 This post is similar to an earlier post of mine about an artist drawing the letter A as a hole in line paper.  Replicating that in Maple I have put in the 'too hard' basket for now.  I decided to draw the capital letters of the alphabet.  I started with the letter A, not just because it is the first letter, but that that I thought it was of intermediate difficulty.   (...as well as having lady friends with names starting  with B!:-))  Easier letters would be I and L.   One can draw these using the polygon command.  'A' is harder as it has inner regions which must be catered for viz the triangle and trapezium base.  There are about ten letters of the alphabet with curves:  {B, D, P, R, S} and  { J. G, C  O }.   They all have curved portions, but the former set have curves which "bulge out to the right", (with the possible exception of letter S.)  I decided to dive in and tackle the letter B.  I'd heard of Bezier curves and tried to learn about these.  (More later).  Owing to the bulging B, I decided I'd try to liken that part to an ellipse.  I was not happy with the curvature, so tried modifying the equation, involving powers of 4.  After quite a lot of time I managed to get the upper part of the letter  B.  There were difficulties in coloring the letter and I am indebted to Carl (Love aka DeVore) who I recalled mentioned about the order of displaying the various sections of the letter: that saved me hours of anguish!  At this stage the resulting output was that of the letter D, and I was getting tired.  I did a copy and paste of this code into the program below, to compare the output with my previous letter A.  I was disappointed  as the output for the D was almost non-existent.  Initially I thought there may be differences in the values used for A and D and changed x0, y0 for x0D, y0D - but to no effect.  The cut and paste section of D is between the # # # # .
   The output of the rotated letter A, has 'worked' but it looks unusual - I'm not sure if I suffer from slight astigmatism, or there's a bug in my code!  Comments on this please.  I'm not expecting a close inspection of the code - that may be like finding a needle in a haystack. Any ideas as to why there is little output for D?.
Bezier Curves
         Restarting from my previous comment on letters C. J etc these have curves which are orientated something akin to y=x^2 - or in maths lingo, their base curves can be represented by functions.  I found sparse mention of Bezier curves on the Maple site, but there are many sites now describing how to construct these.  I'll just constrict talk to quadratic Bezier curves.  A Bez quad curve can be obtained by multiplying PMT - (nothing to do with women's problems!) - where (I think) P is a 1x3 row vector ( P0 P1 P2), M is a 3x3 matrix <1  -2   1,  -2  2  0,  1  0  0> and T is a 3x1 column vector <t^2, t, 1>  and 0<t<1.
  On multiplying this out it comes to something like:
C(t) =(P0-2P1+P2)t^2+ (-2P0+2P1)t +P0
   This is the equation of a quadratic, or parabola, but I'm not sure how to apply it:-(  I believe the P are related to coords of  "control points" , and when t=0 the parabolashould pass through one's begining point, and similarly when t=1 it should correspond to the end point of one's desired curve.
  I'd appreciate some feedback on whether my ideas are correct.  What are P0,P1,P2 ?  Numbers, vectors?  How are they related to the control points?  ...and the coords of initial & last points of one's curve.  It seems to me there is still a lot of trial and error work to do, but I suppose in a GUI environment the user is using a device to view the curve and can quickly choose the appropriate one.
     Thanks for reading this long missive, and again any feedback is much appreciated.
David
# Second attempt at the letter A: earlier working version was
# letterA_Art_trick.mws
# Functional operators.  Use of ->
# to find coords of rotated points.
#To Do:
#Rotate Trig through phi
#   "   trapezL
# Orientation looks wrong
#  Check - then put in a proc
# non-numeric vertex in trigArL
with(plottools):
# Following are parameters for A : to later put in proc(...)
# phi rotates the A through that angle about the origin/
l:=12:w:=2:thet:=Pi/2.7:topl:=2:x0:=2:y0:=5:phi:=3*Pi/4:
 h := (x, y) -> [x*cos(phi)-y*sin(phi), x*sin(phi)+y*cos(phi)]:
#Alist is list of coords for letter A
Alist:=[[x0,y0],[x0+l*cos(thet),y0+l*sin(thet)],[x0+l*cos(thet)+topl,y0+l*sin(thet)],[x0+2*l*cos(thet)+topl,y0], [x0+2*l*cos(thet)+topl-w,y0],[x0+5*l*cos(thet)/3+topl-w,y0+l*sin(thet)/3],[x0+l*cos(thet)/3+w,y0+l*sin(thet)/3], [x0+w,y0]]:
#outA:=polygon([[x0,y0],[x0+l*cos(thet),y0+l*sin(thet)],[x0+l*cos(thet)+topl,y0+l*sin(thet)],[x0+2*l*cos(thet)+topl,y0], [x0+2*l*cos(thet)+topl-w,y0],[x0+5*l*cos(thet)/3+topl-w,y0+l*sin(thet)/3],[x0+l*cos(thet)/3+w,y0+l*sin(thet)/3], [x0+w,y0]]):
#trigA is small inner triangle of letter A - not rotated
eps:=3*w/4:
corr:=.3*w:
#trigA:=polygon([[x0+(2*l*cos(thet)+topl)/2, #y0+l*sin(thet)-eps],[x0+w+(l/3+corr*w)*cos(thet), #y0+(l/3+corr*w)*sin(thet)],[x0+2*l*cos(thet)+topl-w-(l/3+corr*w)*cos(thet)#, y0+(l/3+corr*w)*sin(thet)]], color=white):
trigA_L:=[[x0+(2*l*cos(thet)+topl)/2, y0+l*sin(thet)-eps],[x0+w+(l/3+corr*w)*cos(thet), y0+(l/3+corr*w)*sin(thet)],[x0+2*l*cos(thet)+topl-w-(l/3+corr*w)*cos(thet), y0+(l/3+corr*w)*sin(thet)]]:
trigArL:=[]:
for i from 1 to 3 do
  #Get coords from trigA_L
x:=trigA_L[i][1]:
y:=trigA_L[i][2]:
# Add coords to new rotated list trigAr
#L := [op(L),x[5]];
trigArL:=[op(trigArL), h(x,y)]:
#trigArL;
trigAr := polygon(trigArL, color=white, linestyle=1, thickness=1):
#plots[display](trigAr);
#Read coords of Alist into another list after first transforming the #coords using func op h.  Angle of rot is phi.  thet is inclination of #letter A
#Main Outline of letter - but NOT the convex hull
Alistr:=[]:
#  h := (x, y) -> [x*cos(phi)-y*sin(phi), x*sin(phi)+y*cos(phi)]:
for i from 1 to 8 do
  #Get coords from Alist
x:=Alist[i][1]:
y:=Alist[i][2]:
# Add coords to new rotated list Alistr
#L := [op(L),x[5]];
Alistr:=[op(Alistr), h(x,y)]:
l2 := polygon(Alistr, color=wheat, linestyle=1, thickness=1):
#plots[display](trigAr,l2);
#plots[display](trigAr,trapezL, l2);
#trigAr,
#thet:=Pi/3:
# Rotation by thet  anti-clockwise about the origin
#h := (x, y) -> [x*cos(thet)-y*sin(thet), x*sin(thet)+y*cos(thet)]:
#h(sqrt(3), 1);
# To find a polygon (trapezium EFGH??) which is the shape of he base of A.
# This is necessary as this portion is colored same as rest of A.
#trapezr:=polygon([[(x0+2*l*cos(thet)+topl-w)*cos(phi)-y0*sin(phi),(x0+2*l*#cos(thet)+topl-w)*sin(phi)+y0*cos(phi)],[(x0+5*l*cos(thet)/3+topl-w)*cos(p#hi)-(y0+l*sin(thet)/3)*sin(phi),(x0+5*l*cos(thet)/3+topl-w)*sin(phi)+(y0+l#*sin(thet)/3)*cos(phi)],[(x0+l*cos(thet)/3+w)*cos(phi)-(y0+l*sin(thet)/3)*#sin(phi),(x0+l*cos(thet)/3+w)*sin(phi)+(y0+l*sin(thet)/3)*cos(phi)],[(x0+w#)*cos(phi)-y0*sin(phi),(x0+w)*sin(phi)+y0*cos(phi)]],color=white,filled=tr#ue,  linestyle=DOT):
#trapezL is a list of coords of the base trapezium
#THESE coords have not been rotated.  Repeat previous procedure to obtain #rotated coords
trapezr:=[]:
for i from 5 to 8 do
x:=Alist[i][1]:
y:=Alist[i][2]:
# Add coords to rotated list trapezr
trapezr:=[op(trapezr), h(x,y)]:
#trap2 := polygon(trapezr, color=wheat, linestyle=1, thickness=1):
#trapezL:=polygon([[x0+2*l*cos(thet)+topl-w,y0],[x0+5*l*cos(thet)/3+topl-w,y0+l*sin(thet)/3],[x0+l*cos(thet)/3+w,y0+l*sin(thet)/3], [x0+w,y0]], color=red):
trapezL:=polygon(trapezr, color=white):
# lbase is an unseen line at base of the trapezium of A.  Colored white # as needed to be hidden
lbase:=line([(x0+2*l*cos(thet)+topl-w)*cos(phi)-y0*sin(phi),(x0+2*l*cos(thet)+topl-w)*sin(phi)+y0*cos(phi)], [(x0+w)*cos(phi)-y0*sin(phi),(x0+w)*sin(phi)+y0*cos(phi)], color=white):
# Letter D  (or top part of B!)
a := .6: b := .5: x0D := 1: y0D:=7:
c1:=15:n:=4:
pl1:=plot([x, y0D+b^2*sqrt(c1-(x-x0D)^n/a^2), x=1..2.6], scaling=constrained, color=wheat,filled=true):
pl2:=plot([x, y0D-b^2*sqrt(c1-(x-x0D)^n/a^2), x=1..2.6], scaling=constrained, color=red, filled=true):  #was white
pl3:=plot([x, y0D+b^2*sqrt(c1/2-(x-x0D)^n/a^2), x=1.3..3], scaling=constrained, color=blue,filled=true):  #was white
pl4:=plot([x, y0D-b^2*sqrt(c1/2-(x-x0D)^n/a^2), x=1.3..3], scaling=constrained,color=wheat, filled=true):
x:=1.3:
#Create & Draw inner up line of D
ylow:=eval(y0D-b^2*sqrt(c1/2-(x-x0D)^n/a^2)):
yhigh:=eval(y0D+b^2*sqrt(c1/2-(x-x0D)^n/a^2)):
l_up_in:=line([x,ylow], [x,yhigh], color=wheat):
#Create & Draw outer up line of D
x:=1:
ylow:=eval(y0D-b^2*sqrt(c1-(x-x0D)^n/a^2)):
yhigh:=eval(y0D+b^2*sqrt(c1-(x-x0D)^n/a^2)):
l_up_out:=line([x,ylow], [x,yhigh], color=white):
plots[display]( pl2,pl4,pl3,l_up_in,l_up_out,pl1, scaling=constrained, view=[1..2.6, 6..8.1]);
# removed l_up_in, before l_up_out - no difference
# # # # # # # # # # # # # # # # # # # # # # # # - End of letter D - # # # #
# Display letter A
plots[display](trigAr,lbase,trapezL, l2);
Below I successfully employed the is command to compare Q1 & Q2.  However, attempting to compare T1 & T2 which is essentially Q1 & Q2 but defined as a functions dependent on m does not work so well.  Can I do this comparison?  If so what is the proper syntax to do this?
Ck1 := sin(Pi*k)/(Pi*k);
a[0]+Sum(-(-1+cos(Pi*k))*sin(2*Pi*k*t/T)/(Pi*k), k = 1 .. m)
Q1 := 2*sin(alpha)*(diff(S11, t)); -1; Q2 := sum(2*sin(alpha)*(2*Ck2*Pi*k*cos(2*Pi*k*t/T)/T), k = 1 .. m); -1; is(Q1 = Q2), is(expand(Q1 = Q2)), is(combine(Q1 = Q2)), is(eval(Q1 = Q2)), is(value(Q1 = Q2)), simplify(Q1-Q2)
true, true, true, true, true, 0
T1 := proc (m) options operator, arrow; Q1 end proc; 1; T2 := proc (m) options operator, arrow; Q2 end proc; 1; is(T1 = T2), is(expand(T1 = T2)), is(combine(T1 = T2)), is(eval(T1 = T2)), is(value(T1 = T2)), simplify(T1-T2)
false, false, false, false, false, T1-T2
Download is_command.mw
I am a beginner with Maple. I had some basic tutorials. In fact I want to solve a first order differential equation with non-constant coefficient:
Can you really tell me what are the steps to follow in Maple 18 in order to solve this equation. I didn't find any tutorial or work that deals with variable coefficients.
Thank you in advnace.
sry guys i have a problem with my maple when i use my fsolve sometimes it gave me no solution but i khow we have a solution ill use simplify to gave it a simplified input but also no awenser is there any other command yo make my problem easier for maple and also is there anyway that i can force my cpu and memory to focus more on solving problems
and at last what is default method for fsolve ( i mean is it newton method or something else and can i change it )
tnQ for your attentions
thats my maple file problem.mw
 r(t) = x(t)i + y(t)j  where the curve is given by x=36cos2t and y=36sin2t
1. Is there a command to compute the normal acceleration vector? Or do I have to go through the formula step by step?
2. Same as above, except for tangential acceleration vector.
3. How do I graph the circle, the tangential vector, and the acceleration vector all on one 3dplot?
can anyone one help me to download maple 6 ?
In MAPLE 12 there is an option in the dropdown menu for the conversions command to convert a complex exponential expression into the cartesian form of a + bi.  However, when I review the HELP menu for the convert command I do not see this option.  Below is an example.  How do I execute the conversion via command line option as opposed to the GUI option?
convert_complex_exponential.mw
hey guys does anybody know if i can define a vector from its degree and lenght. instead of having to use coordinates?
the only way i know of defining a vector so far is
Vector1:=<x,y>
sorry my english is'nt the best
- Morten Lund
Hello again, thanks to everyone who has answered my questions.  It's difficult jumping into Maple starting with calculus 3, I wish I would've used it more in 1 and 2... BUT anyways, my question:
How do I get Maple to solve a vector equation given a time t?
For example, my two equations I want to solve are:
eq := r(t) = 2*t^2*_i+16*_j+(10*t-12)*_k
eq := r(t) = (20-6*t)*_i+4*t^2*_j+2*t^2*_k
Both solved at time t=2 ("when the airplanes collide").  I want these solved so I can use another Maple command to find the angle between the two vectors upon collision.  Does all this need to be done in steps or is there a more concise way?
How do I animate a matrixplot frame by frame so it displayes the highest and lowest value first and then sort of starts "relaxing" to the boundary conditions that will be set to 0? Thank you.
Mainly this  error comes when i make u[3] nonzero. when u[3]=0 it works. How can i remove and work with it. May i get your help please?
This is the code nnn.mw
I want to plot contour for piecewise  function , here is my code
d1:=0.1:eta:=0.01:k:=2:L:=1:
mu:=0.01:delta1:=0.1:delta2:=0.2:
d1:=0.2:d2:=0.2:L1:=0.2: L2:=0.2:
h:=z->piecewise( z<=d1,    1,
                 z<=d1+L1,   1-(delta1/(2))*(1 + cos(2*(Pi/L1)*(z - d1 - L1/2))),
                        z<=d1+L1+d2,  1 ,
                    z<=d1+L1+d2+L2,  1-(delta2/(2))*(1 + cos(2*(Pi/L2)*(z - d1 - d2-L1-L2/2))),
                 z<=L,    1):
A1:=((k+2)*(k+3)*(1-mu)^(k+1)-2*(1-mu)^(k+2)*(k+2+mu))^(1/k):
A2:=(A1*r/h(z)^(1+3/k)):
contourplot(A2,z=0..1,r=-h(z)..h(z),colour=black,axes=boxed);
I have a function f(x) = x/2 on Cartesian coordinates. I want to rotate the y-axis clockwise and x-axis anticlockwise by the
same (arbitrary, acute) angle (something like the 2nd figure of http://www.ams.org/publicoutreach/feature-column/fcarc-svd),
yet I also want to retain the Cartesian grid and the function f(x) at the background.
Could someone tell me how to do so? Thanks!
I am writing a simple program on Maple with the command :
som:=0;
for a from 3000 to 5000 by 100 do
for b from 100 to 1000 by 100 do
for c from 3000 to 3000 by 100 do
for d from 1000 to 1000 by 100 do
for e from 1000 to 10000 by 1000 do
for f from 200 to 2000 by 100 do
for p from 1 to 10 by 1 do
tot:=0;
C2:=c*d-N^2*(f^2-b*d);
C3:=a*d-e*f;
C4:=c*e-N^2*(a*f-e*b);
if (C2>0 and C3>0 and C4>0)
then
print(a,b,c,d,e,f,p);
som:=som+1;
fi;
od;od;od;od;od;od;od;
som;
That gives me the error messsage: Error, numeric exception: division by zero
Is there a simple way to say to the program to continue to execute even it falls at some point to « bad » parameter constellations with division by zero ?
Thank you for your help !
Best regards,
Basak
Hello people in mapleprimes,
I am reading Introduction to Maple. There, the following input and output appear.
> convert((-8)^(1/3), RootOf);
1+RootOf(_Z^2 + 3, index = 1)
I think, which implies
beta^3+8=0
with the solution alpha of alpha^2+3=0, beta above is expressed as 1+alpha.
But, probably from my understanding being wrong, I can't understand why this becomes so.
So, though this is about mathematics, not about maple, if possible, can I ask you to teach me why
convert((-8)^(1/3), RootOf) brings 1+RootOf(_Z^2 + 3, index = 1)?
First 906 907 908 909 910 911 912 Last Page 908 of 2467
