Let S(N) the set of all N by N matrices defined this way:
  • each element of a matrix M in S(N) is an integer number between 1 and included N^2
  • all the elements of M are different
For instance the matrix M = < <1, 2>|<3, 4> > belongs to S(2).
I'm interesting in finding the number of singular matrices of S(N), and more reasonnably of S(N <=3).
It's easy to verify that no matrix in S(2) is singular.
For S(3) now: as S(3) contains only 9! = 362880 elements a brute force approach can still be used. It showed that 2736 matrices were singular (about 0.75%).
But I wonderded if a more elegant approach could be used?
In the attached file I wrote all the relations elements of S(2) (and next S(3)) must verify and solved these equations for integer solutions (I only accounted for singular matrices . The case S(2) is tractable, but not S(3) (at least on my computer).
So my question: do you have any idea of some method to tackle this problem, or are you aware of any theoritical results about this issue?
PS: of course a statistical approach in which elements of S(N) would be generated using random permutations of [$1..N^2] is still possible to get a crude approximation of the number of singular matrices, but I'm not interested in this kind of approach.
alias(det = LinearAlgebra[Determinant])
det
Brute Force
S    := 0:
p    := 3:
PERM := combinat:-permute(p^2):
for perm in PERM do
  M := Matrix(p, p, perm):
  if det(M)=0 then S := S+1; end if:
S;
evalf(S/9!);
2736
0.7539682540e-2
A non systematic approach
Case of S(2)
M := Matrix(2, 2, symbol=m):
iM := {indices(M)}:
# set of all relations that define the elements of S(2)
rels :=
    det(M) = 0,
    # each term is equal to an integer between 1 and 4 included
    mul((M[1, 1]-k), k=1..4)=0,
    mul((M[1, 2]-k), k=1..4)=0,
    mul((M[2, 1]-k), k=1..4)=0,
    mul((M[2, 2]-k), k=1..4)=0,
    # the sum of all the terms is equal to 10
    # M[1, 1]+M[1, 2]+M[2, 1]+M[2, 2]=10,
    # all the terms are different
    seq( mul(seq((M[op(im)]-M[op(ij)]), ij in iM minus {im})) <> 0, im in iM)
{(m[1, 1]-1)*(m[1, 1]-2)*(m[1, 1]-3)*(m[1, 1]-4) = 0, (m[1, 2]-1)*(m[1, 2]-2)*(m[1, 2]-3)*(m[1, 2]-4) = 0, (m[2, 1]-1)*(m[2, 1]-2)*(m[2, 1]-3)*(m[2, 1]-4) = 0, (m[2, 2]-1)*(m[2, 2]-2)*(m[2, 2]-3)*(m[2, 2]-4) = 0, m[1, 1]*m[2, 2]-m[1, 2]*m[2, 1] = 0, (m[1, 1]-m[1, 2])*(m[1, 1]-m[2, 1])*(m[1, 1]-m[2, 2]) <> 0, (m[1, 2]-m[1, 1])*(m[1, 2]-m[2, 1])*(m[1, 2]-m[2, 2]) <> 0, (m[2, 1]-m[1, 1])*(m[2, 1]-m[1, 2])*(m[2, 1]-m[2, 2]) <> 0, (m[2, 2]-m[1, 1])*(m[2, 2]-m[1, 2])*(m[2, 2]-m[2, 1]) <> 0}
isolve(rels);  # no solution founds
Case of S(3)
M := Matrix(3, 3, symbol=m):
iM := {indices(M)}:
rels :=
    det(M) = 0,
    # each term is equal to an integer between 1 and 9 included
    mul((M[1, 1]-k), k=1..9)=0,
    mul((M[1, 2]-k), k=1..9)=0,
    mul((M[1, 3]-k), k=1..9)=0,
    mul((M[2, 1]-k), k=1..9)=0,
    mul((M[2, 2]-k), k=1..9)=0,
    mul((M[2, 3]-k), k=1..9)=0,
    mul((M[3, 1]-k), k=1..9)=0,
    mul((M[3, 2]-k), k=1..9)=0,
    mul((M[3, 3]-k), k=1..9)=0,
    # the sum of all the terms is equal to 10*9/2 = 45
    M[1, 1]+M[1, 2]+M[1, 3]+M[2, 1]+M[2, 2]+M[2, 3]+M[3, 1]+M[3, 2]+M[3, 3]=45,
numelems(rels);
20
run_this := false:
if run_this then
  isolve(rels);  # requires a huge amount of memory and computational time
Download HowManyMatricesAreSingular.mw
Is there a pallette that contains the symbol for a contour integral both clockwise and anticlockwise?
doubt5.mw
Hi I want to run the following algorithm in code edit region:
for m in set_m do
    for n in set_n do
      solve for N solving ODE11 and ODE12 simultaneously
      solve for t_2 solving ODE11 and ODE12 simultaneouly
      find t__3 and t__4
      if (N<=t_4 and M>=t_3) then
        d1= TCS__1 using n,m,t__2 and N
          if (d1< d2)
            d2=d1
            print(d2,m,n,N,t_2)
    end do
end do
But I am struck for to how to extract N and t__2 from SOL1 in code edit region
SOL1 := fsolve({ODE11, ODE12}, {N, t__2});
How do I convert the expression
y = (sqrt(x) + 10)^(1/3) - (sqrt(x) - 10)^(1/3);
into
y^3 = 20 - 3*(x - 100)^(2/3);
A post on the Maxima mailing list said this was done by cubing both sides.  I can not seem to be able to get there.  A suggestion that the process involved recognizing the product (a+b)*(a-b)
Could you help me plesase, I have a matrix like this:
And I want to get determinant of this matrix as function f(w1,w2) but when I use Determinant I always get something like this:
doubt4.mw
Hi, As shown in the figure(red color). I am not able to understand why Exp(0) is not showing as 1. As evaluating rules of maple says that it evaluates everything till it gets unassigned variables.
Do I am doing something wrong? There is a link to the file.
Dear friends, please I would like to ask for your help with the following problem:
I have a remember table generated by a recursive procedure
x:= proc(n)
option remember;
It helps compute x(1), x(2), x(3), x(4).
After several additional steps I have a new x(2), say
x(2):= 3;
With this new x(2) I need to recompute x(3), x(4). I've tried
forget( x, [ x(3), x(4) ], subfunctions = false );
x(3);
x(4);
However, I do not get the new values of x(3) and x(4) but the old ones. What could it be wrong?
Many thanks for your help.
I have a matrix and all elements has two indexes. For example 3x3 case:
1,1 1,2 1,3
2,1 2,2 2,3
3,1 3,2 3,3
So if I want to travers this matrix in zig-zag way and fill it with increasing numbers I will get this matrix:
1 2 6
3 5 7
4 8 9
From 1 to 2,3 and 4,5,6 ...
We have 9 elemets in this order:
1 - (1,1); 2 - (1,2); 3 - (2,1); 4 - (3,1); 5 - (2,2); 6 - (1,3); 7 - (2,3); 8 - (3,2); 9 - (3,3).
The question is - do we have a way to convert two indexes in one digit like (3,1) -> 4 or (2,3) -> 7
Could you help me please if there is a way to convert to
I am not able to get the proper integration results
Question_integration_eqn18.mw
Dm(A, p, i(t)) := A^gamma*(a-b*p+c*i(t))
Lsc := cl*(int(Dm(A, p, i(t))*(1-1/(1+delta(T-t))), t = t2 .. T))
cl*(int(A^gamma*(a-b*p+c*i(t))*(1-1/(1+delta(T-t))), t = t2 .. T))
simplify(Lsc)
cl*A^gamma*(int((a-b*p+c*i(t))*delta(T-t)/(1+delta(T-t)), t = t2 .. T))
subs(i(t) = (A^gamma*(-b*p+a)*ln(1+delta*(T-t))-R*delta)/delta, Lsc)
cl*(int(A^gamma*(a-b*p+c*(A^gamma*(-b*p+a)*ln(1+delta*(T-t))-R*delta)/delta)*(1-1/(1+delta(T-t))), t = t2 .. T))
simplify(%)
cl*(int(-(-A^(2*gamma)*c*(-b*p+a)*ln(1+delta*(T-t))+A^gamma*delta*(R*c+b*p-a))*delta(T-t)/(1+delta(T-t)), t = t2 .. T))/delta
Download Question_integration_eqn18.mw
So, here again, I'm still having this problem with Maple 2020 on Machbook OS 10.13.6 (all updates have been performed): Maple 2020 does not start. I see an icon appearing in the dock but it then disappears soon without showing anything like splash something. I reinstalled and restarted the copmuter several times, reactivated the software several times (always successful), and still I'm having the problem. I installed java and then it worked for one time, but after that the same problem happens and I'm still having this issue.
I went through steps suggestged in the help and arrived at JAVA reisntallation. What else can I try?
Please help me. Thanks.
Hiro
Suddently Maple 2020 (on Macbook) stops launching... I reinstalled it and restarted a couple of times.
Can someone give me some clues about what is causing this problem.
I really need it right now...
Hiro
doubt_3.mw
Hi, I am trying to do a simple think like
od2 := diff(x^3, x)+v+2 = 0
od3 := diff(v^2, v)+x+4 = 0
solve({(1),(2)},{x,v})
but with my code,  I am doing the exact same but getting the following error
Error, invalid input: solve expects its 1st argument, eqs, to be of type {`and`, `not`, `or`, algebraic, relation(algebraic), ({list, set})({`and`, `not`, `or`, algebraic, relation(algebraic)})}, but received {[1316.872428*(-0.1500000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)+3.000000*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))-0.2250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))+0.2304687500e-6*t__2^3*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)^3*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))-0.3662109374e-8*t__2^4*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)^4*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))+0.5320312500e-4*t__2^2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)^2*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))-3.000000)*exp(-0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))*(int(.2*(.1*t+1)*i__m2(t), t = 0 .. t__2))/N^.98-11.76000000/(N^.98*((1/12)*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)+t__2))+1185.185185*(-0.1953125000e-5*t__2^3*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)^3*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))+0.4898437500e-3*t__2^2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)^2*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))-0.7500000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))+6.0000*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))-6.0000)*exp(-0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))/(N^.98*((1/12)*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)+t__2))+6.00*(-75.50000000*N^2.02+45.45000000*N^1.02+306.00*N^0.2e-1)/((1/12)*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)+t__2)-1.200000000/((1/12)*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)+t__2)-9.6*(-75.37500000*N^3.02+45.30000000*N^2.02+303.00*N^1.02)/((1/12)*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)+t__2)] = 0, [-650*(0.3750000000e-2*t__2^2+0.7500000000e-1*t__2-0.4166666667e-1*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+3/2+(1/12)*t__2*(0.900e-1*t__2+.90))/((1/12)*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)+t__2)^2+65843.62140*N^0.2e-1*(-0.6750000000e-3*t__2^2-0.1350000000e-1*t__2+0.7500000000e-2*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`-0.9000000000e-1-0.1500000000e-1*t__2*(0.900e-1*t__2+.90)+3.000000*(0.5625000000e-3*t__2^2+0.1125000000e-1*t__2-0.6250000000e-2*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+0.7500000000e-1+0.1250000000e-1*t__2*(0.900e-1*t__2+.90))*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))-0.2250000000e-1*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))-0.2250000000e-1*t__2*(0.900e-1*t__2+.90)*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))-0.2250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)*(0.5625000000e-3*t__2^2+0.1125000000e-1*t__2-0.6250000000e-2*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+0.7500000000e-1+0.1250000000e-1*t__2*(0.900e-1*t__2+.90))*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))+0.6914062500e-6*t__2^2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)^3*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))+0.6914062500e-6*t__2^3*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)^2*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))*(0.900e-1*t__2+.90)+0.2304687500e-6*t__2^3*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)^3*(0.5625000000e-3*t__2^2+0.1125000000e-1*t__2-0.6250000000e-2*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+0.7500000000e-1+0.1250000000e-1*t__2*(0.900e-1*t__2+.90))*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))-0.1464843750e-7*t__2^3*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)^4*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))-0.1464843750e-7*t__2^4*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)^3*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))*(0.900e-1*t__2+.90)-0.3662109374e-8*t__2^4*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)^4*(0.5625000000e-3*t__2^2+0.1125000000e-1*t__2-0.6250000000e-2*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+0.7500000000e-1+0.1250000000e-1*t__2*(0.900e-1*t__2+.90))*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))+0.1064062500e-3*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)^2*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))+0.1064062500e-3*t__2^2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))*(0.900e-1*t__2+.90)+0.5320312500e-4*t__2^2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)^2*(0.5625000000e-3*t__2^2+0.1125000000e-1*t__2-0.6250000000e-2*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+0.7500000000e-1+0.1250000000e-1*t__2*(0.900e-1*t__2+.90))*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)))*exp(-0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))*(int(.2*(.1*t+1)*i__m2(t), t = 0 .. t__2))+65843.62140*N^0.2e-1*(-0.1500000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)+3.000000*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))-0.2250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))+0.2304687500e-6*t__2^3*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)^3*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))-0.3662109374e-8*t__2^4*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)^4*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))+0.5320312500e-4*t__2^2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)^2*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))-3.000000)*(-0.5625000000e-3*t__2^2-0.1125000000e-1*t__2+0.6250000000e-2*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`-0.7500000000e-1-0.1250000000e-1*t__2*(0.900e-1*t__2+.90))*exp(-0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))*(int(.2*(.1*t+1)*i__m2(t), t = 0 .. t__2))+13168.72428*N^0.2e-1*(-0.1500000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)+3.000000*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))-0.2250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))+0.2304687500e-6*t__2^3*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)^3*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))-0.3662109374e-8*t__2^4*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)^4*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))+0.5320312500e-4*t__2^2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)^2*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))-3.000000)*exp(-0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))*(.1*t__2+1)*i__m2(t__2)+588.0000000*N^0.2e-1*(0.3750000000e-2*t__2^2+0.7500000000e-1*t__2-0.4166666667e-1*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+3/2+(1/12)*t__2*(0.900e-1*t__2+.90))/((1/12)*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)+t__2)^2+.60*(98765.43210*N^0.2e-1*(-0.5859375000e-5*t__2^2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)^3*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))-0.5859375000e-5*t__2^3*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)^2*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))*(0.900e-1*t__2+.90)-0.1953125000e-5*t__2^3*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)^3*(0.5625000000e-3*t__2^2+0.1125000000e-1*t__2-0.6250000000e-2*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+0.7500000000e-1+0.1250000000e-1*t__2*(0.900e-1*t__2+.90))*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))+0.9796875000e-3*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)^2*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))+0.9796875000e-3*t__2^2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))*(0.900e-1*t__2+.90)+0.4898437500e-3*t__2^2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)^2*(0.5625000000e-3*t__2^2+0.1125000000e-1*t__2-0.6250000000e-2*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+0.7500000000e-1+0.1250000000e-1*t__2*(0.900e-1*t__2+.90))*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))-0.7500000000e-1*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))-0.7500000000e-1*t__2*(0.900e-1*t__2+.90)*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))-0.7500000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)*(0.5625000000e-3*t__2^2+0.1125000000e-1*t__2-0.6250000000e-2*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+0.7500000000e-1+0.1250000000e-1*t__2*(0.900e-1*t__2+.90))*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))+6.0000*(0.5625000000e-3*t__2^2+0.1125000000e-1*t__2-0.6250000000e-2*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+0.7500000000e-1+0.1250000000e-1*t__2*(0.900e-1*t__2+.90))*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)))*exp(-0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))+98765.43210*N^0.2e-1*(-0.1953125000e-5*t__2^3*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)^3*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))+0.4898437500e-3*t__2^2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)^2*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))-0.7500000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))+6.0000*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))-6.0000)*(-0.5625000000e-3*t__2^2-0.1125000000e-1*t__2+0.6250000000e-2*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`-0.7500000000e-1-0.1250000000e-1*t__2*(0.900e-1*t__2+.90))*exp(-0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))+i__m2(t__2))/((1/12)*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)+t__2)-.60*(98765.43210*N^0.2e-1*(-0.1953125000e-5*t__2^3*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)^3*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))+0.4898437500e-3*t__2^2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)^2*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))-0.7500000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))+6.0000*exp(0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))-6.0000)*exp(-0.1250000000e-1*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6))+int(i__m2(t), t = 0 .. t__2))*(0.3750000000e-2*t__2^2+0.7500000000e-1*t__2-0.4166666667e-1*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+3/2+(1/12)*t__2*(0.900e-1*t__2+.90))/((1/12)*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)+t__2)^2-(0.1500000000e-2*T^2+0.3000000000e-1*T)*(0.3750000000e-2*t__2^2+0.7500000000e-1*t__2-0.4166666667e-1*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+3/2+(1/12)*t__2*(0.900e-1*t__2+.90))/((1/12)*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)+t__2)^2-6.00*(-25.00000000*N^3.02+22.50000000*N^2.02+300*N^1.02)*(0.3750000000e-2*t__2^2+0.7500000000e-1*t__2-0.4166666667e-1*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+3/2+(1/12)*t__2*(0.900e-1*t__2+.90))/((1/12)*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)+t__2)^2-.1700000000*T*(0.3750000000e-2*t__2^2+0.7500000000e-1*t__2-0.4166666667e-1*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+3/2+(1/12)*t__2*(0.900e-1*t__2+.90))/((1/12)*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)+t__2)^2-2.4*(.1000000000*T-.2000000000)*(0.3750000000e-2*t__2^2+0.7500000000e-1*t__2-0.4166666667e-1*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+3/2+(1/12)*t__2*(0.900e-1*t__2+.90))/((1/12)*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)+t__2)^2-4*(0.1562500000e-3*T^2+0.1250000000e-1*T)*(0.3750000000e-2*t__2^2+0.7500000000e-1*t__2-0.4166666667e-1*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+3/2+(1/12)*t__2*(0.900e-1*t__2+.90))/((1/12)*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)+t__2)^2-12.0*(0.2500000000e-1*T-.1000000000*N)*(0.3750000000e-2*t__2^2+0.7500000000e-1*t__2-0.4166666667e-1*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+3/2+(1/12)*t__2*(0.900e-1*t__2+.90))/((1/12)*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)+t__2)^2+9.6*(-18.75000000*N^4.02+15.00000000*N^3.02+150*N^2.02)*(0.3750000000e-2*t__2^2+0.7500000000e-1*t__2-0.4166666667e-1*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+3/2+(1/12)*t__2*(0.900e-1*t__2+.90))/((1/12)*t__2*(0.450e-1*t__2^2+.90*t__2-.50*`#msup(msub(mi("\`t"),mi("2\`")),mn("2"))`+6)+t__2)^2] = 0}
Please help
Unfortunately,  Optimization:-Maximize command in following example returns a not precise result (I use Maple 2020).
s1:= Optimization:-Maximize((x-2*y)/(5*x^2-2*x*y+2*y^2), {2*x^2 - y^2 + x*y=1})
Maple is running the following results:
I read help of  Maximize, It seems to be using only numerical methods .
The Minimize and Maximize commands use various methods implemented in a built-in library provided by the Numerical Algorithms Group (NAG).
Can't Maple find a symbolic solution for extreme values under such constrained inequality or equality conditions?
Ps:
For the correct  symbolic  solution, we can try to  use Mathematica 12.
Maximize[{(x - 2*y)/(5*x^2 - 2*x*y + 2*y^2),
  2*x^2 - y^2 + x*y == 1}, {x, y}]
  We can compare numerical sizes of Optimal solution between maple and mathematica.
Digits:=20;
sqrt(2.)/4.
Another Problem:
If I accept numerical solutions of maple ,how do I estimate errors without knowing the exact solution ?
I am trying to compute the rank of the Commutator Matrix of a Lie algebra. That is, I wish to construct a matrix version of the multiplication table for a given matrix Lie algebra, and then compute the rank of this matrix.
Download CommutatorExample.mw
with(DifferentialGeometry); with(LieAlgebras)
M := [Matrix([[1, 0], [0, 0]]), Matrix([[0, 0], [0, 1]]), Matrix([[0, 1], [0, 0]])]
[Matrix(%id = 18446744078224010646), Matrix(%id = 18446744078224010766), Matrix(%id = 18446744078224003190)]
L := LieAlgebraData(M, Alg1)
_DG([["LieAlgebra", Alg1, [3, table( [ ] )]], [[[1, 3, 3], 1], [[2, 3, 3], -1]]])
DGsetup(L)
`Lie algebra: Alg1`
T := MultiplicationTable("LieTable")
Matrix(%id = 18446744078223968366)
I have the above, but I run into two issues:
1. It doesn't have matrix format, so Rank is undefined (I have tried convert(T,matrix) to no avail),
2. I need to be able to remove the first and second rows and columns from T (because these rows/columns are occupied by the Lie algebra's basis elements, and separating lines, respectively).
I believe that if I can convert T into a matrix somehow, I can simply use SubMatrix to remove the things I don't want, and then Rank should work.
Any help would be greatly appreciated!
P.S. Thanks to dharr1338 for the suggestion of including the worksheet, I'm very new to Maple and MaplePrimes, so I appreciate the patience.
Hi, I am working on a bification diagram and was wondering if there is a way to plot the stable and unstable curves onto one figure.
I have two curves, if the eq1<eq2 I would like to indicate when this happens, with a dashed line.
When eq1>eq3 I would like to indicate this with a soild line.
implicitplot, x[m] vs x[u] with axis[2]=[mode=log]
r:=0.927: K:=1.8182*10^8:d[v]:=0.0038:d[u]:=2: delta:=1: p[m]:=2.5: M:=10^4: p[e]:=0.4: d[e]:=0.1: d[t]:=5*10^(-9): omega:=2.042: b:=1000: h[e]:=1000:h[u]:=1:h[v]:=10^4:
eq1 := r*d[t]*h[e]*x[u]^3+(r*h[e]*(-K*d[t]+d[t]*h[v]+d[e])+r*p[e]*x[m])*x[u]^2+(r*h[e]*(-K*d[t]*h[v]-K*d[e]+d[e]*h[v])+K*p[e]*(d[u]-r)*x[m])*x[u]-r*K*h[e]*d[e]*h[v];
eq2 := (d[t]*x[u]+d[e])*(2*r*x[u]/K+d[u]*p[e]*x[m]*x[u]/((h[v]+x[u])*(d[t]*x[u]+d[e])*(h[e]+p[e]*x[m]*x[u]/((h[v]+x[u])*(d[t]*x[u]+d[e]))))-r)+d[u]*h[e]*x[u]*(p[e]*h[v]*x[m]/(h[v]+x[u])^2-d[t]*p[e]*x[m]*x[u]/((h[v]+x[u])*(d[t]*x[u]+d[e])))/(h[e]+p[e]*x[m]*x[u]/((h[v]+x[u])*(d[t]*x[u]+d[e])))^2
First 530 531 532 533 534 535 536 Last Page 532 of 2434
