Hi everyone how can I plot like a graphic?
I am having problems with the code I am trying to write in Maple 2020. I have attached the code in this question.
I hope someone can help me out.
Error, invalid input: rhs received 0, which is not valid for its 1st argument, expr
Thanks very much
Download EXAMPLE.mw
Hi, how to find the point where two lines intersect each other by using the command.
Help_point_of_intersection.mw
Hi, pls help me to write a loop for prime number....for n between 1 to 100
help_prime_number.mw
When I typ:
> phi; kappa;
It gives symbols φ and K.
I do not want this, I want the words phi and kappa.
How do I turn this off?
I understand it has something to do with SYMBOL or a Palette?
I see a Palette left named 'Greek' or 'Trigonometric & Hyperbolic' that have phi in them, but how do I delete a Palette (If that is how I stop these symbols)?
I'm not really good with the software, I just use it for some school work.
Thank you in advance for your help!
Hey
Is it possible to draw a slope field for a second order differential equation with initial conditions?
I am asking for your help, as I would like to know if it's possible to integrate a function using SI-units.
This is what I get when I try:
Copied directly:
with(Units[Standard]);
∫10 ⟦m⟧/(⟦s⟧^(2))ⅆ⟦s⟧
Error, invalid differential
                       /      (m)
Typesetting:-mambiguous|int10 ----Typesetting:-mambiguous(
                       |         2
                       \      (s)
  DifferentialD(s), Typesetting:-merror("invalid differential"))|
Why 3D .eps figures produced by Maple 2020 are often excessively large?
So, it´s a little heavy to the viewer and to compile to PDF.
  • How could we reduce the size without losing any quality?
Is the following function w
equal to next functions for a=1 or a= -1?
if a=1 then
w=
if a=-1 then
w=
where n>1, B,c and k are arbitrary constants.
a:=-1:
B:=0:
c:=2:
h:=1:
#assume(n>1):
n:=3:
assume(0<=x and x<h):
assume(0<=t and t<h):
a:=-1:
if is(a>0)=true then
omega:=(x,t)->((2*c*n/(a*(n+1)))*(sin ((x-c*t+B)*sqrt(a)*(n-1)/(2*n)))^2 )^(1/(n-1));
print(omega(x,t));
elif is(a<0)=true then
omega:=(x,t)->(-(2*c*n/(a*(n+1)))*sinh ((x-c*t+B)*sqrt(-a)*(n-1)/(2*n))^2 )^(1/(n-1));
print(omega(x,t));
end if:
plot3d(omega(x,t),x=0..1,t=0..1);
a:=-1:
n:=3:
c:=2:
r:=0:
k_1:=0:
k_2:=0:
h:=1:
n:=3:
if a=1 then
  omega:=(x,t)->piecewise(abs(x-c*t)<=2*n*(k_1-r)*Pi/(k_1*(n-1)),(sqrt(2*c*n/(n+1))*sin ((x-c*t)*(n-1)/(2*n)+r*Pi/k_1))^(2/(n-1)),0);
print(omega(x,t));
elif a=-1 then
  omega:=(x,t)->(sqrt(2*c*n/(n+1))*sinh ((x-c*t)*(n-1)/(2*n)+k_2))^(2/(n-1));
print(omega(x,t));
end if:
Hi I have a transfer function first or second order and I want to get it into standard form
Which the transfer function is
of H(s)/(W__I(s) so how height of a tank (H) is affected by incoming flow rate (W__i(s)) but I need to get this transfer function into standard 1st order form
Where I need to find what K and tau are to get it in to this form and tau is always in the units of time. How can I do this in maple? It's pretty impossible by hand I find. I've attached my workbook for it.
General_form.mw
I am doing some analyses of autonomous DEs (single equation and systems). Maple is able to easily produce 2d- and 3d-phase protraits for systems. However, I am struggling to produce 1d-phase portrait for autonomous first-order DEs. I would like to produce a single axis with some labels and decorations which include the following:
  1. All equilibrium/critical solutions of the DE.
  2. Arrows on the axis indicating if the non-equilibrium solutions are increasing or decreasing in a certain interval.
For example, for dy/dx = -y^2*(5*y-1)^2, would like to produce the plot in the attached file.
How might I achieve this?
1d-phase_portrait.pdf
helle to your all
as i can see there are functions to show steps of a calculation
such as ExpandSteps() and ShowSolution()
but would it not be possible to use these or some other function to show steps of the function called isolate()
it should be trivial since most online calculators are able to do this. and so does maple in the back - we just don't see the steps only the result
thanks regards mikkel
RootOfQuestion.mw
Hi Everyone, so i understand (to the best of my knowledge) the purpose of RootOf and I have worked with them before but now for some reason when i try to use allvalues to express the solution explicitly it does not express it, instead just keeps as RootOf expression.
I have attached the maple file I am working with.
I have also tried solve(expr, explicit) as well as convert(expr, radical) and still nothing.
Am I missing something small?
How to plot the phase portrait of the system of fractional DEs?
0< nu<1
Consider the infinite product
(1-qi)(1-qiz-1)(1-qi-1z)
For i > 0
How would I expand this into a power series in qz in Maple? Say I would like the coefficient of q6z2
Or how would I get the first n terms up to some order of qz?
First 444 445 446 447 448 449 450 Last Page 446 of 2434
