i literally cant figure out how to pay money for this
Worm greeting to all
I use the following to plot two orthogonal vectors display(arrow(1,0), arrow(0,1)) as
  Now, I need to shift these two orthogonal vectors to another point.
Does anyone know how the command PLOT(POLYGONS(...)) fills  polygons?
I'm interested in polygons that are not simple, that is polygons for which 2 different sides without common vertex do not intersect.
Is it possible to change programmatically the permissions of a file without using ssystem?
Such as in ssystem("chmod +x MyFile") for instance
TIA
I'm using dsolve command to solve a differential equation. Using infolevel to 3 will tell me the classification of said DE. However, how can I see the step by step solution? I'm using Maple as a study tool so I do solve manually a DE then I'd like to compare my answer with Maple's. How can I acomplish this? Thanks in advance.
How do I write plot ceil(x) mod 2 properly?
If I write:
plot(ceil(x) mod 2, x = 0 .. 4)
it produces a step pattern and not a square wave. (Only 0 and 1 should be plotted.)
Can i use the file tools package to change the file extension of a file or open up a powershell terminal to do so from within the maple interface via command line?
I need to solve a system of differential equations, which have been obtained from the method of multiple scales. However, for some reason Maple returns an error and will not give a solution. Could someone help me find a solution? The associated filed is attached.
File.mw
So, basically i plan to define procedures based on if conditions that will assume arbitarily large float approximations as being infinity, as with the example i have uploaded, but i feel that i need some people from here that are smarter than me to tell me why this is going to be terrible or what i need to consider.
I am willing to consider my current view naive and or inept, however i feel as if computer algebra systems will eventually develop means of reducing the need for floating point results by making concise implicit steps of manipulation on floating point computations, naturally i feel as if these routines are evidence that maybe some of the maple programmers have such an objective, but i do tend to misinterpret everything all the time.
convert(evalf[100](1/RootOf(floor(_Z))), 'rational', 'exact')
infinity
Download primes_Question_Algebra.mw
Please may I know if you can offer ma student's discount ob the seleted version.
Fred.
How can I apply differential transformation method in differential equations with maple commands .DE is y'''(x)+xy''(x)-y(x)=0;
I solve a boundary value problem for a linear system of first order PDEs
in the unknowns u(x, t) and "v(x,t)."  Ultimately, I am interested in the graph
of the function v(0, t) but numerical artifacts distort that graph badly by
imposing spurious oscillation.
Is there a way to maneuver the calculations to obtain the graph of v(0, t)
without the oscillation?
pde1 := diff(u(x,t),t)=diff(v(x,t),x);
diff(u(x, t), t) = diff(v(x, t), x)
pde2 := diff(u(x,t),x)=v(x,t);
diff(u(x, t), x) = v(x, t)
ibc := u(x,0)=1, u(0,t)=0, u(1,t)=0;
u(x, 0) = 1, u(0, t) = 0, u(1, t) = 0
dsol := pdsolve({pde1,pde2}, {ibc}, numeric, spacestep=0.01, timestep=0.01);
_m139872446597344
dsol:-value(output=listprocedure):
my_u := eval(u(x,t), %):
my_v := eval(v(x,t), %%):
plot3d(my_u(x,t), x=0..1, t=0..0.5);
plot3d(my_v(x,t), x=0..1, t=0..0.5);
The oscillations are numerical artifacts.  Can they be avoided?
plot(my_v(0,t), t=0..0.5);
A side comment: By eliminating vbetween the two PDEs we see that u
satisfies the standard heat equation, thus vis the flux.  The expression
v(0, t) expresses the heat flux at the boundary, and that's what I am after.
Download calculating-flux-in-the-heat-equation.mw
I open a completely new document, type in a few simple expressions and get this weird complex number out. Can someone pleas help me fix this?
In this question at here https://tex.stackexchange.com/questions/503745/how-can-i-get-correct-the-point-a-and-b-automatically-in-this-picture/503838?noredirect=1#comment1272706_503838
The points A and B lie on the circle is intersection of the sphere x^2 + y^2 + (z-3)^2 = 25 and the plane z = 0.
How can I find coordinates of the points A and B by Maple?
First 645 646 647 648 649 650 651 Last Page 647 of 2425
