I have created some plots of inverse primes  like this example1.pdf .
The filled color-shape in the middle is what I want do do with all areas in this picture or in other pictures.
In other words the goal is to fill the differnt areas in the print with different colors.
So I need to find the points of the Polygons, as I have done by hand with that yellow Polygon.
A procdure that is ready will give give the crosspoints of the lines.
These are the line-coordinates (the 1st number ist the number of iterations)
2*L[1]=number of lines in L
L:=[14, [[1, 1], [1, 26]], [[1, 26], [26, 26]], [[26, 26], [26, 37]], [[26, 37], [37, 37]], [[37, 37], [37, 39]], [[37, 39], [39, 39]], [[39, 39], [39, 20]], [[39, 20], [20, 20]], [[20, 20], [20, 23]], [[20, 23], [23, 23]], [[23, 23], [23, 30]], [[23, 30], [30, 30]], [[30, 30], [30, 70]], [[30, 70], [70, 70]], [[70, 70], [70, 45]], [[70, 45], [45, 45]], [[45, 45], [45, 34]], [[45, 34], [34, 34]], [[34, 34], [34, 32]], [[34, 32], [32, 32]], [[32, 32], [32, 51]], [[32, 51], [51, 51]], [[51, 51], [51, 48]], [[51, 48], [48, 48]], [[48, 48], [48, 41]], [[48, 41], [41, 41]], [[41, 41], [41, 1]], [[41, 1], [1, 1]]]
These are the crosspoints:
cp := [[23, 26], [30, 37], [32, 37], [26, 30], [48, 45], [39, 34], [41, 34], [45, 41]]
To plot the pdf I used this code:
poly2 := [[32, 32], [34, 32], [34, 34], [39, 34], [39, 39], [37, 39], [37, 37], [32, 37]]
poly 2 is just an axample, how it looks like when its ready.
display(seq(line(op(L[i])), i = 2 .. 2*L[1] + 1), polygonplot([poly2], color = "Resene GoldenTainoi", axes = none, style = polygon), color = blue, thickness = 0.8);
So I hope, you can help me :)
This is a beautyfull way to paint a prime  by just printing the remainders of the recursive dividing of the inverse prime in lines.
Thanks a lot,
Arno
int(sin(x)/x*exp(-2*I*pi*f*x), x = -infinity .. infinity) gives the incorrect answer pi. The correct answer is pi for abs(f)
Dear Maple community,
I'm trying to solve a complex expression by taking its first-order derivative and finding the optimal solution. As a result, I'm getting a rootOf expression, which is further not solved by using explicit or allvalues APIs provided in the maple. Can you guys help me where I'm going wrong?
I'm attaching my code file as well for
U[d] := Zeta[n]*(2^(2/3)*(theta[n]*lambda*A*beta[n])^(2/3)/(4*beta[n])-delta[n]*`λA`+U[n]+alpha[n])+Zeta[g]*(U[g]-delta[g](1-lambda)*A+tau*A+R+(-2*A*theta[g]*(lambda-1)*beta[g])^(2/3)/(4*beta[g]))+tau*A-A
Zeta[n]*((1/4)*2^(2/3)*(theta[n]*lambda*A*beta[n])^(2/3)/beta[n]-delta[n]*`λA`+U[n]+alpha[n])+Zeta[g]*(U[g]-delta[g](1-lambda)*A+tau*A+R+(1/4)*(-2*A*theta[g]*(lambda-1)*beta[g])^(2/3)/beta[g])+tau*A-A
FOC := diff(U[d], A)
(1/6)*Zeta[n]*2^(2/3)*theta[n]*lambda/(theta[n]*lambda*A*beta[n])^(1/3)+Zeta[g]*(-delta[g](1-lambda)+tau-(1/3)*theta[g]*(lambda-1)/(-2*A*theta[g]*(lambda-1)*beta[g])^(1/3))+tau-1
evala(simplify(FOC))
(1/6)*2^(2/3)*(theta[n]*lambda*A*beta[n])^(2/3)*Zeta[n]/(A*beta[n])-(1/6)*Zeta[g]*(-2^(2/3)*(-A*theta[g]*(lambda-1)*beta[g])^(2/3)+6*delta[g](1-lambda)*A*beta[g]-6*tau*A*beta[g])/(A*beta[g])+tau-1
xyz := solve(FOC = 0, A, explicit)
RootOf(-Zeta[n]*theta[n]*lambda*(-_Z*lambda*beta[g]*theta[g]+_Z*beta[g]*theta[g])^(1/3)+3*delta[g](1-lambda)*(theta[n]*lambda*_Z*beta[n])^(1/3)*2^(1/3)*(-_Z*lambda*beta[g]*theta[g]+_Z*beta[g]*theta[g])^(1/3)*Zeta[g]-3*(theta[n]*lambda*_Z*beta[n])^(1/3)*2^(1/3)*(-_Z*lambda*beta[g]*theta[g]+_Z*beta[g]*theta[g])^(1/3)*tau*Zeta[g]+(theta[n]*lambda*_Z*beta[n])^(1/3)*lambda*Zeta[g]*theta[g]-3*tau*(theta[n]*lambda*_Z*beta[n])^(1/3)*2^(1/3)*(-_Z*lambda*beta[g]*theta[g]+_Z*beta[g]*theta[g])^(1/3)-(theta[n]*lambda*_Z*beta[n])^(1/3)*Zeta[g]*theta[g]+3*(theta[n]*lambda*_Z*beta[n])^(1/3)*2^(1/3)*(-_Z*lambda*beta[g]*theta[g]+_Z*beta[g]*theta[g])^(1/3))
allvalues(xyz)
Download RootOf_Maple2.mw
reference.
I am not able to even trap this Maple exception.
Any suggestions what to do? It is not a problem if it can't solve it, but I need to at least be able to  trap the exception in order to go to the next one, else the whole program now stops when it hits this.
I used try..catch but this exception just ignores this and escapes to top level. This is not the first time I've seen Maple exception escape the try/catch. I do not understand why some do that and some not. I
Is this another bug?
eq:=1 = -X*(-1/4*(-40*(X + x0)^(5/3) - 20/3*(X + x0)^(2/3)*Y - 20/3*(X + x0)^(2/3)*y0 - 32*A*(X + x0)^(1/3))/((X + x0)^(5/3)*(Y + y0)) + 5/12*(-15*(X + x0)^(8/3) - 4*(X + x0)^(5/3)*Y - 4*(X + x0)^(5/3)*y0 - 24*A*(X + x0)^(4/3) + 12*A^2)/((X + x0)^(8/3)*(Y + y0)))/(Y*(1/(Y + y0) + 1/4*(-15*(X + x0)^(8/3) - 4*(X + x0)^(5/3)*Y - 4*(X + x0)^(5/3)*y0 - 24*A*(X + x0)^(4/3) + 12*A^2)/((X + x0)^(5/3)*(Y + y0)^2)));
1 = -X*(-(1/4)*(-40*(X+x0)^(5/3)-(20/3)*(X+x0)^(2/3)*Y-(20/3)*(X+x0)^(2/3)*y0-32*A*(X+x0)^(1/3))/((X+x0)^(5/3)*(Y+y0))+(5/12)*(-15*(X+x0)^(8/3)-4*(X+x0)^(5/3)*Y-4*(X+x0)^(5/3)*y0-24*A*(X+x0)^(4/3)+12*A^2)/((X+x0)^(8/3)*(Y+y0)))/(Y*(1/(Y+y0)+(1/4)*(-15*(X+x0)^(8/3)-4*(X+x0)^(5/3)*Y-4*(X+x0)^(5/3)*y0-24*A*(X+x0)^(4/3)+12*A^2)/((X+x0)^(5/3)*(Y+y0)^2)))
try
   sol:=solve(identity(eq,X),[x0,y0]);
catch:
   print("trapped the error");
end try;
Error, (in anonymous procedure called from type/realcons) too many levels of recursion
Download how_to_trap.mw
Update 3 years later. FYI. This error still shows in Maple 2025. It will be nice if Maple returns no solution than an internal error that can not be trapped which means the whole program crashes.
`The "Physics Updates" package is not available for the version of Maple under development`
eq:=1 = X*(2*cos(X)*cos(x0)-X*sin(X)*cos(x0)-2*sin(X)*sin(x0)-X*cos(X)*sin(x0)-x0*sin(X)*cos(x0)-x0*cos(X)*sin(x0))*(2*Y*ln(Y+y0)+Y+2*y0*ln(Y+y0)+y0)/Y/(X*cos(X)*cos(x0)-X*sin(X)*sin(x0)+x0*cos(X)*cos(x0)-x0*sin(X)*sin(x0)+sin(X)*cos(x0)+cos(X)*sin(x0))/(2*ln(Y+y0)+2*Y/(Y+y0)+1+2*y0/(Y+y0));
1 = X*(2*cos(X)*cos(x0)-X*sin(X)*cos(x0)-2*sin(X)*sin(x0)-X*cos(X)*sin(x0)-x0*sin(X)*cos(x0)-x0*cos(X)*sin(x0))*(2*Y*ln(Y+y0)+Y+2*y0*ln(Y+y0)+y0)/(Y*(X*cos(X)*cos(x0)-X*sin(X)*sin(x0)+x0*cos(X)*cos(x0)-x0*sin(X)*sin(x0)+sin(X)*cos(x0)+cos(X)*sin(x0))*(2*ln(Y+y0)+2*Y/(Y+y0)+1+2*y0/(Y+y0)))
solve(identity(eq,X),[x0, y0])
Error, (in signature) too many levels of recursion
normal(eq);
1 = (Y+y0)*(2*ln(Y+y0)+1)*(2*cos(X)*cos(x0)-X*sin(X)*cos(x0)-2*sin(X)*sin(x0)-X*cos(X)*sin(x0)-x0*sin(X)*cos(x0)-x0*cos(X)*sin(x0))*X/((2*ln(Y+y0)+3)*(X*cos(X)*cos(x0)-X*sin(X)*sin(x0)+x0*cos(X)*cos(x0)-x0*sin(X)*sin(x0)+sin(X)*cos(x0)+cos(X)*sin(x0))*Y)
solve(identity(%,X),[x0, y0])
expand(eq);
`[Length of output exceeds limit of 10000]`
Download internal_error_march_27_2025.mw
Hi, I'm working on some chemistry and i'd like for the unit to me mol/l not mol/m^3. How do i fix this? I googled it and it seems like the unit is the universal standard for concentration but i wasn't taught this in school as we were told to use mol/l.
I've tried googling and following the guides on the site but i honestly cant figure out what im doing wrong.
Picture for reference
I don't understand. With 2 degrees of liberty and a factor of 5% (1-95%), the table Khi-2 indicates 5,99.
It is impossible for me to obtain this value with Mapple. 2 following tests :
Y := ChiSquareRandomVariable(2);
                            Y := _R0
PDF(Y, 0.05);
CDF(Y, 0.05);
                          0.4876549560
                       0.0246900878919645
PDF(Y, 0.95);
CDF(Y, 0.95);
                          0.3109425282
                       0.378114901350325
The same problème with the instruction RandomVariable(ChiSquare(v)).
Thank you to help me.
Kinds regards
The netlist in the attached Maple file will not solve.
It will solve if I remove
.CONS Vx=v[D]-v[S]
.VARS Vx
from the netlist.
Syrup returns a 2 element list of [eqs, vars] that can be easily solved using the solve command as shown in the attached file
ModelDebug.mw
It will be great if  DEtools:-convertAlg  which is designed to find coefficients of a linear ode, not to expand the coefficients it finds.
This caused my patterns to fail, as after putting the coefficients in a certain form, and then calling DEtools:-convertAlg later on somewhere else in the program, the patterns no longer worked due to this unexpected expansion.
It will be better if DEtools:-convertAlg returns the coefficients it find as is and not expand them. I could not find an option to use for this. Here is an example.
ode:=b*(x+x^2)*diff(y(x),x$2)+x*(2*a - 1)*diff(y(x),x)+c*y(x)=0;
After the call the coefficients become
L:=DEtools:-convertAlg(ode,y(x))
You might ask that one can easily "fix" this afterwords. Sure. I can use collect on x. But the point is that in general, it might not be clear what to collect on or what the changes that were made are.
In principle, it is better to keep the coefficients in same form as they were in the ode so that the ode do not change form.
Maple 2022.1 on windows.
For example my friend emailed me.
His email address is oneman@gmail.com, the email content is HELLO.
How does Maple print HELLO to the screen so I can see it?
Thanks for your help!
eq1 := (2*(r^2+a^2*cos(theta)^2))*(M*r-(1/2)*a^2-(1/2)*r^2)*(diff(f(r, theta), r, theta))+(2*(a^2*(M-r)*cos(theta)^2-M*r^2+a^2*r))*(diff(f(r, theta), theta))
2*(r^2+a^2*cos(theta)^2)*(M*r-(1/2)*a^2-(1/2)*r^2)*(diff(diff(f(r, theta), r), theta))+2*(a^2*(M-r)*cos(theta)^2-M*r^2+a^2*r)*(diff(f(r, theta), theta))
eq2 := sin(theta)*(r^2+a^2*cos(theta)^2)*(diff(f(r, theta), theta, theta))-cos(theta)*(diff(f(r, theta), theta))*(a^2*cos(theta)^2-2*a^2-r^2)
sin(theta)*(r^2+a^2*cos(theta)^2)*(diff(diff(f(r, theta), theta), theta))-cos(theta)*(diff(f(r, theta), theta))*(a^2*cos(theta)^2-2*a^2-r^2)
eq3 := -2*(r^2+a^2*cos(theta)^2)^2*(M*r-(1/2)*a^2-(1/2)*r^2)*sin(theta)*(diff(g(r, theta), r, r))+sin(theta)*(r^2+a^2*cos(theta)^2)^2*(diff(g(r, theta), theta, theta))+(4*(-(1/4)*cos(theta)^4*a^4+a^2*r*(M-(1/2)*r)*cos(theta)^2-M*a^2*r-(1/4)*r^4))*cos(theta)*(diff(g(r, theta), theta))-2*M*sin(theta)*(diff(g(r, theta), r))*(a^2+r^2)*(cos(theta)*a-r)*(cos(theta)*a+r)
-2*(r^2+a^2*cos(theta)^2)^2*(M*r-(1/2)*a^2-(1/2)*r^2)*sin(theta)*(diff(diff(g(r, theta), r), r))+sin(theta)*(r^2+a^2*cos(theta)^2)^2*(diff(diff(g(r, theta), theta), theta))+4*(-(1/4)*cos(theta)^4*a^4+a^2*r*(M-(1/2)*r)*cos(theta)^2-M*a^2*r-(1/4)*r^4)*cos(theta)*(diff(g(r, theta), theta))-2*M*sin(theta)*(diff(g(r, theta), r))*(a^2+r^2)*(cos(theta)*a-r)*(cos(theta)*a+r)
pdsolve([eq1, eq2, eq3])
[{f(r, theta) = _F1(r)+(Int((r^2+a^2*cos(theta)^2)/((cos(theta)+1)^(1/2)*(cos(theta)-1)^(1/2)), theta))*_C1/(2*M*r-a^2-r^2)}, [diff(diff(g(r, theta), r), r) = (sin(theta)*(sin(theta)^2*a^2-a^2-r^2)^2*(diff(diff(g(r, theta), theta), theta))-4*cos(theta)*((1/4)*a^4*sin(theta)^4+(-(1/2)*a^2+r*(M-(1/2)*r))*a^2*sin(theta)^2+(1/4)*(a^2+r^2)^2)*(diff(g(r, theta), theta))+2*M*sin(theta)*(diff(g(r, theta), r))*(a^2+r^2)*(sin(theta)^2*a^2-a^2+r^2))/(sin(theta)*(sin(theta)^2*a^2-a^2-r^2)^2*(2*M*r-a^2-r^2))]]
Download pde1.mw
A := Omega; assume(Omega > 0); B = Omega
B = Omega
Download assumetest.mw
In a physics problem, I came across the following triple integral:
exp := -sin(alpha)*i*r*(-sin(alpha)*cos(phi)*cos(theta)+sin(theta)*cos(alpha))/(4*sqrt(-2*sin(theta)*sin(alpha)*cos(phi)*p*r-2*cos(alpha)*cos(theta)*p*r+p^2+r^2)*Pi(-2*sin(theta)*sin(alpha)*cos(phi)*p*r-2*cos(alpha)*cos(theta)*p*r+p^2+r^2)*(-2+sqrt(2))*Pi)
`assuming`([int(int(int(exp*p^2*sin(alpha), p = 0 .. 1), alpha = 0 .. (1/4)*Pi), phi = 0 .. 2*Pi)], [alpha > 0, alpha < (1/4)*Pi, r > 0, r < 1, phi > 0, phi < 2*Pi, theta > 0, theta < (1/4)*Pi])
I tried to perform each integration separately, but got no result. Is there any transformation or procedure, that I am not aware of, to accomplish this task?
Grateful,
Oliveira
Download Triple_integral.mw
   A question on programming Procedures (proc).
   What is the best, or most common method, to invoke packages within proc or at the worksheet level?
   I have always been confused about Proc scope for packages.   I use Scientific Constants a lot.   It and several other "with(package)" are part my main loaded pakages right after restart command.   LinearAlgebra is another common used package.
   It has been a question for me of whether to implement a "with()" statement inside of the proc to bound the scope or ensure it is seen/available by the procedure for the available commands inside the packages.
  All thoughts appreciated.
Bill
After substitution of (10) into (4), how to collect the terms of like powers of eta (i.e., eta^-3, eta^-2,eta^-1, eta^0, eta^1,eta^2 ), and equate the coefficients to
zero, get a system of algebraic equations for A[m]?
PA.mw
g := proc() use a=a+b in use b= a-b in a*b end use end use end proc:
Maple shows g := proc() (a+b)*(a+b) end proc.
My guess is (a+b)*a. What is wrong with me?
First 306 307 308 309 310 311 312 Last Page 308 of 2458
