There is a simulation of a T handle in space done in matlab https://rotations.berkeley.edu/a-tumbling-t-handle-in-space/
Would like to see someone do this in Maple. More specifically how the Matlab code would look like translated to Maple
sign(-v1+a);
sign(-V1+a);
my respective outputs are
I cannot understand what is the difference between using lowercase and uppercase variable. Could Someone Explain me please.
I have to Two Lists with Equal size. Each element in one List is an variable and Each element in second List is an Value of the variable corresponds to First List.
Now when Ever I call a variable I need the script to read its value and Compute.
For Example:
List1 := [v1,v2,v3,v4];
List2 := [a*b/c, a/c,a*b-2,d];
computation := v1*diff(expression,x)+v3*diff(expression,y)+ v3*v4;
but I need the script to read it as
requiredComputation :=(a*b/c)*diff(expression,x)+(a*b-2)*diff(expression,y)+ a*b-2*d;
I used to do this kind of computation in matlab using containers and map. Is there any thing similar??
I was trying some calculations for a solar installation.
4.9kW system. 3.5 h sun/day.  $0.27/kWh
with(Units:-Standard):
                     "maple init loaded..."
4.9*Unit(kW)*3.5*Unit(h/day)
714.583333333333*Unit('W')
but I want it to output 17.15 kWh/day
I looked up previous questions, and got this rather convoluted solution:
Units[AddSystem]( NewSI, Units[GetSystem](SI), kWh/day );
 Units[UseSystem]( NewSI );
combine( 4.9*Unit(kW)*3.5*Unit(h/day), units );
17.15*Unit('kWh'/'d')
Hi. I hope this question is not a duplicate of my previous question. Fundiff function results in dirac terms in an equation. Are there commands that simply differentiates a term that is a function of (t) in an equation without involving diracs?
Can we change the color of the units measure?
ie 5 m (5 meters - where m is default black) can the m be changed to a different color for all unit measure entries?
MY CODE:
with(Physics);
Setup(Coordinatesystem = (X = [x, y, z, t]), metric = 4*dx*dt-dy^2-dz^2+4*u*(dt^2));
    * Partial match of  'Coordinatesystem' against keyword
       'coordinatesystems'
    Systems of spacetime Coordinates are: (Xequals(x,y,z,t))
[coordinatesystems = {X},
  metric = {(1, 4) = 2, (2, 2) = -1, (3, 3) = -1, (4, 4) = 4 u}]
g_[];      (here g is diplayed in matrix form)
Weyl[alpha, beta, mu, nu, nonzero];
            Physics:-Weyl[alpha, beta, mu, nu] = {}
So basically i'm trying to find the nonzero components of the weyl tensor which returns the empty set, i.e the weyl tensor apparently equals zero but I know this is not the case, can anyone see if I have input something wrong? Thanks in advance
g_[] in matrix form is
0 0 0 2
0 -1 0 0
0 0 -1 0
2 0 0 4u
UPDATE: u is a function of all varibles and I have not considered this which might be causing the problem
I trying to get a proc to work. In the 1st half of the document, I derive four sections for a pedal curve and plot them fine. In the second I try doing it with a procedure called Pedal. Am having problems. I think it might be something to do with the for.. do loop.
NULLNULL
Typesetting:-mrow(Typesetting:-mi("Trunc", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo("≔", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("proc", bold = "true", font_style_name = "2D Input", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("F", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo("∷", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("procedure", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo(",", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("`+`", italic = "true", font_style_name = "2D Input", mathvariant = "italic")), font_style_name = "2D Input", mathvariant = "normal", open = "{", close = "}"), Typesetting:-mo(",", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("odr", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo("∷", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mi("posint", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo("≔", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mn("2", font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo(",", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("v", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo("∷", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mi("list", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("name", italic = "true", font_style_name = "2D Input", mathvariant = "italic")), font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo("≔", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("x", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo(",", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("y", italic = "true", font_style_name = "2D Input", mathvariant = "italic")), font_style_name = "2D Input", mathvariant = "normal", open = "[", close = "]")), font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mi(""), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("description", bold = "true", font_style_name = "2D Input", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-ms(" Truncates an algebraic equation to required degree"), Typesetting:-mo(";", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "auto"), Typesetting:-mo("local", bold = "true", font_style_name = "2D Input", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("f", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo("≔", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("`if`", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("F", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo("∷", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mi("procedure", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo(",", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("F", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("v", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("")), font_style_name = "2D Input", mathvariant = "normal", open = "[", close = "]")), font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo(",", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("F", italic = "true", font_style_name = "2D Input", mathvariant = "italic")), font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo(";", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mi("print", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("F", italic = "true", font_style_name = "2D Input", mathvariant = "italic")), font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo(";", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.2777778em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "auto"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("if", bold = "true", font_style_name = "2D Input", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("not", bold = "true", font_style_name = "2D Input", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("f", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo("∷", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mi("`+`", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("then", bold = "true", font_style_name = "2D Input", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "auto"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("error", bold = "true", font_style_name = "2D Input", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-ms("Can't truncate 1-term expression"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "auto"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("else", bold = "true", font_style_name = "2D Input", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "auto"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("select", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("q", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo("→", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("degree", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mfenced(Typesetting:-mrow(Typesetting:-mi("q", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo(",", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mi("v", italic = "true", font_style_name = "2D Input", mathvariant = "italic")), font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("≤", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("odr", italic = "true", font_style_name = "2D Input", mathvariant = "italic"), Typesetting:-mo(",", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "true", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.3333333em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mi("f", italic = "true", font_style_name = "2D Input", mathvariant = "italic")), font_style_name = "2D Input", mathvariant = "normal"), Typesetting:-mi(""), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "auto"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("fi", bold = "true", font_style_name = "2D Input", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mspace(height = "0.0ex", width = "0.0em", depth = "0.0ex", linebreak = "newline"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("end", bold = "true", font_style_name = "2D Input", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(" ", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo("proc", bold = "true", font_style_name = "2D Input", mathvariant = "bold", fontweight = "bold", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.0em", rspace = "0.0em"), Typesetting:-mo(":", font_style_name = "2D Input", mathvariant = "normal", fence = "false", separator = "false", stretchy = "false", symmetric = "false", largeop = "false", movablelimits = "false", accent = "false", lspace = "0.2777778em", rspace = "0.2777778em"))
NULLNULLNULL
a := 3; b := -1; c := -1
C := (x^2+y^2+12*x+9)^2-4*(2*x+3)^3
p21 := plots:-implicitplot(C, x = -3 .. 3, y = -5 .. 5, colour = "Salmon", gridrefine = 2, size = [300, 300])
sol1 := [solve(C, y)]
[(-x^2-12*x-9+2*(8*x^3+36*x^2+54*x+27)^(1/2))^(1/2), -(-x^2-12*x-9+2*(8*x^3+36*x^2+54*x+27)^(1/2))^(1/2), (-x^2-12*x-9-2*(8*x^3+36*x^2+54*x+27)^(1/2))^(1/2), -(-x^2-12*x-9-2*(8*x^3+36*x^2+54*x+27)^(1/2))^(1/2)]
f1 := expand(eval(C, [x = X+r, y = Y+s]))
X^4+4*X^3*r+2*X^2*Y^2+4*X^2*Y*s+6*X^2*r^2+2*X^2*s^2+4*X*Y^2*r+8*X*Y*r*s+4*X*r^3+4*X*r*s^2+Y^4+4*Y^3*s+2*Y^2*r^2+6*Y^2*s^2+4*Y*r^2*s+4*Y*s^3+r^4+2*r^2*s^2+s^4-8*X^3-24*X^2*r+24*X*Y^2+48*X*Y*s-24*X*r^2+24*X*s^2+24*Y^2*r+48*Y*r*s-8*r^3+24*r*s^2+18*X^2+36*X*r+18*Y^2+36*Y*s+18*r^2+18*s^2-27
ltg1 := simplify(expand(eval(Trunc(f1, 1, [Y, X]), [X = x-r, Y = y-s])))
-3*r^4+(4*x+16)*r^3+(-6*s^2+4*s*y-24*x-18)*r^2+((4*x-48)*s^2+48*s*y+36*x)*r-27-3*s^4+4*s^3*y+(24*x-18)*s^2+36*s*y
NULLThis*section*works*out*the*pedal*curve
xp1 := 1; yp1 := 2; lprp1 := -coeff(ltg1, y)*x+coeff(ltg1, x)*y+K1; for i to nops(sol1) do s := eval(sol1[i], x = r); print("s  ", s); K1 := solve(eval(lprp1, [x = xp1, y = yp1]), K1); print("K1  ", K1); sol2 := solve([ltg1, lprp1], [x, y]); Pedal || i := [rhs(sol2[1, 1]), rhs(sol2[1, 2])]; p9 || i := plot([op(Pedal || i), r = -20 .. 20], colour = "MediumSeaGreen"); unassign('K1', 'sol2') end do
"K1  ", -4*(-r^2-12*r-9-2*(8*r^3+36*r^2+54*r+27)^(1/2))^(3/2)-4*r^2*(-r^2-12*r-9-2*(8*r^3+36*r^2+54*r+27)^(1/2))^(1/2)+16*(8*r^3+36*r^2+54*r+27)^(1/2)*r-48*r*(-r^2-12*r-9-2*(8*r^3+36*r^2+54*r+27)^(1/2))^(1/2)+192*r^2+96*(8*r^3+36*r^2+54*r+27)^(1/2)-36*(-r^2-12*r-9-2*(8*r^3+36*r^2+54*r+27)^(1/2))^(1/2)+576*r+432
seq(simplify(Pedal || i), i = 1 .. nops(sol1))
[((((2*r+3)^3)^(1/2)+6*r+9)*(-r^2-12*r-9+2*((2*r+3)^3)^(1/2))^(1/2)-2*(r-3)*(r^2+(5/2)*r-((2*r+3)^3)^(1/2)+3/2))/(4*r^2-6*r-18), ((-2*r^2-3*r-((2*r+3)^3)^(1/2))*(-r^2-12*r-9+2*((2*r+3)^3)^(1/2))^(1/2)+6*(r-3)*(r-(1/6)*((2*r+3)^3)^(1/2)+3/2))/(4*r^2-6*r-18)], [((-((2*r+3)^3)^(1/2)-6*r-9)*(-r^2-12*r-9+2*((2*r+3)^3)^(1/2))^(1/2)-2*(r-3)*(r^2+(5/2)*r-((2*r+3)^3)^(1/2)+3/2))/(4*r^2-6*r-18), ((2*r^2+((2*r+3)^3)^(1/2)+3*r)*(-r^2-12*r-9+2*((2*r+3)^3)^(1/2))^(1/2)+6*(r-3)*(r-(1/6)*((2*r+3)^3)^(1/2)+3/2))/(4*r^2-6*r-18)], [((6*r-((2*r+3)^3)^(1/2)+9)*(-r^2-2*((2*r+3)^3)^(1/2)-12*r-9)^(1/2)-2*(r-3)*(r^2+(5/2)*r+((2*r+3)^3)^(1/2)+3/2))/(4*r^2-6*r-18), ((-2*r^2+((2*r+3)^3)^(1/2)-3*r)*(-r^2-2*((2*r+3)^3)^(1/2)-12*r-9)^(1/2)+6*(r-3)*(r+(1/6)*((2*r+3)^3)^(1/2)+3/2))/(4*r^2-6*r-18)], [((((2*r+3)^3)^(1/2)-6*r-9)*(-r^2-2*((2*r+3)^3)^(1/2)-12*r-9)^(1/2)-2*(r-3)*(r^2+(5/2)*r+((2*r+3)^3)^(1/2)+3/2))/(4*r^2-6*r-18), ((2*r^2-((2*r+3)^3)^(1/2)+3*r)*(-r^2-2*((2*r+3)^3)^(1/2)-12*r-9)^(1/2)+6*(r-3)*(r+(1/6)*((2*r+3)^3)^(1/2)+3/2))/(4*r^2-6*r-18)]
plots:-display(p21, seq(p9 || i, i = 1 .. nops(sol1)), size = [600, 600], scaling = constrained, caption = " Curve and it's Pedal curve")
This I can't get to work. All 4 sections of the pedal curve are the same and should not be.
Parse:-ConvertTo1D, "`%1` is not a module or member", RonanRoutines
Pedal2 := Pedal(C, xp1, yp1)
"K||i", -8*r^3+(-4*(-r^2-12*r-9-2*(8*r^3+36*r^2+54*r+27)^(1/2))^(1/2)+48)*r^2-8*(-(-r^2-12*r-9-2*(8*r^3+36*r^2+54*r+27)^(1/2))^(1/2)-3)^2*r-4*(-r^2-12*r-9-2*(8*r^3+36*r^2+54*r+27)^(1/2))^(3/2)+48*r^2+576*r+432+96*(8*r^3+36*r^2+54*r+27)^(1/2)-36*(-r^2-12*r-9-2*(8*r^3+36*r^2+54*r+27)^(1/2))^(1/2)
seq(simplify(Pedal2[i]), i = 1 .. nops(sol1))
[((4*r^2+6*((2*r+3)^3)^(1/2)+30*r+36)*(-r^2-2*((2*r+3)^3)^(1/2)-12*r-9)^(1/2)+(-r^2-34*r-69)*((2*r+3)^3)^(1/2)-26*r^3-243*r^2-540*r-351)/((2*r+30)*((2*r+3)^3)^(1/2)+36*r^2+162*r+162), (((r+9)*((2*r+3)^3)^(1/2)+14*r^2+51*r+45)*(-r^2-2*((2*r+3)^3)^(1/2)-12*r-9)^(1/2)+(12*r+72)*((2*r+3)^3)^(1/2)+4*r^3+126*r^2+432*r+378)/((2*r+30)*((2*r+3)^3)^(1/2)+36*r^2+162*r+162)], [((4*r^2+6*((2*r+3)^3)^(1/2)+30*r+36)*(-r^2-2*((2*r+3)^3)^(1/2)-12*r-9)^(1/2)+(-r^2-34*r-69)*((2*r+3)^3)^(1/2)-26*r^3-243*r^2-540*r-351)/((2*r+30)*((2*r+3)^3)^(1/2)+36*r^2+162*r+162), (((r+9)*((2*r+3)^3)^(1/2)+14*r^2+51*r+45)*(-r^2-2*((2*r+3)^3)^(1/2)-12*r-9)^(1/2)+(12*r+72)*((2*r+3)^3)^(1/2)+4*r^3+126*r^2+432*r+378)/((2*r+30)*((2*r+3)^3)^(1/2)+36*r^2+162*r+162)], [((4*r^2+6*((2*r+3)^3)^(1/2)+30*r+36)*(-r^2-2*((2*r+3)^3)^(1/2)-12*r-9)^(1/2)+(-r^2-34*r-69)*((2*r+3)^3)^(1/2)-26*r^3-243*r^2-540*r-351)/((2*r+30)*((2*r+3)^3)^(1/2)+36*r^2+162*r+162), (((r+9)*((2*r+3)^3)^(1/2)+14*r^2+51*r+45)*(-r^2-2*((2*r+3)^3)^(1/2)-12*r-9)^(1/2)+(12*r+72)*((2*r+3)^3)^(1/2)+4*r^3+126*r^2+432*r+378)/((2*r+30)*((2*r+3)^3)^(1/2)+36*r^2+162*r+162)], [((4*r^2+6*((2*r+3)^3)^(1/2)+30*r+36)*(-r^2-2*((2*r+3)^3)^(1/2)-12*r-9)^(1/2)+(-r^2-34*r-69)*((2*r+3)^3)^(1/2)-26*r^3-243*r^2-540*r-351)/((2*r+30)*((2*r+3)^3)^(1/2)+36*r^2+162*r+162), (((r+9)*((2*r+3)^3)^(1/2)+14*r^2+51*r+45)*(-r^2-2*((2*r+3)^3)^(1/2)-12*r-9)^(1/2)+(12*r+72)*((2*r+3)^3)^(1/2)+4*r^3+126*r^2+432*r+378)/((2*r+30)*((2*r+3)^3)^(1/2)+36*r^2+162*r+162)]
for i to nops(sol1) do p9 || i := plot([op(Pedal2[i]), r = -20 .. 20], colour = "MediumSeaGreen") end do
Download Proc_for_Pedal_not_working.mw
Hi all
I have the following ordinary differential equation, where all the parameter used are constant ( A,B,C,D,E,F,G,H).
Is there any technique gives a solution
diff(y(x), x$2)+(A/x+B/x^2+C)*(diff(y(x), x))+D*(diff(y(x), x))^2/x+E*(diff(y(x), x))^3+F/x+G/x^2+H/x^3 = 0;
 thanks for your help
Dear all;
I hope an idea to solve the following problem.
P(n,t): probability at time t
Lambda and mu : two given parameters ( can be fixed ), and we assure mu greater then lambda
 t : time parameter ( we can say that 0<= t <=T , and T fixed )
 for n an integrer  greater then 1 we have the following equation
eq := diff(P(n, t), t) = -(lambda+mu)*P(n, t)+lambda*P(n-1, t)+mu*P(n+1, t);
for n=0, we have
ics := diff(P(0, t), t) = -lambda*P(0, t)+mu*P(1, t);
How can we compute P(n,t) ,
is there an exact solution or a numerical method to get the value of P(n,t)
Then we plot( P(n,t),t=0..100) ;
Many thinks
Can somebody please help me with this assignment?
Struggling a bit with the Euler-method from task d) and further.
rand1 := rand(2 .. 9):
4
(a*sqrt(a*a^b))^(1/c)
16^(1/4)*2^(1/8)
"example a:=2;b:=6;c:=4; result 2 D output is ((2*sqrt(2*2^(6)))^(1/(4)))"
but*result*is*16^(1/4)*2^(1/8)
assume(x > 0)
sqrt(x^3*(x^(3/4)))
(x^(15/4))^(1/2)
``(15/8)*How*determine*x*exponent*is
Download luythua.mw
From the screenshot we see that Maple has correctly replaced a in the defintion of s. But it has not incorported v[B]. I was a SMath (free from internet) user and this was a simple operation.
Thanks for any advice.
SymbolicEval.mw
How do you can convert g into ?
Can you help me?
I am trying to evaluate a function that contains an infinite sum. I need to evaluate the integral to determine a CDF, and from that hopefully the inverse CDF in order to sample the corresponding PDF.
The sum comes from a 2F1 hypergeometric function, which I have written manually in the attached file.
Can anyone tell me if and how it is possible to evaluate this integral, with respect to x?
I have inserted an image below, but also the entire file :) Marginal2.mw
First 793 794 795 796 797 798 799 Last Page 795 of 2459
