Why this error shows up when adding assuming?
expr:= ln(c^2*y/sqrt(c^2)+sqrt(c^2*y^2+1));
simplify(expr,size=true,evaluate_known_functions=false);
simplify(expr,size=true,evaluate_known_functions=false) assuming real;  #error
Is this to be expected?
Maple 2020.2
I got the plot of an ellipsis and a hyperbola using the following code:
plot([sqrt((1^2 - 0.5)*(1 - x^2/(2^2 - 0.5))), -sqrt((1^2 - 0.5)*(1 - x^2/(2^2 - 0.5))), sqrt((1^2 - 2.5)*(1 - x^2/(2^2 - 2.5))), -sqrt((1^2 - 2.5)*(1 - x^2/(2^2 - 2.5)))], x = -2 .. 2, scaling = constrained, color = [blue, blue, red, red])
How can I get the two vectors n1,n2 as shown in the following picture (the intersection point of the curves defines the beginning of the vectors)
DEAR SIR,
GOOD EVENING.
HOW TO FIND THE AREA BETWEEN THE CURVES  USING MAPLE?
I was trying to use the idea explained in this post (), using `densityplot` to create a barplot. But there are several difficultes specially using new Maple that has problem with exporting plots in pdf format the same as displayed inside Maple.
The example code:
zmin := 0;
zmax := 1;
verthuebar := plots:-densityplot(z, dummy = 0 .. 1, z = zmin .. zmax, grid = [2, 10], style = patchnogrid, size = [90, 260], colorscheme = [ColorTools[Color]([0, 0, 1]), ColorTools[Color]([1, 0, 0])], style = surface, axes = frame, labels = [``, ``], axis[1] = [tickmarks = []], axis[2] = [tickmarks = [aList[1] = "0   ", 0.5 = typeset(alpha*` `), 1 = "1    "]]);
Problems:
1- When I export the bar-plot as `.eps`, it shows white lines as a grid, while I don't want it and it is not the same way it is displayed at Maple!
test-1.pdf
I tried adding `gridlines=false` and other similar things, but had no effect. I changed `10` to `3` in `grid = [2, 10]`, but it increases the distance of 0 and 1 from the borderies and therefore wrong numbers will be read from the color bar. Exporting the picture as `.pdf` doesn't have that gridlines problem, but destroys the proportions of the image, so I want to stick on the `.eps` one, but without those white lines.
2- How can I have 0 and 1 exactly on the start and end of the color bar and with no distance from the edges? I can use `view=[0..1,0..1]` at the end of the above code, but depending on the number in the `grid=[2,n]` that I choose, the colors may not start and end exactly at the specified colors.
I think Maple's simplify could need much more improvement.
Here is another example, which I can't get Maple to simplify to zero for positive x, when it is clearly zero there
ode:=x = (diff(y(x),x)^2+1)^(1/2)*diff(y(x),x);
mysol:=y(x)=_C1+int(  sqrt(-2+2*sqrt(4*a^2+1))/2,a=0..x);
check:=odetest(mysol,ode);
The above is zero for x>0
But I tried every assumption or option on it, and it will not give zero.
simplify(check) assuming x>0;
simplify(check,symbolic);
simplify(check,symbolic,sqrt) assuming x>0;
simplify(check,sqrt) assuming x>0;
simplify(check,radical) assuming x>0;
simplify(check,power) assuming x>0;
etc...
Here it is in Mathematica
ClearAll[x];
check = x - (Sqrt[2 + 2 Sqrt[4 x^2 + 1]]) (Sqrt[-2 + 2 Sqrt[4 x^2 + 1]])/4;
Simplify[check, Assumptions -> x > 0]
Why Maple can't simplify this to zero?  Is there some other specific trick one must use each time?
Maple 2020.2 on windows 10
hi. i write this code with "for" loop. but i dont want to show comma sign in my print. how can i remove it
for example
thanks in advance
code
for i to 2 do
    for j to 2 do S[i, j] := 2*mu*varepsilon[i, j] - add((2*mu)/3*varepsilon[r, r]*delta[i, j], r = 1 .. 3); print("S"[i, j] = S[i, j]); end do;
HI everyone I have this excel spreedsheet ValeursB.xlsx and I know how to import Data in Maple. But What i don t know is how to tell to maple to use this data, to be able to make differents plots like you can see in the picture, i have shared. Your helps is very welcome.
The interval [0,T] is divided into n subintervals [i*h, (i + 1)*h], i = 0,1,2, . . . ,n -1, of equal lengths h where h=T/n.
The first (n + 1) hat functions   is defined as follows:
Question:
How to find g_ij ( the value of the following integral)
where
alpha>0,
0<=t<h.
In fact,
by using the Maple, I want to check whether it is equal to the following expression or not:
There is the following differential equation:
where l(t)=2+t,  g=10 and the goal is to find φ(t). I wrote the following code:
M := diff(phi(t), t);
M1 := diff(M, t);
g := 10;
M2 := diff(l(t), t);
ode := M1 + 2*M2*M/l(t) + g*sin(phi(t))/l(t) = 0;
ics := phi(0) = 1, D(phi)(0) = 1;
l := t -> 2 + t;
ode;
dsovle([ode, ics]);
But I don't get any result. How can I solve this differential equation?
A simple question:
Can I define a Vector using:
a) Initial Value (a), Final Value (b) and the number of elements (N) (assuming linear spacing)
For example: Starts at 1, finishes at 12 with 5 elements:
[ 1 , 3.75 , 6.5 , 9.25 , 12 ]
b) Initial Value (a), Final Value (b) and step (s)
For example: Starts at 2, finishes at 6 with a step of 0.5
[ 2 , 2.5 , 3 , 3.5 , 4 , 4.5 , 5 , 5.5 , 6]
but using only a,b and N ; or a,b and s directly?
I know this can be done using the seq command and some basic definitions:
In the first case:
Vector([ seq(a+(b-a)/N*i,i=0..N) ]); should do the trick
And the second case is even easier:
Vector([seq(i,i=2..6,0.5)]);
PS. I know for the second case that using any arbitrary step can result in loosing the final value "b" of the sequence because you won't step on b using that arbitrary step value.
As I said above. I just want to know if there is a direct way to define these cases.
Does Maple have a built in hash map (associative array) datatype. I need to write a program where I will be iteratively building a lookup table. It will be very convenient for me if Maple has a hash map map structure built in.
Is it possible to capture programatically the values of theta, phi and psi when you manually rotate a 3D plot?
PS: The target version is Maple 2020
sometimes I get equations where there is clearly more simplification on it. For an example
ode:=y(x)=diff(y(x),x)^3*y(x)^2+2*x*diff(y(x),x);
new_ode:=PDEtools:-dchange({y(x)=sqrt(u(x))},ode,{u});
Doing this by hand, I would now write the above as
by multiplying both sides by sqrt(u(x))
new_ode :=sqrt(u(x))*lhs(new_ode)=simplify(sqrt(u(x))*rhs(new_ode))
Since I am doing this in a program, without knowing what the expression is, I need to have this simplification done automatically, since I do not know before hand, if the resulting expression has this form or not. So I automatically call simplify on it.
I tried on a simpler example
expr:=sqrt(u)=1/sqrt(u)
And want to simplify this to u=1
I can't do
new_expr :=sqrt(u)*lhs(expr)=sqrt(u)*rhs(expr)
Since this is done in a program, without the benefit of looking first and then deciding what to do. Everything needs to be automated since the expression can be anything.
So I need a generic operation to apply and have Maple simplify it, if this pattern exist.  I tried many things, but do far nothing is working:
expr:=sqrt(u)=1/sqrt(u);
expand(expr);
expand(expr) assuming real;
combine(expr);
combine(expr,sqrt);
combine(expr,radical);
combine(expr,power);
expand(expr);
collect(expr,sqrt(u));
collect(lhs(expr)-rhs(expr)=0,sqrt(u));
simplify(lhs(expr)-rhs(expr)=0) assuming u<>0; # I expected this to work
simplify(expr) assuming real;
simplify(expr,size=false);
simplify(expr,sqrt) assuming real;
simplify(expr,sqrt) assuming positive;
simplify(expr,sqrt,symbolic) assuming positive;
simplify(expr,sqrt,symbolic,size=false) assuming positive;
simplify(expr,symbolic,size=false);
simplify(expr) assuming u<>0;
rationalize(expr);
no change.
Please do not give me an answer that requires one to use specific solution assuming one can see the expression. The solution needs to be something generic and work on any such expression that I can apply to any expression and have Maple simplify the sqrts on both sides, if they are there, since this is done in a program.
From the above, this should have worked
simplify(lhs(expr)-rhs(expr)=0,symbolic);
Using Mathematica
ClearAll[u];
expr = Sqrt[u] == 1/Sqrt[u]
Simplify[expr[[1]] - expr[[2]] == 0, Assumptions -> u != 0]
Any suggestions? I am sure there is a simple way to do this in Maple, I just have not found it yet.
Maple 2020.2
Why Maple can't simplify this expression to zero?
ode:=diff(y(x),x)-y(x) = x*y(x)^(1/2);
ic:=y(0)=4;
sol:=dsolve([ode, ic],y(x));
check:=odetest(sol,ode);
In Mathematica:
ClearAll[x]
check = -2*x + 4*x*Exp[x/2] - x^2 -x*Sqrt[x^2 - 8*x*Exp[x/2] + 4*x + 16*Exp[x] - 16*Exp[x/2] + 4]
note that using x>=0 instead of x>0 does not change the above output.
Any work around in Maple?
How to change the size of Text area box , i want to increase the box size
First 482 483 484 485 486 487 488 Last Page 484 of 2459
