since i found a way to replace a function like sin i was wondering about it's behavior. I replaced it with:
sin := proc(x):-sin(x*Pi/180);end proc:
The main problem is when i use the proc it execute like a normal proc, and not like the actual sin function. here is some exsamples:
Good Afternoon Everybody,
Attached is copy of Maple file that I'm working on. My first question is, I have used Maple to do linear interpolation inside the procedure to output the coefficient of A(x,T) and B(x,T) with no results would anybody please help.
My second question is if  the variable is a list of values along the length of pile x := [0.0, 2.0, 4.0, 10.0, 15.0, 20.0, 25.0, 30.0]*ft , how should I modify the procedure such that the each value in the list generate A(x,T) and B(x,T).
Please Help.
Moses
How can I save an array plot as an eps(or any other format) in maple. Right now when i am trying to do so it saves just one element, (using plot->export->encapsulated postscript etc...). How can I save the complete array as a single eps file.
If I have a univariate in negative powers , say,  a*x^(-1) + b*x^(-2), maple will expand this expression as
a/x+b/x^2
how can I prevent maple from converting negative powers to explicit division in 1D / 2D - Output, i.e. I want to keep the polynomial displayed as
a*x^(-1) + b*x^(-2)
Dear all, Is it possible for maple to do image cropping? The problem goes like this: i have two images. Image A: a image containing a random shape which is enclosed. Image B: is a normal image What i want to do is: Crop Image B using the shape in Image A. which comes to my mind is: Step 1: read a list of pixels representing the shape in IMAGE A. Step 2: set the pixels in IMAGE B which are not equal to the list of pixels to be "transparent" Is it achievable in Maple? Or matlab can do it also? Thanks all.
which command terminates the execution of the rest of a maple program?
In earlier versions of maple, to jump some characters forward we used tab, but in maple 13 it does sth different, is there any hot key to do that?
    I am trying to plot a rather complicated funtion in semilog plot. The x axis is in log scale, and x is from 1e-7 up to 10. I was able to have it work out except the points are not uniformly distributed. Most of the points are condensed within a small range between 0.1 and 10. So it is not clear how the curve is like from 1e-7 to 1e-2. Is ther anyway aroung that? Thanks a lot.
Yu
i was trying to make a package at my new maple 13. When bad and i ended up getting a error, when doing:
Driving me crazy:
lowest_gradient := proc(a) local i, b, c, gp, gn;
b := Array(1..5):
gp := Array(1..5):
for i from 1 to 5 do:
print(a);
b := a;
b[i] := a[i] + eps1;
gp[i] := b;
d := lowest_gradient(initial_point);
If you try the loop for yourself, you will see that it is changing the value of the local variable a each time the loops runs, yet I have no idea why, since I have not put any code which should change the value of a.
I want to build a sequence with random step between numbers, the first number must be 0 and the last must be 10, for example:
No of numbers 6
[0,2,3,6,9,10]
seq function does not allow rand function, is there any other way?
Dear forum,
i have a MapleSim model that works flawlessly, no errors occur and the plot results are as expected. When i try to use a template however(Analysis, Equations), the following message pops up:
(in PiecewiseTools:-is) Wrong kind of Parameters in piecewise.
What could cause this ? Unfortunately, my model is not for the public yet, so i cannot show you the sheet.
Hints ?
I have a vector and after some manipulation, some of its values are rational and some are decimal with fixed 10 digits after decimal point which is default for maple 13, I want to show all of them in decimal numbers with no zeros, e.g.
[1.1000000000, 2/3, 2.3150000000,10.0000000000]
is there any way to do this?
assume we have a cooling box that we open for a time period delta t. The box may be opened on top, so no cold air gets lost. What is the best way to model this in Maplesim ? So far, i have a heat capacity as box model for the cold air in it. I modeled a constant negative signal   during the time window delta t  and connected  a prescribed heat flow component to it.
Is this a reasonable model  in the easiest case ?
I have some troubles in solving a system of a complex equation using the function 'solve' of Matleb.The program finds no solution but a message of 'Warning: Warning, Warning: Explicit solution could not be found.
x=0:10000:500000;
solve('((2*y*(y/r^2-x)^0.5*besselj(1,(y/r^2-x)^0.5)*besselj(1,(y-x)^0.5))-((y-2*x)^2*besselj(0,(y/r^2-x)^0.5)*besselj(1,(y-x)^0.5))-(4*x*(y/r^2-x)^0.5*(y-x)^0.5*besselj(1,(y/r^2-x)^0.5)*besselj(0,(y-x)^0.5)))=0','y');
first of all I have to say that I'm newbie with Maple.
I tried soluting a 9 non linear equations system reading http://www.mapleprimes.com/forum/solving-a-set-of-linear-and-non-linear-equations but there's nothing to do: with solve or with a Groebner basis Maple looks for a solution for hours and then ends the memory available..
Is the system too much difficult? Can I calculate a solution? (My problem is a pole placement problem)
Thank you very much,
Riccardo
First 2123 2124 2125 2126 2127 2128 2129 Last Page 2125 of 2459
