A:=((y*sqrt(3) + 3)*sqrt(3))/(6*sqrt(y^2 + 1));
B:=(y + sqrt(3))/(2*sqrt(y^2 + 1));
simplify(A-B)
(1/6)*(y*3^(1/2)+3)*3^(1/2)/(y^2+1)^(1/2)
(1/2)*(y+3^(1/2))/(y^2+1)^(1/2)
simplify(arctanh(A)-arctanh(B))
arctanh((1/6)*(y*3^(1/2)+3)*3^(1/2)/(y^2+1)^(1/2))-arctanh((1/2)*(y+3^(1/2))/(y^2+1)^(1/2))
simplify(arctanh(A)-arctanh(B),trig)
simplify(arctanh(A)-arctanh(B)) assuming positive
simplify(arctanh(A)-arctanh(B),trig) assuming positive
plot(arctanh(A),y=-Pi..Pi)
plot(arctanh(B),y=-Pi..Pi)
Download will_not_simplify.mw
Compare to Mathematica:
Dear Users!
Hope you all are fine with everything. How we can identify the same equations from a number of equations using maple command, like
Eq1:=5.09295817894067*`&tau;u`[1, 1]-30.5577490736439*`&tau;u`[2, 1]+178.253536262923*`&tau;u`[3, 1]-30.5577490736439*`&tau;u`[1, 2]+183.346494441862*`&tau;u`[2, 2]-1069.52121757753*`&tau;u`[3, 2]+178.253536262923*`&tau;u`[1, 3]-1069.52121757753*`&tau;u`[2, 3]+6238.87376920228*`&tau;u`[3, 3];
Eq2:=5.09295817894067*`&tau;u`[1, 1]+10.1859163578814*`&tau;u`[2, 1]+15.2788745368241*`&tau;u`[3, 1]-30.5577490736439*`&tau;u`[1, 2]-61.1154981472883*`&tau;u`[2, 2]-91.6732472209439*`&tau;u`[3, 2]+178.253536262923*`&tau;u`[1, 3]+356.507072525849*`&tau;u`[2, 3]+534.760608788841*`&tau;u`[3, 3]-3/7;
Eq3:=5.09295817894067*`&tau;u`[1, 1]-30.5577490736439*`&tau;u`[2, 1]+178.253536262923*`&tau;u`[3, 1]+10.1859163578814*`&tau;u`[1, 2]-61.1154981472883*`&tau;u`[2, 2]+356.507072525849*`&tau;u`[3, 2]+15.2788745368241*`&tau;u`[1, 3]-91.6732472209439*`&tau;u`[2, 3]+534.760608788841*`&tau;u`[3, 3]-9/7;
Eq4:=5.09295817894067*`&tau;u`[1, 1]+10.1859163578814*`&tau;u`[2, 1]+15.2788745368241*`&tau;u`[3, 1]+10.1859163578814*`&tau;u`[1, 2]+20.3718327157631*`&tau;u`[2, 2]+30.5577490736484*`&tau;u`[3, 2]+15.2788745368241*`&tau;u`[1, 3]+30.5577490736484*`&tau;u`[2, 3]+45.8366236104784*`&tau;u`[3, 3]-12/7;
Eq5:=5.09295817894067*`&tau;u`[1, 1]-30.5577490736439*`&tau;u`[2, 1]+178.253536262923*`&tau;u`[3, 1]+50.9295817894067*`&tau;u`[1, 2]-305.577490736439*`&tau;u`[2, 2]+1782.53536262923*`&tau;u`[3, 2]+504.202859715131*`&tau;u`[1, 3]-3025.21715829077*`&tau;u`[2, 3]+17647.1000900295*`&tau;u`[3, 3]-18/7;
Eq6:=5.09295817894067*`&tau;u`[1, 1]+10.1859163578814*`&tau;u`[2, 1]+15.2788745368241*`&tau;u`[3, 1]+50.9295817894067*`&tau;u`[1, 2]+101.859163578814*`&tau;u`[2, 2]+152.788745368241*`&tau;u`[3, 2]+504.202859715131*`&tau;u`[1, 3]+1008.40571943027*`&tau;u`[2, 3]+1512.60857914560*`&tau;u`[3, 3]-3;
Eq7:=5.09295817894067*`&tau;u`[1, 1]+10.1859163578814*`&tau;u`[2, 1]+15.2788745368241*`&tau;u`[3, 1]-30.5577490736439*`&tau;u`[1, 2]-61.1154981472883*`&tau;u`[2, 2]-91.6732472209439*`&tau;u`[3, 2]+178.253536262923*`&tau;u`[1, 3]+356.507072525849*`&tau;u`[2, 3]+534.760608788841*`&tau;u`[3, 3]-3/7;
Eq8:=5.09295817894067*`&tau;u`[1, 1]+10.1859163578814*`&tau;u`[2, 1]+15.2788745368241*`&tau;u`[3, 1]+10.1859163578814*`&tau;u`[1, 2]+20.3718327157631*`&tau;u`[2, 2]+30.5577490736484*`&tau;u`[3, 2]+15.2788745368241*`&tau;u`[1, 3]+30.5577490736484*`&tau;u`[2, 3]+45.8366236104784*`&tau;u`[3, 3]-12/7;
Eq9:=41.7622570673196*`&tau;u`[3, 1]+41.7622570673196*`&tau;u`[1, 3]+15.2788745368220*`&tau;u`[1, 1]+83.5245141346398*`&tau;u`[2, 3]+30.5577490736443*`&tau;u`[2, 1]+113.063671572516*`&tau;u`[3, 3]+83.5245141346398*`&tau;u`[3, 2]+30.5577490736443*`&tau;u`[1, 2]+61.1154981472892*`&tau;u`[2, 2];
In above equations Eq2 and Eq7; Eq4 and Eq8 are same. If I have set of 100 equation how I can identify similar equations?
@acer @Kitonum @Preben Alsholm
First 647 648 649 650 651 652 653 Last Page 649 of 2425
