Below is my attempt to distinguish between add vs sum commands.  In principle, the sum command is symbolic.  I attempt the comparison in general, but get an error for the add command.  This error appears to occur if I do not assign numeric values to the general variables in the function.  I would like to execute the comparison symbolically.  Can this be done or does add only execute numerical evaluations?
Download sum_vs_add.mw
sum_vs_add.mw
How can I find the next number in the following set of numbers?
3,10,2,7,7,?
Thank you for your help!
How do I extract harmonics and plot a spectrum from a piecewise function?
The function is "Ia" shown below near the bottom in the "Plot Line Current" section.
NULLNULL
Parm_List := [Erms = 70.7, L = 0.4e-2, alpha = .524, omega = 2*Pi*60, R = 5, Idc = 22.3, mu = .5490]
[Erms = 70.7, L = 0.4e-2, alpha = .524, omega = 120*Pi, R = 5, Idc = 22.3, mu = .5490]
Va := sqrt(2)*Vrms*sin(theta)Vmax =  RmsMS phase to neutral voltage
Vb := sqrt(2)*Vrms*sin(theta-2*Pi*(1/3))
Vc := sqrt(2)*Vrms*sin(theta+2*Pi*(1/3))
Vab := Va-Vb
Vbc := Vb-Vc
Vca := Vc-Va
com0 := rhs(simplify(solve({Vb = Vc, -Pi < theta and theta < 0}, theta, allsolutions))[1]) = -(1/2)*PiNULL
com1 := rhs(simplify(solve({Vc = Va, 0 < theta and theta < Pi}, theta, allsolutions))[1]) = (1/6)*PiNULL
com2 := rhs(simplify(solve({Vb = Vc, 0 < theta and theta < Pi}, theta, allsolutions))[1]) = (1/2)*PiNULL
com3 := rhs(simplify(solve({Va = Vb, 0 < theta and theta < Pi}, theta, allsolutions))[1]) = (5/6)*PiNULL
com4 := rhs(simplify(solve({Va = Vc, Pi < theta and theta < 2*Pi}, theta, allsolutions))[1]) = (7/6)*Pi
com5 := rhs(simplify(solve({Vb = Vc, Pi < theta and theta < 2*Pi}, theta, allsolutions))[1]) = (3/2)*Pi
com6 := rhs(simplify(solve({Va = Vb, Pi < theta and theta < 2*Pi}, theta, allsolutions))[1]) = (11/6)*PiNULL
NULL  NULL
with(plots)
PlotVpn := plot(subs(Vrms = 100, [Va, Vb, Vc]), theta = -(1/2)*Pi .. 3*Pi)
PlotVpp := plot(subs(Vrms = 100, [Vab, Vbc, Vca]), theta = -(1/2)*Pi .. 3*Pi, linestyle = dot, thickness = 1)``
display({PlotVpn, PlotVpp})
plot(subs(Vrms = 100, [Va, Vb, Vc, Vab, Vbc, Vca]), theta = -(1/2)*Pi .. 3*Pi)
The  #1 diode is forward biased and switches on when Va>Vc (Va=Vc). The voltage VD will be equal to Va-Vb until diode #2 turns on when Vc< Vb. Then VD will equal Vc-Vc.
The switching angle for the diodes is given above. If phase control is used all commutation is delayed by the angle α.
NULL``
Without phase delay the average (DC) voltage applied to the laod is the average value of the 6 commutation periods over one cycle:
Van := sqrt(2)*Erms*sin(theta)Emax =  RmsMS phase to neutral voltage
Vbn := sqrt(2)*Erms*sin(theta-2*Pi*(1/3))
Vcn := sqrt(2)*Erms*sin(theta+2*Pi*(1/3))
Eq1 := Vdo = 6*(int(Van-Vbn, theta = com1 .. com2))/(2*Pi)
Vdo = 3*3^(1/2)*2^(1/2)*Erms/Pi
Eq2 := Vdc = 6*(int(Van-Vbn, theta = com1+alpha .. com2+alpha))/(2*Pi)
Vdc = 3*2^(1/2)*Erms*3^(1/2)*cos(alpha)/Pi
Commutation
The switching between diodes can not occur instantaneously because the supply circuit is inductive. Current can not change instantaneously in and inductive circuit.
The transfer of load current from the out-going phase to the incomming phase is accomplshed by a period of symultaneous conduction of the two adjacent diodes the creation of a circulating current between these two phases that resembles short circuit between the two phases.
The circulating current produces equal voltage drop with opposid polarities in each phase. In the out-going phase the drop adds to the soruce voltage and in the incomming phase the drop subtracts from the source voltage. Only the drop in the incomming phase effects the DC output voltage.
During commutation intervil com1 to com2 phases a and c are shorted while Id is transfered from phase c to phase a. During this time voltage Va-Vb minus the voltage drop in a phase caused by the commutation. This voltage drop is 1/2 the Vac voltage.
`&Delta;e` := 1/2*(Van-Vcn)
(1/2)*2^(1/2)*Erms*sin(theta)-(1/2)*2^(1/2)*Erms*cos(theta+(1/6)*Pi)
and      Va=Vc at π/6
`&Delta;E__Avg` = 6*(int(`&Delta;e`, theta = (1/6)*Pi+alpha .. (1/6)*Pi+alpha+mu))/(2*Pi)
`&Delta;E__Avg` = 3*((1/2)*2^(1/2)*Erms*cos((1/6)*Pi+alpha)+(1/2)*2^(1/2)*Erms*sin((1/3)*Pi+alpha)-(1/2)*2^(1/2)*Erms*sin((1/3)*Pi+alpha+mu)-(1/2)*2^(1/2)*Erms*cos((1/6)*Pi+alpha+mu))/Pi
`&Delta;E__Avg` = (3/2)*2^(1/2)*Erms*(cos((1/6)*Pi+alpha)+sin((1/3)*Pi+alpha)-sin((1/3)*Pi+alpha+mu)-cos((1/6)*Pi+alpha+mu))/Pi
`&Delta;E__Avg` = (3/2)*2^(1/2)*Erms*3^(1/2)*cos(alpha)/Pi-(3/2)*Erms*2^(1/2)*3^(1/2)*cos(alpha)*cos(mu)/Pi+(3/2)*Erms*2^(1/2)*3^(1/2)*sin(alpha)*sin(mu)/Pi
`&Delta;E__Avg` = (3/2)*Erms*2^(1/2)*((-cos(mu)+1)*cos(alpha)+sin(alpha)*sin(mu))*3^(1/2)/Pi
combine(`&Delta;E__Avg` = (3/2)*Erms*2^(1/2)*((-cos(mu)+1)*cos(alpha)+sin(alpha)*sin(mu))*3^(1/2)/Pi, trig)
`&Delta;E__Avg` = (1/2)*(-3*Erms*2^(1/2)*3^(1/2)*cos(alpha+mu)+3*2^(1/2)*Erms*3^(1/2)*cos(alpha))/Pi
`&Delta;E__Avg` = -(3/2)*3^(1/2)*2^(1/2)*Erms*(cos(alpha+mu)-cos(alpha))/Pi
DC output voltage
V__D = Vdc-`&Delta;E__Avg`
subs([Vdc = 3*2^(1/2)*Erms*3^(1/2)*cos(alpha)/Pi, `&Delta;E__Avg` = -(3/2)*3^(1/2)*2^(1/2)*Erms*(cos(alpha+mu)-cos(alpha))/Pi], V__D = Vdc-`&Delta;E__Avg`)
V__D = 3*2^(1/2)*Erms*3^(1/2)*cos(alpha)/Pi+(3/2)*3^(1/2)*2^(1/2)*Erms*(cos(alpha+mu)-cos(alpha))/Pi
V__D = (3/2)*2^(1/2)*Erms*3^(1/2)*(cos(alpha)+cos(alpha+mu))/Pi
Equating the intigral of the voltage drop between the phase A and C  to the intigral of the voltage rise across the two phase inductances (thes intigrals represent eqivalent flux).
int(Van-Vcn, theta = (1/6)*Pi+alpha .. (1/6)*Pi+alpha+mu) = int(2*L*omega, theta = 0 .. Id)
2^(1/2)*Erms*cos((1/6)*Pi+alpha)+2^(1/2)*Erms*sin((1/3)*Pi+alpha)-2^(1/2)*Erms*cos((1/6)*Pi+alpha+mu)-2^(1/2)*Erms*sin((1/3)*Pi+alpha+mu) = 2*L*omega*Id
(14)
2^(1/2)*Erms*3^(1/2)*cos(alpha)-2^(1/2)*Erms*3^(1/2)*cos(alpha)*cos(mu)+2^(1/2)*Erms*3^(1/2)*sin(alpha)*sin(mu) = 2*L*omega*Id
(15)
-((cos(mu)-1)*cos(alpha)-sin(alpha)*sin(mu))*3^(1/2)*2^(1/2)*Erms = 2*L*omega*Id
(16)
combine(-((cos(mu)-1)*cos(alpha)-sin(alpha)*sin(mu))*3^(1/2)*2^(1/2)*Erms = 2*L*omega*Id, trig)
-Erms*2^(1/2)*3^(1/2)*cos(alpha+mu)+2^(1/2)*Erms*3^(1/2)*cos(alpha) = 2*L*omega*Id
(17)
cos(alpha+mu) = -(1/6)*(2*L*omega*Id-2^(1/2)*Erms*3^(1/2)*cos(alpha))*3^(1/2)*2^(1/2)/Erms
(18)
cos(alpha+mu) = -(1/3)*3^(1/2)*2^(1/2)*L*omega*Id/Erms+cos(alpha)
(19)
NULL``
subs(cos(alpha+mu) = -(1/6)*(2*L*omega*Id-2^(1/2)*Erms*3^(1/2)*cos(alpha))*3^(1/2)*2^(1/2)/Erms, V__D = (3/2)*2^(1/2)*Erms*3^(1/2)*(cos(alpha)+cos(alpha+mu))/Pi)
V__D = (3/2)*2^(1/2)*Erms*3^(1/2)*(cos(alpha)-(1/6)*(2*L*omega*Id-2^(1/2)*Erms*3^(1/2)*cos(alpha))*3^(1/2)*2^(1/2)/Erms)/Pi
(20)
V__D = 3*2^(1/2)*Erms*3^(1/2)*cos(alpha)/Pi-3*L*omega*Id/Pi
(21)
Line Currents
NULL NULL
Commutation Intervals
Plot Line Currents
Ia := piecewise((-Pi)*(1/6)+alpha < theta and theta <= (-Pi)*(1/6)+alpha+mu, Ia__Int1, (-Pi)*(1/6)+alpha+mu <= theta and theta <= (1/6)*Pi+alpha, Ia__Int2, (1/6)*Pi+alpha < theta and theta <= (1/6)*Pi+alpha+mu, Ia__Int3, (1/6)*Pi+alpha+mu < theta and theta <= (1/2)*Pi+alpha, Ia__Int4, (1/2)*Pi+alpha < theta and theta <= (1/2)*Pi+alpha+mu, Ia__Int5, (1/2)*Pi+alpha+mu < theta and theta <= 5*Pi*(1/6)+alpha, Ia__Int6, 5*Pi*(1/6)+alpha < theta and theta <= 5*Pi*(1/6)+alpha+mu, Ia__Int7, 5*Pi*(1/6)+alpha+mu < theta and theta <= 7*Pi*(1/6)+alpha, Ia__Int8, 7*Pi*(1/6)+alpha < theta and theta <= 7*Pi*(1/6)+alpha+mu, Ia__Int9, 7*Pi*(1/6)+alpha+mu < theta and theta <= 3*Pi*(1/2)+alpha, Ia__Int10, 3*Pi*(1/2)+alpha < theta and theta <= 3*Pi*(1/2)+alpha+mu, Ia__Int11, 3*Pi*(1/2)+alpha+mu < theta and theta <= 11*Pi*(1/6)+alpha, Ia__Int12, 11*Pi*(1/6)+alpha < theta and theta <= 11*Pi*(1/6)+alpha+mu, Ia__Int13)                Ib := piecewise((-Pi)*(1/6)+alpha < theta and theta <= (-Pi)*(1/6)+alpha+mu, Ib__Int1, (-Pi)*(1/6)+alpha+mu <= theta and theta <= (1/6)*Pi+alpha, Ib__Int2, (1/6)*Pi+alpha < theta and theta <= (1/6)*Pi+alpha+mu, Ib__Int3, (1/6)*Pi+alpha+mu < theta and theta <= (1/2)*Pi+alpha, Ib__Int4, (1/2)*Pi+alpha < theta and theta <= (1/2)*Pi+alpha+mu, Ib__Int5, (1/2)*Pi+alpha+mu < theta and theta <= 5*Pi*(1/6)+alpha, Ib__Int6, 5*Pi*(1/6)+alpha < theta and theta <= 5*Pi*(1/6)+alpha+mu, Ib__Int7, 5*Pi*(1/6)+alpha+mu < theta and theta <= 7*Pi*(1/6)+alpha, Ib__Int8, 7*Pi*(1/6)+alpha < theta and theta <= 7*Pi*(1/6)+alpha+mu, Ib__Int9, 7*Pi*(1/6)+alpha+mu < theta and theta <= 3*Pi*(1/2)+alpha, Ib__Int10, 3*Pi*(1/2)+alpha < theta and theta <= 3*Pi*(1/2)+alpha+mu, Ib__Int11, 3*Pi*(1/2)+alpha+mu < theta and theta <= 11*Pi*(1/6)+alpha, Ib__Int12, 11*Pi*(1/6)+alpha < theta and theta <= 11*Pi*(1/6)+alpha+mu, Ib__Int13)
IaPlot := plot(subs([Erms = 70.7, L = 0.4e-2, alpha = .524, omega = 2*Pi*60, R = 5, Idc = 22.3, mu = .5490], Ia), theta = -(1/6)*Pi .. 3*Pi)
IbPlot := plot(subs([Erms = 70.7, L = 0.4e-2, alpha = .524, omega = 2*Pi*60, R = 5, Idc = 22.3, mu = .5490], Ib), theta = -(1/6)*Pi .. 3*Pi)
NULLNULL
Line Rms Current
with(OrthogonalSeries)
Download Graetz_Bridg7b.mw
Hello all,
How to animate a set of vectors?
for example,
q:=Matrix(3,10,(i,j)->i^2+j+2*i); # some matrix which holds the 3x1 vectors.
animate(arrow,[q(..,i)],i = 1..10);
I get an error
Error, unsupported type of index, i
In real use, the input to 'arrow' function will be a vector valued function so the 'animate' command will show the resulting vectors.
thanks.
EngM.
Hello All,
I am trying to solve a nonlinear equation as a part of inverse kinematic for a robot tip.
The robot is mostly redundant, and thus, the optimization package is the best to use.
I looked the NLPSolve function in matrix form.
the equation(s) am trying to solve is of the following format
Tip - Desired = 0
Tip is a 6x1 vector and is a function (or expression) of q1 ..., qn number of joints.
Desired is 6x1 numerical values representing the desired Tip position and orientation.
for example, for a planar robot with only x,y coordinates
<cos(q[1])*cos(q[3])-sin(q[1])*sin(q[3])+sin(q[1])*q[2]+cos(q[1]), sin(q[1])*cos(q[3])+cos(q[1])*sin(q[3])-cos(q[1])*q[2]+sin(q[1])> - <1,1> = 0
I am a bit confused on how to use the NPLSolve command in matrix form.
I understand that I need to formulate a procedure p(v) where v is a vector (here it will be v := <q[1], .., q[n]> ) , however, I am not solving one objective function rather 6 of them for 6-degrees of freedom.
I tried something like
p:=proc(q)
    <cos(q[1])*cos(q[3])-sin(q[1])*sin(q[3])+sin(q[1])*q[2]+cos(q[1]) - 1,sin(q[1])*cos(q[3])+cos(q[1])*sin(q[3])-cos(q[1])*q[2]+sin(q[1]) -1>;
    Optimization[NLPSolve](3,p,initialpoint = evalf(q_start),maximize = false)
where q_start is 3x1 vector giving the initial point.
but I always get
Error, (in Optimization:-NLPSolve) non-numeric result encountered
How can I solve for set of equations?
thanks.
EngM
Dear all, I've been given the following procedure:
> int_part:=proc(f,h,n::integer) local k,u,v,s;
     > u:=f;
     > v:=h;
     > s:=0;
     > for k from 1 to n do;
     > u:=int(u,t);
     > s:=s-(-1)^(k)*u*v;
     > v:=diff(v,t);
> od;
> s; end:
To apply on the following function: f:=int((exp(-x*t))/sqrt(t(t+1)),t=1..infinity);
And f is a function of x. F(x).
It should give the asymptotic expansion up to O(x^-6). But probably I do something wrong. Can somebody help me please?
Best wishes, Math
I have a trigonometric equation that outputs with a solution in terms of _B1 which I want to remove.
restart: solve({7*cos(2*t)=7*cos(t)^2-5, t>=0, t<=2*Pi}, t, allsolutions, explicit);
output:
{t = arccos((1/7)*sqrt(14))},
{t = 2*Pi-arccos((1/7)*sqrt(14))},
{t = 2*arccos((1/7)*sqrt(14))*_B1-2*_B1*Pi+2*Pi*_Z1-arccos((1/7)*sqrt(14))+Pi}
Is there anyway to get rid of the _B1, or somehow evaluate it by a substitution?
Even numerically the answer still retains the _B1.
{t = 1.006853685}, {t = 5.276331623}, {t = -4.269477938*_B1+6.283185308*_Z1+2.134738969}
Also it would be nice to remove the _Z1 subscript too, as the domain of the equation is [0, 2pi].
I tried removing the 'AllSolutions' command , but then I am missing two solutions:
solve({7*cos(2*t)=7*cos(t)^2-5., t>=0 and t<=2*Pi}, t, Explicit);
 {t = 1.006853685}, {t = 2.134738969}
There should be 4 solutions in the domain [0, 2pi].
If the headline is not the appropriate means, then what is the command line based means of generating a new math container in a worksheet, suppose one has a button with the label "Create New Container inside Selected Section" if that makes my intent any more clear.
At first look the above movement seems to be impossible in real life.
The question is sort of convoluted, but I hope somebody can help.
I have a data set I pulled from an Excel Sheet of the temperature for every day for a year.
Currently, it's in an Array 365x2, where the first column is what day of the year it is and the second column is the temperature. I want to create a plot that on the x-axis shows the day, but on the y-axis shows the amount of a certain chemical in the trees. I have a function of temperature vs chemicals, but I want my graph to show the day of the year vs amount of chemical. How would I go about making such a plot? I don't know how to connect all three.
Hi guys,
how do I rearrange the expression eq16, in order to get eq17 by using maple commands?
thank you!
Can someone explain to me why the following lists do not have the same content?  And suggest how I might be able to fix the problem?
a := (x^2+y^2)^3 = y^2:
b := (x^2+y^2)^(3/2) = y:
listA := sort([seq(evalf(solve({y >= 0, subs(x = i, a)}, {y})), i = 0.5e-1 .. .5, 0.5e-1)]);
listB := sort([seq(evalf(solve({y >= 0, subs(x = i, b)}, {y})), i = 0.5e-1 .. .5, 0.5e-1)]);
evalb(listA = listB);
If I have a position vector r(t) i polar coordinates and want to calculate velocity I can't get maple to differentiate the unit vectors w.r.t time. How do I do that?
hi
I want to equating coefficients of like powers of  in expr732vc and expr732wc, but
this error is appeared.please help me.
Error, unable to compute coeff
3.mw
restart;intSet:={int1,int2}
{int1, int2}
expr732 := 120000*(diff(v[0](x, T[0], T[1])+epsilon*v[1](x, T[0], T[1]), x, x))+1200*(diff(w[0](x, T[0], T[1])+epsilon*w[1](x, T[0], T[1]), x, x))*(diff(w[0](x, T[0], T[1])+epsilon*w[1](x, T[0], T[1]), x))+96.0000*(diff(diff(v[0](x, T[0], T[1])+epsilon*v[1](x, T[0], T[1]), T[0])+epsilon*(diff(v[0](x, T[0], T[1])+epsilon*v[1](x, T[0], T[1]), T[1])), x, x))+.9600*(diff(diff(w[0](x, T[0], T[1])+epsilon*w[1](x, T[0], T[1]), T[0])+epsilon*(diff(w[0](x, T[0], T[1])+epsilon*w[1](x, T[0], T[1]), T[1])), x))*(diff(w[0](x, T[0], T[1])+epsilon*w[1](x, T[0], T[1]), x, x))+.9600*(diff(diff(w[0](x, T[0], T[1])+epsilon*w[1](x, T[0], T[1]), T[0])+epsilon*(diff(w[0](x, T[0], T[1])+epsilon*w[1](x, T[0], T[1]), T[1])), x, x))*(diff(w[0](x, T[0], T[1])+epsilon*w[1](x, T[0], T[1]), x))-(diff(v[0](x, T[0], T[1])+epsilon*v[1](x, T[0], T[1]), T[0], T[0]))-epsilon*(diff(v[0](x, T[0], T[1])+epsilon*v[1](x, T[0], T[1]), T[1], T[0]))-epsilon*(diff(v[0](x, T[0], T[1])+epsilon*v[1](x, T[0], T[1]), T[1], T[0])+epsilon*(diff(v[0](x, T[0], T[1])+epsilon*v[1](x, T[0], T[1]), T[1], T[1]))), .9600*(diff(diff(v[0](x, T[0], T[1])+epsilon*v[1](x, T[0], T[1]), T[0])+epsilon*(diff(v[0](x, T[0], T[1])+epsilon*v[1](x, T[0], T[1]), T[1])), x, x))*(diff(w[0](x, T[0], T[1])+epsilon*w[1](x, T[0], T[1]), x))+.9600*(diff(diff(v[0](x, T[0], T[1])+epsilon*v[1](x, T[0], T[1]), T[0])+epsilon*(diff(v[0](x, T[0], T[1])+epsilon*v[1](x, T[0], T[1]), T[1])), x))*(diff(w[0](x, T[0], T[1])+epsilon*w[1](x, T[0], T[1]), x, x))+0.192e-1*(diff(diff(w[0](x, T[0], T[1])+epsilon*w[1](x, T[0], T[1]), T[0])+epsilon*(diff(w[0](x, T[0], T[1])+epsilon*w[1](x, T[0], T[1]), T[1])), x))*(diff(w[0](x, T[0], T[1])+epsilon*w[1](x, T[0], T[1]), x, x))*(diff(w[0](x, T[0], T[1])+epsilon*w[1](x, T[0], T[1]), x))+0.96e-2*(diff(w[0](x, T[0], T[1])+epsilon*w[1](x, T[0], T[1]), x))^2*(diff(diff(w[0](x, T[0], T[1])+epsilon*w[1](x, T[0], T[1]), T[0])+epsilon*(diff(w[0](x, T[0], T[1])+epsilon*w[1](x, T[0], T[1]), T[1])), x, x))+1200*(diff(v[0](x, T[0], T[1])+epsilon*v[1](x, T[0], T[1]), x, x))*(diff(w[0](x, T[0], T[1])+epsilon*w[1](x, T[0], T[1]), x))+1200*(diff(w[0](x, T[0], T[1])+epsilon*w[1](x, T[0], T[1]), x, x))*(diff(v[0](x, T[0], T[1])+epsilon*v[1](x, T[0], T[1]), x))+18*(diff(w[0](x, T[0], T[1])+epsilon*w[1](x, T[0], T[1]), x))^2*(diff(w[0](x, T[0], T[1])+epsilon*w[1](x, T[0], T[1]), x, x))-1.3943*(diff(w[0](x, T[0], T[1])+epsilon*w[1](x, T[0], T[1]), x, x, x, x))-0.111544e-2*(diff(diff(w[0](x, T[0], T[1])+epsilon*w[1](x, T[0], T[1]), T[0])+epsilon*(diff(w[0](x, T[0], T[1])+epsilon*w[1](x, T[0], T[1]), T[1])), x, x, x, x))+10-(diff(w[0](x, T[0], T[1])+epsilon*w[1](x, T[0], T[1]), T[0], T[0]))-epsilon*(diff(w[0](x, T[0], T[1])+epsilon*w[1](x, T[0], T[1]), T[1], T[0]))-epsilon*(diff(w[0](x, T[0], T[1])+epsilon*w[1](x, T[0], T[1]), T[1], T[0])+epsilon*(diff(w[0](x, T[0], T[1])+epsilon*w[1](x, T[0], T[1]), T[1], T[1]))):
expr732va := 1.20000*10^5*(diff(v[0](x, T[0], T[1]), x, x))+1200.*(diff(w[0](x, T[0], T[1]), x, x))*(diff(w[0](x, T[0], T[1]), x))+96.0000*(diff(v[0](x, T[0], T[1]), T[0], x, x))+.9600*(diff(w[0](x, T[0], T[1]), T[0], x))*(diff(w[0](x, T[0], T[1]), x, x))+.9600*(diff(w[0](x, T[0], T[1]), T[0], x, x))*(diff(w[0](x, T[0], T[1]), x))-1.*(diff(v[0](x, T[0], T[1]), T[0], T[0]))+1.20000*10^5*(diff(v[1](x, T[0], T[1]), x, x))+1200.*(diff(w[0](x, T[0], T[1]), x, x))*(diff(w[1](x, T[0], T[1]), x))+1200.*(diff(w[1](x, T[0], T[1]), x, x))*(diff(w[0](x, T[0], T[1]), x))+96.0000*(diff(v[1](x, T[0], T[1]), T[0], x, x))+96.0000*(diff(v[0](x, T[0], T[1]), T[1], x, x))+.9600*(diff(w[0](x, T[0], T[1]), T[0], x))*(diff(w[1](x, T[0], T[1]), x, x))+(.9600*(diff(w[1](x, T[0], T[1]), T[0], x)+diff(w[0](x, T[0], T[1]), T[1], x)))*(diff(w[0](x, T[0], T[1]), x, x))+.9600*(diff(w[0](x, T[0], T[1]), T[0], x, x))*(diff(w[1](x, T[0], T[1]), x))+(.9600*(diff(w[1](x, T[0], T[1]), T[0], x, x)+diff(w[0](x, T[0], T[1]), T[1], x, x)))*(diff(w[0](x, T[0], T[1]), x))-1.*(diff(v[1](x, T[0], T[1]), T[0], T[0]))-2.*(diff(v[0](x, T[0], T[1]), T[1], T[0])):
expr732vb1:=select(has,expr732[1],intSet)
expr732vb:=convert(series(map(s->remove(has,s,intSet)*subs(epsilon=0,select(has,s,intSet)),expr732vb1),epsilon,2),polynom);
0 = 0
expr732vc := 1.20000*10^5*(diff(v[0](x, T[0], T[1]), x, x))+1200.*(diff(w[0](x, T[0], T[1]), x, x))*(diff(w[0](x, T[0], T[1]), x))+96.0000*(diff(v[0](x, T[0], T[1]), T[0], x, x))+.9600*(diff(w[0](x, T[0], T[1]), T[0], x))*(diff(w[0](x, T[0], T[1]), x, x))+.9600*(diff(w[0](x, T[0], T[1]), T[0], x, x))*(diff(w[0](x, T[0], T[1]), x))-1.*(diff(v[0](x, T[0], T[1]), T[0], T[0]))+(1.20000*10^5*(diff(v[1](x, T[0], T[1]), x, x))+1200.*(diff(w[0](x, T[0], T[1]), x, x))*(diff(w[1](x, T[0], T[1]), x))+1200.*(diff(w[1](x, T[0], T[1]), x, x))*(diff(w[0](x, T[0], T[1]), x))+96.0000*(diff(v[1](x, T[0], T[1]), T[0], x, x))+96.0000*(diff(v[0](x, T[0], T[1]), T[1], x, x))+.9600*(diff(w[0](x, T[0], T[1]), T[0], x))*(diff(w[1](x, T[0], T[1]), x, x))+(.9600*(diff(w[1](x, T[0], T[1]), T[0], x)+diff(w[0](x, T[0], T[1]), T[1], x)))*(diff(w[0](x, T[0], T[1]), x, x))+.9600*(diff(w[0](x, T[0], T[1]), T[0], x, x))*(diff(w[1](x, T[0], T[1]), x))+(.9600*(diff(w[1](x, T[0], T[1]), T[0], x, x)+diff(w[0](x, T[0], T[1]), T[1], x, x)))*(diff(w[0](x, T[0], T[1]), x))-1.*(diff(v[1](x, T[0], T[1]), T[0], T[0]))-2.*(diff(v[0](x, T[0], T[1]), T[1], T[0])))*epsilon = 1.20000*10^5*(diff(v[0](x, T[0], T[1]), x, x))+1200.*(diff(w[0](x, T[0], T[1]), x, x))*(diff(w[0](x, T[0], T[1]), x))+96.0000*(diff(v[0](x, T[0], T[1]), T[0], x, x))+.9600*(diff(w[0](x, T[0], T[1]), T[0], x))*(diff(w[0](x, T[0], T[1]), x, x))+.9600*(diff(w[0](x, T[0], T[1]), T[0], x, x))*(diff(w[0](x, T[0], T[1]), x))-1.*(diff(v[0](x, T[0], T[1]), T[0], T[0]))+(1.20000*10^5*(diff(v[1](x, T[0], T[1]), x, x))+1200.*(diff(w[0](x, T[0], T[1]), x, x))*(diff(w[1](x, T[0], T[1]), x))+1200.*(diff(w[1](x, T[0], T[1]), x, x))*(diff(w[0](x, T[0], T[1]), x))+96.0000*(diff(v[1](x, T[0], T[1]), T[0], x, x))+96.0000*(diff(v[0](x, T[0], T[1]), T[1], x, x))+.9600*(diff(w[0](x, T[0], T[1]), T[0], x))*(diff(w[1](x, T[0], T[1]), x, x))+(.9600*(diff(w[1](x, T[0], T[1]), T[0], x)+diff(w[0](x, T[0], T[1]), T[1], x)))*(diff(w[0](x, T[0], T[1]), x, x))+.9600*(diff(w[0](x, T[0], T[1]), T[0], x, x))*(diff(w[1](x, T[0], T[1]), x))+(.9600*(diff(w[1](x, T[0], T[1]), T[0], x, x)+diff(w[0](x, T[0], T[1]), T[1], x, x)))*(diff(w[0](x, T[0], T[1]), x))-1.*(diff(v[1](x, T[0], T[1]), T[0], T[0]))-2.*(diff(v[0](x, T[0], T[1]), T[1], T[0])))*epsilon:
expr732wa:=convert(series(remove(has,expr732[2],intSet),epsilon,2),polynom):
expr732wb1:=select(has,expr732[2],intSet)
expr732wb:=convert(series(map(s->remove(has,s,intSet)*subs(epsilon=0,select(has,s,intSet)),expr732wb1),epsilon,2),polynom)
0 = 0
expr732wc := .9600*(diff(v[0](x, T[0], T[1]), T[0], x, x))*(diff(w[0](x, T[0], T[1]), x))+.9600*(diff(v[0](x, T[0], T[1]), T[0], x))*(diff(w[0](x, T[0], T[1]), x, x))+0.192e-1*(diff(w[0](x, T[0], T[1]), T[0], x))*(diff(w[0](x, T[0], T[1]), x, x))*(diff(w[0](x, T[0], T[1]), x))+0.96e-2*(diff(w[0](x, T[0], T[1]), x))^2*(diff(w[0](x, T[0], T[1]), T[0], x, x))+1200.*(diff(v[0](x, T[0], T[1]), x, x))*(diff(w[0](x, T[0], T[1]), x))+1200.*(diff(w[0](x, T[0], T[1]), x, x))*(diff(v[0](x, T[0], T[1]), x))+18.*(diff(w[0](x, T[0], T[1]), x))^2*(diff(w[0](x, T[0], T[1]), x, x))-1.3943*(diff(w[0](x, T[0], T[1]), x, x, x, x))-0.111544e-2*(diff(w[0](x, T[0], T[1]), T[0], x, x, x, x))+10.-1.*(diff(w[0](x, T[0], T[1]), T[0], T[0]))+(.9600*(diff(v[0](x, T[0], T[1]), T[0], x, x))*(diff(w[1](x, T[0], T[1]), x))+(.9600*(diff(v[1](x, T[0], T[1]), T[0], x, x)+diff(v[0](x, T[0], T[1]), T[1], x, x)))*(diff(w[0](x, T[0], T[1]), x))+.9600*(diff(v[0](x, T[0], T[1]), T[0], x))*(diff(w[1](x, T[0], T[1]), x, x))+(.9600*(diff(v[1](x, T[0], T[1]), T[0], x)+diff(v[0](x, T[0], T[1]), T[1], x)))*(diff(w[0](x, T[0], T[1]), x, x))+0.192e-1*(diff(w[0](x, T[0], T[1]), T[0], x))*(diff(w[0](x, T[0], T[1]), x, x))*(diff(w[1](x, T[0], T[1]), x))+(0.192e-1*((diff(w[0](x, T[0], T[1]), T[0], x))*(diff(w[1](x, T[0], T[1]), x, x))+(diff(w[1](x, T[0], T[1]), T[0], x)+diff(w[0](x, T[0], T[1]), T[1], x))*(diff(w[0](x, T[0], T[1]), x, x))))*(diff(w[0](x, T[0], T[1]), x))+0.96e-2*(diff(w[0](x, T[0], T[1]), x))^2*(diff(w[1](x, T[0], T[1]), T[0], x, x)+diff(w[0](x, T[0], T[1]), T[1], x, x))+0.192e-1*(diff(w[0](x, T[0], T[1]), x))*(diff(w[1](x, T[0], T[1]), x))*(diff(w[0](x, T[0], T[1]), T[0], x, x))+1200.*(diff(v[0](x, T[0], T[1]), x, x))*(diff(w[1](x, T[0], T[1]), x))+1200.*(diff(v[1](x, T[0], T[1]), x, x))*(diff(w[0](x, T[0], T[1]), x))+1200.*(diff(w[0](x, T[0], T[1]), x, x))*(diff(v[1](x, T[0], T[1]), x))+1200.*(diff(w[1](x, T[0], T[1]), x, x))*(diff(v[0](x, T[0], T[1]), x))+18.*(diff(w[0](x, T[0], T[1]), x))^2*(diff(w[1](x, T[0], T[1]), x, x))+36.*(diff(w[0](x, T[0], T[1]), x))*(diff(w[1](x, T[0], T[1]), x))*(diff(w[0](x, T[0], T[1]), x, x))-1.3943*(diff(w[1](x, T[0], T[1]), x, x, x, x))-0.111544e-2*(diff(w[1](x, T[0], T[1]), T[0], x, x, x, x))-0.111544e-2*(diff(w[0](x, T[0], T[1]), T[1], x, x, x, x))-1.*(diff(w[1](x, T[0], T[1]), T[0], T[0]))-2.*(diff(w[0](x, T[0], T[1]), T[1], T[0])))*epsilon = .9600*(diff(v[0](x, T[0], T[1]), T[0], x, x))*(diff(w[0](x, T[0], T[1]), x))+.9600*(diff(v[0](x, T[0], T[1]), T[0], x))*(diff(w[0](x, T[0], T[1]), x, x))+0.192e-1*(diff(w[0](x, T[0], T[1]), T[0], x))*(diff(w[0](x, T[0], T[1]), x, x))*(diff(w[0](x, T[0], T[1]), x))+0.96e-2*(diff(w[0](x, T[0], T[1]), x))^2*(diff(w[0](x, T[0], T[1]), T[0], x, x))+1200.*(diff(v[0](x, T[0], T[1]), x, x))*(diff(w[0](x, T[0], T[1]), x))+1200.*(diff(w[0](x, T[0], T[1]), x, x))*(diff(v[0](x, T[0], T[1]), x))+18.*(diff(w[0](x, T[0], T[1]), x))^2*(diff(w[0](x, T[0], T[1]), x, x))-1.3943*(diff(w[0](x, T[0], T[1]), x, x, x, x))-0.111544e-2*(diff(w[0](x, T[0], T[1]), T[0], x, x, x, x))+10.-1.*(diff(w[0](x, T[0], T[1]), T[0], T[0]))+(.9600*(diff(v[0](x, T[0], T[1]), T[0], x, x))*(diff(w[1](x, T[0], T[1]), x))+(.9600*(diff(v[1](x, T[0], T[1]), T[0], x, x)+diff(v[0](x, T[0], T[1]), T[1], x, x)))*(diff(w[0](x, T[0], T[1]), x))+.9600*(diff(v[0](x, T[0], T[1]), T[0], x))*(diff(w[1](x, T[0], T[1]), x, x))+(.9600*(diff(v[1](x, T[0], T[1]), T[0], x)+diff(v[0](x, T[0], T[1]), T[1], x)))*(diff(w[0](x, T[0], T[1]), x, x))+0.192e-1*(diff(w[0](x, T[0], T[1]), T[0], x))*(diff(w[0](x, T[0], T[1]), x, x))*(diff(w[1](x, T[0], T[1]), x))+(0.192e-1*((diff(w[0](x, T[0], T[1]), T[0], x))*(diff(w[1](x, T[0], T[1]), x, x))+(diff(w[1](x, T[0], T[1]), T[0], x)+diff(w[0](x, T[0], T[1]), T[1], x))*(diff(w[0](x, T[0], T[1]), x, x))))*(diff(w[0](x, T[0], T[1]), x))+0.96e-2*(diff(w[0](x, T[0], T[1]), x))^2*(diff(w[1](x, T[0], T[1]), T[0], x, x)+diff(w[0](x, T[0], T[1]), T[1], x, x))+0.192e-1*(diff(w[0](x, T[0], T[1]), x))*(diff(w[1](x, T[0], T[1]), x))*(diff(w[0](x, T[0], T[1]), T[0], x, x))+1200.*(diff(v[0](x, T[0], T[1]), x, x))*(diff(w[1](x, T[0], T[1]), x))+1200.*(diff(v[1](x, T[0], T[1]), x, x))*(diff(w[0](x, T[0], T[1]), x))+1200.*(diff(w[0](x, T[0], T[1]), x, x))*(diff(v[1](x, T[0], T[1]), x))+1200.*(diff(w[1](x, T[0], T[1]), x, x))*(diff(v[0](x, T[0], T[1]), x))+18.*(diff(w[0](x, T[0], T[1]), x))^2*(diff(w[1](x, T[0], T[1]), x, x))+36.*(diff(w[0](x, T[0], T[1]), x))*(diff(w[1](x, T[0], T[1]), x))*(diff(w[0](x, T[0], T[1]), x, x))-1.3943*(diff(w[1](x, T[0], T[1]), x, x, x, x))-0.111544e-2*(diff(w[1](x, T[0], T[1]), T[0], x, x, x, x))-0.111544e-2*(diff(w[0](x, T[0], T[1]), T[1], x, x, x, x))-1.*(diff(w[1](x, T[0], T[1]), T[0], T[0]))-2.*(diff(w[0](x, T[0], T[1]), T[1], T[0])))*epsilon:
eqEps:=seq(convert(map(s->coeff(s,epsilon,i)=0,[expr732vc,expr732wc]),exp),i=0..1)
Download 3.mw
limit(Re(exp(1/4-(1/4)*signum(x))*cos((1/2)*ln(abs(x))/Pi)-I*exp(1/4-(1/4)*signum(x))*sin((1/2)*ln(abs(x))/Pi)), x = infinity)
-1 .. 1
limit(Re(exp(1/4-(1/4)*signum(x))*cos((1/2)*ln(abs(x))/Pi)-I*exp(1/4-(1/4)*signum(x))*sin((1/2)*ln(abs(x))/Pi)), x = -infinity)
-exp(1/2) .. exp(1/2)
Download maplehelp_limit_inferior_superior.mw
Hello, i was just curious about why when i plot the function it indicates the values for both the limits are actually the limit sups, and if anyone has a good reference for me as far as computing these limits by hand and verifying that the precise limit does not actually exist, but can only be indicated by the range (inf(L),sup(L)) as the output suggests.
Thankyou in advance!
First 905 906 907 908 909 910 911 Last Page 907 of 2467
