I try to get real solutions for a PDE, i.e. real-valued functions depending on real variables. Maple computer complex solutions, i.e. complex-valued functions depending on complex variables.
Here is the example in question: (the four function f1, f2, f3, f4 depend on the four unknowns lam, mu, l, m)
`assuming`([pdsolve([diff(f2(lam, mu, l, m), m)-(diff(f1(lam, mu, l, m), l))-(diff(f4(lam, mu, l, m), mu))+diff(f3(lam, mu, l, m), lam) = 0, diff(f1(lam, mu, l, m), m)+diff(f2(lam, mu, l, m), l)-(diff(f3(lam, mu, l, m), mu))-(diff(f4(lam, mu, l, m), lam)) = 0])], [real])
How can I solve my problem and receive only real solutions to my PDE?
A similar problem had been posted before (see here), but I can only find a cached version of the post where no answers are displayed.
I would like to control the extents of my 3D parametric plot. Increasing the grid creates too many gridlines and I just get a black plot  (and I still don't get the extent in the y-coordinate that I want).
Any suggestions how I might be able to get this plot from -360 to 0 and -20 to 60 completely filled in? (see attached workbook).
Any suggestions on how to control the gridlines?
An idea of what I am trying to do...I want to plot argument(z/(1+z)) vs. argument(z)*180/pi vs. 20*log10(abs(z)) with contours of argument(z/(1+z)) and 20*log10(abs(z/(1+z))
This is a 3D plot of the output phase of a Nichol's Chart (with the output contours of the Nichol's chart).
phaseplot.mw
I need a little help...
what I want to do, if i have 3 equations  with multiple variables and i want to get derivative of some of these variables wrt other variables while setting others as constants
here in the example
1st i thought the last equation should have partial m / partial f ... how can i get that
2nd if ,another problem, i wanted to set z as a constant so it won't consider getting its derivative, how do i get that
diff_test.mw
f1 := x = y+z
x = y+z
f2 := y = 2*f^2+3
y = 2*f^2+3
f3 := z = 22*f^3+33*f+m
z = 22*f^3+33*f+m
implicitdiff({f1, f2, f3}, {x, y, z}, x, f)
66*f^2+4*f+33
Download diff_test.m
hope i was clear in my explanation. thank you
I am getting this error for almost everything that i write in maple today, and i simply have no idea what causes it or what it means
"?SetOfCommonDivisors:=(X,Y)->{[[1,X intersect (map(numtheory:-divisors, Y))<>{???}],[0,otherwise]]??"
Error, unable to parse 'mverbatim'
Download WTF_ERROR.mw
i have a function,when using fsolve to solve it, it has two roots. when i substitute it into the main function, it has some residual and it is not exactly 0. how should i remove the residual ? i do not want to use "solve" command and i should use "fsolve" command. tnx in advance
f:=3*(2*x-1)^2*(1/2)-1/2;
(3/2)*(2*x-1)^2-1/2
ans:=fsolve(f)
.2113248654, .7886751346
eval(f,x=ans[2])
-0.4e-9
Download problem.mw
So my questions is fairly simple but I am not sure if Maple can do this. I want to create a Matrix full of partial derivatives (Jacobian), but computing this Jacobian is maxing out my RAM. So I would like to create each row (or column) of the Jacobian seperately and save each row (or column) in a Matrix that has already been saved to a file. Basically I would like to store values in a file (in a loop) without overwriting the file.
hey
not from a ready-made example from a module
Hello I trie this code C:
FUNCTION ran1(idum)
INTEGER idum,IA,IM,IQ,IR,NTAB,NDIV
REAL ran1,AM,EPS,RNMX
PARAMETER (IA=16807,IM=2147483647,AM=1./IM,IQ=127773,IR=2836,
* NTAB=32,NDIV=1+(IM-1)/NTAB,EPS=1.2e-7,RNMX=1.-EPS)
“Minimal” random number generator of Park and Miller with Bays-Durham shuffle and
added safeguards. Returns a uniform random deviate between 0.0 and 1.0 (exclusive of
the endpoint values). Call with idum a negative integer to initialize; thereafter, do not
alter idum between successive deviates in a sequence. RNMX should approximate the largest
floating value that is less than 1.
INTEGER j,k,iv(NTAB),iy
SAVE iv,iy
DATA iv /NTAB*0/, iy /0/
if (idum.le.0.or.iy.eq.0) then Initialize.
idum=max(-idum,1) Be sure to prevent idum = 0.
do 11 j=NTAB+8,1,-1 Load the shuffle table (after 8 warm-ups).
k=idum/IQ
idum=IA*(idum-k*IQ)-IR*k
if (idum.lt.0) idum=idum+IM
if (j.le.NTAB) iv(j)=idum
enddo 11
iy=iv(1)
endif
k=idum/IQ Start here when not initializing.
idum=IA*(idum-k*IQ)-IR*k Compute idum=mod(IA*idum,IM) without overflows by
if (idum.lt.0) idum=idum+IM Schrage’s method.
j=1+iy/NDIV Will be in the range 1:NTAB.
iy=iv(j) Output previously stored value and refill the shuffle taiv(
j)=idum ble.
ran1=min(AM*iy,RNMX) Because users don’t expect endpoint values.
return
END
How does this code in Maple?.
There are any sintaxis as *Value(point of addrees) that i  dont know this in Maple.
best Regars,
Can i un a maple program in console mode (example, cmd of MS-DOS), by command line?. I ask this, beacause it would take a lot less time to execute.
Hi every body:
I have to obtain Amax where is the maximum value of the f(t) function at steady state but at first i don't know steady sate what's the mean and the second i don't know how to obtain it with maple. help me plz. tnx.
f:=(t)->A*sin(x*t)
A := -6000.*x^3*((5.925123867*10^87*I)*x+5.830850605*10^88*x^2+1.752916719*10^90)/((4.241561702*10^89*I)*x^4-2.669934485*10^90*x^5-(3.812926555*10^90*I)*x^2+7.038145625*10^91*x^3+3.174301659*10^89*I-8.376628660*10^90*x)
Sin.mw
I am looking for advice as to avoiding or identifying what may elude to the cause of the error "Error, (in simplify/do) invalid simplification command" in circumstances where i have simply enclosed an expression with simplify(expression), and in most cases an error is not returned.
Thankyou in advance
Dear Maple users
I have been investigating the one-dimensional Wave Equation for the vibrating string with fixed endpoints. Before trying to use Maple for a solution, I surfed on Google and stumbled upon a solution given in a GeoGebra animation:
https://www.geogebra.org/m/eKkFV8uz
I succeded in making a similar animation in Maple. See the attached Maple file: The last line is out-commented in order for the file not to be too big (saving many frames...). Remove the # and recalculate, select the animation object and eventually resize it. Then hit the Play Button in the Toolbar. It should work very much like the animation above.
Now my question: I assume the numerical solution is solved using the Finite Difference Scheme in the background? How do I receive the numerical data, which lies behind the animation? Is it possible to evaluate the solution at specific (x,t) points?
I am quite impressed that GeoGebra can solve this PDE, by the way!
Erik
Wave_Equation_-_vibrating_string2.mw
How to 'Test Relation' the Euler Product formula in Maple?
Euler product formula in Maple:
sum(1/n^s, n = 1 .. infinity) = product(ithprime(j)^s/(ithprime(j)^s-1), j = 1 .. infinity);
I often do "Test -> Relation" from the right-click context menu in Maple to verify equations as I enter them.
When I do that for the above Euler Product "formula", it says it is false.  I know it is because I need to further add that s > 1.
 However, I am not sure how to enter the further constraint that s must be greater than 1 (s > 1) so that Maple recognizes that before Testing the Ralation of the Euler Product equation I entered.  What is the syntax for entering that further constraint of s > 1?
Dear Users!
I want to simple the Gamma function occures in a matrix. I need the simpliest form of this matrix. If there is some thing common in all entries take it common. Thanks
Matrix(6, 6, {(1, 1) = 2*GAMMA(alpha+5/2)*Pi^(1/4)*sqrt(GAMMA(alpha+1)*GAMMA(alpha+1/2)^3)/(alpha*(2*alpha+3)*(1+2*alpha)*GAMMA(alpha)*GAMMA(alpha+1/2)^2), (1, 2) = 0, (1, 3) = 0, (1, 4) = 0, (1, 5) = 0, (1, 6) = 0, (2, 1) = (1/2)*GAMMA(alpha+5/2)*Pi^(1/4)*sqrt(GAMMA(alpha+1)*GAMMA(alpha+1/2)^3)/(alpha*(2*alpha+3)*(1+2*alpha)*GAMMA(alpha)*GAMMA(alpha+1/2)^2), (2, 2) = (1/4)*GAMMA(alpha+5/2)*sqrt(2)*sqrt(GAMMA(alpha+1/2)^3*alpha^3*(alpha+1)^3*GAMMA(alpha)^3)*Pi^(1/4)/((2*alpha+3)*(1+2*alpha)*GAMMA(alpha+1/2)^2*alpha^2*(alpha+1)^2*GAMMA(alpha)^2), (2, 3) = 0, (2, 4) = 0, (2, 5) = 0, (2, 6) = 0, (3, 1) = (1/16)*GAMMA(alpha+5/2)*Pi^(1/4)*sqrt(GAMMA(alpha+1)*GAMMA(alpha+1/2)^3)/(GAMMA(alpha+1/2)^2*alpha*(alpha+1)*(1+2*alpha)*GAMMA(alpha)), (3, 2) = (1/8)*GAMMA(alpha+5/2)*sqrt(2)*sqrt(GAMMA(alpha+1/2)^3*alpha^3*(alpha+1)^3*GAMMA(alpha)^3)*Pi^(1/4)/((2*alpha+3)*(1+2*alpha)*GAMMA(alpha+1/2)^2*alpha^2*(alpha+1)^2*GAMMA(alpha)^2), (3, 3) = (1/32)*GAMMA(alpha+5/2)*sqrt(2)*sqrt(alpha^3*GAMMA(alpha+3/2)^3*(2+alpha)^3*GAMMA(alpha)^3)*Pi^(1/4)/((alpha+1)*(2*alpha+3)*alpha^2*GAMMA(alpha+3/2)^2*(2+alpha)^2*GAMMA(alpha)^2), (3, 4) = 0, (3, 5) = 0, (3, 6) = 0, (4, 1) = 0, (4, 2) = 0, (4, 3) = 0, (4, 4) = 2*GAMMA(alpha+5/2)*Pi^(1/4)*sqrt(GAMMA(alpha+1)*GAMMA(alpha+1/2)^3)/(alpha*(2*alpha+3)*(1+2*alpha)*GAMMA(alpha)*GAMMA(alpha+1/2)^2), (4, 5) = 0, (4, 6) = 0, (5, 1) = 0, (5, 2) = 0, (5, 3) = 0, (5, 4) = (3/2)*GAMMA(alpha+5/2)*Pi^(1/4)*sqrt(GAMMA(alpha+1)*GAMMA(alpha+1/2)^3)/(alpha*(2*alpha+3)*(1+2*alpha)*GAMMA(alpha)*GAMMA(alpha+1/2)^2), (5, 5) = (1/4)*GAMMA(alpha+5/2)*sqrt(2)*sqrt(GAMMA(alpha+1/2)^3*alpha^3*(alpha+1)^3*GAMMA(alpha)^3)*Pi^(1/4)/((2*alpha+3)*(1+2*alpha)*GAMMA(alpha+1/2)^2*alpha^2*(alpha+1)^2*GAMMA(alpha)^2), (5, 6) = 0, (6, 1) = 0, (6, 2) = 0, (6, 3) = 0, (6, 4) = (1/16)*(18*alpha+19)*GAMMA(alpha+5/2)*Pi^(1/4)*sqrt(GAMMA(alpha+1)*GAMMA(alpha+1/2)^3)/(alpha*(alpha+1)*(2*alpha+3)*(1+2*alpha)*GAMMA(alpha)*GAMMA(alpha+1/2)^2), (6, 5) = (3/8)*GAMMA(alpha+5/2)*sqrt(2)*sqrt(GAMMA(alpha+1/2)^3*alpha^3*(alpha+1)^3*GAMMA(alpha)^3)*Pi^(1/4)/((2*alpha+3)*(1+2*alpha)*GAMMA(alpha+1/2)^2*alpha^2*(alpha+1)^2*GAMMA(alpha)^2), (6, 6) = (1/32)*GAMMA(alpha+5/2)*sqrt(2)*sqrt(alpha^3*GAMMA(alpha+3/2)^3*(2+alpha)^3*GAMMA(alpha)^3)*Pi^(1/4)/((alpha+1)*(2*alpha+3)*alpha^2*GAMMA(alpha+3/2)^2*(2+alpha)^2*GAMMA(alpha)^2)})
First 865 866 867 868 869 870 871 Last Page 867 of 2459
