Hello pdsolve experts:
Using Maple 2018.2.1 and Physics 292 on windows 10.
pde := diff(w(x,y),x)+ (arccot(x)^n *y^2 + y-  arccot(x)^n )*diff(w(x,y),y) = 0;
pdsolve(pde,w(x,y));
When I try
PDEtools:-charstrip(pde,w(x,y))
It does not generate error.
Should pdsolve have generated this error message instead of returning no solution?
I found that when lambda2 take a small value this integration cannot be evaluated by maple is there any command to solve this problem
lambda1 := 0.733e-1; lambda2 := 5.3344; alpha := 4.8492
X[6] := evalf(int((Z^(lambda2/lambda1))^2*ln(Z)^2/((Z-1+alpha)^2*(Z^(lambda2/lambda1)-1+alpha)^3), Z = 1 .. infinity, numeric));
Download ask.mw
Good day everyone,
I have a problem building the code attached below. The series is not substituting F[0](eta) and T[0](eta).
Please, anyone with useful information should contact.
HAM_build.mw
i have a problem to solve this system ?
The program was written in 2004 with maple 6. Now i'am working by maple 18. And i did'nt launch the program. painleve_test.zip
Thank you for your interest in advance.
Hi everybody:
I have 12 equations with 12 unknowns(c(1),c(2),...,c(12) and omega), I want to obtain c(1),c(2),...,c(12) and omega, how can I do it? The Maple file(solve.mw) is attached.
with regards...
solve.mw
Hello my friends
I want to solve first order non-linear differential equation by maple 2018 but it does not give me the explicit form for a(t) as the function of time t.
this is my equation where z,k,c, and w are non zero constants
3*a(t)-a(t)^2-3*z*(diff(a(t), t))^2+k*c*a(t)+w/a(t) = 0
please guide me.
with the best regard
I would like to designate AU as currency for my application, rather than the USD.
I can do it to a degree, but when I use combine I have problems. Compare output 8 and 9 to 17 and 18. help?
CURRENCY.mw
I'm presently interested in PDE and I have just discovered the impressive work Nasser Abbasi,has done, and keeps doing, concerning the solution of PDE benchmarks with Maple and Mathematica.
https://www.12000.org/my_notes/pde_in_CAS/pdse3.htm
It seems that the result Maple returns for the test case below is not the general solution.
  • 4.19 first order PDE of three unknowns
    problem number 19
    (from example 3.5.4, p 212, nonlinear ode’s by Lokenath Debnath, 3rd edition)
It is rather simple to see that any spherical function u(x, y, z) =f(x^2+y^2+z^2) is a solution of the PDE.
Then any function of the form u(x, y, z) = f(x^2+y^2+z^2) * exp(x+y+z) *C1 (C1 being any constant) is also a solution.
Maple returns only the solution u(x, y, z) = exp(C2*(x^2+y^2+z^2)) * exp(x+y+z) * C1
u := (x, y, z) -> f(x^2+y^2+z^2)
proc (x, y, z) options operator, arrow; f(x^2+y^2+z^2) end proc
expr := (y-z)*diff(u(x, y, z), x)+(z-x)*diff(u(x, y, z), y)+(x-y)*diff(u(x, y, z), z)
2*(y-z)*(D(f))(x^2+y^2+z^2)*x+2*(z-x)*(D(f))(x^2+y^2+z^2)*y+2*(x-y)*(D(f))(x^2+y^2+z^2)*z
simplify(%);
u := (x, y, z) -> C*f(x^2+y^2+z^2)*exp(x+y+z)
proc (x, y, z) options operator, arrow; C*f(x^2+y^2+z^2)*exp(x+y+z) end proc
(y-z)*(2*C*(D(f))(x^2+y^2+z^2)*x*exp(x+y+z)+C*f(x^2+y^2+z^2)*exp(x+y+z))+(z-x)*(2*C*(D(f))(x^2+y^2+z^2)*y*exp(x+y+z)+C*f(x^2+y^2+z^2)*exp(x+y+z))+(x-y)*(2*C*(D(f))(x^2+y^2+z^2)*z*exp(x+y+z)+C*f(x^2+y^2+z^2)*exp(x+y+z))
simplify(%);
pdsolve((y-z)*diff(U(x, y, z), x)+(z-x)*diff(U(x, y, z), y)+(x-y)*diff(U(x, y, z), z)=0, U(x,y,z),'build')
U(x, y, z) = exp((1/2)*x^2*_C2)*exp(_C1*x)*exp((1/2)*y^2*_C2)*exp(_C1*y)*_C3*_C5*_C4*exp((1/2)*z^2*_C2)*exp(_C1*z)
combine(rhs(%), exp)
exp((1/2)*x^2*_C2+_C1*x+(1/2)*y^2*_C2+_C1*y+(1/2)*z^2*_C2+_C1*z)*_C3*_C5*_C4
Download Problem_19.mw
I got problem how to rewrite formula in maple, I have tried so many times but it is not working.
How to rewrite sum of double sum like this formula (4th constraints in the following picture)
H := numelems(N); for k from 2 to H do for i to k-1 do cons[k] := add(x[i, k], i = N)+add(x[k, j], N) = 2 end do end do;
                             H := 5
Error, invalid input: add received {1, 2, 3, 4, 5}, which is not valid for its 2nd argument, i
for example, there is an expression exp1=(a+b)*(a+c),  I want to find all the position in DAG of a specific operand, such as 'a' ; also I want to find the position in the DAG of  sub-expression which type is '+' .
 is there any function in maple which can return the  integers indicating position of an operand or type in an expression? i.e. with this function, assume its name is 'find',then
find(exp1, a) will return  [1,1],[2,1];
find(exp1,'+') will return  [1,0],[2,0];
hi
i got a problem to solve 2 nonlinear  pde equation that are not coupled but there is 8 coupled boundary condition. i can use pdsolve in maple.anyone can help me in numerical solving of these pdes?
How can I set the range (bounds) of all of the function's variables to the same range at once? Here is a simple exaple:
Input:
Minimize((x[1]-1)^2+(x[2]-1)^2+(x[3]-1)^2, {8 <= x[1]*(x[2]^2+x[3]^2+1)}, x[1] = 1 .. 2, x[2] = 1 .. 2, x[3] = 1 .. 2);
Results:
[0.693290283715211841, [x[1] = 1.53166579937811,  x[2] = 1.45311243719790, x[3] = 1.45311243719790]]
My function have 15 variables x[1] -> x[15]. How can I set their bounds to a global range, say: x[i]=1..2 ?
I'm using Maple 17.3 at work.
Thanks, and sorry for the bad English.
This is from the documentation of ?plot3d,light:
light=[phi, theta, r, g, b]
    This option adds [my emphasis] a directed light source
    from the direction phi, theta in spherical coordinates.
The "adds" in that sentence seems to imply that
multiple light sources are possible, but it does not seem
to work that way.  Each subsequent light option overrides
the previous one as we see in the following illustration
where we render a ball three times by illuminating it
(a) from the north, (b) from the south, and (c) from
both the north and south.  In (c) Maple accounts for only
the south light.
with(plots): with(plottools):
ball := sphere(1, style=surface, color=gold):
display(<
    display(ball,light=[0,0,1,1,1])   |
    display(ball,light=[180,0,1,1,1]) |
    display(ball,light=[0,0,1,1,1], light=[180,0,1,1,1])
Download light.mw
When I try:
X≔Statistics[RandomVariable](Normal(0,1)):
Statistics[Sample](X,10);
I get:
Error, (in Statistics:-Sample) invalid input: expected distribution or algebraic expression with random variables, but received X
What am I doing wrong?
First 757 758 759 760 761 762 763 Last Page 759 of 2459
