I have two vectors, I would like if possible using maple  I find  determine the real number t  such that  the subset  { v1, v2} of C^2 ( where C is the set of complex number) is  linearly dependent?
Linearly_dependence_of_C2.mw
Many thinks for your help
Hi, I have the following simple differential equation.
2x dx -9y^2 dy = 0
How can I enter the command to solve it? I know I'm supposed to use dsolve command, but I keep getting an input error saying that it expected an ODE. Google says that said message is because for whatever reason Maple cannot understand dx or dy, and that instead I need to use diff command. But when I enter:
2x diff(x) - 9 y^2 diff(y) = 0
I get another error. I have tried other combinations, but at times I get errors like y(x) and y cannot both appear in the given ODE, which I don't understand why they can't as they are like basic run of the mill ODEs, so I'm a bit confused.
I have also checked Maple's docs but they don't help either, I tried the first example given here:
https://www.maplesoft.com/support/help/Maple/view.aspx?path=dsolve
 and I got the same "expecting an ODE or a set or list of ODEs" as in my own examples, so I'm guessing the docs are assuming steps or some configuration.
How am I supposed to enter the command? Thanks in advance!
Lecture 4 - Problem 2
a)
> a := -2100; b := 2100; N := 8; h := (b-a)/N; C := 4491; x := [seq(h, h = -2100 .. 2100, h)]; y := proc (x) options operator, arrow; sqrt(1+((1/2)*exp(x/C)-(1/2)*exp(-x/C))^2) end proc; evalf(y(x[1])); evalf(y(x[N+1])); L := (1/3)*h*(y(x[1])+4*(y(x[2])+y(x[4])+y(x[6])+y(x[N]))+2*(y(x[3])+y(x[5])+y(x[N-1]))+y(x[N+1])); evalf(L);
                             -2100
                              2100
                               8
                              525
                              4491
     [-2100, -1575, -1050, -525, 0, 525, 1050, 1575, 2100]
         /                           2\
         |    /1    /x\   1    /  x\\ |
x -> sqrt|1 + |- exp|-| - - exp|- -|| |
         \    \2    \C/   2    \  C// /
                          1.111332350
                          1.111332350
                                           (1/2)
         /                               2\
         |    /1    /-700\   1    /700 \\ |
     175 |1 + |- exp|----| - - exp|----|| |
         \    \2    \1497/   2    \1497// /
                                               (1/2)
              /                              2\
              |    /1    /-175\   1    /175\\ |
        + 700 |1 + |- exp|----| - - exp|---|| |
              \    \2    \499 /   2    \499// /
                                                (1/2)
              /                               2\
              |    /1    /-175\   1    /175 \\ |
        + 700 |1 + |- exp|----| - - exp|----|| |
                                                (1/2)
              /                               2\
              |    /1    /175 \   1    /-175\\ |
                                               (1/2)
              /                              2\
              |    /1    /175\   1    /-175\\ |
        + 700 |1 + |- exp|---| - - exp|----|| |
              \    \2    \499/   2    \499 // /
                                                (1/2)
              /                               2\
              |    /1    /-350\   1    /350 \\ |
        + 350 |1 + |- exp|----| - - exp|----|| |      + 350
                                                (1/2)
              /                               2\
              |    /1    /350 \   1    /-350\\ |
                                                (1/2)
              /                               2\
              |    /1    /700 \   1    /-700\\ |
        + 175 |1 + |- exp|----| - - exp|----|| |
                          4354.742601
> L := (1/3)*h*(y(x[1])+4*add(y(i), i = y(x[2]) .. y(x[N]), 2)+2*add(y(i), i = y(x[3]) .. y(x[N-1]), 2)+y(x[N+1])); evalf(L);
Error, invalid input: add expects 2 arguments, but received 3
                          4354.742601
We've just decided to jump from Mathcad to Maple, and are doing our very first steps with Maple.
Our company is a small sized engineering company (15 employees), and what I am looking for is a bit help to make a working company setup.
This includes in the first run - how do I create and tell Maple where to find those items?
  • Templates with company logo
  • Programs and packages
  • Are there any configuration variables that can / should be set?
  • Are there any other common files that can be made accessible for all on a common network server?
Error
can not raise the datalimit above hard limit
my new notebook has 32GB memory
kernelopts(datalimit=28*unit(gibibtye)):
do i need to assign datalimit with kernelopts?
I remember i set a trick to protected this file
now I can read and run
but return above error
does it mean that I do not need to set limit?
Minimise(eq1, {eq2>=0,eq3>=0,eq4>=0, a1<>0,a2<>0,a3<>0,a4<>0})
can not handle strict inequalities error
I created a user library and added a component that I had created from a shared subsystem and this worked fine.
I edited the component in the library to add some additional functionality and saved it.  I then had to reload the library in Maplesim but now I get this error everytime I try to run the simulation:
Cannot resolve `ControlLogix.PIDE` in model `Main`; there is no `ControlLogix` visible
Yet I dragged and dropped the component PIDE from the ControlLogix library.
Can anyone help me to resolve this?
I have specified the problem in the red comments of the worksheet i am uploading:
with(FileTools):
currentdir("H:\\USB 1 BACKUP\\ESD-USB\\maple_library"):
["ArithmeticMean_Display_Definition.txt", "BinomialCoefficient_PadicOrder.txt", "Binomial_coefficent_p_adic_valuation_Display_Definition.txt", "CompareGeometricMean.txt", "CompareHarmonicMean.txt", "CompareMean.txt", "Compare_Arithmetic_Mean_Description.txt", "Compare_Mean_Description.txt", "ConsistencyCompareGeometricMean.txt", "ConsistencyCompareHarmonicMean.txt", "ConsistencyCompareMean.txt", "delta.txt", "delta_Display_Definition.txt", "digit_base_conversion.txt", "EulerProduct.txt", "GeometricMean_Display_Definition.txt", "HarmonicMean_Display_Definition.txt", "Mobius.txt", "MultiplicitySet.txt", "omega.txt", "p_adic_valuation.txt", "p_adic_valuation_Display_Definition.txt", "RationalParition.txt", "SquareFreeCount.txt", "WilsonTheoremLemma.txt", "WilsonTheoremLemma1_Display_Definition.txt", "WilsonTheoremLemma2_Display_Definition.txt", "WilsonTheoremLemma3_Display_Definition.txt"]
with(StringTools):
L := map(StringTools:-Has, FunctionList, "_Display_Definition"):
S[display] := {}:
for k to nops(L) do if L[k] = true then S[display] := `union`(S[display], {FunctionList[k]}) else S[procedure] := `union`(S[procedure], {FunctionList[k]}) end if end do;
for t to nops(S[display]) do read S[display][t] end do;
S[display]
{"p_adic_valuation.txt", "Compare_Mean_Description.txt", "delta_Display_Definition.txt", "digit_base_conversion.txt", "ArithmeticMean_Display_Definition.txt", "BinomialCoefficient_PadicOrder.txt", "Compare_Arithmetic_Mean_Description.txt", "GeometricMean_Display_Definition.txt", "HarmonicMean_Display_Definition.txt", "p_adic_valuation_Display_Definition.txt", "WilsonTheoremLemma1_Display_Definition.txt", "WilsonTheoremLemma2_Display_Definition.txt", "WilsonTheoremLemma3_Display_Definition.txt", "Binomial_coefficent_p_adic_valuation_Display_Definition.txt"}
read S[display][5]
`The Arithmetic Mean for the multiset:`
[a[j]][j = 1 .. n]
mu[A] = (sum(a[j], j = 1 .. n))/n
read S[display][7]
`CompareArithmeticMean(L,N) will return output informing you of what percentage of N random`
`natural number multisets of the same length as the multiset L and same range=[min(L),max(L)]`
`have a lower arithmetic mean than L, equal to L, and greater than L.`
Download possible_string_tools_bug.mw
Can someone explain the content and detail of this message:
com.maplesoft.mathdoc.model.plot.PlotException: Unrecognized option in COLOR: RGBA
Have quadrature detected time domain complex data arrays.  Trying to fft array to get frequency domain arrays.  Arrays returned are always sinusoidal in nature rotating between + and - y axis.  Can not phase correct these sinusoidal frequency arrays.  Any ideas how to pretreat time domain arrays before fft or posttreat frequency domain arrays after fft in order to determine phase correction angles that will allow combination of real and imaginary frequency domain data points that are only in + y axis.
How can I set the alpha for the plot symbols? I would like to add some alpha for blending purposes(will help with the visual in my case).
Idealy I would like to plot a 2d "guassian" fade.
A warm greeting for all
How to import a figure from Mathematica to Maple.
Amr
I have a dependent and independent variables u(x),v(x),w(x),....diff( u(x),x$n)=U(k),diff( v(x),x$n)=V(k)......
Is it possible to create, diff(     , x$n)  is an operator or any differentiable function?
I'm having trouble connecting from Maple on Windows 10 to MSQL Server. I tried Microsoft recommended drivers such as sqljdbc_6.4.0.0, did (as I thought) all required steps. The only invariable result I get is "Cannot load driver". I was wandering if anyone had implemented such a construction. Driver name & version , connection string and Java version would be greatly appreciated. Another option is to have any driver, which connects to any of standard databases (Oracle, MySQL).  The only limitation is- it must be from Windows 7 or 10.
           A.B.
The results should be the same, right?
50/3.(Vector(2, {(1) = .72, (2) = 0.6e-1})) = Vector[column](%id = 18446745399574633758)NULL
NULLNULL
50/3*.72 = 12.00000000
50/3*0.6e-1 = 1.000000000NULL
Download test.mw
First 676 677 678 679 680 681 682 Last Page 678 of 2458
