Dear power users, I was wondering whether it is possible to import a xlsx file in such a way that the first row of the file is imported as column headers of the dataframe in Maple? Thank you in advance for any help given.
intersections := proc(P, Q, T)
local R, W, w, t, a, b, sol, buff, v;
sol := NULL;
if T = Y then W := X; else
W := Y; end if;
R := resultant(P, Q, T);
print(`Résultant :`); print(R);
w := fsolve(R, W); t := NULL;
for v in [w] do t := t, fsolve(subs(W = v, P), T); end do;
for a in {w} do for b in {t} do if T = Y then
buff := abs(subs(X = a, Y = b, P)) + abs(subs(X = a, Y = b, Q));
printf(`X=%a,   Y=%a   --->  %a\\n`, a, b, buff); if buff < 1/100000000 then sol := sol, [a, b]; end if;
else buff := abs(subs(X = b, Y = a, P)) + abs(subs(X = b, Y = a, Q));
printf(`X=%a,   Y=%a   --->  %a\\n `, a, b, buff); if buff < 1/100000000 then sol := sol, [b, a]; end if; end if; end do; end do; printf(`Nombre de solutions :  %a\\n`, nops({sol})); print({sol}); end proc:
intersections(X^2 + Y^2 - 1, X - Y, X);
X=-.7071067812,   Y=-.7071067812   --->  0.\n
I do not wish to find \n in the answer
Here is another ode solution by Maple, I am not able to get zero from odetest.
If someone could come up with a trick or method to verify this, that will be great. I tried all sort of assumptions and not able to get zero. Even coulditbe() could not give zero.
It is a Chini ode and also homogeneous, `class G`.
Solving using either method, odetest do not returns zero.  There are no initial conditions. I am sure the solutions are correct, but odetest need some help or may be this requires different method to verify not using odetest?
Worksheet below.
`The "Physics Updates" version in the MapleCloud is 1796 and is the same as the version installed in this computer, created 2024, August 29, 14:22 hours Pacific Time.`
libname;
ode:=diff(y(x),x) = a*x^(n/(1-n))+b*y(x)^n;
DEtools:-odeadvisor(ode,y(x));
diff(y(x), x) = a*x^(n/(1-n))+b*y(x)^n
[[_homogeneous, `class G`], _Chini]
maple_sol:=dsolve(ode,y(x),[Chini],useInt,implicit); #explicit makes it take very long time
Intat(1/(_a^n/(b^(-n-1)*(a*x^(-n/(-1+n)))^(-2*n+1)*(-x^(-n/(-1+n)-1)*a*n*b/(-1+n))^n*n^(-n))-_a+1), _a = -y(x)/((-1+n)*x*a*x^(-n/(-1+n))))-(Int(-1/((-1+n)*x), x))+c__1 = 0
residual:=odetest(maple_sol,ode); #how to show this is zero?
n^n*(-y(x)*x^(1/(-1+n))/(a*(-1+n)))^n*(a*x^(-n/(-1+n)))^(2*n)*(-a*b*n*x^(-2*n/(-1+n)+1/(-1+n))/(-1+n))^(-n)*b^(n+1)-b*y(x)^n
coulditbe(residual=0) assuming real;
FAIL
#now solving as homog. (which gives simpler looking solution
maple_sol:=dsolve(ode,y(x),[homogeneous]);
Int(x^(n/(-1+n))/((b*x*(-1+n)*_a^n+_a)*x^(n/(-1+n))+a*x*(-1+n)), _a = _b .. y(x))-c__1 = 0
-b*y(x)^n*n/(-1+n)-x^(-1-1/(-1+n))*a*n/(-1+n)+b*y(x)^n/(-1+n)+x^(-1-1/(-1+n))*a/(-1+n)-y(x)/(x*(-1+n))
FAIL
Download challenge_odetest_sept_1_2024.mw
how to evaluate summation upto infinity in maple including exponential function too if it is possible or we can evaluate it upto finite number of terms?. kindly explain with example
Ive been wondering what i can use this for and where maybe it has been overlooked ,if any one has any ideas im really interested, that pi^ cubed
360°/rad/pi^2
I
What is the correct syntax in Maple to do integration of variables on
So that the new integration variable is using the mapping    u=y*x^(1/3) so that the result is
The problems seems is that there is no option to tell Maple what the new integration variable is. So it does not know it should be y or x?
I looked at help and all my tries failed. Below is worksheet and also examples from another software as reference. The other software has argument to tell change of variable what is the new integration variable should be. But in Maple, there is no such option.,  Does this mean in Maple change of integration variables only works when the right hand side of the transformation has only one symbol and not two or more? i.e. this works   u=y, but not u=y*x
T:=Student:-MultivariateCalculus;
e:=Int(1/(3*u^4 + u + 3),u);
T:-ChangeOfVariables(e,[u=y*x^(1/3)]);
T:-ChangeOfVariables(e,[y=u*x^(-1/3)]);
Int(1/(3*u^4+u+3), u)
Error, (in Student:-MultivariateCalculus:-ChangeOfVariables) unable to complete the change-of-variables operation
Student[Calculus1][IntTutor](); #did not help either
Download change_of_variables_integration_august_31_2024.mw
I searched help and see nothing specific to change of variable for integration, so I assumed the above is the command to use. Am I using the wrong command for integration change of variables in Maple?
For reference, I need to duplicate this in Maple:
My group recently published a DAEsolver in Maple, https://mapletransactions.org/index.php/maple/article/view/16701
This solver is very competive compared to existing large scale DAE solvers (even in other languages) by performing symbolic calculation for analytical Jacobian (including sparsity pattern), and by using parallel sparse direct solver (PARDISO).
The code and paper use ListTools. If the attached procedure can be made threadsafe and parallelized, then the resulting DAEsolver is publishable and will be better than most solvers (from any language) today. We welcome collaborations and suggestions. The code works for N = 40, but kernel connection is lost for higher values of N and it is not stable.
Dr. Venkat Subramanian
PS, for the specific problem, it is trivial to write the Jacobian and residue in a for loop that can be run in parallel (and it helps us to solve > 1 Million or more DAEs), but the attached code (makeproc) helps in solving DAEs resulting from sophisticated discretization approaches for PDEs without user input.
Digits:=15;
15
makeproc:=proc(n0,nf,Nt,Eqode::Array,Vars::list,Vars1::list,Equation::Array,j11::Matrix(storage=sparse))
local i,j,LL,LL2,L,i1,varsdir,varsdir1,node,eqs;
for i from n0 to nf do
eqs:=rhs(Eqode[i]):
L:=indets(eqs)minus{t};#print(L);
if nops(L)>0 then
LL := [seq(ListTools:-Search(L[j], Vars),
             j = 1 .. nops(L))];
 LL2 := ListTools:-MakeUnique(LL);
if LL2[nops(LL2)] = 0 then
             LL := [seq(LL2[i1], i1 = 1 .. nops(LL2) - 1)];
         if LL2[1]= 0 then LL:=[seq(LL2[i1],i1=2..nops(LL2))]: end:#print(1,LL);
varsdir:=[seq(Vars[LL[i1]]=0.5*uu[LL[i1]]+uu_old[LL[i1]],i1=1..nops(LL))];
else varsdir:=[1=1]:end:
Equation[i]:=uu[i]-deltA*subs(varsdir,t=tnew,eqs):#print(i,Equation[i]);
        L := indets(Equation[i]);
        LL := [seq(ListTools:-Search(L[j], Vars1),j = 1 .. nops(L))];
        for j to nops(LL) do
            j11[i, LL[j]] := diff(Equation[i], uu[LL[j]]);
CodeTools[ThreadSafetyCheck](makeproc);
0, 1
#infolevel[all]:=10;
N:=40;h:=1.0/N:
40
with(Threads[Task]):
Eqs:=Array(1..N,1..N):
for i from 1 to N do for j from 1 to N do
if i = 1 then left:=0: else left:=(c[i,j](t)-c[i-1,j](t))/h:end:
if i = N then right:=-0.1: else right:=(c[i+1,j](t)-c[i,j](t))/h:end:
if j = 1 then bot:=0: else bot:=(c[i,j](t)-c[i,j-1](t))/h:end:
if j = N then top:=-0.1: else top:=(c[i,j+1](t)-c[i,j](t))/h:end:
Eqs[i,j]:=diff(c[i,j](t),t)=(right-left)/h+(top-bot)/h-c[i,j](t)^2:
od:od:
eqs1:=Array([seq(seq(Eqs[i,j],i=1..N),j=1..N)]):
ics:=[seq(seq(c[i,j](t)=1.0,i=1..N),j=1..N)]:
Vars:=[seq(seq(c[i,j](t),i=1..N),j=1..N)]:
Vars1:=[seq(uu[i],i=1..N^2)]:
Equation:=Array(1..N^2):j11:=Matrix(1..N^2,1..N^2,storage=sparse):eqs:=copy(Equation):
CodeTools:-Usage(makeproc(1,N^2,N^2,eqs1,Vars,Vars1,Equation,j11));
memory used=21.47MiB, alloc change=24.99MiB, cpu time=235.00ms, real time=231.00ms, gc time=62.50ms
1-deltA*(-1600.00000000000-.50*uu[1600]-1.0*uu_old[1600])
j11[5,5];
1-deltA*(-2400.00000000000-.50*uu[5]-1.0*uu_old[5])
#Equation[1];
makeprocDistribute := proc(i_low, i_high,Nt,Eqode::Array,Vars::list,Vars1::list,Equation::Array,j11::Matrix(storage=sparse))
local i_mid;
if 200 < i_high - i_low then
#if i_low > 250 then
#i_mid := floor(1/2*i_high - 1/2*i_low) + i_low;
i_mid:=iquo(i_low+i_high,2):
Continue(null,
Task = [makeprocDistribute, i_low, i_mid,Nt,Eqode,Vars,Vars1,Equation,j11],
Task = [makeprocDistribute,i_mid + 1, i_high,Nt,Eqode,Vars,Vars1,Equation,j11]);
makeproc(i_low, i_high,Nt,Eqode,Vars,Vars1,Equation,j11); end if;
j11[5,5];
N^2;
1600
NN:=N^2;
1600
CodeTools:-Usage(Start(makeprocDistribute,1,NN,NN,eqs1,Vars,Vars1,Equation,j11)):
memory used=22.01MiB, alloc change=239.31MiB, cpu time=985.00ms, real time=241.00ms, gc time=1.61s
j11[5,5];
Download makeproctest.mw
I analyzed the kinetic equation of the system and got this formula. I want to realize the sweep frequency analysis of the kinetic function by changing the size of omega2, but I don't know how to write a program. Want to ask for help
solve831.mw
In the attached file I would like to use the functions "Gradient" and "Hessian". Hessian should also calculate the determinant and check positive definiteness. I was unable to do that. Other questions for me as a beginner are:
How are the long brackets and the > sign on the left edge created? What does a semicolon at the end of the command mean? How is a 3D plot created? What does "restart" mean?
Regards, Alfred_FAF_20240831.mwAF_20240831.mw
 In the calculation process, I selected (num=5). How can I detect the maximum value of num to ensure the series solution would be converged?
seried.mw
If there any way to make text  parallel to a line in textplot3d.
display(line([1,2,3],[4,5,-2],linestyle=longdash),
        point([2.5,3.5,0.5]),
        textplot3d([2.5,3.5,0.5,"not aligned"]))
I know to ways:
- calling the returned procedure with a value for the independend variable
- printing the procedure with interface(verboseproc=2)
The first requires a procedure and a values that work, the second is quite some typing.
Any other ways?
Update Nov 2024:
The option output = listprocedure provides a way.
Is one not supposed to make _Z local variable?  If not, then how to insure the global _Z do not have some value assigned to it?
In this example below, I build some integral. I used local _Z for upport limit. But now Maple generate internal error.
If I do not declare _Z as local, and leave it global, then no error is generated.
But if I also declare _Z inside the proc as global _Z, then the error also goes away.
So is one always supposed to use _Z as global?
The strange thing _Z is protected, so I cant assign to it value from global space. Message says Try declaring `local _Z`; see ?protect for details. but when I do that, I still get an error.
So is the bottom line here is that one should not declare _Z local to a proc, and just assume it is always global symbol that has no assigned value to it, and that will always be safe to do?  I do not assign value to _Z inside my proc. Just wanted to use it for upper limit, as symbol.
foo:=proc()
 local _Z;
 local F,G,H,n;
 F:=x;G:=x;G:=x;n:=4;
 -RootOf(Intat(F^(-n-1)*H^(-2*n+1)*(-G*F*n*H)^n*n^(-n)/(-
         tau*F^(-n-1)*H^(-2*n+1)*(-G*F*n*H)^n*n^(-n)+F^(-n-1)*H^(-2*n+1)*(-G*F
         *n*H)^n*n^(-n)+tau^n),tau = _Z)-Int(-G,x)+C1)/G*H;
foo()
Error, (in RootOf) expression independent of, _Z
boo:=proc()
 local F,G,H,n;
boo();
-RootOf(Intat(x^3/(H^3*tau^4-tau*x^3+x^3), tau = _Z)-(Int(-x, x))+C1)*H/x
boo2:=proc()
 global _Z;
 local F,G,H,n;
boo2()
_Z:=5;
Error, attempting to assign to `_Z` which is protected.  Try declaring `local _Z`; see ?protect for details.
local _Z;
foo();
Warning, A new binding for the name `_Z` has been created. The global instance of this name is still accessible using the :- prefix, :-`_Z`.  See ?protect for details.
_Z
Download using_Z_inside_proc_august_28_2024.mw
For me this result is suspicious. What do you think?
This ode diff(y(x),x) = f*y(x)^4+g*y(x)+h; is clearly quadrature, since I did not tell Maple that f,g,h depend on x. So this can be solved by just integration. But when asking odeadvisor if it is Chini, it says yes. When asking it what type it is, now it says it is quadrature.
Am I missing something here? I was expecting [NONE] when asking it if it is Chini.
Yes, the ode has the form of Chini, which is   y'=f(x)*y^n + g(x)*y + h(x), where n=4 here. But if f,g,h do not depend on x, then this is now just quadrature. Right? Calling it Chini is little misleading I think.
libname;
ode:=diff(y(x),x) = f*y(x)^4+g*y(x)+h;
DEtools:-odeadvisor(ode,y(x),[Chini]);
diff(y(x), x) = f*y(x)^4+g*y(x)+h
[_Chini]
[_quadrature]
dsolve(ode,y(x),[quadrature]);
x-Intat(1/(_a^4*f+_a*g+h), _a = y(x))-c__1 = 0
dsolve(ode,y(x),[Chini]);
y(x) = -RootOf(Intat(g^4/(_a^4*f*h^3-_a*g^4+g^4), _a = _Z)+g*x+c__1)*h/g
Download question_on_advisor_august_28_2024.mw
Notice another problem in this solutions. If g=0, then the Chini solution gives divison by zero now, while the quadrature solution still works.
First 75 76 77 78 79 80 81 Last Page 77 of 2426
