I hope you can help me. I like to use the Workbook feature in Maple 2018. I save variables in one document to use them in another document as well. If, however, the value of the variable changes, I have to delete the variable in the variable manager each time and save it again.
Is there a command I can use to delete and re-save the saved variables?
I've been trying to make Julia sets using maple for a project im working on, but the maple help function tells me to embed the image, which does not give me the Plot options or the option to zoom in for a more detailed view.  I have tried using several different image tools, and the only one that seems to output it as a plot is Preview, but then when i zoom in it is in terrible detail and is very pixelated.  I think i just need to use a different output than Embed, but i can't find one that will work, can anyone help please?
Here is the code i've been using:
> with(Fractals:-EscapeTime);
> with(ImageTools);
> bl, ur, c := -2.0-1.5*I, 2.0+1.5*I, -.92+.25*I;
> M := Julia(500, bl, ur, c);
> Embed(M);
For example, A with a B weighting?
QuestionHistogramme.mw
Hi All,
I have been using trignometric functions where the inputs are sometimes intergers. When ever I am having an interger as argument for trignometric functions the out is unevaluated.
expression := 3*sin(z)+9*sin(x)*(1/4);
values := [x = 1, z = 1.570796327];
Now if I evaluate the above expression
eval(expression, values);
output is something like below
3.+9*sin(1)*(1/4)
but if I change the x value from 1 to 1.0
expression := 3*sin(z)+9*sin(x)*(1/4); values := [x = 1.0, z = 1.570796327];
My output is 4.893309716;
I am doing ths inside a procedure hence I cannot change the values to float manually, Is it possible to change the intergers to floats when using trig functions??
I have written a procedure in which the content is written as either for loop or add commands. Since this procedure need to be evaluated around 1-1.5 lakhs times during iteration (running an iterative method) I need to know which of the two procedure will consume less memory. The whole calculation takes 4 gb. So i am trying to optimize the code. Thank you.
procedure_new.mw
Hey,
I have just started using Maple for my university project and I am follwing this guide https://www.maplesoft.com/support/help/maple/view.aspx?path=DifferentialGeometry%2FTensor%2FKillingVectors to calculate Killing Vectors. My issue is that when I try and define a metric using evalDG, I need to write dx&tdx to mean the tensor product between the two. Maple interperates this as a neutral operator and gives me "Error, invalid neutral operator".
I am not sure where the issue is as I have written exactly the same code as the guide and yet it gives me an error 3 lines in. Is there some issue that I am not aware of as someone who hasn't used Maple before? Any advice would be useful as I am not really sure how it is possible and I need to be able to write the tensor product to define the metric.
Even for the simplest metric it does not work. My code is:
with(DifferentialGeometry): with(Tensor): with(LieAlgebras):
DGsetup([x, y], M):
g1:=evalDG( dx&tdx):
Any help would be greatly appreciated.
Suppose that A is an nxn matrix over the finite field Z:=GF(2,q) for some q. I wan to get the smitform of A over Z. First I used the package
with(LinearAlgebra[Generic])
and after that I applied the command
S := SmithForm[Z](A)
but the mentioned command made some errors. In fact, I do not how to define commands igcdex, iquo, irem, sign and abs for SmithForm over finite fields.
Thanks for any suggestions
how I can find solutions for non linear equations.
I want to find non zero solution.
thank you
ZAH.mw
Maple Worksheet - Error
Failed to load the worksheet /maplenet/convert/ZAH.mw .
Download ZAH.mw
I get this problem in a paper published in 2011. there is a table which compares the solution of a differential equation and gives the range of initial guesses. I got confused when saw maple and approximated maple, please any help me
I'm attaching the link of paper. Please have a look at table 3.
https://www.sciencedirect.com/science/article/pii/S0098135411000056
Hi, Maple is totally new to me and I found something confusing.
Here is what I have:
the_first_element:= proc( A:: Array( numeric ) ) ;
A[1];
end proc():
And it shows Error, invalid input: unknown uses a 1st argument, A (of type Array(numeric)), which is missing.
But in another similar procedure, I have exactly the same lines but it goes without error.
locate_max := proc( A :: Array( numeric ) )
if ArrayNumDims(A) <> 1 then
    error "can only search 1d arrays"
  end if:
I have no idea what is wrong with these 4 lines.
Thank you in advance!
If I add "restart" to a program, then interface(imaginaryunit=j) don't work. Why?
interface(imaginaryunit = j);
j^2;
The output is j^2  but the output should be -1.
How can I input different spacesteps in numerical solution of PDE (Heat equation) with pdsolve of Maple?
For example, the x range is x=0..L,
and I'd like to solve the PDE with spacestep1=L/100 for x=0..a and spacestep2=L/10 for x=a..L.
How to generate the whole table of quantiles for a normal reduced centered N(0,1)?
Chargement Statistics
X := RandomVariable(Normal(0, 1));
                            X := _R
Statistics[Quantile](X, 0.1e-1);
                       -2.32634787404074
Does maple have the ability to create probability trees / branch plots? (representing a sample space).  I would like to represent a problem more elegantly while learning how to use the software.  For example, a sample space that can be represented could be a coin toss.
Hi guys,
I have got serious problem with solving this system of ODE, where psi is equal to 10*sqrt(da) and uB,E,kL,uc are constants:
firstly I have to find missing initial condition using shooting method and calculate cA(z=2) using Runge-Kutta 4th order then. And plot following concentration profile for cA and dA. So far, I have dealt with first diff eq 2nd order dividing by two diff eq of 1st order using mentioned constants so I got these ones:
  dy[1]:=y2(z);
  dy[2]:=1.000000000*sqrt(y1(z))-6.000000000*y2(z)-10.00000000*y3(z);
  dy[3]:=-0.8333333333e-2*sqrt(y1(z))-0.8333333333e-1*y3(z);
I understand I need a condition da(z=0) that I should obtain using shooting method, but I do not know how to do it in spite of I understand it in theoretical way. And same problem I have with RK4th order. Anybody here with a hint, please?
There is my maple file (unfinished version of mine): maple-shoot_RK4.mw
First 759 760 761 762 763 764 765 Last Page 761 of 2459
