I think I've seen such a problem before but thought it was fixed.
Here is an example, where depending on what one calls the constant of integration, maple can or not, verify the solution of the ode.
This should not happen.
When calling the constant of integration C[1] or _C Maple does not verify the solution. Only when using _C1 it does.
This is a problem, since I do not use _C1 or _C2  in my solution (so not to conflict with Maple's), I use C[1] and C[2].
Is there a workaround for this?
Example 1
ode:=diff(z(x),x)+z(x)*cos(x)=z(x)^n*sin(2*x);
mysol:=z(x) = 1/((_C1*exp(sin(x)*(n - 1))*n - _C1*exp(sin(x)*(n - 1)) + 2*sin(x)*n - 2*sin(x) + 2)/(n - 1))^(1/(n - 1));
odetest(mysol,ode);
Now I just changed _C1 to C[1]
mysol:=z(x) = 1/(( C[1]*exp(sin(x)*(n - 1))*n - C[1]*exp(sin(x)*(n - 1)) + 2*sin(x)*n - 2*sin(x) + 2)/(n - 1))^(1/(n - 1));
odetest(mysol,ode);
and I get 2 pages full of stuff thrown at the screen. Same when using C as constant of integration.
I could change my C[1] and C[2] to _C1 and _C2 each time just before calling odetest as workaround.
But would like to ask if this is supposed to happen and why it happens. I depend on odetest alot, as I use it to tell me if my solution is correct or not and I do not want false negatives.
I have found additional ones. May be these will help locate the problem
Example 2
ode:=diff(y(x),x) = (1+x+y(x))^(1/2);
mysol1:=y(x) = LambertW(-exp(-x/2 - 1 + C[1]/2))^2 + 2*LambertW(-exp(-x/2 - 1 + C[1]/2)) - x:
odetest(mysol1,ode);
gives
But when using _C1 instead of C[1], this is the answer
ode:=diff(y(x),x) = (1+x+y(x))^(1/2):
mysol2:=y(x) = LambertW(-exp(-x/2 - 1 + _C1/2))^2 + 2*LambertW(-exp(-x/2 - 1 + _C1/2)) - x:
odetest(mysol2,ode);
Example 3
ode:=diff(y(x),x) = f(x)*y(x)+g(x)*y(x)^k:
mysol1:=y(x) = (-exp(-(k - 1)*Int(f(x), x))*(int(g(x)*exp((k - 1)*Int(f(x), x)), x)*k - int(g(x)*exp((k - 1)*Int(f(x), x)), x) - C[1]))^(-1/(k - 1)):
   #long output is given
Changing C[1] to _C1 gives 0 right away
mysol2:=y(x) = (-exp(-(k - 1)*Int(f(x), x))*(int(g(x)*exp((k - 1)*Int(f(x), x)), x)*k - int(g(x)*exp((k - 1)*Int(f(x), x)), x) - _C1))^(-1/(k - 1)):
Example 4
ode:=3*y(x)*diff(y(x),x)+5*cot(x)*cot(y(x))*cos(y(x))^2 = 0:
mysol1:=y(x) = RootOf(10*ln(sin(x))*cos(_Z)^2 - 3*cos(_Z)*sin(_Z) + 30*C[1]*cos(_Z)^2 + 3*_Z):
Gives pages long output. Changing C[1] to _C1 gives zero
mysol2:=y(x) = RootOf(10*ln(sin(x))*cos(_Z)^2 - 3*cos(_Z)*sin(_Z) + 30*_C1*cos(_Z)^2 + 3*_Z):
Example 5
ode:=x*(x-a*y(x))*diff(y(x),x) = y(x)*(y(x)-a*x);
mysol1:=y(x) = exp((-a + 1)*RootOf(x*exp(ln(x)*a + _Z*a + C[1]*a + C[1]) + exp(ln(x)*a + _Z*a + C[1]*a - _Z + C[1])*x - 1) - ln(x)*a - C[1]*(a + 1)):
gives
mysol2:=y(x) = exp((-a + 1)*RootOf(x*exp(ln(x)*a + _Z*a + _C1*a + _C1) + exp(ln(x)*a + _Z*a + _C1*a - _Z + _C1)*x - 1) - ln(x)*a - _C1*(a + 1)):
Example 6
ode:=x*diff(y(x),x)^2-a*y(x)*diff(y(x),x)+b = 0:
mysol1:=y(x) = x*RootOf(2*x*_Z^2*a - 2*C[1]*_Z^((2*a - 1)/(a - 1))*a - x*_Z^2 + C[1]*_Z^((2*a - 1)/(a - 1)) - b)/a + b/(RootOf(2*x*_Z^2*a - 2*C[1]*_Z^((2*a - 1)/(a - 1))*a - x*_Z^2 + C[1]*_Z^((2*a - 1)/(a - 1)) - b)*a):
gives many pages of output. Changing C[1] to _C1 gives zero
mysol2:=y(x) = x*RootOf(2*x*_Z^2*a - 2*_C1*_Z^((2*a - 1)/(a - 1))*a - x*_Z^2 + _C1*_Z^((2*a - 1)/(a - 1)) - b)/a + b/(RootOf(2*x*_Z^2*a - 2*_C1*_Z^((2*a - 1)/(a - 1))*a - x*_Z^2 + _C1*_Z^((2*a - 1)/(a - 1)) - b)*a):
and more. I think the above should hopefully help locate the issue.
Maple 2020.1 with Physics 708
The general solution of x2y'' + 3xy' + λy = 0 is (from Example 4 here)
Why does dsolve(x^2*diff(y(x), x, x) + 3*x*diff(y(x), x) + lambda*y(x) = 0) give only the third case instead of the whole solution?
How to find all solutions [xi,yi] to the following system of equations
x3y=1
y-sin(12x)=0
which satisfies condition 1,2<x<2
I want to show the animation of the polar equation r=cos(2theta) be plotted from theta=0 to 2pi
Hello,The system of equations is as follows:
I'd like to find all integer solutions in [1,20], when I use isolve ,the results are not good.  Since at least one variable is equal to 0 in evey solution.
{isolve}({a+b+c=a1+b1+c1, a^2+b^2+c^2=(a1)^2+(b1)^2+(c1)^2,a*b*c=2*a1*b1*c1})
 In maple I did not  want to use less efficient for-loop like C programing as following.
#include <math.h>
#include <stdio.h>
void main()
    long int a,b,c,d,e,f;
    for(a=1;a<20;a++)
        for(b=1;b<20;b++)
            for(c=1;c<20;c++)
                for(d=1;d<20;d++)
                    for(e=1;e<20;e++)
                        for(f=1;f<20;f++)
                            if(a+b+c==d+e+f&&a*a+b*b+c*c==d*d+e*e+f*f&&a*b*c==2*d*e*f)                                             printf("a=%d,b=%d,c=%d,d=%d,e=%d,f=%d\n",a,b,c,d,e,f);
a=3,b=5,c=16,d=1,e=8,f=15
a=3,b=5,c=16,d=1,e=15,f=8
a=3,b=5,c=16,d=8,e=1,f=15
a=3,b=5,c=16,d=8,e=15,f=1
a=3,b=5,c=16,d=15,e=1,f=8
a=3,b=5,c=16,d=15,e=8,f=1
a=3,b=16,c=5,d=1,e=8,f=15
a=3,b=16,c=5,d=1,e=15,f=8
a=3,b=16,c=5,d=8,e=1,f=15
a=3,b=16,c=5,d=8,e=15,f=1
a=3,b=16,c=5,d=15,e=1,f=8
a=3,b=16,c=5,d=15,e=8,f=1
a=5,b=3,c=16,d=1,e=8,f=15
a=5,b=3,c=16,d=1,e=15,f=8
a=5,b=3,c=16,d=8,e=1,f=15
a=5,b=3,c=16,d=8,e=15,f=1
a=5,b=3,c=16,d=15,e=1,f=8
a=5,b=3,c=16,d=15,e=8,f=1
a=5,b=16,c=3,d=1,e=8,f=15
a=5,b=16,c=3,d=1,e=15,f=8
a=5,b=16,c=3,d=8,e=1,f=15
a=5,b=16,c=3,d=8,e=15,f=1
a=5,b=16,c=3,d=15,e=1,f=8
a=5,b=16,c=3,d=15,e=8,f=1
a=16,b=3,c=5,d=1,e=8,f=15
a=16,b=3,c=5,d=1,e=15,f=8
a=16,b=3,c=5,d=8,e=1,f=15
a=16,b=3,c=5,d=8,e=15,f=1
a=16,b=3,c=5,d=15,e=1,f=8
a=16,b=3,c=5,d=15,e=8,f=1
a=16,b=5,c=3,d=1,e=8,f=15
a=16,b=5,c=3,d=1,e=15,f=8
a=16,b=5,c=3,d=8,e=1,f=15
a=16,b=5,c=3,d=8,e=15,f=1
a=16,b=5,c=3,d=15,e=1,f=8
a=16,b=5,c=3,d=15,e=8,f=1
Does Maple have more good ways to solve that?
I had to save previous results of a calculation to files as the number of elements is too big for my computer to handle in one go.   Here it is an idea of what I am doing to read the files and perform the calculations.
mainproc:=proc(arg1,arg2,arg3,arg4) ... end proc:
Grid:-Set(mainproc):
Grid:-Set(arg2,arg3,arg4):   #  They don't change ever.
for i from 1 to number_of_files do
   read(...):  # it reads arg1 from a file
   Grid:-Set(arg1):
   ans:=Grid:-Seq(mainproc(arg1[i],arg2,arg3,arg4),i=1..numelems(arg1))):
   Grid:-Wait():
   save ans, ....:
   unassign('arg1'):
   unassign('ans'):
   gc():  # An attempt
The actual code works but, for every step in the loop, the memory used by Maple increases by a certain amount that seems to be mostly related to arg1 (as if arg1 is piling up from iteration to iteration).
I read some of the earlier posts on a similar subject dated 5 to 10 years old.  I wonder if there is something new that can be done to minimize the usage of memory.
Many thanks
Ed
PS. I am aware of tasksize, numcpus and Threads.
I have a simple matrix, 11 rows x 3 columns, with header row.  <<
I multiply column 1 and 2 to get <<0.,0.031,0.218,0.657,1.084,1.095,0.654,0.217>>
Now, I just want to add up these elements, but 'sum' doesn't work 'Sum' doesn't work either. Is there a simpel way to do this?
m1 := `<|>`(`<,>`("# girls", 0, 1, 2, 3, 4, 5, 6, 7, 8), `<,>`("P(x)", 0.4e-2, 0.31e-1, .109, .219, .271, .219, .109, 0.31e-1, 0.4e-2), `<,>`("x*P(x)", 0, 0, 0, 0, 0, 0, 0, 0, 0))
Matrix(%id = 18446745635438952446)
m1[2 .. 9, 3] := `~`[`*`](m1[2 .. 9, 1], m1[2 .. 9, 2])
Vector[column](%id = 18446745635417541318)
"Sum?"
Vector[column](%id = 18446745635493441398)
"sum?"
Error, (in LinearAlgebra:-Multiply) invalid arguments
Download Untitled_(3).mw
I must do some formula manipulation
Classification of conic sections
restart; with(student):
A*x^2+B*y^2+C*x+D*y+E=0;
A*x^2+B*y^2+C*x+D*y+E = 0
f:= A*x^2+B*y^2+C*x+D*y+E;
completesquare(f, x);
A*(x+(1/2)*C/A)^2-(1/4)*C^2/A+B*y^2+D*y+E
ans:=Student[Precalculus][CompleteSquare]( (4), [y] );
B*(y+(1/2)*D/B)^2+A*x^2+C*x+E-(1/4)*D^2/B
ans1:=Student[Precalculus][CompleteSquare]( (4), [x] );
ans+ans1;
B*(y+(1/2)*D/B)^2+A*x^2+C*x+2*E-(1/4)*D^2/B+A*(x+(1/2)*C/A)^2-(1/4)*C^2/A+B*y^2+D*y
B*(y + D/(2*B))^2 + A*x^2 + C*x + 2*E - D^2/(4*B) + A*(x + C/(2*A))^2 - C^2/(4*A) + B*y^2 + D*y = 0;
B*(y+(1/2)*D/B)^2+A*x^2+C*x+2*E-(1/4)*D^2/B+A*(x+(1/2)*C/A)^2-(1/4)*C^2/A+B*y^2+D*y = 0
Now i must  get this form A( )^2 +B( )^2 = M
Download vraag_herleiding_conic_sections_formule.mw
Does this condition happen when the character is too long?
Hello everybody,
i am trying to use PDEchangecoords to transform a system of differential equations from Cartesian coordinates to toroidal coordinates. However, when i use a user defined coordinate transform from toroidal to Cartesian, i don't get the initial equations. Please find attached a minimal working environment.
i would highly appreciate your hints and suggestions!
Best regards,
F
question.mw
restart; with(DEtools); addcoords(invToroidal, [xi, eta, phi], [sinh(xi)*cos(phi)/(cosh(xi)-cos(eta)), sinh(xi)*sin(phi)/(cosh(xi)-cos(eta)), sin(eta)/(cosh(xi)-cos(eta))]); PDEchangecoords(diff(f(x, y, z), z), [x, y, z], toroidal, [xi, eta, phi]); PDEchangecoords(%, [xi, eta, phi], invToroidal, [x, y, z]); print("i would expect here to get", diff(f(x, y, z), z))
Download question.mw
Dear Community,
I would like to have an inverse interpolation with a 2D lookup table in MapleSim. The usual 2D lookup interpolation has u1 column values, and u2 row values, and a corresponding   y   table values, i.e. y = f(u1,u2). Now I would like to go the reverse way. Suppose I know y, and u2, and I would like to get u1. How can I implement this in MapleSim? An additional information is, that the 3D surface represented by the f(u1, u2) function is a smooth, slightly curved, monotonically sloping surface, so to any  y  value a unique pair of u1 and u2 values belong.
With my specific data, which are attached in the TestVLP.xlsx file:
  • u2 values are: 1st row, cells 2 .. 14
  • u1 values are  1st column, rows 2 .. 11
  • tabulated values are all the rest, i.e. from cell(2,2) .. cell(11,14)
Now for my case:
  • u2 = 42000.0
  • y   = 94.5614
How much is u1? I know the correct answer from elsewhere, it should be something very close to u1 ~ 85. This  y  value is in the rectangle bordered by columns 7 .. 8  and rows 5 .. 6 in the Excel file.
So my question is how do I correctly implement this in MapleSim? As visible from the attached TestInverse2DInterpolation.msim file I tried to do it with an Inverse Block Constraints component and a horizontally flipped 2D Lookup Table (VLP) and Constants for y and u2, but upon running MapleSim I get an error message that no solution is found, although the solution is relatively easy and straightforward. May I ask you to have a look at it, what can be the problem here, what do I do wrong? I’m using MapleSim 2019.2.
Your kind help is appreciated in advance
best regards
Andras
TestVLP.xlsx
Hello Everyone!
I have one more challenge for you.
How can I find for a Free-Pinned-Pinned-Free (3-span) beam (Picture A below) using the Krylov–Duncan Method (Literature links and references below):
- the matrix of the system?
- the transcendental equation in order to determine the natural frequencies?
- the first three mode shapes?
I tried to do it as you can see from my MAPLE (file below), but I got stuck when I use the command "determinant" and it did not find the transcendental equation.
Krylov_function_free_pinned_pinned_free_beam.mw
Picture_A
References:
https://link.springer.com/content/pdf/10.1007%2F978-1-4419-1047-9_14.pdf
Krylov–Duncan Functions - page 96
You can find that book using the https://libgen.is/
https://www.amazon.com/Formulas-Structural-Dynamics-Tables-Solutions/dp/0071367128
Hello.
I would like to solve numerically highly nonlinear and cumbersome the second order differential equation.
Applying the numerical procedure I got an error "Error, (in dsolve) found wrong extra argument(s): range = 0 .. 4*Pi, type = numerical". The similar problem has been described earlier here however I can't realize my problem.
Below is my code
A1 := 8*Pi^3*R^2*n(x)^4*m+(2*Pi*sin((1/2)*x)*m*omega0*p+Pi*sin((1/2)*x)*m*omega0+3*Pi^2*(diff(n(x), x, x)))*n(x)^3+(-2*sin((1/2)*x)^2*m^2*omega0^2*p^2+2*cos((1/2)*x)^2*m^2*omega0^2*p^2-2*sin((1/2)*x)^2*m^2*omega0^2*p+2*cos((1/2)*x)^2*m^2*omega0^2*p)*n(x)^2+(-4*(diff(n(x), x, x))*sin((1/2)*x)^2*m^2*omega0^2*p^2-8*sin((1/2)*x)*(diff(n(x), x))*cos((1/2)*x)*m^2*omega0^2*p^2-4*(diff(n(x), x, x))*sin((1/2)*x)^2*m^2*omega0^2*p-8*sin((1/2)*x)*(diff(n(x), x))*cos((1/2)*x)*m^2*omega0^2*p)*n(x)+8*sin((1/2)*x)^2*(diff(n(x), x))^2*m^2*omega0^2*p^2+8*sin((1/2)*x)^2*(diff(n(x), x))^2*m^2*omega0^2*p;
R := 1; m := 1; p := 10; omega0 := 1000;
A2 := A1;
A3 := dsolve({A2, n(0) = n(4*Pi), (D(n))(0) = (D(n))(4*Pi)}, type = numerical, range = 0 .. 4*Pi):
odeplot(A3);
I appreciate for any help and suggestion.
Help required to plot the real part only in  multiple plots. i have written some codes  please help me to rectify the errors.Thanks in advance
n:=0.75:Eh:=100:mn:=1:t0:=0.2:
a1:=(mn/t0)^((n-1)/(n))*(tb)^(1/n):a3:=Eh/tb:a4:=(Eh)^2:
U1:=(a1/Eh)*(-1+(a3*r/Eh))^(1/n)*(n*a4/(1+n))*(1/a3-(r/Eh))-a1*(-1+(1/tb))^(1/n)*(n/(n+1)*(tb-1)):
plot([Re(seq(eval(U1,tb=j),j in[0.8,0.9,1.0]))],r=0..1,legend = [tb =0.8, tb=0.9,tb =1.0],  labels = ["z ", "U"], labeldirections = ["horizontal", "vertical"],  linestyle = [solid,dash,dot],color = [black, red,green]);
I want to shade the area where the two polar curves overlap. The first curve is r=2 and the other curve is r=2(1-cos(theta)). How do I do this?
First 560 561 562 563 564 565 566 Last Page 562 of 2459
