which version of maple start to support Grid Computing Toolbox?
It has become more and more common to meet questions as labelled as "Spam". What does this classification mean?
Strangely if you click on the little red flag "Spam" it even seems that you can delete the corresponding question.
Does it mean that some people here have the power to decide if a question deserves to be answered or merits to be put on the trash?
Given that these questions are answered the same way than any other non spam labelled question, why are they labelled as spam?
Hi I need to write procedure to find a cubic equation... anyone could help me ...?
 Every time im working with maple and answer is in term of sin or cos maple dont calculate them for example it give me sin(pi/2) but i want it himself know that sin(pi/2)=1 some times i use of [eval] but it again dont calculate it what i should do?
Generate Matrix Automatically for solving Higher order Differential Equation For Chebyshev Polynomial
What is the concept of these terms?
(D[2, 2](T))(x, 0) = 0, (D[1, 1](T))(x, 0) = 0 ? I want to know these terms show
with respect by which parameter?
At a point in a worksheet I end up with an equation that has summations on both sides.  The range of summation is the same but the summands are different.  I want to remove the summations from both sides, keeping the equation with just the summands. How can this be done?  The only way I have found is to manually select each summand with the mouse and paste it into a new line which breaks the 'automation' of the script.
This
expr:='1/r^2*diff(r^2*diff(v(r),r),r)'
gives
And when evaluated second time it gives
expr
The question is, how to put expr back to its original form shown at the top?
I tried simplify, combine, etc.. but nothing puts back to same form.
The reason I am asking, is that I need put more complicated expression in form that resembles when I am looking at in textbook. For an example, the Laplacian
VectorCalculus:-Laplacian(u(r,theta,phi),'spherical'[r,theta,phi])
But the above should be the same as
So I figured if I can rewrite each term to look like in the shorter version above (complete derivative version), it will be easier for me to compare what Maple gives and the text book shows,
ps. I found that the following command in Maples gives a little clearer Laplacian, but it is still not as simplified as the book but it is better than using VectorCalculus:-Laplacian
Physics[Vectors]:-Laplacian(u(r,theta,phi));
At least this has each term a little more seprated.
Even using the command "discont=true", some of the functions I plot still present discontinuities, but some of them do not present.
How can I fix this? This one file ilustrates perfectly the problem.
file_discont.mw
Is there any way to automatically create a legend for a plot of a list of functions? The problem is, I'd rather not specify the legend and maple require the exact number so I cannot specify a generic length such as [1,2,3,4,5,6,7,8].
plot([f1(x), f2(x), f3(x), sin(x)*cos(x)*sin(3x^2 + cos(x))], x=1..34)
The point is that I do not want or care what the legend is(except the names shouldn't be long). I just want to be able to use it to select the plots easily and to be able to reference them(so the naming matters in that the order shoudl be obvious).
Sorry for bad english.
Hello. I can not realize such a thing. There is an equal tetrahedron NET on the plane. Choose a point on the edge and start a vector from it (the sum of red vectors with some integer coefficients). We obtain a closed geodesic. Depending on the coefficients, the geodesic will intersect the edges and faces in a different sequence. How to unNET into tetrahedron and so that the geodesic is displayed on it? Thank you in advance.
When I try to get a higher resolution plot using numpoints, the lines are jagged and look lower resolution.
plot(sin(x),x=-10..10,numpoints=3000,resolution=10000)plot(sin(x),x=-10..10,numpoints=400,resolution=10000)
You can see the difference, the first does not look anti-aliased whil ethe second does(although the 2nd looks far better on my comp)
A way to define a N *N matrix with the help of loop
with(inttrans):
sinc := x->piecewise(x = 0, 1, sin(Pi*x)/x/Pi):
S := x->sinc(x):
SE := x->sinc(x)*exp(-x^2):
plot(abs(fourier(SE(x),x,s)),s=0..5)
works fine for S but when trying to plot SE I get
I simply want to plot the fourier transform of a function so I can see it's frequency response. Maple seems to be breaking for more complex functions. It seems to be doing this when it can't evaluate the function exactly, which I don't care for plots.
Let s_n be the number of ternary strings (of 0s, 1s and 2s) of length n that have no
adjacent even digits.
For example, s_0 = 1 (the empty string),
s1 = 3 (the strings 0, 1 and 2),
while s2 = 5:  01; 10; 11; 12; 21;
We can compute by hand  Find s3; and we obtain 11
My question how can use maple to get a general recurrence relation for s_n.
many think for your help
First 723 724 725 726 727 728 729 Last Page 725 of 2459
