Suppose we have:-
x = a * e  + (2*b - 3*a^2) * e^2
Now let us find functions:
F(x) = 1 + a * e + (2 * b - a^2) * e^2 + ......
we are just interested in the first three terms.
Now two such functions can be:
F1(x) =  1 + x + 2 * x^2
F2(x) = (1-x)/(1-2*x)
How can we find all such functions F(x)?
I have a 3-dimensional dynamic system of ODEs characterized by zero eigenvalues at the origin. I would like to know if it's possible to find one trajectory converging towards the origin.
My system is derived from a control problem and has consequently control-like and state-like variables -- while the neighborhood is typically unstable I need to know if an appropriate choice of initial values can steer the system towards the origin;  I expect at most one such trajectory.
Is there a way to set a default header for every new maple document?
hi everyone. i am a complete beginner to maple, have used it for about 1 hour in total.  could you take me through step by step how to solve coupled equations please. for example:
3x+5y+7x=25, 4x-2y-3z=15, x+y+z=0
to obtain solutions for x, y and z
any help is very appreciated. thank you
What's the difference between VerticalBar and VerticalLine?
we have:
x = c[2]*e/c[1]+(2*c[3]*c[1]-3*c[2]^2)*e^2/c[1]^2+(3*c[4]*c[1]^2-10*c[2]*c[3]*c[1]+8*c[2]^3)*e^3/c[1]^3
how can we find a function "F(x)" the first three terms of whose power series around "e=0"  is given as:
1+c[2]*e/c[1]+(2*c[3]*c[1]-c[2]^2)*e^2/c[1]^2
I'm try to access some external Fortran routines within maple. I have a Fortran datatype of
  character*255 hf(20)
This is an input parameter, and I believe this will map into a maple Array object, but I'm not sure of the datatype. The help says that the datatype can only be "hardware datatypes" so I take to mean it would have to be of type integer[4]...when I do this I get the error below.
I am interested in computing the image of a constructible set in Maple.  I am using Maple 12 on a remote machine.  I am able to load the ConstructibleSetTools, ChainTools, and RegularChains libraries.  This paper indicates that the authors were using Maple 12 and have defined the RationalMap command.
Just a question about presentation.
If I have  a program like this:
for i to N do
for j to N do
i+j
od;
od;
How to show it like this?
for i to N do
   for j to N do
        i+j
    od;
od;
I have tryed some compositions with the keyboard but "everything doen't work".
Many thanks,
Ternox
How do i code into maple to check if a matrix is diagonally dominant?
s:=Matrix([[2,1,2],[-5/4,-5,5/4],[21/5,-14/5,7]]):
s[1,1];
s[1,2] + s[1,3];
this is what av done so far but i dont think its correct
for i from 1 to 3 do
for j from 1 to 3 do
s[i,i] <= s[i,j] + s[i,j+1]
od:od:
hello everybody,
Just a little question about lists.
I have a result like this
Result := {alpha[2] = -1.536774530, alpha[3] = -2.345615736};
How to select -1.536774530 and -2.345615736 ???
If I do Result[1];     it return alpha[2] = -1.536774530.
Many thanks !!!
Ternox
How do I label something without having to have maple evaluate it first?
For instance I would like something like this
to be labeled on the right side, when i try it just retuns false.
I defined five functions f[i] and three functions u[j].
Afterwards I integrated f[1]*u[1] for x=-infinity..infinity and defined it as E[11].
Then I defined an equation eqn[11] := E[11] = u[1]
Last but not least I solved eqn[11] to x. So far my doing was none of a problem and produced the expected result.
Then I wanted to let maple do this procedure with all combinations of f[i] and u[j].
So I wrote the following nested for loops:
Maple is plotting the first plot, but at the second, it tells me
and plots nothing. What did I do wrong?
rect := proc (t) options operator, arrow; Heaviside(t+1/2)-Heaviside(t-1/2) end proc
plot(limit(rect(t/T-1/2)*cos(t), T = 5.5), t = 0 .. 7)
I want to integrate a function which includes a proc. For example
P:=proc(t,w::list)
local v;
v:=choose an element from the list w, according to the value of t
return v
end proc
and my integrand is like this:
F:=(a,b,c,d)->a*b*c*P(d)
First 2069 2070 2071 2072 2073 2074 2075 Last Page 2071 of 2434
