i want to compute and draw  lattice points from a given lattice basis.
for example 2d cartesian coordinate system;
thank
How to display combinations without repetition of a set ( order does not matter)
CAP13Combinatoire.mw
My points are all numerical values. Why gives me such error?
Download temp.mw
I need to represent the contourplot of sum a function as
contourplot(sum(BesselJ(n,r),n=0..5),r=-10..10).
can anyone know what the problem is ?
Hello Maple experts;
We've talked about this subject before. odetest not verifying dsolve output. And very useful input was given:
https://www.mapleprimes.com/questions/227546-How-To-Make-Odetest-Verify-Dsolve
https://www.mapleprimes.com/questions/227638-How-To-Make-Odetest-Give-Zero-On-Its
Here, I thought to give a collection from my ode database of ode's that are solved by Maple, but odetest does not give zero, all in one place.
I know this is a hard problem to get odetest to always verify its own solution. May be each case needs custom solution?
It would be nice if this area in Maple could be improved on more if possible (Maple is already a CAS leader in solving ODE's).
If some of the experts here like to see if they can get odetest to give zero on some of these examples, they are welcome to and will be useful to see. I only tried just simplify().
I depend on odetest to tell me if my solution is correct or not, and getting false negative makes me spend more time trying to find where my error in my solution, where there might be no error there, and it is just that odetest could not verify it.
These are all from different text books. I put the reference on each ODE where it was obtained from.
Two of these ODE can also hang or take very long time. I indicated that there so one might want to skip these two.
edit added new one, #1822, uploaded new worksheet
`Standard Worksheet Interface, Maple 2020.2, Windows 10, November 11 2020 Build ID 1502365`
Physics:-Version()
`The "Physics Updates" version in the MapleCloud is 884 and is the same as the version installed in this computer, created 2020, November 25, 16:49 hours Pacific Time.`
#796
#Book: Elementary differential equations with boundary value problems. William F. Trench. Brooks/Cole 2001
#Section: Section 1.2 Page 14
#Problem number: 9.
ode:=diff(y(x),x) = abs(y(x))+1;
sol:=dsolve(ode,y(x));
odetest(sol[1],ode):
simplify(%);
diff(y(x), x) = abs(y(x))+1
y(x) = -exp(-x)/_C1+1, y(x) = exp(x)*_C1-1
(-abs((-exp(-x)+_C1)/_C1)*_C1+exp(-x)-_C1)/_C1
#878
#Section: Section 2.3 Page 55
#Problem number: 10.
ode:=diff(y(x),x) = x*(y(x)^2-1)^(2/3);
odetest(sol,ode):
simplify(%);
diff(y(x), x) = x*(y(x)^2-1)^(2/3)
(1/2)*x^2-(-signum(y(x)^2-1))^(2/3)*y(x)*hypergeom([1/2, 2/3], [3/2], y(x)^2)/signum(y(x)^2-1)^(2/3)+_C1 = 0
-x*(4*y(x)^2*(y(x)^2-1)^(2/3)*signum(y(x)^2-1)^(1/3)*hypergeom([3/2, 5/3], [5/2], y(x)^2)+9*(y(x)^2-1)^(2/3)*signum(y(x)^2-1)^(1/3)*hypergeom([1/2, 2/3], [3/2], y(x)^2)+9*(-signum(y(x)^2-1))^(1/3))
#903
#Section: Section 2.4 Page 57
#Problem number: 13.
ode:=diff(y(x),x)-y(x) = x*y(x)^(1/2);
ic:=y(0)=4;
sol:=dsolve([ode,ic],y(x));
odetest(sol,ode):
simplify(%);
diff(y(x), x)-y(x) = x*y(x)^(1/2)
y(0) = 4
y(x) = 16*(exp((1/2)*x))^2-8*x*exp((1/2)*x)+x^2-16*exp((1/2)*x)+4*x+4
-x*(((-8*x-16)*exp((1/2)*x)+x^2+4*x+16*exp(x)+4)^(1/2)-4*exp((1/2)*x)+x+2)
#1330
#Book: Differential equations and their applications, 3rd ed., M. Braun
#Section: Section 1.10. Page 80
#Problem number: 5.
ode:=diff(y(t),t) = 1+y(t)+y(t)^2*cos(t);
sol:=dsolve(ode,y(t)):
timelimit(60,odetest(sol,ode)); #WARNING, will either hang or take long time then timeout
diff(y(t), t) = 1+y(t)+y(t)^2*cos(t)
#1498
#Book: Differential Gleichungen, Kamke, 3rd ed
#Section: section 1.0
#Problem number: 25.
ode:=diff(y(x),x) = c*x^(-1+v)+b*x^(2*v)-a*y(x)^2;
sol:=dsolve(ode,y(x)):
odetest(sol,ode): #output too long to post
diff(y(x), x) = c*x^(-1+v)+b*x^(2*v)-a*y(x)^2
#1822
#Book: Advanced Mathematica, Book2, Perkin and Perkin, 1992
#Section: Chapter 11.3, page 316
ode:=x*y(x)*diff(y(x),x) = (y(x)^2-9)^(1/2);
ic:=y(exp(4)) = 5;
odetest(sol,[ode,ic]);
#needs:
odetest(sol,[ode,ic]) assuming x>1
x*y(x)*(diff(y(x), x)) = (y(x)^2-9)^(1/2)
y(exp(4)) = 5
y(x) = (9+ln(x)^2)^(1/2)
[-ln(x)*(csgn(ln(x))-1), 0]
[0, 0]
#1966
#Book: Differential equations for engineers by Wei-Chau XIE, Cambridge Press 2010
#Section: Chapter 2
#Problem number: 92.
ode:=2*x*diff(y(x),x)-y(x) = ln(diff(y(x),x));
simplify(%);
odetest(sol[2],ode);
simplify(%);
2*x*(diff(y(x), x))-y(x) = ln(diff(y(x), x))
y(x) = 1+(4*_C1*x+1)^(1/2)-ln((1/2)*(1+(4*_C1*x+1)^(1/2))/x), y(x) = 1-(4*_C1*x+1)^(1/2)-ln(-(1/2)*(-1+(4*_C1*x+1)^(1/2))/x)
-ln(2)+ln((1+(4*_C1*x+1)^(1/2))/x)-ln((2*x*_C1+(4*_C1*x+1)^(1/2)+1)/(x*(1+(4*_C1*x+1)^(1/2))))
-ln(2)+ln(-(-1+(4*_C1*x+1)^(1/2))/x)-ln((-2*x*_C1+(4*_C1*x+1)^(1/2)-1)/(x*(-1+(4*_C1*x+1)^(1/2))))
-ln(2)+ln((-(4*_C1*x+1)^(1/2)+1)/x)-ln((-2*x*_C1+(4*_C1*x+1)^(1/2)-1)/(x*(-1+(4*_C1*x+1)^(1/2))))
#2031
#Book: Ordinary differential equations and their solutions. By George Moseley Murphy. 1960
#Section: Various 3
#Problem number: 57.
ode:=diff(y(x),x) = a*x^(n-1)+b*x^(2*n)+c*y(x)^2;
odetest(sol,ode):
simplify(%)
diff(y(x), x) = a*x^(n-1)+b*x^(2*n)+c*y(x)^2
(1/2)*(-20*(I*a*c*(n+6/5)*b^(3/2)+(1/5)*b*a*(2*x^(n+1)*b+a)*c^(3/2)+(6/5)*(n+4/3)*(I*b^(5/2)*x^(n+1)*c-b^2*c^(1/2)*(n+1)))*(n+1)*WhittakerW(-(I*c^(1/2)*a+(-2*n-2)*b^(1/2))/(b^(1/2)*(2*n+2)), 1/(2*n+2), (2*I)*b^(1/2)*c^(1/2)*x^(n+1)/(n+1))+WhittakerW(-I*c^(1/2)*a/(b^(1/2)*(2*n+2)), 1/(2*n+2), (2*I)*b^(1/2)*c^(1/2)*x^(n+1)/(n+1))*(-(7*I)*a*c*(n^2+(16/7)*n+8/7)*b^(3/2)-5*a^2*b*(n+6/5)*c^(3/2)+3*b^2*(2+n)*(n+4/3)*n*c^(1/2)+I*c^2*a^3*b^(1/2)))*_C1/(c^(3/2)*b^(3/2)*(I*c^(1/2)*a+(-3*n-4)*b^(1/2))*x^2*(WhittakerW(-I*c^(1/2)*a/(b^(1/2)*(2*n+2)), 1/(2*n+2), (2*I)*b^(1/2)*c^(1/2)*x^(n+1)/(n+1))*_C1+WhittakerM(-I*c^(1/2)*a/(b^(1/2)*(2*n+2)), 1/(2*n+2), (2*I)*b^(1/2)*c^(1/2)*x^(n+1)/(n+1))))
#2372
#Section: Various 14
#Problem number: 407
ode:=diff(y(x),x)*(x^3+1)^(2/3)+(1+y(x)^3)^(2/3) = 0;
odetest(sol,ode):
simplify(%)
(diff(y(x), x))*(x^3+1)^(2/3)+(1+y(x)^3)^(2/3) = 0
-9*((4/9)*(1+y(x)^3)^(2/3)*Pi*3^(1/2)*LegendreP(-1/3, -1/3, (-y(x)^3+1)/(1+y(x)^3))*(-x^3)^(1/6)+(-(4/9)*(1+y(x)^3)^(1/3)*Pi*3^(1/2)*(x^3+1)^(1/3)*LegendreP(-1/3, -1/3, (-x^3+1)/(x^3+1))+GAMMA(2/3)*(-x^3)^(1/6)*((-y(x)^6-y(x)^3)*hypergeom([4/3, 5/3], [7/3], -y(x)^3)+x^3*(1+y(x)^3)^(1/3)*hypergeom([4/3, 5/3], [7/3], -x^3)*(x^3+1)^(2/3)))*(-y(x)^3)^(1/6))/((-x^3)^(1/6)*(9*hypergeom([4/3, 5/3], [7/3], -y(x)^3)*y(x)^3*(-y(x)^3)^(1/6)*(1+y(x)^3)^(1/3)*GAMMA(2/3)-4*Pi*3^(1/2)*LegendreP(-1/3, -1/3, (-y(x)^3+1)/(1+y(x)^3))))
#3035
#Section: Various 37
#Problem number: 1118.
ode:=(diff(y(x),x)^2+1)^(1/2)+a*diff(y(x),x) = x;
sol:=[dsolve(ode,y(x))]:
simplify(%);
odetest(sol[2],ode):
simplify(%)
((diff(y(x), x))^2+1)^(1/2)+a*(diff(y(x), x)) = x
((a^2+x^2-1)^(1/2)*(a^2-1)*((a^4+(x^2-1)*a^2+2*a*x*(a^2+x^2-1)^(1/2)+x^2)/(a^2-1)^2)^(1/2)+a^3+a*x^2+x*(a^2+x^2-1)^(1/2)-a)/((a^2+x^2-1)^(1/2)*(a^2-1))
-((-a^2+1)*(a^2+x^2-1)^(1/2)*((a^4+(x^2-1)*a^2-2*a*x*(a^2+x^2-1)^(1/2)+x^2)/(a^2-1)^2)^(1/2)+a^3+a*x^2-x*(a^2+x^2-1)^(1/2)-a)/((a^2+x^2-1)^(1/2)*(a^2-1))
#3036
#Problem number: 1119.
ode:=(diff(y(x),x)^2+1)^(1/2)+a*diff(y(x),x) = y(x);
sol:=[dsolve(ode,y(x))];
simplify(%);
simplify(%)
((diff(y(x), x))^2+1)^(1/2)+a*(diff(y(x), x)) = y(x)
[x-Intat(-(a-1)*(a+1)/(-a*_a+(_a^2+a^2-1)^(1/2)), _a = y(x))-_C1 = 0, x-Intat((a-1)*(a+1)/(a*_a+(_a^2+a^2-1)^(1/2)), _a = y(x))-_C1 = 0]
(((y(x)^2*a^2+a^4-2*y(x)*(y(x)^2+a^2-1)^(1/2)*a+y(x)^2-a^2)/(a^2-1)^2)^(1/2)*a^2-(y(x)^2+a^2-1)^(1/2)*a+y(x)-((y(x)^2*a^2+a^4-2*y(x)*(y(x)^2+a^2-1)^(1/2)*a+y(x)^2-a^2)/(a^2-1)^2)^(1/2))/(a^2-1)
(((y(x)^2*a^2+a^4+2*y(x)*(y(x)^2+a^2-1)^(1/2)*a+y(x)^2-a^2)/(a^2-1)^2)^(1/2)*a^2+(y(x)^2+a^2-1)^(1/2)*a-((y(x)^2*a^2+a^4+2*y(x)*(y(x)^2+a^2-1)^(1/2)*a+y(x)^2-a^2)/(a^2-1)^2)^(1/2)+y(x))/(a^2-1)
#3040
#Problem number: 1126.
ode:=a*x*(diff(y(x),x)^2+1)^(1/2)+x*diff(y(x),x)-y(x) = 0;
odetest(sol[1],ode): #too large to display
odetest(sol[2],ode): #too large to display
a*x*((diff(y(x), x))^2+1)^(1/2)+x*(diff(y(x), x))-y(x) = 0
[x-exp(arcsinh(((-a^2*x^2+x^2+y(x)^2)^(1/2)*a+y(x))/((a^2-1)*x))/a)*_C1/((-a^2*x^2+a^2*y(x)^2+2*(-a^2*x^2+x^2+y(x)^2)^(1/2)*a*y(x)+x^2+y(x)^2)/((a^2-1)^2*x^2))^(1/2) = 0, x-exp(-arcsinh(((-a^2*x^2+x^2+y(x)^2)^(1/2)*a-y(x))/((a^2-1)*x))/a)*_C1/(-(a^2*x^2-a^2*y(x)^2+2*(-a^2*x^2+x^2+y(x)^2)^(1/2)*a*y(x)-x^2-y(x)^2)/((a^2-1)^2*x^2))^(1/2) = 0]
#3054
#Problem number: 1146.
ode:=ln(diff(y(x),x))+4*x*diff(y(x),x)-2*y(x) = 0;
simplify(%);
simplify(%);
ln(diff(y(x), x))+4*x*(diff(y(x), x))-2*y(x) = 0
[y(x) = (1/2)*ln((1/4)*(-1+(16*_C1*x+1)^(1/2))/x)-1/2+(1/2)*(16*_C1*x+1)^(1/2), y(x) = (1/2)*ln(-(1/4)*(1+(16*_C1*x+1)^(1/2))/x)-1/2-(1/2)*(16*_C1*x+1)^(1/2)]
ln(2)+ln((8*x*_C1-(16*_C1*x+1)^(1/2)+1)/(x*(-1+(16*_C1*x+1)^(1/2))))-ln((-1+(16*_C1*x+1)^(1/2))/x)
ln(2)+ln((-8*x*_C1-(16*_C1*x+1)^(1/2)-1)/(x*(1+(16*_C1*x+1)^(1/2))))-ln((-1-(16*_C1*x+1)^(1/2))/x)
#3128
#Book: Differential Equations, By George Boole F.R.S. 1865
#Section: Chapter 7
#Problem number: 7.
ode:=y(x) = a*diff(y(x),x)+(diff(y(x),x)^2+1)^(1/2);
simplify(%);
simplify(%);
y(x) = a*(diff(y(x), x))+((diff(y(x), x))^2+1)^(1/2)
((y(x)^2+a^2-1)^(1/2)*a-y(x)-((y(x)^2*a^2+a^4-2*y(x)*(y(x)^2+a^2-1)^(1/2)*a+y(x)^2-a^2)/(a^2-1)^2)^(1/2)*(a^2-1))/(a^2-1)
(-(y(x)^2+a^2-1)^(1/2)*a-y(x)-((y(x)^2*a^2+a^4+2*y(x)*(y(x)^2+a^2-1)^(1/2)*a+y(x)^2-a^2)/(a^2-1)^2)^(1/2)*(a^2-1))/(a^2-1)
#3129
#Section: Chapter 7
#Problem number: 8.
ode:=x = a*diff(y(x),x)+(diff(y(x),x)^2+1)^(1/2);
simplify(%);
simplify(%);
x = a*(diff(y(x), x))+((diff(y(x), x))^2+1)^(1/2)
[y(x) = (1/2)*x*(a^2+x^2-1)^(1/2)/((a-1)*(a+1))+(1/2)*ln(x+(a^2+x^2-1)^(1/2))*a^2/((a-1)*(a+1))-(1/2)*ln(x+(a^2+x^2-1)^(1/2))/((a-1)*(a+1))+(1/2)*a*x^2/((a-1)*(a+1))+_C1, y(x) = -(1/2)*x*(a^2+x^2-1)^(1/2)/((a-1)*(a+1))-(1/2)*ln(x+(a^2+x^2-1)^(1/2))*a^2/((a-1)*(a+1))+(1/2)*ln(x+(a^2+x^2-1)^(1/2))/((a-1)*(a+1))+(1/2)*a*x^2/((a-1)*(a+1))+_C1]
-((a^2+x^2-1)^(1/2)*(a^2-1)*((2*a*x*(a^2+x^2-1)^(1/2)+a^4+(x^2-1)*a^2+x^2)/(a^2-1)^2)^(1/2)+a^3+a*x^2+x*(a^2+x^2-1)^(1/2)-a)/((a^2+x^2-1)^(1/2)*(a^2-1))
#3136
#Section: Chapter 7
#Problem number: 15
ode:=y(x) =x*diff(y(x),x)+a*x*(diff(y(x),x)^2+1)^(1/2);
simplify(%):# output too large
y(x) = x*(diff(y(x), x))+a*x*((diff(y(x), x))^2+1)^(1/2)
#3138
#Section: Chapter 7
#Problem number: 17
ode:=x+y(x)*diff(y(x),x) = a*(diff(y(x),x)^2+1)^(1/2);
odetest(sol[1],ode): #WARNING. hangs. try with timelimit
[y(x) = (a*(tan(RootOf(a^2*_Z^2*cos(2*_Z)+2*_C1*a*_Z*cos(2*_Z)+4*sin(_Z)*a*x*_Z-a^2*_Z^2+_C1^2*cos(2*_Z)+a^2*cos(2*_Z)+4*sin(_Z)*_C1*x-2*_C1*a*_Z-_C1^2+a^2-2*x^2))^2+1)^(1/2)-x)/tan(RootOf(a^2*_Z^2*cos(2*_Z)+2*_C1*a*_Z*cos(2*_Z)+4*sin(_Z)*a*x*_Z-a^2*_Z^2+_C1^2*cos(2*_Z)+a^2*cos(2*_Z)+4*sin(_Z)*_C1*x-2*_C1*a*_Z-_C1^2+a^2-2*x^2)), y(x) = (a*(tan(RootOf(a^2*_Z^2*cos(2*_Z)+2*_C1*a*_Z*cos(2*_Z)-4*sin(_Z)*a*x*_Z-a^2*_Z^2+_C1^2*cos(2*_Z)+a^2*cos(2*_Z)-4*sin(_Z)*_C1*x-2*_C1*a*_Z-_C1^2+a^2-2*x^2))^2+1)^(1/2)-x)/tan(RootOf(a^2*_Z^2*cos(2*_Z)+2*_C1*a*_Z*cos(2*_Z)-4*sin(_Z)*a*x*_Z-a^2*_Z^2+_C1^2*cos(2*_Z)+a^2*cos(2*_Z)-4*sin(_Z)*_C1*x-2*_C1*a*_Z-_C1^2+a^2-2*x^2))]
edit 12/23/2020
Found one more.
#3647
ode:=diff(y(x),x)=2*(x*sqrt(y(x))-1)*y(x);
ic:=y(0)=1;
sol:=dsolve([ode,ic]);
odetest(sol,ode);
The above becomes zero only for x>-1
ps. I added this to the worksheet, but since upload now does not work, did not re upload so not to lose the display above. Will do that later when it is working.
edit 12/25/2020
Found one more.
#3607
#Book: Fundamentals of Differential Equations. By Nagle, Saff and Snider. 9th edition. Boston. Pearson 2018.
#Section: Chapter 2, First order differential equations. Section 2.2 Exercises. page 46
#Problem number: 19.
ode:=1/2*diff(y(x),x) = (y(x)+1)^(1/2)*cos(x);
ic:=y(Pi)=0:
sol:=dsolve([ode,ic],y(x)):
res:=odetest(sol,ode);
edit 12/26/2020
Found one more
#3613
#Problem number: 26.
ode:=(x+1)*diff(y(x),x)+y(x)^(1/2) = 0;
ic:=y(0) = 1;
PDEtools:-Solve(res=0,x) assuming real;
edit 1/10/2021
Found one more
#2406
#Problem number: 406.
ode:=(x^3+1)^(2/3)*diff(y(x),x)+(y(x)^3+1)^(2/3) = 0;
check:=simplify(odetest(sol,ode));  #tried other simplication, can't get it to zero. But sol is correct
Download examples_of_odes_that_do_not_odetest.mw
Hello! I am trying to create a DEplot for some differential equations. I have used DEplot before and it works just fine and the direction field arrows appear however with this question it is not working. I have tried restarting my system, removing some options, and still am having issues. The interface version I am working with is "Standard Worksheet Interface, Maple 2020.1, Mac OS X, July 30 2020 Build ID 1482634".  Any help would be appreciated. Thank you!
Maple program for extended Euclidean algorithm for polynomials with rational coefficients
54*x^3-54*x^2+84*x-48
-12*x^3-28*x^2+72*x-32
I have problem that Maple is not evaluating integral (I need equation for distance for Lissajous curve):
with(Physics);
with(LinearAlgebra);
with(IntegrationTools);
x := A*sin(a*t + d);
y := B*sin(b*t);
u := diff(x, t);
u2 := diff(y, t);
u3 := sqrt(u^2 + u2^2);
u5 := int(u3, t);
I am only getting:
I tried to find the set of real parameters a1, a2, a3, a4 and u1, u2, u3 which make a subalgebra L an ideal of a finite real Lie algebra LieAlg. Unfortunately, the "Query" command with the "Ideal" argument returns an error message that I can't get around. What should I change in this command?
with(DifferentialGeometry):
with(LieAlgebras):
DGsetup([x1,x2,x3],R3):
Lie_Generators := [D_x1*x1+D_x2*x2+D_x3*x3, D_x3*k^2*x1+D_x1*x3, -D_x1*x2+D_x2*x1, D_x3*k^2*x2+D_x2*x3, D_x1, D_x2, D_x3]:
LieAlg:=LieAlgebraData(Lie_Generators):
DGsetup(LieAlg):
L:= evalDG([e3+u2*e5-u1*e6,e2-u3*e5-k^2*u1*e7,e4-u3*e6-k^2*u2*e7,e1-u1*e5-u2*e6-u3*e7]);
Sub_Alg_L:=LieAlgebraData(L);
TrueFalse,Equations,Solutions,IdealList:=Query(L,{u1,u2,u3},"Ideal");
TrueFalse,Equations,Solutions,IdealList:=Query([DGzip([a1,a2,a3,a4], L, "plus")],{a1,a2,a3,a4,u1,u2,u3},"Ideal");
Thanks for your help.
Jaqr
I would like to solve a fourth order PDEs, using fourier transform.
How can I apply fourier transform to get solution of my problem
Fourier_transform.mw
Let's suppose
f := piecewise(x < 1, x, -x)
Using
discont(f, x)
says me x=1 is a discontinuity point.
But can I obtain that f is continuous over  these two intervals?
(-infinity, 1)
[1, +infinity)
PS: I'm sure I've seen this type of question here before, but I couldn't find them.
lign1 := S*`union`(T intersect R);
                 lign1 := S (`intersect`(R, T))
lign2 := (S union T) intersect (S union R);
       lign2 := `intersect`(`union`(R, S), `union`(S, T))
verify({lign1}, {lign2});
My textbook says the expression lign1 and lign2 should be the same, but it outputs false. I suspect it's because Maple is ignoring the parenthesis in the first expression.
I m Stucked with this step
restart; with(plots)
eq1 := 2*n*4^n*eta^((n+1)*(1/2))*(diff(f(eta), `$`(eta, 2)))^(n-1)*(diff(f(eta), `$`(eta, 3)))+4^n*(n+1)*eta^((n-1)*(1/2))*(diff(f(eta), `$`(eta, 2)))^n+4*f(eta)*(diff(f(eta), `$`(eta, 2)))-4*m*(diff(f(eta), eta))^2+m-2*M*(diff(f(eta), eta)) = 0;
2*n*4^n*eta^((1/2)*n+1/2)*(diff(diff(f(eta), eta), eta))^(n-1)*(diff(diff(diff(f(eta), eta), eta), eta))+4^n*(n+1)*eta^((1/2)*n-1/2)*(diff(diff(f(eta), eta), eta))^n+4*f(eta)*(diff(diff(f(eta), eta), eta))-4*m*(diff(f(eta), eta))^2+m-2*M*(diff(f(eta), eta)) = 0
eq2 := 2*eta*(diff(theta(eta), `$`(eta, 2)))+2*(diff(theta(eta), eta))+Pr*(f(eta)*(diff(theta(eta), eta))-s*(diff(f(eta), eta))*theta(eta))+Nb*(diff(theta(eta), eta))*(diff(phi(eta), eta))+Nt*(diff(theta(eta), `$`(eta, 2)))^2 = 0;
2*eta*(diff(diff(theta(eta), eta), eta))+2*(diff(theta(eta), eta))+Pr*(f(eta)*(diff(theta(eta), eta))-s*(diff(f(eta), eta))*theta(eta))+Nb*(diff(theta(eta), eta))*(diff(phi(eta), eta))+Nt*(diff(diff(theta(eta), eta), eta))^2 = 0
eq3 := 2*eta*(diff(phi(eta), `$`(eta, 2)))+2*(diff(phi(eta), eta))+Sc*(f(eta)*(diff(phi(eta), eta))-s*(diff(f(eta), eta))*phi(eta))+Nb*(2*eta*(diff(theta(eta), `$`(eta, 2)))+2*(diff(theta(eta), eta)))/Nt = 0;
2*eta*(diff(diff(phi(eta), eta), eta))+2*(diff(phi(eta), eta))+Sc*(f(eta)*(diff(phi(eta), eta))-s*(diff(f(eta), eta))*phi(eta))+Nb*(2*eta*(diff(diff(theta(eta), eta), eta))+2*(diff(theta(eta), eta)))/Nt = 0
eq4 := 2*eta*(diff(chi(eta), `$`(eta, 2)))+2*(diff(chi(eta), eta))+Lb*(f(eta)*(diff(chi(eta), eta))-s*(diff(f(eta), eta))*chi(eta))-Pe*(2*eta*chi(eta)*(diff(phi(eta), `$`(eta, 2)))+2*chi(eta)*(diff(phi(eta), eta))+2*eta*(diff(chi(eta), `$`(eta, 2)))*(diff(phi(eta), `$`(eta, 2)))) = 0;
2*eta*(diff(diff(chi(eta), eta), eta))+2*(diff(chi(eta), eta))+Lb*(f(eta)*(diff(chi(eta), eta))-s*(diff(f(eta), eta))*chi(eta))-Pe*(2*eta*chi(eta)*(diff(diff(phi(eta), eta), eta))+2*chi(eta)*(diff(phi(eta), eta))+2*eta*(diff(diff(chi(eta), eta), eta))*(diff(diff(phi(eta), eta), eta))) = 0
bcs := (D(f))(a) = 0, f(a) = 2*s*a*(D(phi))(a)/Sc, theta(a) = 1, phi(a) = 1, chi(a) = 1, (D(f))(10) = 1/2, theta(10) = 0, phi(10) = 0, chi(10) = 0;
params := {Lb = .1, M = .1, Nb = .6, Nt = .2, Pe = 5, Pr = 6.2, Sc = .1, a = 0.1e-1, m = 1/3, n = 1, s = .1};
sol := dsolve(eval([eq1, eq2, eq3, eq4, bcs], params), numeric, output = listprocedure, maxmesh = 1024)
odeplot(sol, [[eta, f(eta)][eta, phi(eta)], [eta, theta(eta)], [eta, chi(eta)]], eta = eval(c, params) .. 10)
Download Pblm2.mw
Hello. I want to solve a 2X2 system using Maple. I have written this code but I do not get expected results.
with(DEtools);
with(plottools);
with(Algebraic);
F := -1 - y - exp(x);
G := x^2 + y*(exp(x) - 1);
sol1 := eliminate({F, G}, {x, y});
sol1 := [{x = RootOf(-exp(_Z)^2 + _Z^2 + 1), y = -exp(RootOf(-exp(_Z)^2 + _Z^2 + 1)) - 1}, {}]
But, the solutions are x=0 and y=-2 (I have solved the system by hand).
Any help?!
Hi,how to separate the letters with commas, to put them in a set like { a,b,c,d} instead of {abcd} ?
 CAP13CombinatoireQuestion.mw?
First 503 504 505 506 507 508 509 Last Page 505 of 2459
