I have been trying to figure out a good way to work with z-transform expressions which display keeping everything in terms of negative powers of z. I am not using the z-transform procedure, but writing the equations directly by hand.
For example, given an expression a*z^(-1), Maple will output this as a/z. This is even more dramatic when dealing with rational forms in z^(-1).
The issue here is that z^(-1) has an explicit meaning in terms of delay blocks and causality.
If anyone has a nice way for Maple to return these in a pretty-printed fashion retaining the z^(-1) terms, that would be great. I still need to be able to manipulate the expressions algebraically.
I think this is also wrong ode type given by ode advisor.   The following clearly can't be _dAlembert ode.
ode:=diff(y(x),x)*tan(diff(y(x),x))+ln(cos(diff(y(x),x))) = y(x);
It does not even have an explicit on its own, in the RHS. D'Alembert ode has the form
The ode above has the form   y=f(p)+g(p)  or one can argue the form y=F(p). Either way, there is no in the RHS.
For the first form above, f(p)=p*ln(p) and g(p)=ln(cos(p))
So why Maple says
DEtools:-odeadvisor(ode)
And Maple knows this. But for some reason, for the above ode, I think it made the wrong call.
ode:=y(x)=x*f(diff(y(x),x))+g(diff(y(x),x));
DEtools:-odeadvisor(ode);
ode:=y(x)=f(diff(y(x),x))+g(diff(y(x),x));   #no x
Is there something I am overlooking here?
Maple 2020.2 with Physics 908 on windows 10
I need to find and remove any abs that shows up only inside ln anywhere in an expression.
I used to do this in multiple steps before, by using loop and subs. But I am now learning evalindet which is powerful command. I should use it more.
I wanted to see if it is possible to do this in one call to evalindent. Both finding and replacing.
Here is an example. Given
expr:=sin(x)+ln(abs(x))+ln(x+abs(y)/sqrt(abs(x+3)))+ln(x^3)+cos(abs(x));
The goal is to change it to the following
This is what I ended up with
expr:=evalindets(expr,
          'specfunc( satisfies(u->has(u,abs)),  ln)',
          f->evalindets(f,'specfunc(anything,abs)',f->op(1,f))
My question is: Is there a more optimal or better way to do this? I had to use evalindets inside the transformer to remove the abs. At first I did not know if it will work, but it did work.
Any place for improvement?
Maple 2020.2
Knowing the realations between cartesian ans shperoidal coordinates (x,y,z and v,u,w respectively)
the goal is to take the following graph:
This graphic consists of three planes (One with v=const, let's say v=2, the other one with u=const, let's say u=π/4 and the last one with w=const let's say w=π/4), of three coordinate lines (line v with u=π/4 and w=π/4, line u with v=2 and w=π/4 and finally line w with v=2 and u=π/4). I wrote the following code but an error occurs...
with(LinearAlgebra);
F := <2*cosh(1)*cos(x), 2*sinh(1)*sin(x)*sin(t), 2*sinh(1)*sin(x)*cos(t)>;
S1 := plot3d(F, x = -Pi/2 .. Pi/2, t = 0 .. 2*Pi, color = "Green");
F, 1.5*Normalize(diff(F, x), 2);
eval(%, {t = Pi/4, x = Pi/4});
A1 := arrow(%, color = red);
V1 := textplot3d(<`+`(`%%`), v^`0`>, align = {'above', 'right'}, font = [Roman, bold, 14]);
F, 1.5*Normalize(diff(F, t), 2);
A2 := arrow(%, color = red);
V2 := textplot3d(<`+`(`%%`), u^`0`>, align = {'below'}, font = [Roman, bold, 14]);
G := <2*cosh(x)*cos(Pi/4), 2*sinh(x)*sin(Pi/4)*sin(t), 2*sinh(x)*sin(Pi/4)*cos(t)>;
S2 := plot3d(G, x = 0 .. 100, t = 0 .. 2*Pi, color = "Cyan");
G, 1.5*Normalize(diff(G, x), 2);
A3 := arrow(%, color = red);
V3 := textplot3d(<`+`(`%%`), w^`0`>, align = {'above', 'left'}, font = [Roman, bold, 14]);
display(S1, S2, A1, A2, A3, V1, V2, V3, scaling = constrained, axes = framed, labels = [x, y, z]);
Given an expression, I want to obtain list of all functions in it, that contains as argument, anywhere another function.
I can do this now using 2 steps. I was wondering if there is a way to do it in one call.
Here is an example.
expr:=sin(x)+ln(abs(x))+ln(x+1/sqrt(abs(x+3)))+ln(x^3);
The goal is to find all ln functions, with abs inside them. Now, I do this
lis:=indets(expr,'specfunc(anything,ln)');
select(Z->has(Z,abs),lis)
I could not find a way to do it in one call, If I do this
indets(expr,'specfunc(abs(anything),ln)');
it only finds
Which overlooked the other one, since abs there is elsewhere in side ln.
I looked at help Definition of a Structured Type in Maple but do not know yet if there is an option there to do this.
Is it possible to do this on one call?  Just wondering, that is all. The above works OK for me now.
Maple 2020.2
How I can edit and apply the following conditions to my plot functions
`######   I want to change q  (starting from 0.3) from 0.3 by .001 to 0.377 and plot 2D (u-q) ,(v,q), (u,v) and  plot3D (u,v,q)`
`######   I want to change q (starting from 0.37727) from 0.37727 by .001 to 0.390059 and h from 0.1 by .001 to 0.138462  and plot 2D (h-q)  and  plot3D (u,h,q),(v,h,q)`
I couldn't attach my file here, so I uploaded that here
https://drive.google.com/file/d/17purRxEdDqrTJeFDcF1-d9J7b3LkuJnF/view?usp=sharing
I just got a "new" graphics card, NVIDIA GT630, and was wondering whether the CUDA capabilities are accessible. But no luck:
CUDA:-Enable();
Error, (in CUDA:-Enable) CUDA not supported on the current system (see CUDA,supported_hardware for more information)
The CUDA help page with the example, when run, just shows a host of error messages.
I have OS X 10.11.6, the above mentioned GT630 card with claimed 384 CUDA cores and 2 GB of VRAM; NVIDIA WebDriver 346.03.15f16 for the card (i.e. latest for this OS) and NVIDIA CUDA driver 8.0.90 (again, latest for this OS as far as I can tell). My Maple is 2015.2. All this running on a MacPro 4,1.
I am not having great illusions about the performance I should get (this is not a state-of-the-art card today), but it seems to me this combination should be working with Maple 2015 and not throw an error, shouldn't it? Checking the system extensions: CUDA.kext is loaded and its dependencies are satisfied, so I don't see any problem there.
Am I missing something?
M.D.
We have the equation of the following plane in the three-dimension space :
with m1=10, m2=2, C=20 and r1 and r2 given by the following expressions:
with d1=0.6 and d2=0.4. How can we get in Maple the graph of this equation on the x0y plane (z=0) ?
I'm having an issue with Maple 2020.2 classic interface being *very* slow on a new MacBook pro with Big Sur. It takes about 1 second between each keystroke and it appearing on the screen.
Is this a known bug?
the problem is (FROBENIUS METHOD)
Determine the singular points and identify which of these points are regular points
x(x2-9)2 y'' + (x+3) y' +5y = 0
can anyone show me how to do it in maple?  thank you.
Hi. i have a nonlinear integral equation. any idea for solving it? tnx in advance
integral-equation.mw
with(Syrup);
ckt := "*\n\
V1 1 0 -10*exp(-2*t)\n\
R1 1 2 2\n\
R2 2 3 2\n\
C1 3 0 0.5F\n\
R3 2 4 4\n\
L1 4 3 1H\n\
.end";
volts,others:=Solve(ckt,'tran', 'returnall'):
How do I get an expression for diff(i1(t),t)?    I tried
eval(diff(i[R1](t),t), volts union others);
But, this looks very strange
diff(i2(t),t)?  I tried a similar expression, but, it is ver different than the one by OP.
How do I set the initial conditions?  I can use init=1, on L1 for i2(0)=1.  But, how about i1(0)=1?
I could not create a 50 X 17 matrix, part of a multiple linear regression exercise & received the message:
"error in (Matrix) too many patterns for typematch". This appears to be an undocumented message in the help page.
I was using the DirectSearch:-GlobalSearch function on a LaguerrelL for values of 4 and 5. At a value of 4 I get a solution, but at 5 I get an error message that the Kernel connection is lost. I ran this script on two different PCs using Maple 2019 and 2020 with WIN 10 and get the same results. Why does this happen?
Here is my worksheet. Thanks for looking.
mysearch2.mw
I am studying nonlinear differential equations, and came across an interesting one on maple's help page.  I made a post about this equation already, but I have decided to make a new post because the topic is slightly different than from the previous post.
The topic of this post is:
"Can numerical methods and exact, implicit techniques find false solutions?"
To make the discussion clearer, the rest of this post can be found in the maple file I created.
First 483 484 485 486 487 488 489 Last Page 485 of 2459
