I would like to calculate the number of partitions of a number s with length n, where the maximum value in the partitions is also n.
For example: s=10, n=4
The result should be 5, because there are 5 partions with length 4 and maximum value 4:
4411, 4321, 4222, 3331, 3322
If I use "PartitionFixedSize(10,'parts'=4)", it makes also partitions with values > 4, for example 5311. How to limit this?
Thank you for an answer!
Kind regards
Suppose we have the following simple Matrix
T := <1,2;3,4>;
How do we replace an entry with another expression?
I know that for a list L := [1,2,3] we can do, for example subsop(2=500,L) to replace the entry at index 2.
This creates a new list since lists are immutable.
As far as I can tell, a Matrix is mutable.
However, I wish to change an entry in a Matrix without mutating it.
My actual use case is the following.
I use LinearAlgebra:-Eigenvectors to obtain a Matrix of eigenvectors. Some of the entries are huge expressions with many variables. I would like to sub in placeholders where these huge expressions are so I can visualize the Matrix better, but without modifying the original Matrix.
Is it possible to  convert an existing document in worksheet mode to document mode in Maple22 ?
It seems you can only select either at creation of document but not convert documents already existing.
I switched to using smart plot in Maple since it makes it easier. Here is an example
sol:=[-1/4*x^2, x];
plot(sol,legend=sol)
But sometimes it gives internal error, like in this example, because some of the list of solutions give complex over some x domain
sol:=[-1/4*x^2, (-1/2-1/2*(-3)^(1/2))^2+(-1/2-1/2*(-3)^(1/2))*x, (-1/2+1/2*(-3)^(1/2))^2+(-1/2+1/2*(-3)^(1/2))*x];
Luckily I can trap this error and workaround it.
The strange thing is that if I give it explicit x range, then it works. It now can remove the solutions which give complex values automatically
p:=plot(sol,x=-4..4,legend=sol);
question is: Should not smart plot have done this automatically? That is why it is called smart plot.
i.e. remove those solutions that give complex values like the case the above?
Maple 2024.1 on windows 10
I want to define a piecewise function. How do I test if a variable t is in a definite open or closed real range?
I am using the smart plot (i.e plot without giving the x=from..to) since I am generating these plots programmatically and better let Maple figure the best range to use.
But found Maple hangs on some solutions.
Here is an example
sol:=1/2/cos(x)*(sin(x)^2+(sin(x)^4+36*cos(x))^(1/2));
plot(sol);
I waited for 30 minutes and nothing happened.
If I change the above command to
plot(sol,x=-Pi..Pi);
then it finishes instantly. It looks like Maple is stuck trying to find correct x and y ranges to use.
Is this known limitation  or smart plot or is this a bug?
Maple 2024.1 on windows 10.
What exactly is the difference between the differential operator d_[] from the physics package and diff() ? Why is it not possible for me to differentiate a scalar function g or a coordinate r with the help of the operator? d_[1] should correspond to d/dx (X = (x, y, z, t)) or not?
with(Physics)
with(Vectors)NULL
Setup(coordinates = cartesian)
[coordinatesystems = {X}]
r = sqrt(x^2+y^2+z^2)
r = (x^2+y^2+z^2)^(1/2)
d_[1](g(r))
diff(g(r), x)
(D(g))((x^2+y^2+z^2)^(1/2))*x/(x^2+y^2+z^2)^(1/2)
d_[1](r)
diff(r, x)
d_[1](x)
diff(x, x)
Download example_d_[].mw
with(Plot);
params := {alpha = 2.5, k = 3, w = 2, beta[3] = 3, beta[4] = 1.7};
xi := beta[3]*(2*alpha*k*t + x)*sqrt(1/(36*alpha*beta[4] + 36*gamma*beta[4]));
          xi := beta[3] (2 alpha k t + x)
                                                 (1/2)
            /                 1                 \
            \36 alpha beta[4] + 36 gamma beta[4]/
sol1n := u(x, t) = U(xi)*exp((-sqrt(1/(36*alpha*beta[4] + 36*gamma*beta[4]))*x + w*t + theta)*I);
 sol1n := u(x, t) = U|beta[3] (2 alpha k t + x)
                                        (1/2)\    /  /
   /                 1                 \     |    |  |
   |-----------------------------------|     | exp|I |
   \36 alpha beta[4] + 36 gamma beta[4]/     /    \  \
                                       (1/2)                \\
  /                 1                 \                     ||
 -|-----------------------------------|      x + w t + theta||
  \36 alpha beta[4] + 36 gamma beta[4]/                     //
plot3d(rhs(sol1n), x = 0 .. 250, t = 0 .. 4);
how plot the the solution of PDE of this kind of function?
Download plot.mw
Here is the ODE
sys := {diff(w(t), t) = y(t)*z(t), diff(x(t), t) = a*w(t), diff(y(t), t) = x(t)*z(t) + w(t), diff(z(t), t) = -x(t)*y(t), w(0) = w0, x(0) = x0, y(0) = y0, z(0) = z0}
with initial parameters a=2, w0 = -0.727367040, x0 = -0.728244724, y0 = -0.237753623 and z0 = 0.014225402.
With these parameters I have no problem to plot the solution.
nsys := subs({a=2,w0 = -0.727367040, x0 = -0.728244724, y0 = -0.237753623, z0 = 0.014225402},sys);
numsol := dsolve(nsys, numeric, method = rkf45);
vars:=[x,y,z,w];
col := [red, magenta, cyan, blue]:
display(
  seq(
    plots:-odeplot(numsol, [t, vars[i](t)], t=0..3, color=col[i], legend=vars[i](t))
    , i=1..numelems(vars)
How to use animate (or explore?)  with a slider for each parameter (a,x0,y0,z0,w0)? And if I want to add a tfinal as well for the simulation (in place of 3)? ( I am newbie as far as using plot and related functions in Maple).
Many thanks.
sometimes (not often) I get this pop-up window when I open new worksheet and run something first time in it.
And it can last for 10-20 seconds until connection is made.
I have my preferences set to  create new engine for each worksheet.
The strange thing when this happened now, is that I only had 4 worksheets open and was not running anything in any of them. So Maple was not "busy". Task manage showed 8 mservers.exe processes on it at the time. Which is not unormal.
I have 128 GB and PC was not busy at the time this happened.
Any idea what can cause this to happen?
Windows 10 home edition, Maple 2024.1
When making this plot, using smart plot (i.e. not giving the plot command the x=from..to and also not giving it y=from...to
p:=plot(0,color=red);
I need to programatically find the x=-10..10 and y=-1..1 from the variable p. But if I do
rhs~(indets(p, identical("originalview")=anything));
it gives
              {[-10. .. 10., 0. .. 0.]}
But clearly looking at the plot the y axis is from -1..1
The reason I need to determine the view from the above plot, is that I need to use same view windows size in another plot not using smart plot (phase plot) which requires one to provide explicit x and y ranges. i.e I'd like the phase plot to have same view size in terms of x range and y range.
I printed the PLOT structure but do not see another field to look at.
Any idea or trick to find y=-1..1 values in this example ? I am using Maple 2024.1
lprint(p)
PLOT(CURVES(Matrix(200,2,{(1, 1) = -10., (2, 1) = -9.89484789949749, (3, 1) =
-9.80335561909548, (4, 1) = -9.70046298090452, (5, 1) = -9.59688830351759, (6,
1) = -9.49380589849246, (7, 1) = -9.39823531356784, (8, 1) = -9.29927750854271,
(9, 1) = -9.19693520502513, (10, 1) = -9.09492111457286, (11, 1) =
-8.98998708341709, (12, 1) = -8.89756113165829, (13, 1) = -8.79351140100503, (
14, 1) = -8.6890344321608, (15, 1) = -8.58835151356784, (16, 1) =
-8.49692177788945, (17, 1) = -8.38820297889447, (18, 1) = -8.29610389547739, (
19, 1) = -8.18897076683417, (20, 1) = -8.09413979497487, (21, 1) =
-7.99009518894472, (22, 1) = -7.89102011959799, (23, 1) = -7.78764567839196, (
24, 1) = -7.69271567135678, (25, 1) = -7.59032083417085, (26, 1) =
-7.4839613758794, (27, 1) = -7.39137515477387, (28, 1) = -7.29137949949749, (29
, 1) = -7.18807420301508, (30, 1) = -7.08701012462312, (31, 1) =
-6.9892254321608, (32, 1) = -6.88065220301508, (33, 1) = -6.78309432763819, (34
, 1) = -6.67893047236181, (35, 1) = -6.58454253768844, (36, 1) =
-6.48135159396985, (37, 1) = -6.38425695778894, (38, 1) = -6.28276508643216, (
39, 1) = -6.18353823115578, (40, 1) = -6.07965690954774, (41, 1) =
-5.97960685025126, (42, 1) = -5.87729121407035, (43, 1) = -5.77582280301507, (
44, 1) = -5.68258387135678, (45, 1) = -5.57572153366834, (46, 1) =
-5.48014258492462, (47, 1) = -5.37823549045226, (48, 1) = -5.28069739798995, (
49, 1) = -5.17239388140703, (50, 1) = -5.07861099396985, (51, 1) =
-4.97216657788945, (52, 1) = -4.87515404824121, (53, 1) = -4.76903758693467, (
54, 1) = -4.67747702713568, (55, 1) = -4.57320023718593, (56, 1) =
-4.47247400603015, (57, 1) = -4.37181357688442, (58, 1) = -4.27152345929648, (
59, 1) = -4.17517605326633, (60, 1) = -4.07102195577889, (61, 1) =
-3.97175554874372, (62, 1) = -3.86728232964824, (63, 1) = -3.77270890854271, (
64, 1) = -3.66818757386935, (65, 1) = -3.56807434874372, (66, 1) =
-3.46820480201005, (67, 1) = -3.36389067336683, (68, 1) = -3.26781355276382, (
69, 1) = -3.16941743919598, (70, 1) = -3.06077643819095, (71, 1) =
-2.96241091055276, (72, 1) = -2.86181373366834, (73, 1) = -2.7595089959799, (74
, 1) = -2.66547103417085, (75, 1) = -2.5652296120603, (76, 1) =
-2.46575123417085, (77, 1) = -2.35934029145729, (78, 1) = -2.26543724422111, (
79, 1) = -2.15709262110553, (80, 1) = -2.05931995175879, (81, 1) =
-1.96257900603015, (82, 1) = -1.85855141105528, (83, 1) = -1.75410300301508, (
84, 1) = -1.65907041708543, (85, 1) = -1.5581500321608, (86, 1) = -1.4596616, (
87, 1) = -1.35289910050251, (88, 1) = -1.26051985527638, (89, 1) =
-1.15441893366834, (90, 1) = -1.05467848944724, (91, 1) = -.955901429145728, (
92, 1) = -.857045790954773, (93, 1) = -.756219297487437, (94, 1) =
-.649344903517589, (95, 1) = -.551351549748743, (96, 1) = -.454619526633167, (
97, 1) = -.351214585929648, (98, 1) = -.248034748743718, (99, 1) =
-.155424717587939, (100, 1) = -.0457214572864313, (101, 1) = .0460731437185924,
(102, 1) = .153437240201004, (103, 1) = .255905869346734, (104, 1) =
.347398149748743, (105, 1) = .4502907879397, (106, 1) = .553865465326634, (107,
1) = .656947870351759, (108, 1) = .752518455276382, (109, 1) = .851476260301508
, (110, 1) = .953818563819095, (111, 1) = 1.05583265427136, (112, 1) =
1.16076668542714, (113, 1) = 1.25319263718593, (114, 1) = 1.3572423678392, (115
, 1) = 1.46171933668342, (116, 1) = 1.56240225527638, (117, 1) =
1.65383199095477, (118, 1) = 1.76255078994975, (119, 1) = 1.85464987336683, (
120, 1) = 1.96178300201005, (121, 1) = 2.05661397386935, (122, 1) =
2.1606585798995, (123, 1) = 2.25973364924623, (124, 1) = 2.36310809045226, (125
, 1) = 2.45803809748744, (126, 1) = 2.56043293467337, (127, 1) =
2.66679239296482, (128, 1) = 2.75937861407035, (129, 1) = 2.85937426934673, (
130, 1) = 2.96267956582914, (131, 1) = 3.06374364422111, (132, 1) =
3.16152833668342, (133, 1) = 3.27010156582915, (134, 1) = 3.36765944120603, (
135, 1) = 3.47182329648241, (136, 1) = 3.56621123115578, (137, 1) =
3.66940217487437, (138, 1) = 3.76649681105528, (139, 1) = 3.86798868241206, (
140, 1) = 3.96721553768844, (141, 1) = 4.07109685929648, (142, 1) =
4.17114691859297, (143, 1) = 4.27346255477387, (144, 1) = 4.37493096582915, (
145, 1) = 4.46816989748744, (146, 1) = 4.57503223517588, (147, 1) =
4.6706111839196, (148, 1) = 4.77251827839196, (149, 1) = 4.87005637085427, (150
, 1) = 4.97835988743719, (151, 1) = 5.07214277487437, (152, 1) =
5.17858719095477, (153, 1) = 5.27559972060302, (154, 1) = 5.38171618190955, (
155, 1) = 5.47327674170854, (156, 1) = 5.57755353165829, (157, 1) =
5.67827976281407, (158, 1) = 5.7789401919598, (159, 1) = 5.87923030954774, (160
, 1) = 5.97557771557789, (161, 1) = 6.07973181306533, (162, 1) =
6.1789982201005, (163, 1) = 6.28347143919598, (164, 1) = 6.37804486030151, (165
, 1) = 6.48256619497488, (166, 1) = 6.5826794201005, (167, 1) =
6.68254896683417, (168, 1) = 6.78686309547739, (169, 1) = 6.8829402160804, (170
, 1) = 6.98133632964824, (171, 1) = 7.08997733065327, (172, 1) =
7.18834285829146, (173, 1) = 7.28894003517588, (174, 1) = 7.39124477286432, (
175, 1) = 7.48528273467337, (176, 1) = 7.58552415678392, (177, 1) =
7.68500253467337, (178, 1) = 7.79141347738694, (179, 1) = 7.88531652462311, (
180, 1) = 7.9936611477387, (181, 1) = 8.09143381708543, (182, 1) =
8.18817476281407, (183, 1) = 8.29220235778895, (184, 1) = 8.39665076582915, (
185, 1) = 8.49168335175879, (186, 1) = 8.59260373668342, (187, 1) =
8.69109216884422, (188, 1) = 8.79785466834171, (189, 1) = 8.89023391356784, (
190, 1) = 8.99633483517588, (191, 1) = 9.09607527939699, (192, 1) =
9.1948523396985, (193, 1) = 9.29370797788945, (194, 1) = 9.39453447135678, (195
, 1) = 9.50140886532663, (196, 1) = 9.59940221909548, (197, 1) =
9.69613424221106, (198, 1) = 9.79953918291458, (199, 1) = 9.9027190201005, (200
, 1) = 10.},datatype = float[8],storage = rectangular,order = Fortran_order,
shape = []),COLOUR(RGB,.47058824,0.,.54901961e-1,_ATTRIBUTE("source" =
"mathdefault"))),AXESLABELS("",""),VIEW(-10. .. 10.,DEFAULT,_ATTRIBUTE("source"
= "mathdefault")),_ATTRIBUTE("input" = [table([(1)=plot,(2)=[0]]),
"originalview" = [-10. .. 10., 0. .. 0.], "originalaxesticks" = AXESTICKS(
DEFAULT,DEFAULT,_ATTRIBUTE("source" = "mathdefault"))]))
Update
This below is a proc that takes PLOT data struct and returns correct x,y ranges.  It seems to work ok on few tests I did. Bug reports are welcome.
#gets a PLOT struct and returns correct x,y ranges
get_x_y_range:=proc(p)::list;
local T,from_x,to_x,from_y,to_y;
   try
      T:=plottools:-getdata(p,'rangesonly');
   catch:
      error StringTools:-FormatMessage( lastexception[2..-1] );
   end try;
  from_x := op(1,T[1]);
  to_x   := op(2,T[1]);
  from_y := op(1,T[2]);
  to_y   := op(2,T[2]);
  if from_y=to_y then
     if from_y<0 then
        to_y   := 0;
        from_y := from_y-abs(from_y)/2;
     elif from_y>0 then
        from_y := 0;
        to_y   := to_y+to_y/2;
        from_y := -1;
        to_y   := 1;
    fi;
  fi;
  RETURN([from_x..to_x,from_y..to_y]);
p := plot(6);
get_x_y_range(p)
[-10. .. 10., 0 .. 9.000000000]
p := plot(-3);
get_x_y_range(p)
[-10. .. 10., -4.500000000 .. 0]
p := plot(0);
get_x_y_range(p)
[-10. .. 10., -1 .. 1]
p := plot(x);
get_x_y_range(p)
[-10. .. 10., -10. .. 10.]
p := plot(sin(x));
get_x_y_range(p)
[-6.25176936900243163 .. 6.25176937505602837, -1. .. 1.]
p := plot(exp(x));
get_x_y_range(p)
[-9.94999999999999929 .. 9.94999999999999929, 0.477276339400000010e-4 .. 20952.2223799999992]
Download get_x_y_range.mw
Update
Warning.  plottools:-getdata(p,'rangesonly') is buggy. I replaced this with
                  rhs~(indets(p, identical("originalview")=anything))[];
which gives more accurate Y ranges used. Here is example showing that getdata(p,'rangesonly') returns wrong y ranges for a plot compared to how it shows on the screen, So in the function above, better use the second method instead. This whole getdata(p,'rangesonly'); should be looked at by Maplesoft and fix to make it return correct values that agrees with screen view.
p:=plot(sol,x=-3..3);
(1/2)*(sin(x)^2+(sin(x)^4+36*cos(x))^(1/2))/cos(x)
plottools:-getdata(p,'rangesonly'); #WRONG y values compared to the above plot
[-1.59843684366660455 .. 1.59843684366660455, -709.846391756980552 .. 432.636304188149381]
rhs~(indets(p, identical("originalview")=anything))[]; #better result compared to plot (still not exact but better).
[-1.50000000000 .. 1.50000000000, 2.50000000000 .. 8.50000000000]
Download fixed_plot_Y_range.mw
I teach Pre-Calulus High School level, and our school recently upgraded to Maple 2024. Like in Maple 2023 we use Assistant-Tools-import DATA and chosing an Excel file from which to import to do regression on.  In the new 2024 we have experienced, that Maple cannot read in DATA, meaning it cannot read column of DATA into a Maple document. However if we copy into Excel document on the machine locally, then there is no issue and the data is imported.
Any idear what can cause this?
before run file remove all (:) i want calculate equation but with a condition for example: when a=4 then find other parameter in my equation with respect to a=4 find other
usesol.mw
sigma1:=10^(-5):sigma2:=10^(5):sigma3:=3.7*10^(6):alpha:=5*10^(-7):beta1:=0.5*10^(-4):beta2:=0.5*10^(-4):beta3:=0.5*10^(-4):ky:=1:kz:=10^4:mu1:=10:mu2:=11:mu3:=0.86:mu4:=0.2:mu5:=1:v1:=0.5:v2:=1:alphaa:=0.6:alphas:=0.24:alphad:=0.16:A:=0.5:mus:=0.17:k:=0.2:#parameters
dsys:={diff(x1(t),t)=sigma1*y(t)-beta1*x1(t)*y(t)/(ky+x1(t)+x2(t))-v1*x1(t)-mu1*x1(t)+(2*alphad+alphaa)*k*A*S(t),diff(x2(t),t)=v1*x1(t)-beta2*x2(t)*y(t)/(ky+x1(t)+x2(t))+alpha*v2*x1(t)*z(t)-mu2*x2(t),diff(y(t),t)=sigma2*(beta1*x1(t)*y(t)/(ky+x1(t)+x2(t))+beta2*x2(t)*y(t)/(ky+x1(t)+x2(t)))-mu4*y(t)-mu5*y(t)^2,diff(z(t),t)=sigma3+y(t)*beta3/(kz+y(t))-mu3*z(t)-v2*z(t)*x2(t),diff(S(t),t)=(k*(alphas-alphad)-mus)*S(t) }; #SYS ODE
rhs; with(DEtools);# to find the equilibrium points
fx1 = sigma1*y-beta1*x1*y-v1*x1-mu1*x1+(2*alphad+alphaa)*k*A*s; fx2 = alpha*v2*x1*z-beta2*x2*y-mu2*x2+v1*x1; fy = sigma2*(beta1*x1*y+beta2*x2*y)-mu4*y-mu5*y^2; fz = sigma3+y*(kz+y)-mu3*z-v2*z*x2; fs = (k*(alphas-alphad)-mus)*s;
eqs := solve({fs, fx1, fx2, fy, fz}, {s, x1, x2, y, z})
L := map(subs, [eqs], [x1, x2, y, z, s])
J := unapply(VectorCalculus:-Jacobian([fx1, fx2, fy, fz, fs], [x1, x2, y, z, s]), x1, x2, y, z, s); J(x1, x2, y, z, s)
Verification_known_T_R_30_07_2024.mw That`s the worksheet.
For some strange reason the command simplify doesn`t work. Beforehand it managed to simplify quite bulky expressions.
Thank you in advance!
First 117 118 119 120 121 122 123 Last Page 119 of 2457
