I'm working with inverse of a complicated matrix, which is 12*12, and all the elements are symbols. I included that matrix at the end. The program is running forever, no results, no error message? Anybody has such kind of experience, any suggestion that what I can do? Thanks a lot, I appreciate your help! Matrix([ [a+b+c+d+e,a+b+d+w*e,a+b+d+w^2*e,a+b+c,a+b,a+b,a+c,a, a,a+c,a,a], [a+b+d+w*e,a+b+c+d+e,a+b+d+w*e,a+b,a+b+c,a+b,a,a+c,a, a,a+c, a], [a+b+d+w^2*e,a+b+d+w*e,a+b+c+d+e,a+b,a+b,a+b+c,a,a,a+c,a, a,a+c], [a+b+c,a+b,a+b,a+b+c+d+e,a+b+d+w*e,a+b+d+w^2*e,a+c,a,a, a+c,a, a],
Hi !
I'm wanting to make an animation from images. But these images are not plots, they are lists of plots, which I display simultaneously using the display function. So I've a list of list of plots, which I want to be displayed as an animation. The syntax is animate(function_that_returns_a_plot, ...), and I can't return a plot, since a list of plots is not a plot. Does anybody know what to do ?
Thanks in advance :)
Hi, this is my first time posting, so I'm not even sure if this is the right place to ask this. But, I'm having trouble defining a function. I'm using the document view and trying to establish Q(variables)= some function and it returns "Error, invalid parameters for inline function." More specifically:
I've been trying figure out how to code up arbitrary volume and surface integrals in Maple. I know that Maple has the VectorCalculus package but there doesn't appear to be a way to specify a volume integral (where the infinitesimal is dV). Also, there doesn't seem to be a way to specify a surface integral without defining the surface in advance (i.e., integrate over S with an infinitesimal of dS). In both cases, I'd like to have general integrals where I can specify the bounds at a later time (e.g., inert integrals). I know that there is the triple integrals in the student package but they aren't the same as a volume integral.
Dear all : I have a function qx(x):= 1/21 x in (20,40) = 0 others ; My double integral is like integral ( integral (qx(x1), x1=x-10..40)*integral(qx(x1),x1=x-20..40)*1/20, x = 20...30); since the qx(x)'s is not keep constant on whole range, I am confused with the double integral. Any help is appreciated. Thanks
I have two lists viz. X:=[a,b,c,d,e,f,g,h,i] of size 9. And I:=[1,2,3]. I want to generate a list of all the possible patterns of size 9 which can be made using 1,2,3. For example a few patterens which the code is to produce, among many others, are as follows: [1,1,1,2,2,2,3,3,3] [1,2,2,1,2,2,1,2,2] [2,3,3,2,3,3,2,3,3] [2,2,2,2,3,3,3,3,3] etc. Your help would be a great great help to me. I need it direly.
Here is my problem:
> vec1:=Vector(2): plot(vec1[floor(x)], x = 1 .. 2);
Error, bad index into Vector
The above should give the zero plot, but it gives the error message.
Of course, vec1[floor(x)] gives the correct answer for any specific x. (i.e. vec1[floor(1.5324)] gives 0, which is correct).
I get the same problem when plotting or integrating functions that simliarly depend on Matrices. What's going on?
Sincerely,
Adeel
I'm looking for a method to extract the (unique) functions of a specific variable from a sum of functions, for example from u=sin(x)*sin(th)+sin(x)^2+sin(2x)+sin(th)^2+exp(x)+x i want to extract for x unique functions = {sin(x),sin(2x),exp(x),x} and for th unique functions = {sin(th)}. For a sum of only trigiometric functions, I use indets(u,trig(x)) and indets(u,trig(th)). However, for a sum of general functions I have no clue how to do this. Any help is welcome. Niels.
I had installed Maple 9.0 for linux (SUSE 10.0). When I start it, I see an error message "Connection to Kernel lost". Have someone any advice? Thanks Angela
Hi, How do I calculate Kronecker/tensor products in Maple 10? Regards, Evyn
I am attempting to use document blocks to hide the Maple code for an interactive document and I'm encountering an unbelievably frustrating issue: if I create a new document block and suppress the output of the function calls therein with a colon, when I collapse the document block, the function calls are not hidden at all, but are displayed in a continuous line. If I do not supress the output, once I collapse the block, only the output is visible (which may be desirable except that I am doing things like loading packages, storing plot3d and plot variables, etc., and I DO NOT WANT THE OUTPUT VISIBLE).
I'd like to define a function f(a,b)= product(product(p(a,b,c[i],d[j])^x[ij]*(1-p(a,b,c[i],d[j]))^(1-x[ij]),j=1..n),i=1..n) (The x's are known data, each 0 or 1, the c's and d's are also known.) Is there a way to do this without writing it out long-hand, say using a matrix of the x's and vectors of the c's and d's? Thanks.
I have an array of functions involving x such that array[i] is valid only on the interval x=i..(i+1). I am trying to create a piecewise function that includes all array[i] terms valid in their respective ranges, but I am running into some syntax problems.
Hi! I am new! I can't integrate this... could u help me? (exp(-1/2*(ln(y)-(x*b+2))^2/(sigma^2*(x^2+1)))/(y*sigma*sqrt(2*Pi*(x^2+1))))*(2-1.666666667*x), x=0.6..1.2, y=3.6..4.5
Can any one of you help me to solve the question below? Please... Question: Find non-negative integers solutions that satisfy the following conditions: Given: p,k,h,a,b,c are integers. The conditions are: (1) a+b+c=k*h-h-h*h+1 (2) (p-k+h)*(p-h-1)*(p-1)-(p-k)*(p-2)*(p)=a*(p-1)+b*(p-h-1)+c*(p-k+h) (3) h>=1 (4) h
First 2424 2425 2426 2427 2428 2429 2430 Last Page 2426 of 2463
