Hello everyone!
Could you help me with the next problem:
1. I have a nonlinear pde system(two equations, two unknown functions: tau(t, r) & R(t, r)) of hyperbolic type.
2. And I have no idea how to solve it.
3. But I know some interesting things about it:
  • In direct variables (tau(t, r) & R(t, r)) this is a nonlinear system maple2.mw
  • But in inverse variables (t(tau, R) & r(tau, R)) it splits into two independent linear differential equations.maple3.mw And we can get a solutions of each in HeunC functions(it would be great if maple could give me an inverse Heun's functions, I couldn't find how).
4(last). I have a condition in which one of two equtaions = 0, (this condition: tau(t, r) = t) and now I want to try to see what one of the unknown functions(R(t, r)) looks like. But I can not use numeric values. The system describes a spherical gravitational wave, depends on time and distance. r > mass so i want to see some discrete solutions of R(t, r)(jpeg file).the dimensions of t and r are the same. Maybe you have some ideas?
In the realm of tetrads where both world indices and Lorentz indices are present, contractions, say, using simultaneously the Minkowskian (galilean) Levi-Civita symbol,
and the curvilinear Levi-Civita (pseudo-)tensor,
can be considered. Although each of the two types of Levi-Civitas can easily be obtained separately by specifying Setup(levicivita = galilean) or Setup(levicivita = nongalilean), I cannot figure out how to have them both available at the same time. Any suggestions?
PS: I am, of course, aware of the fact that the two Levi-Civitas are related by some appropiate square-root of the determinant of the metric, but I have no desire to fiddle around with explicit such determinants if they can be avoided.
This is probably a question to Edgardo: In another thread, the following quantity is considered [Eqs. (5) and (6) combined]:
expand(gamma_[definition]);
This is all very well, but it seems to depend on the metric loaded: if the Schwarzschild metric g_[sc] is loaded, then the above output results, but if the Minkowski metric g_[minkowski] is loaded, then the output of the above expansion is identically zero. Does that make sense? Is that intentional? The explicitly evaluated Ricci rotation coefficients vanish identically for the Minkowski metric, of course, but if evaluation is performed for that case, then why not also for the Schwarschild metric [not meaning to say that I want evaluation]?
In the following codes I am very sure exp(-3*q) is a factor both at numerator and denominator. However, I dont know how to annihilate this factor. Can someone kindly help to ensure it cancels out? Thanks and kind regards.
s:=(sum(a[j]*x^j,j=0..2)+sum(a[j]*exp(-(j-2)*x),j=3..4)):
F:=diff(s,x):
p1:=simplify(eval(s,x=q))=y[n]:
p2:=simplify(eval(F,x=q))=f[n]:
p3:=simplify(eval(F,x=q+h))=f[n+1]:
p4:=simplify(eval(F,x=q+3*h/2))=f[n+3/2]:
p5:=simplify(eval(F,x=q+2*h))=f[n+2]:
vars:= seq(a[i],i=0..4):
Cc:=eval(<vars>, solve({p||(1..5)}, {vars})):
for i from 1 to 5 do
	a[i-1]:=Cc[i]:
Cf:=s:
T:y[n+2]=collect(simplify(eval(Cf,x=q+2*h)), [y[n],f[n],f[n+1],f[n+3/2],f[n+2]], recursive);
Does anyone know why Maple doesn't simplify the following expression?
Hi dears,
I hope that my request (question) is appropriate for Mapleprimes.
I know Gröbner bases and Buchberger's algorithm and I want to understand  the F4-algorithm. However, I know that  the corresponding paper can be found:
https://www.sciencedirect.com/science/article/pii/S0022404999000055
Could you please state the sketch and main parts of the algorithm s.t. I can understand it?
Is there any primary Maple implementation of F4-algorithm?
Hello All,
Please any sugestions on mathmateical projects. They assigned me to do a project for my math class for something I should be interested about. But since the deadline is one week and I don't have anything in mind right now. So I just need y'all help t suggest for me any ideas
I believe I've found a bug, where Eigenvectors returns two eigenvectors which are the same (even though the eigenvalues are different). The expressions involves RootOf's, and it seems that the eigenvalues use "index" to distinguish themselves, yet the eigenvectors do not.
with(LinearAlgebra);
x := RootOf(z^2-t, z);
m := Matrix(2, (i,j) -> evala(add(a[j, k]*((-1)^(i-1))^k*x^k, k = 0..1)));
ev := Eigenvectors(m);
sin(Pi/12);
(1/4)*6^(1/2)*(1-(1/3)*3^(1/2))
Download calculation.mws
can anyone explain to me this result ?
in the book "maple by example" they said that sin(Pi/12);
sin (1/12 π)
returns sin(π/12) because it does not know a formula for the explicit value of sin(π/12). but when i'm calculated this in maple i had got , this result, what does this result mean ?
hello,
this is my first post here so sorry if it's done wrong...
I'm having difficulties with the following command because maple only returns a solution if the first two boundary conditions of the "if" arguments are true. If the the first or the second condition is false then maple doesn't give a solution solution.
for i to n do if H[i] < 2.7 then if A[i, f] < 12 then if A[i, o] < 1.2 then Q[i, foo] := evalf(610*(A[i, o]*sqrt(H[i])*h[k]*A[i, T])^(1/2)) else Q[i, foo] := evalf(7.8*A[i, t]+378*A[i, o]*sqrt(H[i])) end if end if end if; print(Q[i, foo]); end do;
I've also tried with the elif command but it gives a similar problem
Anyone knows how to solve this?
suppose for example i am working on the function
exp(-I*Pi*(n+2*n*(m-1))/m);
and i wanted to for what ever reason assign a unique symbol to each of the two times the indeterminant 'n' occurs:
exp(-I*Pi*(n[1]+2*n[2]*(m-1))/m)
How could i accomplish this for any function F?
i have tried the method of
map(op, [op(op(exp(-I*Pi*(n+2*n*(m-1))/m)))]);
                [-1, Pi, n, 2 n (m - 1), m, -1]
And though i could then use algsubs on the original function for each in the above list, but then ran into problems arising that for any function the number of times i need to map op in iteration is not known, i will actually work this out by the end of the night so i dont know why im bothering asking
Edit 2: yep its ok i discovered subsop
Hello All,
This is Alex, I'm doing a master degree in computer sience at UMICH. They assigned me to do a math project and deadlined by next week, and I need y'all help to suggest some ideas for me if you guys having any
Ali
Why input fraction to eigenvector and then evalf output are all the same when input different ?
i would like to see more decimal numbers
digits := 36
command can not show more decimal numbers
why can not see the difference?
if start from fraction
After set round screen display to 36 digits in options
If start from floating value
the result different from start from fraction
start from which is the most accurate and correct?
if fraction is correct, why all result are the same even if input are different?
I'm absolutely new in maple, but I need to solve PDE and I don't understand why maple do not solve it
restart; with(PDEtools);
U := diff_table(u(x, t));
pde[1] := U[t, t] = U[x, x]+5*sin(3*x);
bc[1] := eval(U[], x = 0) = 0; bc[2] := eval(U[], x = Pi) = 0;
ic[1] := eval(U[], t = 0) = 0; ic[2] := eval(D[2]*U[], t = 0) = 1;
sys[1] := [pde[1], bc[1], bc[2], ic[1], ic[2]];
pdsolve(sys[1]);
Error: Error, (in PDEtools:-Library:-NormalizeBoundaryConditions) unable to isolate the functions {u(0, t), u(Pi, t), u(x, 0)} in the given boundary conditions {D[2]*u(x, 0) = 1, u(0, t) = 0, u(Pi, t) = 0, u(x, 0) = 0}
If I solve it  with only boundary conditions or without any conditions, maple gives me an answer.
Please, help me to understand, how to solve this pde system with boundary and initials conditions. This is my firs use of maple so I hardly understand how to write code correctly.
Real part + complex part
but
sometimes it display
complex part + real part
how to consistent display real part + complex part?
First 852 853 854 855 856 857 858 Last Page 854 of 2427
