In the Programming Guide, Ch. 3 "Maple Expressions", subsection 3.13 "Other Expressions" there is a section called "Composition".
There is the following snippet
In particular, although the inverses of the circular functions are commonly denoted by a power-like notation in written mathematics, in Maple, for example, sin^(-1) denotes the reciprocal of the sin function, while sin@@(-1) denotes the arcsine (arcsin).
I opened a new worksheet to check this. I found the results confusing.
1/sin
1/sin
arcsin(x)
arcsin(x)
sin^(-1)
1/sin
sin^(-1)(x)
1/sin
(sin^(-1))(x)
1/sin(x)
sin@@(-1)
arcsin
sin@@(-1)*x
arcsin*x
sin@@(-1)
arcsin
sin@@(-1)(x)
arcsin
(sin@@(-1))(x)
arcsin(x)
Consider (1) and (2).
(1) is in accordance with the quoted snippet: sin^(-1) is the reciprocal of the sine function. But when we use this same expression as a function call, the function that is called is arcsine. Does this make sense to be this way?
Next, consider (3), (4), and (5), which I expected to be the same expressions as (1), (2) and (2), respectively. The only difference is that (1) and (2) use 2D math and (3), (4), and (5) use Maple input.
Both results using Maple input give as output the reciprocal of sine.
Why is there this difference between the 2D version and the Maple input version?
Consider (4) and (5). Why is it that we need to add parentheses for the argument x to be applied to the function?
Finally, what is the reasoning behind the syntax sin@@(-1) denoting arcsine?
@@ represents repeated composition. sin@@3 represents the function sin(sin(sin))).
Is sin@@(-1) equal to arcsine simply by convention or is there some logical reason?
Download Repeated_Composition.mw
I am reading the Maple Programming Guide chapter 3 "Maple Expressions". There are subsections on "Indexed Expressions" and "Member Selection".
The following is based on reading these sections.
Consider the following module definition
m := module() export e, f:=2; end module:
What is the difference between m[e] and m:-e or m[f] and m:-f?
The documentation says that both evaluate module m's export e but the difference is that the index selection form will evaluate e before resolving the export.
What does this mean exactly?
When I try out in a worksheet both m[f] and m:-f return 2 and m[e] and m:-e return the name e.
when i finding parameter i want just choose a case for example a_1=a_1  and any other case a_2=0,and remove other case how i can do in maple
with(PDEtools)
undeclare(prime)
with(DEtools)
with(DifferentialAlgebra)
"with(Student[ODEs][Solve]): "
with(IntegrationTools)
with(inttrans)
with(PDEtools)
with(Physics)
with(PolynomialTools)
with(RootFinding)
with(SolveTools)
with(LinearAlgebra)
with(sumtools)
ode := F(xi)^5*a[4]+F(xi)^4*a[3]+F(xi)^3*a[2]+(-k^2*a[1]+(diff(diff(F(xi), xi), xi))*a[5]-w)*F(xi)^2+(1/2)*F(xi)*(diff(diff(F(xi), xi), xi))*a[1]-(1/4)*(diff(F(xi), xi))^2*a[1] = 0
L := convert((cosh(xi)+sinh(xi))/(cosh(xi)-sinh(xi)), trig)
"Q(xi):=L:"
S := sum(A[i]*Q(xi)^i, i = 0 .. 1)+sum(B[i]*Q(xi)^(-i), i = 1 .. 1)
S
K := F(xi) = S
F1 := eval(ode, K)
simplify(%)
P := numer(lhs())*denom(rhs()) = numer(rhs())*denom(lhs())
solve(identity(P, xi), {k, w, A[0], A[1], B[1], a[1], a[2], a[3], a[4], a[5]})
{k = k, w = w, A[0] = 0, A[1] = A[1], B[1] = 0, a[1] = a[1], a[2] = a[2], a[3] = a[3], a[4] = a[4], a[5] = a[5]}, {k = k, w = -4*A[0]*a[5], A[0] = A[0], A[1] = A[1], B[1] = B[1], a[1] = 0, a[2] = -4*a[5], a[3] = 0, a[4] = 0, a[5] = a[5]}, {k = k, w = (1/2)*A[0]*(3*k^2*A[0]^2*a[4]+2*k^2*A[0]*a[3]+k^2*a[2]+4*k^2*a[5]+2*A[0]^2*a[4]+2*A[0]*a[3]+2*a[2]), A[0] = A[0], A[1] = 0, B[1] = 0, a[1] = -(1/2)*A[0]*(3*A[0]^2*a[4]+2*A[0]*a[3]+a[2]+4*a[5]), a[2] = a[2], a[3] = a[3], a[4] = a[4], a[5] = a[5]}, {k = k, w = w, A[0] = A[0], A[1] = 0, B[1] = 0, a[1] = a[1], a[2] = (-A[0]^3*a[4]+k^2*a[1]-A[0]^2*a[3]+w)/A[0], a[3] = a[3], a[4] = a[4], a[5] = a[5]}, {k = k, w = 4*A[1]*a[5]+4*B[1]*a[5], A[0] = -A[1]-B[1], A[1] = A[1], B[1] = B[1], a[1] = 0, a[2] = -4*a[5], a[3] = 0, a[4] = 0, a[5] = a[5]}, {k = k, w = -k^2*a[1]-4*A[0]*a[5]+a[1], A[0] = A[0], A[1] = (1/4)*A[0]^2/B[1], B[1] = B[1], a[1] = a[1], a[2] = -4*a[5], a[3] = 0, a[4] = 0, a[5] = a[5]}, {k = k, w = w, A[0] = 2*B[1], A[1] = B[1], B[1] = B[1], a[1] = a[1], a[2] = (1/2)*(k^2*a[1]+w-a[1])/B[1], a[3] = 0, a[4] = 0, a[5] = -(1/8)*(k^2*a[1]+w-a[1])/B[1]}, {k = k, w = w, A[0] = A[0], A[1] = B[1], B[1] = B[1], a[1] = 0, a[2] = w/A[0], a[3] = 0, a[4] = 0, a[5] = -(1/4)*w/A[0]}, {k = k, w = 0, A[0] = 0, A[1] = B[1], B[1] = B[1], a[1] = 0, a[2] = a[2], a[3] = 0, a[4] = 0, a[5] = -(1/4)*a[2]}
Download choose_case.mw
dear maple user help me to correct this error .
I want to solve the coupled pdes  plot the graphs but unable to get it. please help me. Here are the maple codes
L:=0.4:
d1:=0.3: d2:=0.3:
h:=z->piecewise( z<=d1,   1,
                 z<=d1+L,   1-(delta/(2))*(1 + cos((2*(Pi)/L)*(z - d1 - L/2))),
                 z<=d1+L+d2,  1 ):
a:=x4*S*Gr/(4*x1*x5)*sin(alpha):
b:=1/Da+(x3*M/(x1*(1+m^2))):
c:=(1/x1)*DP:
x1:=1/((1-phi1)^2.5*(1-phi2)^2.5):
x5:=khnf/kf:
x3:=shnf/sf:
x4:=(1-phi2)*((1-phi1)+phi1*(RBs1)/(RBf))+phi2*RBs2/RBf:
shnf:=sbf*((ss2+2*sbf-2*phi2*(sbf-ss2))/(ss2+2*sbf+phi2*(sbf-ss2))):
sbf:=sf*((ss1+2*sf-2*phi1*(sf-ss1))/(ss1+2*sf+phi1*(sf-ss1))):
ss2:=2.7*10^(-8):
ss1:=59.6*10^(6):
sf:=6.67*10^(-1):
khnf:=kbf*((ks2+2*kbf-2*phi2*(kbf-ks2))/(ks2+2*kbf+phi2*(kbf-ks2))):
kbf:=kf*((ks1+2*kf-2*phi1*(kf-ks1))/(ks1+2*kf+phi1*(kf-ks1))):
ks1:=401:
ks2:=76.5:
kf:=0.4972:
RBs1:=8933*16.7*10^(6):
RBs2:=6320*18*10^(6):
RBf:=1063*1.8*10^(6):
DP:=(1/192)*(18432*F-77*b^2*h(z)^8+308*b*h(z)^8*a+768*h(z)^6*a+12*b*h(z)^8)/(h(z)^4*(b*h(z)^2-6)):
conds:= w(h(z),0)=0, theta(h(z),0)=0, D[1](w)(r,0)=0, D[1](theta)(r,0)=0:
pdes:= diff(w(r, z), r, r)+(1/r)*(diff(w(r, z), r))-(1/Da+(x3/x1)*M)*w(r, z)-(1/x1)*(DP+theta*x4*sin(alpha))=0,
         diff(theta(r, z), r,r)+(1/r)*(diff(theta(r, z), r))+(S/x5)=0:
pars:= { F=1.5,Da=0.1,phi1=0.01,phi2=0.02,alpha=Pi/4,S=0.1,Gr=2,m=0.5}:
  PrVals:=[2, 5, 7,9]:
  colors:=[red, green, blue, black]:
  for j from 1 to numelems(PrVals) do
      pars1:=`union`( pars, {M=PrVals[j]}):
      pdSol:= pdsolve( eval([pdes], pars1),
                       eval([conds], pars1),
                       numeric
      plt[j]:=pdSol:-plot( w(r,z), z=1, r=0..1, numpoints=200, color=colors[j]);
  plots:-display( [seq(plt[j], j=1..numelems(PrVals))]);
Error, final value in for loop must be numeric or character
Error, unable to execute seq
                       numeric
      plt[j]:=pdSol:-plot( theta(r,z), z=1, r=0..1, numpoints=200, color=colors[j]);
                       numeric
      plt[j]:=pdSol:-plot( DP,  z=0..1, numpoints=200, color=colors[j]);
i am looking for simplify this type of simplifying assume beta is Real and there is any stuf package for working with complex and conjugate automaticaly
with(inttrans)
with(PDEtools)
with(DEtools)
with(inttrans)
with(PDEtools)
with(Physics)
with(RootFinding)
with(SolveTools)
with(LinearAlgebra)
with(sumtools)
declare(u(x, t), conjugate(u(x, t)))
undeclare(prime)
B__0 := I*G(x)^3*conjugate(G(x))^2+(2*I)*G(x)^2*(diff(G(x), x))+(2*I)*(diff(G(x), x))*G(x)*conjugate(G(x))
"G(x):=beta*exp(I*x) "
proc (x) options operator, arrow, function_assign; Physics:-`*`(beta, exp(Physics:-`*`(I, x))) end proc
R__0 := diff(G(x), `$`(x, 2))
-beta*exp(I*x)
B__0
I*beta^3*(exp(I*x))^3*conjugate(beta*exp(I*x))^2-2*beta^3*(exp(I*x))^3-2*beta^2*(exp(I*x))^2*conjugate(beta*exp(I*x))
"#`B__0 `must equal to (I*beta^(5)*exp(I*x)) after simplify betwen expresion  what code need i don't know"?""
B1 := laplace(B__0, t, s)
(-2*beta^2*exp((2*I)*x)*conjugate(beta*exp(I*x))+(I*conjugate(beta*exp(I*x))+1+I)*(conjugate(beta*exp(I*x))+(-1+I))*exp((3*I)*x)*beta^3)/s
R1 := laplace(R__0, t, s)
-beta*exp(I*x)/s
B2 := invlaplace(B1/s, s, t)
(-2*beta^2*exp((2*I)*x)*conjugate(beta*exp(I*x))+(I*conjugate(beta*exp(I*x))+1+I)*(conjugate(beta*exp(I*x))+(-1+I))*exp((3*I)*x)*beta^3)*t
R2 := invlaplace(R1/s, s, t)
-beta*exp(I*x)*t
Sol := B2+R2
(-2*beta^2*exp((2*I)*x)*conjugate(beta*exp(I*x))+(I*conjugate(beta*exp(I*x))+1+I)*(conjugate(beta*exp(I*x))+(-1+I))*exp((3*I)*x)*beta^3)*t-beta*exp(I*x)*t
simplify((-2*beta^2*exp((2*I)*x)*conjugate(beta*exp(I*x))+(I*conjugate(beta*exp(I*x))+1+I)*(conjugate(beta*exp(I*x))+(-1+I))*exp((3*I)*x)*beta^3)*t-beta*exp(I*x)*t)
(I*exp((3*I)*x)*conjugate(beta*exp(I*x))^2*beta^2-2*exp((2*I)*x)*conjugate(beta*exp(I*x))*beta-2*exp((3*I)*x)*beta^2-exp(I*x))*beta*t
expand((I*exp((3*I)*x)*conjugate(beta*exp(I*x))^2*beta^2-2*exp((2*I)*x)*conjugate(beta*exp(I*x))*beta-2*exp((3*I)*x)*beta^2-exp(I*x))*beta*t)
I*beta^3*t*(exp(I*x))^3*conjugate(beta)^2*(exp(-I*conjugate(x)))^2-2*t*beta^2*(exp(I*x))^2*conjugate(beta)*exp(-I*conjugate(x))-2*t*(exp(I*x))^3*beta^3-beta*exp(I*x)*t
Download simplify.mw
A little continuation of topics 1 and 2. This is a very similar cube from 2
but with a different equation:
f1 := (x1-sin(x1))^2+(x2-sin(x2))^2+(x3-sin(x3))^2-0.02513144866;
And other point coordinates (-.8283302152, -.8283302152, .8283302152) and (.8283302152, .8283302152, -.8283302152).
I'm a little busy with the Rule feature in Maple
Just started with the limits and can't get 1 limit rule working in my FSimp procedure yet
As a limit example I saw this in Maple help
with(Student:-Calculus1);
infolevel[Student[Calculus1]] := 1;
Rule[lhopital, ln(x)](Limit(x*ln(x), x = 0, right));
Creating problem #2
                  lim   (x ln(x)) =   lim   (-x)
                x -> 0+             x -> 0+
A meaningless example of how one limit of a function is equal to another limit of a function, when I think there is no connection between the two functions. ( I don't see it )
You might as well calculate the limit value right away.
It gets more interesting when you analyze the function/expression : x*ln(x) and start rewriting it, to a [0/0] or [infinity/infinity] form in this case and from this it shows the need to start using lhopital rule.
The Rule feature has a Hint capability and gives as a hint, lhopital that this rule is applied
Of course, you also have a series of standard limits, beyond the lhopital limits
The Rule feature for the limit is not yet step by step, because the need to start using a lhopital limit rule has not yet been demonstrated by the user
I'm interested in installing the package update from I M Anderson's site, the Differential Geometry Software Project. This corresponds to the 2022 update. There are many new features:
- Submanifold theory
- Differential operators and  Pseudo-Differential Operators
- Principal connections
- Integrable System Library
- Cartan normal connections
and more.
It's unfortunate that this update isn't included in this version of Maple 2024
Hi all guys, how can I extract the coefficient of order 6 of expand(SUMY-T) as below? I use the coeff but no use and I search last posts in mapleprime but no fit for my case, and substitute the parematers of a,b,c....
A[21] = 3/20-(1/20)*sqrt(5), A[31] = 0, A[32] = 3/20+(1/20)*sqrt(5), a[21] = 1/30-(1/75)*sqrt(5), a[31] = -1288/452405, a[32] = 98209/2714430-(1/75)*sqrt(5), b[1] = 1/24, b[2] = 1/16+(1/48)*sqrt(5), b[3] = 1/16-(1/48)*sqrt(5), bp[1] = 1/12, bp[2] = 5/24+(1/24)*sqrt(5), bp[3] = 5/24-(1/24)*sqrt(5), c[2] = 1/2-(1/10)*sqrt(5), c[3] = 1/2+(1/10)*sqrt(5)
T := (1/6)*h^3*G+(1/24)*h^4*((diff(y(x), x))*G[y]+F*G[z])+(1/120)*h^5*(G[yy]*(diff(y(x), x))^2+2*G[yz]*(diff(y(x), x))*F+F*G[y]+G[zz]*F^2+G*G[z])+(1/720)*h^6*(G[yyy]*(diff(y(x), x))^3+3*(diff(y(x), x))^2*G[yyz]*F+3*(diff(y(x), x))*G[yy]*F+3*(diff(y(x), x))*G[yzz]*F^2+3*G[yz]*(diff(y(x), x))*G+3*G[yz]*F^2+G[y]*G+G[zzz]*F^3+3*F*G[zz]*G+G[z]*((diff(y(x), x))*G[y]+F*G[z]))
SUMY := y(x)+h*(diff(y(x), x))+(1/2)*h^2*F+h^3*b[1]*G+h^3*b[2]*(G+((diff(y(x), x))*G[y]*c[2]+F*G[z]*c[2])*h+((1/2)*(diff(y(x), x))^2*G[yy]*c[2]^2+(diff(y(x), x))*F*G[yz]*c[2]^2+(1/2)*F^2*G[zz]*c[2]^2+(1/2)*F*G[y]*c[2]^2+G*G[z]*A[21])*h^2+((diff(y(x), x))*G*G[yz]*A[21]*c[2]+F*G*G[zz]*A[21]*c[2]+(1/6)*(diff(y(x), x))^3*G[yyy]*c[2]^3+(1/6)*F^3*G[zzz]*c[2]^3+(1/2)*(diff(y(x), x))*F*G[yy]*c[2]^3+G*G[y]*a[21]+(1/2)*(diff(y(x), x))^2*F*G[yyz]*c[2]^3+(1/2)*(diff(y(x), x))*F^2*G[yzz]*c[2]^3+(1/2)*F^2*G[yz]*c[2]^3)*h^3+((1/8)*F^2*G[yy]*c[2]^4+(1/2)*G^2*G[zz]*A[21]^2+(1/4)*F^3*G[yzz]*c[2]^4+(1/6)*(diff(y(x), x))^3*F*G[yyyz]*c[2]^4+(1/4)*(diff(y(x), x))^2*F^2*G[yyzz]*c[2]^4+(1/6)*(diff(y(x), x))*F^3*G[yzzz]*c[2]^4+(1/4)*(diff(y(x), x))^2*F*G[yyy]*c[2]^4+(1/2)*(diff(y(x), x))*F^2*G[yyz]*c[2]^4+(1/2)*G[yyz]*(diff(y(x), x))^2*G*A[21]*c[2]^2+(1/2)*G[zzz]*F^2*G*A[21]*c[2]^2+(1/24)*(diff(y(x), x))^4*G[yyyy]*c[2]^4+(1/24)*F^4*G[zzzz]*c[2]^4+G[yzz]*(diff(y(x), x))*F*G*A[21]*c[2]^2+(1/2)*F*G*G[yz]*A[21]*c[2]^2+(diff(y(x), x))*G*G[yy]*a[21]*c[2]+F*G*G[yz]*a[21]*c[2])*h^4+((1/120)*(diff(y(x), x))^5*G[yyyyy]*c[2]^5+(1/8)*F^3*G[yyz]*c[2]^5+(1/120)*F^5*G[zzzzz]*c[2]^5+(1/12)*F^4*G[yzzz]*c[2]^5+(1/12)*(diff(y(x), x))^2*F^3*G[yyzzz]*c[2]^5+(1/12)*(diff(y(x), x))^3*F^2*G[yyyzz]*c[2]^5+(1/24)*(diff(y(x), x))^4*F*G[yyyyz]*c[2]^5+(1/24)*(diff(y(x), x))*F^4*G[yzzzz]*c[2]^5+(1/8)*(diff(y(x), x))*F^2*G[yyy]*c[2]^5+(1/4)*(diff(y(x), x))*F^3*G[yyzz]*c[2]^5+(1/4)*(diff(y(x), x))^2*F^2*G[yyyz]*c[2]^5+(1/12)*(diff(y(x), x))^3*F*G[yyyy]*c[2]^5+G^2*G[yz]*A[21]*a[21]+(1/2)*G[yzz]*F^2*G*a[21]*c[2]^2+(1/2)*G[zzz]*F*G^2*A[21]^2*c[2]+(1/2)*F*G*G[yy]*a[21]*c[2]^2+(1/6)*G[zzzz]*F^3*G*A[21]*c[2]^3+(1/2)*G[yyy]*(diff(y(x), x))^2*G*a[21]*c[2]^2+(1/2)*G[yzz]*(diff(y(x), x))*G^2*A[21]^2*c[2]+(1/6)*G[yyyz]*(diff(y(x), x))^3*G*A[21]*c[2]^3+(1/2)*G[yzz]*F^2*G*A[21]*c[2]^3+(1/2)*G[yzzz]*(diff(y(x), x))*F^2*G*A[21]*c[2]^3+(1/2)*G[yyzz]*(diff(y(x), x))^2*F*G*A[21]*c[2]^3+(1/2)*G[yyz]*(diff(y(x), x))*F*G*A[21]*c[2]^3+G[yyz]*(diff(y(x), x))*F*G*a[21]*c[2]^2)*h^5+((1/6)*G[zzz]*G^3*A[21]^3+(1/16)*F^4*G[yyzz]*c[2]^6+(1/720)*F^6*G[zzzzzz]*c[2]^6+(1/48)*F^5*G[yzzzz]*c[2]^6+(1/2)*G^2*G[yy]*a[21]^2+(1/720)*G[yyyyyy]*(diff(y(x), x))^6*c[2]^6+(1/48)*F^3*G[yyy]*c[2]^6+(1/8)*(diff(y(x), x))*F^3*G[yyyz]*c[2]^6+(1/16)*(diff(y(x), x))^2*F^2*G[yyyy]*c[2]^6+(1/12)*(diff(y(x), x))*F^4*G[yyzzz]*c[2]^6+(1/8)*(diff(y(x), x))^2*F^3*G[yyyzz]*c[2]^6+(1/12)*(diff(y(x), x))^3*F^2*G[yyyyz]*c[2]^6+(1/48)*(diff(y(x), x))^4*F*G[yyyyy]*c[2]^6+(1/36)*F^3*G[yyyzzz]*(diff(y(x), x))^3*c[2]^6+(1/48)*F^4*G[yyzzzz]*(diff(y(x), x))^2*c[2]^6+(1/48)*F^2*G[yyyyzz]*(diff(y(x), x))^4*c[2]^6+(1/120)*F*G[yyyyyz]*(diff(y(x), x))^5*c[2]^6+(1/120)*F^5*G[yzzzzz]*(diff(y(x), x))*c[2]^6+(1/4)*G[yzzz]*F^3*G*A[21]*c[2]^4+(1/6)*G[yzzz]*F^3*G*a[21]*c[2]^3+(1/4)*G[zzzz]*F^2*G^2*A[21]^2*c[2]^2+(1/2)*G[yyz]*F^2*G*a[21]*c[2]^3+(1/4)*G[yzz]*F*G^2*A[21]^2*c[2]^2+(1/24)*G[zzzzz]*F^4*G*A[21]*c[2]^4+(1/8)*G[yyz]*F^2*G*A[21]*c[2]^4+(1/6)*G[yyyy]*(diff(y(x), x))^3*G*a[21]*c[2]^3+(1/4)*G[yyzz]*(diff(y(x), x))^2*G^2*A[21]^2*c[2]^2+(1/24)*G[yyyyz]*(diff(y(x), x))^4*G*A[21]*c[2]^4+G[yyz]*(diff(y(x), x))*G^2*A[21]*a[21]*c[2]+(1/4)*G[yyzzz]*(diff(y(x), x))^2*F^2*G*A[21]*c[2]^4+(1/6)*G[yyyzz]*(diff(y(x), x))^3*F*G*A[21]*c[2]^4+(1/2)*G[yzzz]*(diff(y(x), x))*F*G^2*A[21]^2*c[2]^2+(1/4)*G[yyyz]*(diff(y(x), x))^2*F*G*A[21]*c[2]^4+(1/2)*G[yyzz]*(diff(y(x), x))*F^2*G*A[21]*c[2]^4+G[yzz]*F*G^2*A[21]*a[21]*c[2]+(1/2)*G[yyyz]*(diff(y(x), x))^2*F*G*a[21]*c[2]^3+(1/2)*G[yyzz]*(diff(y(x), x))*F^2*G*a[21]*c[2]^3+(1/6)*G[yzzzz]*(diff(y(x), x))*F^3*G*A[21]*c[2]^4+(1/2)*G[yyy]*(diff(y(x), x))*F*G*a[21]*c[2]^3)*h^6+O(h^7))+h^3*b[3]*(G+((diff(y(x), x))*G[y]*c[3]+F*G[z]*c[3])*h+((1/2)*F*G[y]*c[3]^2+(1/2)*(diff(y(x), x))^2*G[yy]*c[3]^2+(1/2)*F^2*G[zz]*c[3]^2+G*G[z]*A[31]+G*G[z]*A[32]+(diff(y(x), x))*F*G[yz]*c[3]^2)*h^2+(G*G[y]*a[31]+(1/6)*(diff(y(x), x))^3*G[yyy]*c[3]^3+(1/6)*F^3*G[zzz]*c[3]^3+(1/2)*(diff(y(x), x))*F*G[yy]*c[3]^3+(1/2)*(diff(y(x), x))^2*F*G[yyz]*c[3]^3+(1/2)*(diff(y(x), x))*F^2*G[yzz]*c[3]^3+(1/2)*F^2*G[yz]*c[3]^3+G[y]*G[z]*(diff(y(x), x))*A[32]*c[2]+G[z]^2*F*A[32]*c[2]+G*G[y]*a[32]+F*G*G[zz]*A[32]*c[3]+(diff(y(x), x))*G*G[yz]*A[32]*c[3]+F*G*G[zz]*A[31]*c[3]+(diff(y(x), x))*G*G[yz]*A[31]*c[3])*h^3+((1/24)*(diff(y(x), x))^4*G[yyyy]*c[3]^4+(1/8)*F^2*G[yy]*c[3]^4+(1/4)*F^3*G[yzz]*c[3]^4+(1/24)*F^4*G[zzzz]*c[3]^4+(1/2)*G^2*G[zz]*A[31]^2+(1/2)*G^2*G[zz]*A[32]^2+G[yzz]*(diff(y(x), x))*F*G*A[31]*c[3]^2+G[yzz]*(diff(y(x), x))*F*G*A[32]*c[3]^2+G[y]*G[yz]*(diff(y(x), x))^2*A[32]*c[2]*c[3]+G[z]*G[yz]*F*(diff(y(x), x))*A[32]*c[2]^2+G[z]*G[zz]*F^2*A[32]*c[2]*c[3]+(1/2)*(diff(y(x), x))*F^2*G[yyz]*c[3]^4+(1/4)*(diff(y(x), x))^2*F*G[yyy]*c[3]^4+(1/2)*G[zzz]*F^2*G*A[31]*c[3]^2+(1/2)*F*G*G[yz]*A[31]*c[3]^2+F*G*G[yz]*a[31]*c[3]+(1/2)*G[yyz]*(diff(y(x), x))^2*G*A[31]*c[3]^2+(diff(y(x), x))*G*G[yy]*a[31]*c[3]+(1/2)*F*G*G[yz]*A[32]*c[3]^2+F*G*G[yz]*a[32]*c[3]+(1/2)*G[zzz]*F^2*G*A[32]*c[3]^2+(1/2)*G[z]*G[yy]*(diff(y(x), x))^2*A[32]*c[2]^2+(diff(y(x), x))*G*G[yy]*a[32]*c[3]+(1/2)*G[yyz]*(diff(y(x), x))^2*G*A[32]*c[3]^2+(1/2)*G[z]*G[zz]*F^2*A[32]*c[2]^2+(1/2)*G[y]*G[z]*F*A[32]*c[2]^2+G[y]*G[z]*F*a[32]*c[2]+(1/6)*(diff(y(x), x))^3*F*G[yyyz]*c[3]^4+(1/4)*(diff(y(x), x))^2*F^2*G[yyzz]*c[3]^4+(1/6)*(diff(y(x), x))*F^3*G[yzzz]*c[3]^4+G[y]^2*(diff(y(x), x))*a[32]*c[2]+G^2*G[zz]*A[31]*A[32]+G[z]^2*G*A[21]*A[32]+G[y]*G[zz]*F*(diff(y(x), x))*A[32]*c[2]*c[3]+G[z]*G[yz]*F*(diff(y(x), x))*A[32]*c[2]*c[3])*h^4+((1/2)*G[z]*G[yzz]*F^2*(diff(y(x), x))*A[32]*c[2]^3+(1/8)*(diff(y(x), x))*F^2*G[yyy]*c[3]^5+(1/4)*(diff(y(x), x))*F^3*G[yyzz]*c[3]^5+(1/4)*(diff(y(x), x))^2*F^2*G[yyyz]*c[3]^5+(1/12)*(diff(y(x), x))^3*F*G[yyyy]*c[3]^5+(1/24)*(diff(y(x), x))^4*F*G[yyyyz]*c[3]^5+(1/12)*(diff(y(x), x))^3*F^2*G[yyyzz]*c[3]^5+(1/12)*(diff(y(x), x))^2*F^3*G[yyzzz]*c[3]^5+(1/24)*(diff(y(x), x))*F^4*G[yzzzz]*c[3]^5+(1/2)*G[y]^2*F*a[32]*c[2]^2+(1/2)*G[z]*G[yy]*F*(diff(y(x), x))*A[32]*c[2]^3+G[y]*G*G[zz]*(diff(y(x), x))*A[32]^2*c[2]+(1/2)*G[y]*G[yyz]*(diff(y(x), x))^3*A[32]*c[2]*c[3]^2+(1/2)*G[z]*G[zzz]*F^3*A[32]*c[2]*c[3]^2+G[z]*G[yz]*F^2*a[32]*c[2]*c[3]+G[z]*G*G[zz]*F*A[32]^2*c[2]+(1/2)*G[z]*G[yz]*F^2*A[32]*c[2]*c[3]^2+(1/2)*G[y]*G[zz]*F^2*A[32]*c[2]^2*c[3]+(1/6)*G[z]*G[zzz]*F^3*A[32]*c[2]^3+G^2*G[yz]*A[32]*a[31]+G^2*G[yz]*A[31]*a[31]+G^2*G[yz]*A[31]*a[32]+(1/2)*G[yz]*G[yy]*(diff(y(x), x))^3*A[32]*c[2]^2*c[3]+G[y]*G[yz]*F*(diff(y(x), x))*a[32]*c[2]^2+(1/2)*G[y]*G[yy]*(diff(y(x), x))^2*a[32]*c[2]^2+(1/6)*(diff(y(x), x))^3*G*G[yyyz]*A[32]*c[3]^3+G[y]*G[yzz]*F*(diff(y(x), x))^2*A[32]*c[2]*c[3]^2+G[z]*G[yz]*(diff(y(x), x))*G*A[21]*A[32]*c[2]+G[y]*G[zz]*(diff(y(x), x))*G*A[31]*A[32]*c[2]+G[z]*G[yz]*(diff(y(x), x))*G*A[21]*A[32]*c[3]+G[z]*G[zz]*F*G*A[21]*A[32]*c[2]+G[z]*G[zz]*F*G*A[31]*A[32]*c[2]+G[z]*G[zz]*F*G*A[21]*A[32]*c[3]+G[y]*G[z]*G*A[32]*a[21]+(1/2)*G[yzz]*(diff(y(x), x))*G^2*A[31]^2*c[3]+(1/6)*G[yyyz]*(diff(y(x), x))^3*G*A[31]*c[3]^3+(1/2)*F*G*G[yy]*a[31]*c[3]^2+(1/6)*G[zzzz]*F^3*G*A[31]*c[3]^3+G[y]*G[z]*G*A[21]*a[32]+(1/120)*F^5*G[zzzzz]*c[3]^5+G[y]*G[yz]*F*(diff(y(x), x))*a[32]*c[2]*c[3]+(1/2)*G[z]*G[yyz]*F*(diff(y(x), x))^2*A[32]*c[2]*c[3]^2+(1/6)*F^3*G*G[zzzz]*A[32]*c[3]^3+(1/2)*F^2*G*G[yzz]*A[32]*c[3]^3+(1/2)*F^2*G*G[yzz]*a[32]*c[3]^2+(1/2)*(diff(y(x), x))^2*G*G[yyy]*a[32]*c[3]^2+(1/2)*(diff(y(x), x))*G^2*G[yzz]*A[32]^2*c[3]+G[z]*G[yzz]*F^2*(diff(y(x), x))*A[32]*c[2]*c[3]^2+(1/12)*F^4*G[yzzz]*c[3]^5+(1/8)*F^3*G[yyz]*c[3]^5+(1/120)*(diff(y(x), x))^5*G[yyyyy]*c[3]^5+(1/2)*G[z]*G[yz]*F^2*A[32]*c[2]^3+(1/2)*G[zz]^2*F^3*A[32]*c[2]^2*c[3]+G[y]*G[yy]*(diff(y(x), x))^2*a[32]*c[2]*c[3]+G[yz]^2*F*(diff(y(x), x))^2*A[32]*c[2]^2*c[3]+(diff(y(x), x))*F*G*G[yyz]*a[32]*c[3]^2+(1/2)*(diff(y(x), x))*F^2*G*G[yzzz]*A[32]*c[3]^3+(1/2)*(diff(y(x), x))*F*G*G[yyz]*A[32]*c[3]^3+(1/2)*(diff(y(x), x))^2*F*G*G[yyzz]*A[32]*c[3]^3+(1/2)*G[yyz]*(diff(y(x), x))*F*G*A[31]*c[3]^3+(1/2)*G[yyzz]*(diff(y(x), x))^2*F*G*A[31]*c[3]^3+(1/2)*G[yzzz]*(diff(y(x), x))*F^2*G*A[31]*c[3]^3+G[yyz]*(diff(y(x), x))*F*G*a[31]*c[3]^2+G[yzz]*(diff(y(x), x))*G^2*A[31]*A[32]*c[3]+G[zzz]*F*G^2*A[31]*A[32]*c[3]+3*G[yz]*G[zz]*F^2*(diff(y(x), x))*A[32]*c[2]^2*c[3]*(1/2)+(1/2)*F*G^2*G[zzz]*A[32]^2*c[3]+(1/2)*G[yyy]*(diff(y(x), x))^2*G*a[31]*c[3]^2+(1/2)*G[yzz]*F^2*G*A[31]*c[3]^3+(1/2)*G[yzz]*F^2*G*a[31]*c[3]^2+(1/2)*G[zzz]*F*G^2*A[31]^2*c[3]+(1/2)*F*G*G[yy]*a[32]*c[3]^2+(1/2)*G[z]*G[yyz]*F*(diff(y(x), x))^2*A[32]*c[2]^3+(1/6)*G[z]*G[yyy]*(diff(y(x), x))^3*A[32]*c[2]^3+(1/2)*G[y]*G[zz]*F^2*a[32]*c[2]^2+(1/2)*G[y]*G[yz]*F*(diff(y(x), x))*A[32]*c[2]^2*c[3]+G[z]*G[yy]*F*(diff(y(x), x))*a[32]*c[2]*c[3]+(1/2)*G[y]*G[zzz]*F^2*(diff(y(x), x))*A[32]*c[2]*c[3]^2+(1/2)*G[yy]*G[zz]*F*(diff(y(x), x))^2*A[32]*c[2]^2*c[3]+(1/2)*G[y]*G[yz]*F*(diff(y(x), x))*A[32]*c[2]*c[3]^2+G^2*G[yz]*A[32]*a[32])*h^5+((1/6)*G[z]*G[yzzz]*F^3*(diff(y(x), x))*A[32]*c[2]^4+(1/16)*F^4*G[yyzz]*c[3]^6+(1/2)*G[z]*G[yyz]*F^2*(diff(y(x), x))*A[32]*c[2]*c[3]^3+(1/2)*G^2*G[yy]*a[31]^2+(1/2)*G[y]*G[yzz]*F^2*(diff(y(x), x))*a[32]*c[2]^3+(1/6)*G[zz]*G[yyy]*F*(diff(y(x), x))^3*A[32]*c[2]^3*c[3]+(1/2)*(diff(y(x), x))*F*G^2*G[yzzz]*A[32]^2*c[3]^2+(1/6)*(diff(y(x), x))*F^3*G*G[yzzzz]*A[32]*c[3]^4+(1/4)*G[y]*G[yz]*F^2*A[32]*c[2]^2*c[3]^2+(1/36)*F^3*G[yyyzzz]*(diff(y(x), x))^3*c[3]^6+(1/48)*F^4*G[yyzzzz]*(diff(y(x), x))^2*c[3]^6+(1/6)*G^3*G[zzz]*A[32]^3+(diff(y(x), x))*G^2*G[yyz]*A[32]*a[32]*c[3]+(1/2)*(diff(y(x), x))*F*G*G[yyy]*a[32]*c[3]^3+(1/2)*G[y]*G[yz]*F^2*a[32]*c[2]^2*c[3]+(1/4)*G[yz]*G[yy]*F*(diff(y(x), x))^2*A[32]*c[2]^2*c[3]^2+(1/12)*(diff(y(x), x))^3*F^2*G[yyyyz]*c[3]^6+(1/8)*(diff(y(x), x))^2*F^3*G[yyyzz]*c[3]^6+(1/6)*G[zzz]*G^3*A[31]^3+(1/2)*G[zz]*G[yyz]*F^2*(diff(y(x), x))^2*A[32]*c[2]^3*c[3]+(1/4)*G[z]*G[yyzz]*F^2*(diff(y(x), x))^2*A[32]*c[2]^4+G[z]*G[zz]*G^2*A[21]*A[32]^2+3*G[yz]*G[yy]*F*(diff(y(x), x))^2*a[32]*c[2]^2*c[3]*(1/2)+(1/4)*(diff(y(x), x))^2*F*G*G[yyyz]*A[32]*c[3]^4+(1/4)*(diff(y(x), x))^2*F^2*G*G[yyzzz]*A[32]*c[3]^4+(1/2)*G[yz]*G[zz]*F^3*a[32]*c[2]^2*c[3]+G[y]*G*G[zzz]*F*(diff(y(x), x))*A[32]^2*c[2]*c[3]+(1/720)*F^6*G[zzzzzz]*c[3]^6+(1/720)*G[yyyyyy]*(diff(y(x), x))^6*c[3]^6+(1/2)*G[y]*G*G[zz]*F*A[32]^2*c[2]^2+(1/24)*G[z]*G[yyyy]*(diff(y(x), x))^4*A[32]*c[2]^4+(1/2)*(diff(y(x), x))*F^2*G*G[yyzz]*a[32]*c[3]^3+(1/4)*G[z]*G[yyy]*F*(diff(y(x), x))^2*A[32]*c[2]^4+(1/6)*G[z]*G[yyyz]*F*(diff(y(x), x))^3*A[32]*c[2]^4+(1/2)*G[y]*G[yzzz]*F^2*(diff(y(x), x))^2*A[32]*c[2]*c[3]^3+(1/6)*(diff(y(x), x))^3*G*G[yyyy]*a[32]*c[3]^3+(1/2)*G[yy]*G[yzz]*F*(diff(y(x), x))^3*A[32]*c[2]^2*c[3]^2+(1/48)*F^2*G[yyyyzz]*(diff(y(x), x))^4*c[3]^6+G[y]^2*G*a[21]*a[32]+(1/2)*G[y]*G[yyz]*F*(diff(y(x), x))^2*a[32]*c[2]^3+(1/2)*G[yz]^2*F^2*(diff(y(x), x))*A[32]*c[2]^3*c[3]+(1/4)*(diff(y(x), x))^2*G^2*G[yyzz]*A[32]^2*c[3]^2+(1/2)*G[y]*G[yy]*F*(diff(y(x), x))*a[32]*c[2]^2*c[3]+(1/2)*G[z]^2*G[zz]*F^2*A[32]^2*c[2]^2+(1/2)*G[yyzz]*(diff(y(x), x))*F^2*G*A[31]*c[3]^4+G[yyz]*(diff(y(x), x))*G^2*A[31]*a[31]*c[3]+(1/2)*G[y]*G[yzz]*F^2*(diff(y(x), x))*A[32]*c[2]*c[3]^3+(1/120)*F^5*G[yzzzzz]*(diff(y(x), x))*c[3]^6+(1/120)*F*G[yyyyyz]*(diff(y(x), x))^5*c[3]^6+(1/4)*G[yz]*G[zz]*F^3*A[32]*c[2]^2*c[3]^2+(1/2)*(diff(y(x), x))^2*F*G*G[yyyz]*a[32]*c[3]^3+G[yzz]*F*G^2*A[32]*a[31]*c[3]+(1/2)*G[zzzz]*F^2*G^2*A[31]*A[32]*c[3]^2+(1/6)*G[yzzzz]*(diff(y(x), x))*F^3*G*A[31]*c[3]^4+(1/2)*G[yyzz]*(diff(y(x), x))^2*G^2*A[31]*A[32]*c[3]^2+(1/2)*G[yyy]*(diff(y(x), x))*F*G*a[31]*c[3]^3+(1/2)*G[zz]^2*F^2*G*A[31]*A[32]*c[2]^2+G[z]*G[zz]*G^2*A[21]*A[31]*A[32]+G[yzz]*F*G^2*A[31]*a[32]*c[3]+(1/2)*G[yzz]*F*G^2*A[31]*A[32]*c[3]^2+(1/2)*G[z]*G[yzz]*F^3*A[32]*c[2]*c[3]^3+(1/2)*G[yz]*G[zzz]*F^3*(diff(y(x), x))*A[32]*c[2]^2*c[3]^2+G[z]*G[yzz]*(diff(y(x), x))*F*G*A[21]*A[32]*c[3]^2+G[z]*G[yzz]*(diff(y(x), x))*F*G*A[21]*A[32]*c[2]^2+G[z]*G[zzz]*F^2*G*A[31]*A[32]*c[2]*c[3]+G[zz]*G[yz]*(diff(y(x), x))*F*G*A[31]*A[32]*c[2]^2+G[y]*G[yzz]*(diff(y(x), x))^2*G*A[31]*A[32]*c[2]*c[3]+(1/2)*G[y]*G[yzz]*F^2*(diff(y(x), x))*A[32]*c[2]^2*c[3]^2+(1/4)*G[zzzz]*F^2*G^2*A[31]^2*c[3]^2+(1/2)*G[yyz]*F^2*G*a[31]*c[3]^3+(1/8)*G[yyz]*F^2*G*A[31]*c[3]^4+(1/4)*G[yzz]*F*G^2*A[31]^2*c[3]^2+(1/2)*G[y]^2*G[zz]*(diff(y(x), x))^2*A[32]^2*c[2]^2+(1/6)*G[y]*G[yyy]*(diff(y(x), x))^3*a[32]*c[2]^3+(1/6)*G[y]*G[yyyz]*(diff(y(x), x))^4*A[32]*c[2]*c[3]^3+G[yz]^2*F^2*(diff(y(x), x))*a[32]*c[2]^2*c[3]+(1/2)*G[yy]*G[zz]*F^2*(diff(y(x), x))*A[32]*c[2]^3*c[3]+(1/2)*G[y]*G[yy]*F*(diff(y(x), x))*a[32]*c[2]^3+(1/2)*G[yz]*G[yyz]*F*(diff(y(x), x))^3*A[32]*c[2]^2*c[3]^2+(1/4)*G[zz]*G[yyz]*F^2*(diff(y(x), x))^2*A[32]*c[2]^2*c[3]^2+(1/8)*G[z]*G[yy]*F^2*A[32]*c[2]^4+(1/2)*G[z]*G[yyy]*F*(diff(y(x), x))^2*a[32]*c[2]*c[3]^2+(1/2)*G[zzz]*G^3*A[31]*A[32]^2+G^2*G[yy]*a[31]*a[32]+(1/2)*G[y]*G[yyz]*F*(diff(y(x), x))^2*A[32]*c[2]*c[3]^3+(1/12)*(diff(y(x), x))*F^4*G[yyzzz]*c[3]^6+(1/2)*G[zzz]*G^3*A[31]^2*A[32]+(1/4)*G[yy]*G[zzz]*F^2*(diff(y(x), x))^2*A[32]*c[2]^2*c[3]^2+F*G^2*G[yzz]*A[32]*a[32]*c[3]+(1/6)*G[yz]*G[zzz]*F^3*(diff(y(x), x))*A[32]*c[2]^3*c[3]+(1/48)*(diff(y(x), x))^4*F*G[yyyyy]*c[3]^6+(1/8)*(diff(y(x), x))*F^3*G[yyyz]*c[3]^6+(1/16)*(diff(y(x), x))^2*F^2*G[yyyy]*c[3]^6+G[y]*G[z]*G[zz]*F*(diff(y(x), x))*A[32]^2*c[2]^2+G[yzz]*F*G^2*A[31]*a[31]*c[3]+(1/2)*G[yzzz]*(diff(y(x), x))*F*G^2*A[31]^2*c[3]^2+2*G[z]*G[yz]*G*F*A[32]*a[32]*c[2]+(1/2)*G[y]*G[yzz]*F^2*(diff(y(x), x))*a[32]*c[2]*c[3]^2+(1/2)*G[zz]*G[yzz]*F^3*(diff(y(x), x))*A[32]*c[2]^3*c[3]+(1/2)*G*G[yy]*G[zz]*(diff(y(x), x))^2*A[32]^2*c[2]^2+(1/2)*G[z]*G[yy]*F^2*a[32]*c[2]*c[3]^2+(1/2)*G[z]*G[yz]*F*G*A[21]*A[32]*c[2]^2+G[y]*G[yz]*(diff(y(x), x))*G*A[32]*a[21]*c[3]+(1/2)*G[z]*G[zzz]*F^2*G*A[21]*A[32]*c[2]^2+(1/4)*G[yzzz]*F^3*G*A[31]*c[3]^4+(1/24)*G[zzzzz]*F^4*G*A[31]*c[3]^4+(1/6)*G[yzzz]*F^3*G*a[31]*c[3]^3+G[yz]^2*(diff(y(x), x))^2*G*A[21]*A[32]*c[2]*c[3]+(1/24)*(diff(y(x), x))^4*G*G[yyyyz]*A[32]*c[3]^4+(1/24)*G[z]*G[zzzz]*F^4*A[32]*c[2]^4+G[yz]*G[yzz]*F^2*(diff(y(x), x))^2*A[32]*c[2]^2*c[3]^2+(1/24)*F^4*G*G[zzzzz]*A[32]*c[3]^4+(1/2)*G[yy]^2*(diff(y(x), x))^3*a[32]*c[2]^2*c[3]+(1/2)*G[y]*G[yy]*F*(diff(y(x), x))*a[32]*c[2]*c[3]^2+(1/2)*G[yz]^2*F^2*(diff(y(x), x))*A[32]*c[2]^2*c[3]^2+(1/2)*G[y]*G[yyzz]*F*(diff(y(x), x))^3*A[32]*c[2]*c[3]^3+2*G[y]*G[yz]*G*(diff(y(x), x))*A[32]*a[32]*c[2]+(1/4)*G[yy]*G[yyz]*(diff(y(x), x))^4*A[32]*c[2]^2*c[3]^2+(1/2)*G[z]*G[zz]*G^2*A[21]^2*A[32]+(1/6)*G[yyyy]*(diff(y(x), x))^3*G*a[31]*c[3]^3+(1/4)*G[yyzz]*(diff(y(x), x))^2*G^2*A[31]^2*c[3]^2+(1/24)*G[yyyyz]*(diff(y(x), x))^4*G*A[31]*c[3]^4+(1/6)*G[z]*G[zzzz]*F^4*A[32]*c[2]*c[3]^3+(1/4)*G[y]*G[yyz]*F*(diff(y(x), x))^2*A[32]*c[2]^2*c[3]^2+G[y]*G[zz]*F*G*A[32]*a[21]*c[3]+(1/2)*G[yy]*G[zz]*(diff(y(x), x))^2*G*A[31]*A[32]*c[2]^2+(1/2)*G[z]*G[zzz]*F^2*G*A[21]*A[32]*c[3]^2+G[z]*G[yz]*F*G*A[21]*a[32]*c[3]+G[zz]^2*F^2*G*A[21]*A[32]*c[2]*c[3]+(1/2)*G[yy]*G[zz]*F^2*(diff(y(x), x))*a[32]*c[2]^2*c[3]+(1/2)*G[z]*G[yzz]*F^3*a[32]*c[2]*c[3]^2+(1/4)*G[y]*G[zzz]*F^3*A[32]*c[2]^2*c[3]^2+(1/4)*G[zz]*G[zzz]*F^4*A[32]*c[2]^2*c[3]^2+(1/2)*G[y]*G[yyy]*(diff(y(x), x))^3*a[32]*c[2]*c[3]^2+(1/2)*(diff(y(x), x))*F^2*G*G[yyzz]*A[32]*c[3]^4+G[yz]*G*G[zz]*F*(diff(y(x), x))*A[32]^2*c[2]^2+(1/6)*G[z]*G[yyyz]*F*(diff(y(x), x))^3*A[32]*c[2]*c[3]^3+(1/2)*G[yz]*G[yyz]*F*(diff(y(x), x))^3*A[32]*c[2]^3*c[3]+G[y]*G[zzz]*(diff(y(x), x))*F*G*A[31]*A[32]*c[2]*c[3]+2*G[zz]*G[yz]*(diff(y(x), x))*F*G*A[21]*A[32]*c[2]*c[3]+G[z]*G[yzz]*(diff(y(x), x))*F*G*A[31]*A[32]*c[2]*c[3]+G[z]*G[yz]*F*G*A[32]*a[21]*c[2]+G[y]*G[zz]*F*G*A[21]*a[32]*c[2]+(1/2)*G[z]*G[yz]*F*G*A[21]*A[32]*c[3]^2+(1/2)*G[y]*G[zz]*F*G*A[31]*A[32]*c[2]^2+G[z]*G[yz]*F*G*A[31]*a[32]*c[2]+(1/2)*G[z]*G[yyz]*(diff(y(x), x))^2*G*A[21]*A[32]*c[2]^2+G[z]*G[yy]*(diff(y(x), x))*G*A[32]*a[21]*c[2]+G[y]*G[yz]*(diff(y(x), x))*G*A[21]*a[32]*c[2]+G[yzzz]*(diff(y(x), x))*F*G^2*A[31]*A[32]*c[3]^2+G[z]*G[yz]*F*G*A[32]*a[31]*c[2]+(1/2)*G[z]*G[yyz]*F^2*(diff(y(x), x))*A[32]*c[2]^4+(1/2)*G[zz]*G[yzz]*F^3*(diff(y(x), x))*A[32]*c[2]^2*c[3]^2+(1/2)*G[z]*G[yyzz]*F^2*(diff(y(x), x))^2*A[32]*c[2]*c[3]^3+G[y]*G*G[yzz]*(diff(y(x), x))^2*A[32]^2*c[2]*c[3]+(1/2)*G[yz]*G[yzz]*F^2*(diff(y(x), x))^2*A[32]*c[2]^3*c[3]+(1/2)*G[yz]*G[yy]*F*(diff(y(x), x))^2*A[32]*c[2]^3*c[3]+(1/2)*G[z]*G[yzzz]*F^3*(diff(y(x), x))*A[32]*c[2]*c[3]^3+(1/48)*F^3*G[yyy]*c[3]^6+(1/48)*F^5*G[yzzzz]*c[3]^6+(1/2)*G^2*G[yy]*a[32]^2+(1/4)*G[z]*G[yzz]*F^3*A[32]*c[2]^4+(1/6)*G[zz]*G[zzz]*F^4*A[32]*c[2]^3*c[3]+G[z]*G*G[zzz]*F^2*A[32]^2*c[2]*c[3]+(1/2)*F^2*G*G[yyz]*a[32]*c[3]^3+(1/6)*G[y]*G[zzzz]*F^3*(diff(y(x), x))*A[32]*c[2]*c[3]^3+(1/6)*(diff(y(x), x))^3*F*G*G[yyyzz]*A[32]*c[3]^4+(1/6)*G[yz]*G[yyy]*(diff(y(x), x))^4*A[32]*c[2]^3*c[3]+(1/2)*G[y]*G[yz]*F^2*a[32]*c[2]^3+(1/2)*G*G[zz]^2*F^2*A[32]^2*c[2]^2+(1/2)*G[yz]*G[zz]*F^3*A[32]*c[2]^3*c[3]+G[z]*G[yyz]*F^2*(diff(y(x), x))*a[32]*c[2]*c[3]^2+G[y]*G[yyz]*F*(diff(y(x), x))^2*a[32]*c[2]*c[3]^2+(1/4)*F^3*G*G[yzzz]*A[32]*c[3]^4+G[z]*G*G[yzz]*F*(diff(y(x), x))*A[32]^2*c[2]*c[3]+(1/6)*G[yyyzz]*(diff(y(x), x))^3*F*G*A[31]*c[3]^4+(1/4)*G[yyzzz]*(diff(y(x), x))^2*F^2*G*A[31]*c[3]^4+(1/2)*G[yyzz]*(diff(y(x), x))*F^2*G*a[31]*c[3]^3+(1/2)*G[yyyz]*(diff(y(x), x))^2*F*G*a[31]*c[3]^3+(1/4)*G[yyyz]*(diff(y(x), x))^2*F*G*A[31]*c[3]^4+G[yyz]*(diff(y(x), x))*G^2*A[32]*a[31]*c[3]+G[yyz]*(diff(y(x), x))*G^2*A[31]*a[32]*c[3]+G[y]*G[yz]*(diff(y(x), x))*G*A[32]*a[31]*c[2]+(1/2)*G[z]*G[yyz]*(diff(y(x), x))^2*G*A[21]*A[32]*c[3]^2+G[y]*G[yz]*(diff(y(x), x))*G*A[31]*a[32]*c[2]+G[z]*G[yy]*(diff(y(x), x))*G*A[21]*a[32]*c[3]+(1/6)*F^3*G*G[yzzz]*a[32]*c[3]^3+(1/4)*F^2*G^2*G[zzzz]*A[32]^2*c[3]^2+(1/4)*F*G^2*G[yzz]*A[32]^2*c[3]^2+(1/8)*F^2*G*G[yyz]*A[32]*c[3]^4+(1/6)*G[y]*G[zzz]*F^3*a[32]*c[2]^3)*h^6+O(h^7))
coeff(SUMY, h, 6)
Error, unable to compute coeff
Download location_truncation_error_of_y.mw
I am going through the documentation on ScientificConstants and trying things out in a worksheet.
My first question about this package is about the following
with(ScientificConstants)
GetConstants()
`A[r](alpha)`, `A[r](d)`, `A[r](e)`, `A[r](h)`, `A[r](n)`, `A[r](p)`, E[h], F, G, G[0], K[J], M[Earth], M[Sun], M[u], N[A], Phi[0], R, R[Earth], R[K], R[infinity], V[m], Z[0], a[0], a[e], a[mu], alpha, b, c, c[1, L], c[1], c[2], e, epsilon[0], g, g[e], g[mu], g[n], g[p], gamma[e], gamma[n], gamma[p], gamma_prime[h], gamma_prime[p], h, hbar, k, l[P], lambda[C, mu], lambda[C, n], lambda[C, p], lambda[C, tau], lambda[C], m[P], m[alpha], m[d], m[e], `m[e]/m[mu]`, m[h], m[mu], m[n], m[p], m[tau], `m[tau]c^2`, m[u], mu[0], mu[B], mu[N], mu[d], `mu[d]/mu[e]`, mu[e], `mu[e]/mu[p]`, `mu[e]/mu_prime[p]`, mu[mu], mu[n], `mu[n]/mu_prime[p]`, mu[p], mu_prime[h], `mu_prime[h]/mu_prime[p]`, mu_prime[p], n[0], r[e], sigma, sigma[e], sigma_prime[p], t[P]
Copy and paste from the list above.
GetConstant(g[n])
neutron_g_factor, symbol = g[n], derive = 2*mu[n]/mu[N]
Manually try to type in g__n.
GetConstant(g__n)
Error, (in ScientificConstants:-GetConstant) `g__n` is not a known Constant
Why doesn't the latter work?
Download ScientificConstants.mw
I have multiple questions on how Units[TestDimensions] works from reading the Maple documentation. I will use this thread to ask them.
My first question regards the difference between Unit(expr) and units inserted using shortcut (CMD+SHIFT+U) on a mac?
Automatically loading the Units[Simple] subpackage
What is the difference between the following two commands?
Units:-TestDimensions(x*Unit('m')+y*Unit('s'), output = dimensions)
{x::(length^(-1+_t3[7, 1])*mass^_t3[7, 2]*time^_t3[7, 3]*electric_current^_t3[7, 4]*thermodynamic_temperature^_t3[7, 5]*amount_of_substance^_t3[7, 6]*luminous_intensity^_t3[7, 7]*currency^_t3[7, 8]*amount_of_information^_t3[7, 9]*logarithmic_gain^_t3[7, 10]), y::(length^_t3[7, 1]*mass^_t3[7, 2]*time^(-1+_t3[7, 3])*electric_current^_t3[7, 4]*thermodynamic_temperature^_t3[7, 5]*amount_of_substance^_t3[7, 6]*luminous_intensity^_t3[7, 7]*currency^_t3[7, 8]*amount_of_information^_t3[7, 9]*logarithmic_gain^_t3[7, 10]), (x*Units:-Unit(m))::(length^_t3[7, 1]*mass^_t3[7, 2]*time^_t3[7, 3]*electric_current^_t3[7, 4]*thermodynamic_temperature^_t3[7, 5]*amount_of_substance^_t3[7, 6]*luminous_intensity^_t3[7, 7]*currency^_t3[7, 8]*amount_of_information^_t3[7, 9]*logarithmic_gain^_t3[7, 10]), (y*Units:-Unit(s))::(length^_t3[7, 1]*mass^_t3[7, 2]*time^_t3[7, 3]*electric_current^_t3[7, 4]*thermodynamic_temperature^_t3[7, 5]*amount_of_substance^_t3[7, 6]*luminous_intensity^_t3[7, 7]*currency^_t3[7, 8]*amount_of_information^_t3[7, 9]*logarithmic_gain^_t3[7, 10]), (x*Units:-Unit(m)+y*Units:-Unit(s))::(length^_t3[7, 1]*mass^_t3[7, 2]*time^_t3[7, 3]*electric_current^_t3[7, 4]*thermodynamic_temperature^_t3[7, 5]*amount_of_substance^_t3[7, 6]*luminous_intensity^_t3[7, 7]*currency^_t3[7, 8]*amount_of_information^_t3[7, 9]*logarithmic_gain^_t3[7, 10])}
Units:-TestDimensions(2*Unit(m)+y*Unit(s), output = dimensions)
{y::(length/time), (y*Units:-Unit(s))::length, (2*Units:-Unit(m)+y*Units:-Unit(s))::length}
I think my question is what is the difference between inserting units using CMD+SHIFT+U on a mac, which generates the units as seen in the first command, versus using Unit(expr) as in the second version of the command?
Download Units_-_TestDimensions.mw
I read in the programming guide that to print the body of Maple library commands we set the Maple interface variable `verboseproc` to 2 then use the print command passing in the procedure we're interested in as argument.
Built-in kernel commands are compiled in machine code and not written in Maple language so we cannot view their definitions.
According to the guide, if we try to print such procedures we will see that the procedure has only an `option builtin` statement and no visible body.
If I try to view `Units:-TestDimensions`, as follows
```interface(verboseproc=1);
print(Units:-TestDimensions);
then what I see is
In this case there isn't the `option builtin` but neither is there a visible body.
Is this procedure built-in or is there a way to see the code?
i write my code for calculate this type of function but the result is so different from mine i  will post here i hope someone tell me where is problem
i have this
i want this
Download EX1.mw
I am wondering if there is any way i can produce a cayley graph of a fixed radius for a finitely presented infinite group? That is if i take a FinPresInfGrp such as Z² is there any way i could create the cayley graph for the first 5 steps away from e?
I have tried increasing  _EnvMaxCosetsToddCoxeter however i imagine that this is a bit pointless!
Any help would be very much appriciated :)
Is there a way to reassign the arcsecant function "arcsec()" as "asec()" so that "arcsec" can be assigned to the arcsecond unit "Unit(arcsec)"?
Ideally, I would like all of the inverse trigonometric functions to use the shorter notation "asec()" instead of "arcsec()".  I usually do this as aliases, i.e. "alias(asin = arcsin) : alias(asec = arcsec) :" but this won't allow reusing "arcsec" for a unit instead.
Example error for Maple 2023:
AddUnit(astronomical_unit, context = astronomy, default = true, prefix = SI, conversion = 149597870700*m) : # https://en.wikipedia.org/wiki/astronomical_unit
AddUnit(second, context = angle, spelling = arcsecond, plural = arcseconds, symbol = arcsec, prefix = SI_negative) :
AddUnit(parsec, context = astronomy, default = true, prefix = SI, conversion = AU/tan(arcsec)) ; # https://en.wikipedia.org/wiki/Parsec#Calculating_the_value_of_a_parsec
"Pi/648000" has to be used instead of "arcsec" here when defining the parsec since "arcsec" is already reserved for the arcsecant function, even with "alias(asec = arcsec) ;".
Correction: it looks like the parsec was redefined by the IAU in 2012 as exactly "648000*AU/Pi" without any tangents (or sines) in the definition (so the angle subtended by 1 AU at 1 PC is actually 0.999999999992" not 1").  Both "astronomical_unit" and "parsec" have the wrong values in Maple 2023 which need to be corrected manually.  But the conflict between arcseconds and arcsecants remains the same.
https://iau.org/static/resolutions/IAU2015_English.pdf
https://iopscience.iop.org/article/10.3847/0004-6256/152/2/41
First 124 125 126 127 128 129 130 Last Page 126 of 2463
