how to obtain the sequence of sin(((Kπ)/4)), where the integer K  is varying from 1 to 8, and then to delete the zeros.
i'm triying to solve this sytem ,
solve({x^2+y^2=3,x^2+2*y^2=3},{x,y});
{y = 0, x = RootOf(_Z^2-3)}
what is the meaning of RootOf
maple gives me this, can anyone explain to me,the signification of the solutions ?
Dear Users!
Hope you would be fine with everying. I want to solve the following 2nd order linear differential equation.
(1+B)*(diff(theta(eta), eta, eta))+C*A*(diff(theta(eta), eta)) = 0;
where A is given as
A := -(alpha*exp(-sqrt((omega+1)*omega*(M^2+alpha+1))*eta/(omega+1))*omega+alpha*exp(-sqrt((omega+1)*omega*(M^2+alpha+1))*eta/(omega+1))+exp(-sqrt((omega+1)*omega*(M^2+alpha+1))*eta/(omega+1))*omega-alpha*omega+exp(-sqrt((omega+1)*omega*(M^2+alpha+1))*eta/(omega+1))-alpha-omega-1)/sqrt((omega+1)*omega*(M^2+alpha+1));
I want solution for any values of omega, alpha, M, B, C and L. The BCs are below:
BCs := (D(theta))(0) = -1, theta(L) = 0.
I am waiting your response,
Write a command maple to count each two elements distincts of a list L ?
There is a error happened when i use the command "eliminate" ,
And,the target two equations is:
[190.0315457*d^6-7.601261828*d^4+344.0*c^2*d^2-2.677685950*c^4, 0.6830134554e-2*c^4+2084.317025*d^8-166.7453620*d^6+3.334907240*d^4-c^2*d^2]
The error is happened like that shown below.
Error, (in unknown) invalid arguments to divide: 4903.60312, 1.000000000 to use eliminate command!
I wonder why this error happened, could anyone help me!
Thanks!!!
to get the list where all the elements of a list L equal to its largest element are replaced by 0 ?
Hi everyone,
I have a x -> y = f(x) function from R to R (you may suppose f is C(infinity)),  given by an explicit relation.
This function is not strictly monotonic over R.
I want to construct the global inverse of f over R by putting "side by side" local inverse functions.
Let a__0, ..., a__n values of x such that:
  1. -infinity =a__0 < a__1 < ... a__(n-1) < a__n = + infinity
  2. f is monotonic over ] a__p, a__(p+1) [   for each p=0..n-1
The idea is to define the global inverse g of f over R by
g := y ->  piecewise(y < f(a__1), g__0(y), ..., y < f(a__n), g__(n-1)(y))
where g__p(y), is the inverse function of the restriction of f to ] a__p, a__(p+1) [
Toy problem
f := x ->1-(1-x)^2;
x__1 := solve(diff(f(x), x);
y__1 := f(x__1);
# I thought one of these commands could work (but they don't return me a single branch as I had expected)
solve(f(x)=y, x) assuming y < y__1;
solve({f(x)=y, x < x__1}, x);
How can I obtain the inverse of a function f over an interval where f is bijective ?
TIA
I think that maple is actually evaluating this series into what ever ridiculously long closed form expression the expansion of the series has, but i just want the latex for what i have entered.
How do i tell maple to not evaluate something?
latex(a[p, q] = sum(cos(2*Pi*(p+1)*(n-1)/q), n = 1 .. q))
a_{{p,q}}= \left( -4\, \left( \cos \left( {\frac {\pi }{q}} \right)
 \right) ^{2}+8\, \left( \cos \left( {\frac {\pi \,p}{q}} \right)
 \right) ^{2} \left( \cos \left( {\frac {\pi }{q}} \right)  \right) ^{
2}-8\,\sin \left( {\frac {\pi \,p}{q}} \right) \cos \left( {\frac {
\pi \,p}{q}} \right) \sin \left( {\frac {\pi }{q}} \right) \cos
 \left( {\frac {\pi }{q}} \right) +3-4\, \left( \cos \left( {\frac {
\pi \,p}{q}} \right)  \right) ^{2} \right)  \left( \cos \left( {\frac
{\pi \, \left( q+1 \right) }{q}} \right)  \right) ^{2}+ \left( -4\,
 \left( \cos \left( {\frac {\pi }{q}} \right)  \right) ^{2}+8\,
 \left( \cos \left( {\frac {\pi \,p}{q}} \right)  \right) ^{2} \left(
\cos \left( {\frac {\pi }{q}} \right)  \right) ^{2}-8\,\sin \left( {
\frac {\pi \,p}{q}} \right) \cos \left( {\frac {\pi \,p}{q}} \right)
\sin \left( {\frac {\pi }{q}} \right) \cos \left( {\frac {\pi }{q}}
 \right) +3-4\, \left( \cos \left( {\frac {\pi \,p}{q}} \right)
 \right) ^{2} \right)  \left( \cos \left( {\frac {\pi \, \left( q+1
 \right) p}{q}} \right)  \right) ^{2}+ \left( 8\, \left( \cos \left( {
\frac {\pi }{q}} \right)  \right) ^{2}-16\, \left( \cos \left( {\frac
{\pi \,p}{q}} \right)  \right) ^{2} \left( \cos \left( {\frac {\pi }{q
}} \right)  \right) ^{2}+16\,\sin \left( {\frac {\pi \,p}{q}} \right)
\cos \left( {\frac {\pi \,p}{q}} \right) \sin \left( {\frac {\pi }{q}}
 \right) \cos \left( {\frac {\pi }{q}} \right) -6+8\, \left( \cos
 \left( {\frac {\pi \,p}{q}} \right)  \right) ^{2} \right)  \left(
\cos \left( {\frac {\pi \, \left( q+1 \right) p}{q}} \right)  \right)
^{2} \left( \cos \left( {\frac {\pi \, \left( q+1 \right) }{q}}
 \right)  \right) ^{2}+ \left( 8\,\sin \left( {\frac {\pi \,p}{q}}
 \right) \cos \left( {\frac {\pi \,p}{q}} \right)  \left( \cos \left(
{\frac {\pi }{q}} \right)  \right) ^{4}-4\, \left( \cos \left( {\frac
{\pi }{q}} \right)  \right) ^{3}\sin \left( {\frac {\pi }{q}} \right)
+8\, \left( \cos \left( {\frac {\pi \,p}{q}} \right)  \right) ^{2}
 \left( \cos \left( {\frac {\pi }{q}} \right)  \right) ^{3}\sin
 \left( {\frac {\pi }{q}} \right) -4\,\sin \left( {\frac {\pi \,p}{q}}
{\frac {\pi }{q}} \right)  \right) ^{2}-8\,\sin \left( {\frac {\pi \,p
}{q}} \right)  \left( \cos \left( {\frac {\pi \,p}{q}} \right)
 \right) ^{3} \left( \cos \left( {\frac {\pi }{q}} \right)  \right) ^{
2}-8\,\sin \left( {\frac {\pi }{q}} \right) \cos \left( {\frac {\pi }{
q}} \right)  \left( \cos \left( {\frac {\pi \,p}{q}} \right)  \right)
^{4}+\sin \left( {\frac {\pi }{q}} \right) \cos \left( {\frac {\pi }{q
}} \right) +4\, \left( \cos \left( {\frac {\pi \,p}{q}} \right)
 \right) ^{2}\sin \left( {\frac {\pi }{q}} \right) \cos \left( {\frac
{\pi }{q}} \right) +4\,\sin \left( {\frac {\pi \,p}{q}} \right)
 \left( \cos \left( {\frac {\pi \,p}{q}} \right)  \right) ^{3}-\sin
 \left( {\frac {\pi \,p}{q}} \right) \cos \left( {\frac {\pi \,p}{q}}
 \right)  \right) \sin \left( {\frac {\pi \, \left( q+1 \right) }{q}}
 \right) \cos \left( {\frac {\pi \, \left( q+1 \right) }{q}} \right)
 \left( - \left( \cos \left( {\frac {\pi \,p}{q}} \right)  \right) ^{2
}+ \left( \cos \left( {\frac {\pi }{q}} \right)  \right) ^{2} \right)
^{-1}+ \left( 8\,\sin \left( {\frac {\pi \,p}{q}} \right) \cos \left(
{\frac {\pi \,p}{q}} \right)  \left( \cos \left( {\frac {\pi }{q}}
 \right)  \right) ^{4}-4\, \left( \cos \left( {\frac {\pi }{q}}
 \right)  \right) ^{3}\sin \left( {\frac {\pi }{q}} \right) +8\,
\cos \left( {\frac {\pi }{q}} \right)  \right) ^{3}\sin \left( {\frac
{\pi }{q}} \right) -4\,\sin \left( {\frac {\pi \,p}{q}} \right) \cos
 \left( {\frac {\pi \,p}{q}} \right)  \left( \cos \left( {\frac {\pi }
{q}} \right)  \right) ^{2}-8\,\sin \left( {\frac {\pi \,p}{q}}
 \right)  \left( \cos \left( {\frac {\pi \,p}{q}} \right)  \right) ^{3
} \left( \cos \left( {\frac {\pi }{q}} \right)  \right) ^{2}-8\,\sin
 \right)  \left( \cos \left( {\frac {\pi \,p}{q}} \right)  \right) ^{4
}+\sin \left( {\frac {\pi }{q}} \right) \cos \left( {\frac {\pi }{q}}
 \right)  \right) \sin \left( {\frac {\pi \, \left( q+1 \right) p}{q}}
 \right) \cos \left( {\frac {\pi \, \left( q+1 \right) p}{q}} \right)
^{-1}-2\, \left( 8\,\sin \left( {\frac {\pi \,p}{q}} \right) \cos
{q}} \right)  \right) ^{4}-4\, \left( \cos \left( {\frac {\pi }{q}}
 \right)  \right)  \left( \cos \left( {\frac {\pi \, \left( q+1
 \right) p}{q}} \right)  \right) ^{2}\sin \left( {\frac {\pi \,
 \left( q+1 \right) }{q}} \right) \cos \left( {\frac {\pi \, \left( q+
1 \right) }{q}} \right)  \left( - \left( \cos \left( {\frac {\pi \,p}{
q}} \right)  \right) ^{2}+ \left( \cos \left( {\frac {\pi }{q}}
 \right)  \right) ^{2} \right) ^{-1}-2\, \left( 8\,\sin \left( {\frac
 \left( \cos \left( {\frac {\pi }{q}} \right)  \right) ^{4}-4\,
 \left( {\frac {\pi }{q}} \right) +8\, \left( \cos \left( {\frac {\pi
\,p}{q}} \right)  \right) ^{2} \left( \cos \left( {\frac {\pi }{q}}
 \right)  \right) ^{3}\sin \left( {\frac {\pi }{q}} \right) -4\,\sin
 \right)  \left( \cos \left( {\frac {\pi }{q}} \right)  \right) ^{2}-8
\,\sin \left( {\frac {\pi \,p}{q}} \right)  \left( \cos \left( {\frac
{\pi \,p}{q}} \right)  \right) ^{3} \left( \cos \left( {\frac {\pi }{q
}} \right)  \right) ^{2}-8\,\sin \left( {\frac {\pi }{q}} \right) \cos
 \left( {\frac {\pi }{q}} \right)  \left( \cos \left( {\frac {\pi \,p}
{q}} \right)  \right) ^{4}+\sin \left( {\frac {\pi }{q}} \right) \cos
 \left( {\frac {\pi }{q}} \right) +4\, \left( \cos \left( {\frac {\pi
\,p}{q}} \right)  \right) ^{2}\sin \left( {\frac {\pi }{q}} \right)
\cos \left( {\frac {\pi }{q}} \right) +4\,\sin \left( {\frac {\pi \,p}
 \right) ^{3}-\sin \left( {\frac {\pi \,p}{q}} \right) \cos \left( {
\frac {\pi \,p}{q}} \right)  \right) \sin \left( {\frac {\pi \,
 \left( q+1 \right) p}{q}} \right) \cos \left( {\frac {\pi \, \left( q
+1 \right) p}{q}} \right)  \left( \cos \left( {\frac {\pi \, \left( q+
1 \right) }{q}} \right)  \right) ^{2} \left( - \left( \cos \left( {
\frac {\pi \,p}{q}} \right)  \right) ^{2}+ \left( \cos \left( {\frac {
\pi }{q}} \right)  \right) ^{2} \right) ^{-1}+ \left( -8\, \left( \cos
 \left( {\frac {\pi }{q}} \right)  \right) ^{2}+16\, \left( \cos
 \left( {\frac {\pi \,p}{q}} \right)  \right) ^{2} \left( \cos \left(
{\frac {\pi }{q}} \right)  \right) ^{2}-16\,\sin \left( {\frac {\pi \,
p}{q}} \right) \cos \left( {\frac {\pi \,p}{q}} \right) \sin \left( {
\frac {\pi }{q}} \right) \cos \left( {\frac {\pi }{q}} \right) +6-8\,
 \right) \sin \left( {\frac {\pi \, \left( q+1 \right) p}{q}} \right)
\cos \left( {\frac {\pi \, \left( q+1 \right) p}{q}} \right) \sin
 \left( {\frac {\pi \, \left( q+1 \right) }{q}} \right) \cos \left( {
\frac {\pi \, \left( q+1 \right) }{q}} \right) - \left( -4\, \left(
\cos \left( {\frac {\pi }{q}} \right)  \right) ^{2}+8\, \left( \cos
\frac {\pi }{q}} \right) \cos \left( {\frac {\pi }{q}} \right) +3-4\,
 \left( -4\, \left( \cos \left( {\frac {\pi }{q}} \right)  \right) ^{2
}+8\, \left( \cos \left( {\frac {\pi \,p}{q}} \right)  \right) ^{2}
 \right) \sin \left( {\frac {\pi }{q}} \right) \cos \left( {\frac {
\pi }{q}} \right) +3-4\, \left( \cos \left( {\frac {\pi \,p}{q}}
 \right)  \right) ^{2} \right)  \left( \cos \left( {\frac {\pi \,p}{q}
} \right)  \right) ^{2}- \left( 8\, \left( \cos \left( {\frac {\pi }{q
}} \right)  \right) ^{2}-16\, \left( \cos \left( {\frac {\pi \,p}{q}}
 \right)  \right) ^{2} \left( \cos \left( {\frac {\pi }{q}} \right)
 \right) ^{2}+16\,\sin \left( {\frac {\pi \,p}{q}} \right) \cos
\cos \left( {\frac {\pi \,p}{q}} \right)  \right) ^{2} \left( \cos
 \left( {\frac {\pi }{q}} \right)  \right) ^{2}- \left( 8\,\sin
 \right)  \left( \cos \left( {\frac {\pi }{q}} \right)  \right) ^{4}-4
\, \left( \cos \left( {\frac {\pi }{q}} \right)  \right) ^{3}\sin
\frac {\pi \,p}{q}} \right)  \right) \sin \left( {\frac {\pi }{q}}
 \right) \cos \left( {\frac {\pi }{q}} \right)  \left( - \left( \cos
 \left( {\frac {\pi \,p}{q}} \right)  \right) ^{2}+ \left( \cos
 \left( {\frac {\pi }{q}} \right)  \right) ^{2} \right) ^{-1}- \left(
8\,\sin \left( {\frac {\pi \,p}{q}} \right) \cos \left( {\frac {\pi \,
p}{q}} \right)  \left( \cos \left( {\frac {\pi }{q}} \right)  \right)
^{4}-4\, \left( \cos \left( {\frac {\pi }{q}} \right)  \right) ^{3}
\sin \left( {\frac {\pi }{q}} \right) +8\, \left( \cos \left( {\frac {
\pi \,p}{q}} \right)  \right) ^{2} \left( \cos \left( {\frac {\pi }{q}
} \right)  \right) ^{3}\sin \left( {\frac {\pi }{q}} \right) -4\,\sin
\frac {\pi \,p}{q}} \right)  \right) \sin \left( {\frac {\pi \,p}{q}}
 \right) \cos \left( {\frac {\pi \,p}{q}} \right)  \left( - \left(
\cos \left( {\frac {\pi \,p}{q}} \right)  \right) ^{2}+ \left( \cos
 \left( {\frac {\pi }{q}} \right)  \right) ^{2} \right) ^{-1}+2\,
 \left( 8\,\sin \left( {\frac {\pi \,p}{q}} \right) \cos \left( {
 \right)  \right)  \left( \cos \left( {\frac {\pi \,p}{q}} \right)
{\pi }{q}} \right)  \left( - \left( \cos \left( {\frac {\pi \,p}{q}}
 \right)  \right) ^{2}+ \left( \cos \left( {\frac {\pi }{q}} \right)
 \right) ^{2} \right) ^{-1}+2\, \left( 8\,\sin \left( {\frac {\pi \,p}
{q}} \right) \cos \left( {\frac {\pi \,p}{q}} \right)  \left( \cos
 \left( {\frac {\pi }{q}} \right)  \right) ^{4}-4\, \left( \cos
 \left( {\frac {\pi }{q}} \right)  \right) ^{3}\sin \left( {\frac {
\pi }{q}} \right) +8\, \left( \cos \left( {\frac {\pi \,p}{q}}
 \right) ^{3}\sin \left( {\frac {\pi }{q}} \right) -4\,\sin \left( {
\,p}{q}} \right)  \right) ^{3} \left( \cos \left( {\frac {\pi }{q}}
{\frac {\pi }{q}} \right)  \right) ^{2} \left( - \left( \cos \left( {
\pi }{q}} \right)  \right) ^{2} \right) ^{-1}- \left( -8\, \left( \cos
 \right) \sin \left( {\frac {\pi \,p}{q}} \right) \cos \left( {\frac {
Download MAPLE_PLEASE_HELPS_BECOZ_MAPLE_IS_FRENS.mw
I am trying to use Monte Carlo integration example given at: https://www.maplesoft.com/products/maple/new_features/maple15/examples/montecarlo.aspx.
After coding the procedure, the statement approxint(x^2, x = 1 .. 3)
gives error: Error, (in approxint) invalid input: `if` expects 3 arguments, but received 1
But I have used in exactly the same way as given in the page. What is the problem
Are we allowed to ask questions about only math or does it have to only be a problem with maple code?
I have modeled a 3D flexible manipulator in Maplesim. I intend to measure the torsional strain of the flexible beams. How can I do this??
Hey guys, I have created this vector field at t=0. Now I would like to ask how can I animate this vector field changing to let say t=0 to 10. Thanks already! Check the code I already wrote and uploaded.upload.mw
Can there be approximate ways of calculating the derivative? Maybe I should count on some formula? Or can not it be calculated in any way at all?
I want to solve transcendental equation in maple and facing problem to plot  “β” vs “a” plot, using Eq. 8, 9, 10...
PDF file attached below:
Equation_file.pdf
restart; with(plots);
G := 1; M := .1; R := 1; P := .72; alpha := .1; phi := 1; K := 1; n := 2; beta := 1;
                              0.1
ode1 := {(1+(4/3)*R)*(diff(theta(x), x, x))+(1/2)*P*f(x)*(diff(theta(x), x))+alpha*theta(x) = 0, n*(diff(f(x), x, x))^(n-1)*(diff(f(x), x, x, x))+f(x)*(diff(f(x), x, x))/(n+1)+G*theta(x)-M*(diff(f(x), x)) = 0, f(0) = 0, theta(10) = 0, (D(f))(0) = beta*K*((D@@2)(f))(0), (D(f))(10) = 1, (D(theta))(0) = -phi*(1-theta(0))};
 /7  d  / d          \                     / d          \
{ - --- |--- theta(x)| + 0.3600000000 f(x) |--- theta(x)|
 \3  dx \ dx         /                     \ dx         /
                         / d  / d      \\ / d  / d  / d      \\\
   + 0.1 theta(x) = 0, 2 |--- |--- f(x)|| |--- |--- |--- f(x)|||
                         \ dx \ dx     // \ dx \ dx \ dx     ///
     1      / d  / d      \\                  / d      \
   + - f(x) |--- |--- f(x)|| + theta(x) - 0.1 |--- f(x)| = 0,
     3      \ dx \ dx     //                  \ dx     /
  f(0) = 0, theta(10) = 0, D(f)(0) = @@(D, 2)(f)(0),
  D(f)(10) = 1, D(theta)(0) = -1 + theta(0) }
dsol := dsolve(ode1, numeric, method = bvp[midrich], range = 0 .. 10);
First 864 865 866 867 868 869 870 Last Page 866 of 2459
