Hello.
I am relatively new to MAPLE. I have a large fraction (actually a Bessel differential equation) which I like to break into single terms, i.e. to cancel the denominator with single summands.
"(diff(g(r),r)*f(phi)*r+r^2*diff(diff(g(r),r),r)*f(phi)+g(r)*diff(diff(f(phi),phi),phi)+h^2*g(r)*f(phi)*r^2)/g(r)/f(phi) = 0"
I tried full partial fraction, but it doesn't accept "g(r)*f(phi)" as variable.
any ideas?
all the best.
Hi all, i have been using maple for some time now. But one thing still bothers me. The use of radian in stead og degree. I found a way to work around it, but still.
So i looked at the help file, and found some intresting commands like:
  • AddSystem - "The AddSystem(unit_name, opts, units) function adds or redefines a system of units in the current session"
  • UseSystem
Can't that be used to forcing maple to calculate in degrees rather then radian.
/Simon Johansen
hi!
i am new to Maple (just purchased 13) as well as trigonometry, which i am using Maple for! i'm trying to use Maple for all of my Chem and Trig homework because I am a Physics major and I think i'll probably be using this for years, so might as well get accustomed now!
basically, one of the problems has a figure with a unit circle on a cartesian plane. the "t-line" (or plot line, i dont know) has tick marks that represent the length of (t), and they go from 1 to 6. to give a better "mental image":
hi all! i am **brand new** with maple 13 as well as trigonometry, which i am using the program for. i have figured out how to plot the unit circle with the command:
>plot( [cos(t), sin(t), t=0..2*Pi] );<
Dear experts, I need to know how I can calculate the mean and the standard deviation from a matrix? Can anybody help me with this? Kind regards! Marc
I would like to experiment with the Mastery Dialog option e.g. making a tutorial. Does anyone tried this in practice? And can I download a question bank that uses this option?
kind regards,
Harry Garst
the implemented Power Sensor calculates the instantenious power, it just multiplies u(t) and i(t). What i need now is a device that gives me the average power, the sources all have periodic voltages/currents (most common case: sin shaped sources). I thought i could use the power sensor and integrate over a period, but i don't know how to  enter the upper time limit.
Thoughts ?
How can I add a super-script circle degrees symbol in a plot label?
E.g. plot(x^2, labels=["Distance", "Temperature (degrees celcius)"]); ... etc
it shouldn't be hard to, do, but i cannot get this working. I just want to create a signal source that creates a pulse form signal with the pulse width parameter as a realsignal input. I used the custom component template and tried the DynamicSystems[Square] command, but the error messages that came up during this process didn't help me too much, because they seem to be unrelated (error in collect/series...). Do i have to create a new System first (DynamicSystems[NewSystem])?
Wondering if there is a way to change the HUE color range that will be used for listdensity plot.
Currently default setting is to use the full HUE color. But what we need is a shorter range, e.g., only from orange to blue.
Can it be achieved?
Or the PLOT structure has to be used?
This is the code i am using now.
Is there any function that we can sort a list / vector?
What abt a matrix? e.g.
M:=Matrix([[2, 5], [4, 0], [3, 9]]);
The sorted matrix (based on its first column) will be:
Matrix([[2, 5], [3, 9],[4, 0]]);
hello
I use
plots[odeplots](dsol,[t,(D(X[5](t))(t),0..5,numpoints=100);
when dsol=dsolve(..........) which is a procedure to plot first derivative of X[5] now I wanna know what should I use to plot second derivative of that
I used
plots[odeplots](dsol,[t,(D[1,1](X[5](t))(t),0..5,numpoints=100); but nothing shows up
and some other commands none of them works for me.
bye
Is there any maple command that I can use dsolve with method=implicit I could not find that in help?
A:=RandomMatrix(3,2, generator=1..3);
                               [1   1]
> A:=Matrix([[1,2,2,3],[5,1,0,4],[6,7,3,4]]);
> V:=<6,5,9>;
I want to add vector V as a new column [e.g. 3rd column] in matrix A, is there any function to do that simply? What abt to add as a row?
First 2125 2126 2127 2128 2129 2130 2131 Last Page 2127 of 2459
